Results 1 to 4 of 4
Thread: LED Headlight range adjustment (2019 GTI Rabbit)
    Mar 2019
    I’m looking to perform a headlight height adjustment and the previous information for the MK7 Golf line is for the Xenon module while doesn’t exist on the models with LED lighting. I have two modules for each side, neither have any option under basic settings besides reset all in VCDS. Has the location for the range adjustment moved for models with LED headlight or perhaps is there a new process?
    Saturday,16,March,2019,15:48:24:20003
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F A9
              BB BC D6 D7
    VIN:   Mileage: 724km-449miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    BB-Door Rear Drv -- Status: Not registered 0001
    Address 01: Engine (J623-DKFA)       Labels: None
       Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
       Component: 2.0l R4 TFSI  H13 0002
       Revision: --H13---
       Coding: 091900122424002F1000
       Shop #: WSC 00066 790 00072
       ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
       ROD: EV_ECM20TFS0205G0906259Q_VW37.rod
       VCID: 3C21360076EF45D7825-8068
    Readiness: 0000 0100
       Part No SW: 5Q0 614 517 DR    HW: 5Q0 614 517 BM
       Component: ESC           H45 0108
       Revision: 00000000    Serial number: 50708000000068
       Coding: 01FA6BA150200975407C020360C66880D60A90024006163610435051D0894B0B0000000012121212B835351919323200
       Shop #: WSC 01383 790 50316
       ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
       VCID: 04518EE04E9FFD17BA5-8050
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0498848062
       Coding: 132C0C0623
       VCID: 43D34DFC0B113A2FC3F-8016
       Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
       Component: AC Manuell    H03 2001
       Revision: 00001K05
       Coding: 00020004200110000000000000000006
       ROD: EV_ACManueBHBVW37X_004_VW37.rod
       VCID: 4CC166C0264FF557325-8018
       Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
       Revision: --------    Serial number: C86409121800TG
       Shop #: WSC 00066 790 00248
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7BA3F51C336182EFCBF-802E
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    181010  043 0551
       Serial number: 97022066181018035412
       Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
       Component: RLS  050 0105
       Serial number: S2Y18M10D25H07M35S38
       Coding: 00A8DD
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0300191220180C204977
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Coding: 2D00008101FFC728949C810500401600000000000000000004
       VCID: 44D14EE00E1F3D17FA5-8010
       Serial number: 003GCR0AP4Z3
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 47CB59EC3F29160F1F7-8012
       Occupant Detection:
       Serial number: IBH00000000000ARBPC2
       Coding: 30305A
       Subsystem 2 - Part No SW: -----------    HW: 480 003 010 18
       Serial number: 35700000000E7239553K
       Subsystem 3 - Part No SW: -----------    HW: 480 001 310 18
       Serial number: 3580000000000770253/
       Subsystem 4 - Part No SW: -----------    HW: 480 402 208 18
       Component: SideSensor_Dr  004 6149
       Serial number: 35100011C2B7DB94A5FO
       Subsystem 5 - Part No SW: -----------    HW: 480 402 208 18
       Component: SideSensor_Pr  004 6149
       Serial number: 3520001262B7DB946376
       Subsystem 6 - Part No SW: -----------    HW: 480 401 911 18
       Component: FrontSensor_D  004 6149
       Serial number: 35500012C2B6CE95D5EX
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 911 18
       Component: FrontSensor_P  004 6149
       Serial number: 35600012A2B6CE93948J
       Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
       Component: KOMBI         351 2500
       Coding: 0BAD0912A988CF0502882A095000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBAB 009065
       VCID: 2F3B114CB799AE4F377-807A
              U1110 00 [008] - -
              [BAP_TEL_0x28 keine Kommunikation]
                        Reset counter: 62
                        Mileage: 724 km
                        Date: 2019.03.16
                        Time: 14:26:06
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 04121800841829
       Coding: 0101000830085900FB00002B080F00000001070000000000000000000000
       Shop #: WSC 00066 790 00091
       ROD: EV_GatewNF_VW37.rod
       VCID: 6E85CC487013E7477C1-803A
       Component: 0-00-0d-00-04
       Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0052
       Serial number: 29180002432410068415
       Coding: 28FFFF
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
    0033 - Supply voltage
              [Supply voltage - lower limit exceeded]
                        Reset counter: 47
                        Mileage: 266 km
                        Date: 2019.02.28
                        Time: 17:35:24
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H07 0021
       Serial number: 18000345075010
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 313F1734A1ADB8BF213-8064
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
       Component: Quersperre    H52 8043
       Serial number: HA1-00006.07.18
       Coding: 0001
       Shop #: WSC 01687 666 30448
       ASAM Dataset: EV_LockElectHA1VW37X 001007
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 52FD78B8C46BA3A7789-8006
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
                        Reset counter: 47
                        Mileage: 266 km
                        Date: 2019.02.28
                        Time: 17:35:24
       Component: HRE_Master    H12 0081
       Serial number: 0500022618
       Coding: 01011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D273B046DF54CDFB5B-8068
       Component: HRE_Slave  H12 0081
       Serial number: 0501010098
       Coding: 010111
       Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
       Component: TSG FS        006 0247
       Serial number: 42038831502603
       Coding: 003E13200000040000000000
       VCID: 4FFB71CCD759CE4F577-801A
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
       Serial number: 00000000000001347478
       Coding: 011000
       Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
       Component: EPS_MQB_ZFLS  507 5081
       Coding: 810A0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 50F972B0CA67D1B74ED-8004
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 23111800840436
       Coding: 000000050900210A01110F00030000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: 3537232455C5949F7DB-8060
       Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0247
       Serial number: 46038833500038
       VCID: 4EC56CC8D053C7475C1-801A
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
       Serial number: 00000000000001337865
       Coding: 091000
       Part No SW: 5G6 035 868     HW: 5G6 035 868
       Component: MU-E--ER      695 8742
       Serial number: 08101800011978
       Coding: 02730000BE00000041220001001000009F0003D40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       VCID: 70B9D2306A27F1B76ED-8024
       Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0001
       Serial number: 181017201964
       VCID: 323D1838A4AB83A7589-8066
    Address BB: Door Rear Drv
    Address BC: Door Rear Pass
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392F2F1479DD70FF993-806C
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----------(Elapsed Time: 01:32, VBatt start/end: 12.4V/12.4V)-----------
    Apr 2018
    ITALY
    I suppose you are saying you have module 4B instead of 55, and then four other modules for lights, two on the left and two on the right.
    if that's the case, the height level sensor is probably connected to the BCM. see if you find anything under module 09 basic settings.
    Mar 2019
    In that there is a headlight adjustment and confirm headlight adjustment function. I ran the first, after a few minutes a missing basic settings warning popped up. Ran the adjustment setting again, followed by the confirm setting and the message cleared. As to what that did I don’t know but maybe that is the height setting?
    Below is what I'm working with.
    EDIT: Googling around it looks like the process I followed here is in fact the method you use to level these headlamps.
    https://www.audizine.com/forum/showt...7#post12095387
    United States
    Yeah, you still use the older 2-step Basic Setting process but in 4B rather than 55.
  5. Likes Uwe liked this post
