Why would multiple controllers be ‘Cannot be reached’?
Gizmo
S.E.Kent UK
C?ID=49193
I coded an 2015 Audi A5 today and multiple controllers (01, 02, 04, 15, 42, 52, 62, 6C, & 72) all came back as “Cannot be reached”??
This was on both Beta 19.1.2 and also release 18.9.1
Sunday,07,April,2019,11:02:34:36443VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.1.2.0 (x64)  HEX-NET CB: 0.4502.4
Data version: 20190131 DS301.0
VIN:    License Plate: FX64 ***
Mileage: 72770km-45217mi   Repair Order: 1
Chassis Type: 8R0
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          6C 72
   Mileage: 72770km-45217miles
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
04-Steering Angle -- Status: Cannot be reached 1100
15-Airbags -- Status: Cannot be reached 1100
Address 01: Engine
Address 02: Auto Trans
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Coding: 391DCC01
   Shop #: WSC 06325 000 00000
   VCID: 095A5878A0B71901E4-805C
   Part No SW: 8K0 907 064 JE    HW: 8K0 907 064 JE
   Component: BCM2 2.0      H14 0650
   Coding: 01B44040000000000000
   VCID: 7CB431ACFF653CA9EF-8028
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000088578009
   Serial number: 0214000116103008
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01240620141510
   Coding: 3624028000
   VCID: 78BC2DBCCB5D10898B-802C
   Revision: 08016001    Serial number: 00000843231102
   Coding: 260000108034AFC00081400300001D0D001D430827090201000008004400030100000034000000
   Subsystem 1 - Part No SW: 8T2 955 119 D    HW: 8J2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 030614  H13 0080
   Serial number: SWF14066035002
   Coding: 00FD11
   Serial number: 22795526
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001606140116
                    Fault Status: 00101100
                    Reset counter: 228
                    Mileage: 72082 km
                    Date: 2019.03.26
                    Time: 16:08:00
                    Reset counter: 228
                    Mileage: 72082 km
                    Date: 2019.03.26
                    Time: 16:24:10
Address 15: Airbags
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NFP001T1
   Coding: 000036
   VCID: 48DC9D7CFB3DA0093B-801C
   Part No SW: 8T0 920 984 K    HW: 8T0 920 984 K
   Component: KOMBIINSTR.   H35 0564
   Revision: 00000000    Serial number: Z9H33WP6F
   Coding: 33A7310003012600010000
   VCID: 47DE9E40F623AF7132-8012
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y14610087B
   Coding: 80CD07FF00
   VCID: 4AD8A774E53152192D-801E
   Serial number: 7632603603
   Serial number: 14175000656011200410
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000105624757
   Coding: 01781300000000000000
   VCID: 3B36F2B0BAEBFB91A6-806E
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H40 0509
   Revision: 00001000    Serial number: 0015686399
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 383CEDBC83DDD0894B-806C
   Revision: 00002001    Serial number: 0338888741
   Coding: 013B0622A0B900808320043680000047
   Revision: 00005001    Serial number: 94813031257505
   VCID: 2D12CCE8749F652128-8078
                    Reset counter: 209
                    Voltage: 12.30 V
                    Temperature: 30.0∞C
                    Temperature: 30.0∞C
                    Bin. Bits: 00000100
                    Bin. Bits: 00001000
                    Bin. Bits: 00000000
Address 52: Door Elect, Pass.
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000231019
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A38F7B4BDD1C299BD-806E
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109F10E7940549
   Coding: 010103010000000001
   VCID: 281C3DFC5B7D4009DB-807C
   Part No SW: 8R2 035 670 H    HW: 8R2 035 670 E
   Component: H-BNT-EU      H48 0809
   Revision: --------    Serial number: 208FW0EB000582
   Coding: 130101040006A1EF41808B5E00000403040000000000000000
   VCID: 393AE8B8B0D7C981B4-806C
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Component: DU7 High  H42 0104
   Serial number: A130FO0E3064434
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001898743
   Component: CD-Database  5950
Address 62: Door, Rear Left
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
End----(Elapsed Time: 01:23, VBatt start/end: 12.3V/12.3V. VIgn 0.0V)------
This suggests the ignition wasn't turned on...
Gizmo
S.E.Kent UK
C?ID=49193
Never even noticed that!
however if it was off then surely I wouldn’t be able to access any of them?
I had no problem with coding any of the other controllers (which AIUI you cannot do without the ignition being on)
I didn’t physically turn it on myself however, but the owner pushed the key in and the ‘staging’ did it’s thing suggesting it was indeed on.
Recent cars will have some modules accessible for quite a while after the ignition is turned off.
Gizmo
S.E.Kent UK
C?ID=49193
Thanks, I will make 100% sure by doing it myself when I see the car again in a few weeks (after retro-fitting door puddle lights)
