Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: New Guy here! Retrofit aid in 2018 tiguan help please!
    Apr 2019
    Hey guys I am looking to get some wisdom about my aid and nav. I recently swapped over aid into my 2018 sel tiguan that had the analog cluster. I followed the mk7 alltrack vagcom steps and i am unsuccessful in getting the nav to come on the screen. I only get the compass and at times a blank screen with like 4 lines that will move with the car. What is also weird in the navigation screen i cannot get the screen where it says display or enlarge map? it will revert back to the compass and just state the current street I am on. I ran the fiber optic splitter form the back of the mib2 to the cluster. My mib fiber optic port had a blank in it removed and plugged the new wire in leaving the one port blank on the splitter wire.
    Apr 2019
    Saturday,06,April,2019,21:39:06:55532
    VCDS Version: 18.9.1.0 (x64)
    VIN: 3VV2B7AXXJM025088   License Plate:
    Chassis Type  AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 22 2B 3C 42 44 52 5F 6C 6D
              75 CA
    VIN: 3VV2B7AXXJM025088   Mileage: 19938km-12388miles
    CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122466010FB4000000000000000000000000000000
       Shop #: WSC 00066 790 00454
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C77E72BB7B34BAAC1-8068
    Readiness: 0000 1101
       Part No SW: 09G 927 158 Q    HW: 09G 927 158
       Component: AISIN AQ8     206 3379
       Coding: 0002000100000000000000000000000000000000
       ROD: EV_TCMAQ450031_VW32.rod
       VCID: 418996DFD051264292-8014
       Revision: 00000000    Serial number: 51807000000198
       Coding: 0BFA6BA454221B71C5770308A2CB49D0D62AD8A3C045927C18415058C28A4200002864121A1C230935351919323200
       Shop #: WSC 01383 790 50316
       VCID: 77FD3807CE15A8F2EC-8022
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0441463904
       Coding: 132C0C0723
       VCID: 3E73ED23A1AF59BAEF-806A
       Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000D00030763
       Coding: 0002002420011800100501001211140E
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: 4A9BB1F3ED67E51A43-801E
       Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C86427061700O6
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0C1777EBA793BB2AB1-8058
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170630  034 0373
       Serial number: 17061721063740
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 71893780
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 160
                        Mileage: 19910 km
                        Date: 2011.01.01
                        Time: 00:27:08
    204546 - Remote key 2
                        Reset counter: 160
                        Mileage: 19910 km
                        Date: 2011.01.01
                        Time: 00:27:10
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200008150FF8728749C8145304097
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM05TXT2
       Coding: 8CCCFC00000000005000001AC20800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 050142CF84F9CA62EE-8050
       Occupant Detection:
       Serial number: IBH000000000007IB4PP
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 002 705 17
       Serial number: 35700000000C5651C42J
       Subsystem 3 - Part No SW: -----------    HW: 480 002 705 17
       Serial number: 3580000000096BACF32+
       Subsystem 4 - Part No SW: -----------    HW: 480 401 706 17
       Serial number: 3510001C526441E5325U
       Subsystem 5 - Part No SW: -----------    HW: 480 401 706 17
       Serial number: 3520001B72625E12B52-
       Subsystem 6 - Part No SW: -----------    HW: 480 402 906 17
       Serial number: 3550001B12600D55181O
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 906 17
       Component: FrontSensor_P  000 6149
       Serial number: 3560001B12600D54549W
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 30061708491646
       Coding: 0410
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 071D48C7BEF5D8729C-8052
       Part No SW: 5NA 920 891 B    HW: 5NA 920 891 B
       Component: KOMBI         407 3193
       Coding: 03A5041AA788CF0502886B0954000000A0000000
       Shop #: WSC 08245 444 12345
       VCID: 43859CD7CA4D345280-8016
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 06071700840074
       Coding: 030500347F085900FB0322581E0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: 3365CC179AED84D210-8066
       Subsystem 2 - Part No SW: 5NN 959 442 A    HW: 5NN 959 442 A
       Serial number: 1381705274000624BL2B
       Coding: 2C0000
       Serial number: 3617523904
       Serial number: HA1-00022.04.17
       Coding: 0101
       Serial number: 17000154000009
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71E9061FA071F6C222-8024
       Component: HRE_Master    H12 0081
       Serial number: 0445781324
       Coding: 01011103
       Shop #: WSC 49034 001 1048576
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D71EA2FACA942A2F6-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0081
       Serial number: 0443785600
       Coding: 010111
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 7038720500252
       Coding: 00301B200000028000000000
       VCID: 458182CFC4790A62AE-8010
       Serial number: 00000000000006990334
       Coding: 011000
       Revision: 00000000    Serial number: 0001774810
       Coding: 01000010004001
       ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
       VCID: 408F93DBDB5B2F4A9D-8014
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 8038720600318
       Coding: 003013200000028000000000
       VCID: 44879FCBCF43336AB9-8010
       Serial number: 00000000000006943284
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    851 0842
       Coding: 02730602BE00000051220001001808001F0500C401200405C6
       ROD: EV_MUStd4CDELP_VW26.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZHT1973001
       Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
       Component: NAR 2017/18  --- 0620
       Coding: 0123060120002017300040
       VCID: 3979FE3FB8817E82DA-806C
       Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0261
       Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
       Coding: 0A08
       Component: OCULowMQBUS   007 0570
       Coding: 02230602C2823A017F1E06020000
       ROD: EV_OCULowMQB.rod
    9458451 - Cellular Antenna
              B1053 13 [009] - Open Circuit
                        Reset counter: 161
                        Mileage: 19910 km
                        Date: 2011.01.01
                        Time: 00:24:53
    Address CA: Sunroof
    Interface not compatible.
    End-------------------------(Elapsed Time: 04:59)--------------------------
    Apr 2019
    I was able to get the navigation to say start loading map and the loading thing spinning but it doesnt load the map. I am at a stand still.
    Since the OP just got Verified, moving this to Retrofits.
    Apr 2019
    thank you very much!
    Apr 2019
    Update I am able to get the screen to say loading maps but it just spins and never loads the map. I also had to remove the female plug from the splitter due to my mib not using that port so i didnt have a fiber optic cable to plug in to it.
  7. #7
    Mar 2015
    Australia
    Quote Originally Posted by adema69 View Post
    Don't quite understand this post...do you have an optical MOST link between your MIB and the new AID cluster?
    This is essential for map streaming.
    Secondly, most of the configuration changes required to get the AID fully working with the MIB unit are contained in adaptation channels in the 5F infotainment unit.
    Post your adaptation channel map from 5F (and also 17 instruments just for completeness).
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  8. #8
    Apr 2019
    Quote Originally Posted by kamold View Post
    Yes I have the fiber optic cable ran from the aid to mib. What I was trying to say that the cable I bought was a splitter y cable but my car doesn’t have an amp so the fiber optic port on my mib just have a block off on it. I will get the adaptation maps
  9. #9
    Apr 2019
    ;SW:3Q0-035-876-B   HW:3Q0-035-876-B ---  Information Electr.
    ;Component:MU-S-NS-US    851 0842, Coding:02730602BE00000051220001001808001F0500C401200405C6
    ;EV_MUStd4CDELP,001001,EV_MUStd4CDELP_VW26.rod
    ;Friday,12,April,2019,20:56:00:55532
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: 3365CC179AED84D210-8066
    IDE00346-Summertime-automatic,manual ,1
    IDE00758-Base volume of telephone,50 %,1
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,27 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,27 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,27 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,27 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,27 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,27 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,27 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,27 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,27 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,27 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,27 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,27 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,27 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,27 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,27 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,27 ,49
    IDE02502-Confirmation of installation change,CE A5 ,2
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,OFF ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,OFF ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_NAR ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,Data & language service active ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,OFF ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,OFF ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE05111-Fee-based traffic information (TMC),1537 ,2
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
    IDE10604-Menu entries for mobile online services,not activated ,1
    IDE11122-Country identification: country of sale HMI,US ,2
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,blocked ,21
    IDE11502-ENG127612-Locked menu contents-FB_CAR_11,blocked ,21
    IDE11502-ENG127613-Locked menu contents-FB_CAR_12,blocked ,21
    IDE11502-ENG127603-Locked menu contents-FB_CAR_2,blocked ,21
    IDE11502-ENG127604-Locked menu contents-FB_CAR_3,blocked ,21
    IDE11502-ENG127608-Locked menu contents-FB_CAR_7,blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,blocked ,21
    IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,blocked ,21
    IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,blocked ,21
    IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,blocked ,21
    IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,blocked ,21
    IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,blocked ,21
    IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,blocked ,21
    IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,blocked ,21
    IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,blocked ,21
    IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,blocked ,21
    IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,blocked ,21
    IDE11502-ENG127635-Locked menu contents-FB_MISC_10,blocked ,21
    IDE11502-ENG127636-Locked menu contents-FB_MISC_11,blocked ,21
    IDE11502-ENG127637-Locked menu contents-FB_MISC_12,blocked ,21
    IDE11502-ENG127638-Locked menu contents-FB_MISC_13,blocked ,21
    IDE11502-ENG127639-Locked menu contents-FB_MISC_14,blocked ,21
    IDE11502-ENG127643-Locked menu contents-FB_MISC_18,blocked ,21
    IDE11502-ENG127644-Locked menu contents-FB_MISC_19,blocked ,21
    IDE11502-ENG127627-Locked menu contents-FB_MISC_2,blocked ,21
    IDE11502-ENG127645-Locked menu contents-FB_MISC_20,blocked ,21
    IDE11502-ENG127647-Locked menu contents-FB_MISC_22,blocked ,21
    IDE11502-ENG127669-Locked menu contents-FB_MISC_44,blocked ,21
    IDE11502-ENG127670-Locked menu contents-FB_MISC_45,blocked ,21
    IDE11502-ENG127671-Locked menu contents-FB_MISC_46,blocked ,21
    IDE11502-ENG127672-Locked menu contents-FB_MISC_47,blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,blocked ,21
    IDE11502-ENG127634-Locked menu contents-FB_MISC_9,blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,blocked ,21
    IDE11502-ENG127582-Locked menu contents-FB_NAV_21,blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127565-Locked menu contents-FB_NAV_4,blocked ,21
    IDE11502-ENG127567-Locked menu contents-FB_NAV_6,blocked ,21
    IDE11502-ENG127570-Locked menu contents-FB_NAV_9,blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,blocked ,21
    IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,blocked ,21
    IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,blocked ,21
    IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,blocked ,21
    IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,blocked ,21
    IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,blocked ,21
    IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,blocked ,21
    IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,blocked ,21
    IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,blocked ,21
    IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,blocked ,21
    IDE11503-Satellite radio tuner: pre-activated subscription,07 ,1
    IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
    IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
    IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
    IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
    IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
    IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,not activated ,192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,not activated ,192
    IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
    IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
    IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
    IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
    IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
    IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
    IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
    IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
    IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
    IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
    IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
    IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
    IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
    IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
    IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
    IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
    IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
    IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
    IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
    IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
    IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
    IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
    IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
    MAS00951-Bluetooth,On ,1
    MAS01968-Fan,normal ,1
    MAS03782-WLAN,On ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated ,60
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,not activated ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Not available ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,On ,10
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming ,10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ,10
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,activated ,5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,activated ,5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
    ENG117808-p_HMI_Display,13 %,1
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    Elapsed Time: 00:45
  10. #10
    Apr 2019
    ;SW:5NA-920-891-B   HW:5NA-920-891-B ---  Instruments
    ;Component:KOMBI         407 3193, Coding:03A5041AA788CF0502896B0954000000A0000000
    ;EV_DashBoardVDDMQBAB,009058,EV_DashBoardVDDMQBAB_009_VW37.rod
    ;Friday,12,April,2019,20:54:56:55532
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: 43859CD7CA4D345280-8016
    IDE00295-Oil temperature display,On ,1
    IDE00301-Distance,20294 km,3
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,US English ,1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,20 H,1
    IDE00501-Minute,55 min,1
    IDE00502-Year,2019 yr,2
    IDE00503-Month,4 mon,1
    IDE00504-Day,12 d,1
    IDE00510-ESI: distance driven from inspection,6193 km,3
    IDE00511-ESI: time from inspection,122 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,poor oil quality ,1
    IDE00517-ESI: soot entry,0 km,2
    IDE00518-ESI: thermal load,14000 km,2
    IDE00819-Day counter,617 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,16100 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 2 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
    IDE03329-Driving profiled for range remaining,8.6 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,miles ,3
    IDE03346-MAS01230-Units adjusted-Date,mm_dd_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Miles per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,Degrees Fahrenheit ,3
    IDE03346-MAS02957-Units adjusted-Time,12h AM_PM ,3
    IDE03346-MAS03032-Units adjusted-Volume,gallons (US) ,3
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Miles per gallon (US) ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
    IDE03348-MAS01456-Speed warning-Speed,0 ,2
    IDE03348-MAS01561-Speed warning-Unit,Miles per hour ,2
    IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,32200 km,2
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,6100 km,2
    IDE03352-FIX: Time since last time-dependent inspection,122 d,2
    IDE03372-Source for synchronization of time,internal clock ,1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE03867-Deactivate seat belt warning,No ,1
    IDE05930-Service notification in days,30 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,32200 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,730 d,2
    IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
    IDE06588-Ignition active message: actuator,No display ,1
    IDE06922-No-voltage display,Unknown (2),1
    IDE07221-Cylinder shut-off,Display ,1
    IDE11086-Service notification,30 d,1
    IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
    IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
    IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
    IDE12226-MAS03686-Display of longitudinal regulation coordinator-Automatic distance regulation,not active ,1
    IDE12226-MAS05203-Display of longitudinal regulation coordinator-CCS,not active ,1
    IDE12226-MAS10720-Display of longitudinal regulation coordinator-Speed limiter,not active ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
    ENG119875-defuel_threshold,9 l,1
    ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
    ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
    ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
    ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
    ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
    ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
    ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
    ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
    ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
    ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
    ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
    ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
    ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
    ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
    ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 64 ,24
    ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 96 ,24
    ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 DC ,24
    ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
    ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 09 ,24
    ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 09 ,24
    ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 50 ,24
    ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,01 90 ,24
    ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,03 52 ,24
    ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
    ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 01 ,20
    ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 32 ,20
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,01 2C ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 0A ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 32 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
    ENG119874-Gas_functionality,not active ,1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light ,1
    ENG119882-init_fuel_algorithm,No ,1
    ENG130585-Leaving_warning_delay,1.6 s,1
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
    ENG126396-Scale_switching_algorithm,lowbeam_foglight ,1
    ENG153765-Second_digital_speed,Display ,1
    ENG119876-Service_Key_Clear_All_Counter,Yes ,1
    ENG130584-Statistic_phev_mileage,5 km,1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.20 s,18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.15 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,not active ,4
    ENG153766-Tube_version,variant_2 ,1
    Elapsed Time: 00:35
