Results 11 to 20 of 22
Thread: New Guy here! Retrofit aid in 2018 tiguan help please!
    hmmm.............. here's an expanded version of the code-string for your hex5F module
    Byte	Hex	Binary
    0	02	00000010
    1	73	01110011
    2	06	00000110
    3	02	00000010
    4	BE	10111110
    5	00	00000000
    6	00	00000000
    7	00	00000000
    8	51	01010001
    9	22	00100010
    10	00	00000000
    11	01	00000001
    12	00	00000000
    13	18	00011000
    14	08	00001000
    15	00	00000000
    16	1F	00011111
    17	05	00000101
    18	00	00000000
    19	C4	11000100
    20	01	00000001
    21	20	00100000
    22	04	00000100
    23	05	00000101
    24	C6	11000110
    I'll gladly accept advice to the contrary, but shouldn't Byte 19, Bit 5 be set for AID - according to this:
  2. Likes Uwe liked this post
  3. #12
    Apr 2019
    Byte	Hex	Binary
    0	02	00000010
    1	73	01110011
    2	06	00000110
    3	02	00000010
    4	BE	10111110
    5	00	00000000
    6	00	00000000
    7	00	00000000
    8	51	01010001
    9	22	00100010
    10	00	00000000
    11	01	00000001
    12	00	00000000
    13	18	00011000
    14	08	00001000
    15	00	00000000
    16	1F	00011111
    17	05	00000101
    18	00	00000000
    19	C4	11000100
    20	01	00000001
    21	20	00100000
    22	04	00000100
    23	05	00000101
    24	C6	11000110
    I don’t have that availability in the coding?
  4. #13
    Quote Originally Posted by adema69 View Post
    You're using an old HEX+CAN and don't get "experimental" coding info.
    But that doesn't prevent you from changing the bit in question.
  5. #14
    Apr 2019
    Could it be possible the aid is not programmed correctly from the dealership?
  6. #15
    See the field with the yellow "Binary:" representation? You can change the bit there. Bit 0 is on the right (least significant bit) and Bit 7 is on the left (most significant bit).
  7. #16
    Apr 2019
    Ok so what should I change the bit to?
    Should I make the binary 10010110
  8. #17
    Mar 2015
    Australia
    You need to change byte 19 to 11100100 (hex E4)
    Also try these adaptations:
    5F:
    ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps --> ON
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most --> OFF
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  9. Likes Uwe liked this post
  10. #18
    Apr 2019
    Quote Originally Posted by kamold View Post
    5F:
    Tried this byte and still nothing just spins. Also tried the different adaptation and nothing. Could it be have the the fiber optic cable ports mixed up?
  11. #19
    Apr 2019
    Got it work! Thank you all for the help!
  12. Likes Uwe liked this post
  13. #20
    What did you change to get it to work?
  14. Likes Uwe liked this post
