Skoda octavia 5E ACC MQB retrofit SWaP function unlock
mrfox
Poland
C?ID=144585
Hello. I fitted the vehicle with radar acc. The components' protection has been removed. I need to unlock the functions in the radar. I am sending autoscan. Please help. I have a lot of time. We can test :)
Saturday,06,April,2019,09:56:36:63421
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4438.4
VIN: TMBJG7NEXE0124801   License Plate: ACC SWAP
Mileage: 147732km-91796mi   Repair Order:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 42 44 52 55 5F
VIN: TMBJG7NEXE0124801   Mileage: 147732km-91796miles
   Part No SW: 04L 906 021 N    HW: 04L 907 309 B
   Component: R4 1.6l TDI   X22 9213
   Revision: 84X22---
   Coding: 0125003A036401090000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM16TDI01104L906021N 002014
   ROD: EV_ECM16TDI01104L906021N_002.rod
   VCID: 302CE7436BD4EECA6D-8064
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [039] - -
          [Lost Communication WithCruise Control Front Distance Range Sensor]
                    Mileage: 147732 km
                    Time: 00:00:00
                    Coolant temperature: 43 °C
                    Intake air temperature: 31 °C
                    Voltage terminal 30: 12.040 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.000 m/s˛
   Part No SW: 0CW 300 047 C    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5261
   Revision: 00043014    Serial number: CU501311237651
   Shop #: WSC 73430 031 00140
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3B36C06FB2921D92C8-806E
21193 - No Communication with Cruise Control Module
          U0104 00 [011] - -
                    Mileage: 147732 km
                    Date: 2019.04.06
                    Time: 09:51:32
                    Engine speed: 2310.00 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 64 km/h
                    Control Module temperature: 63 °C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 8704
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 63293000000596
   Coding: 1C07629124220970007F060041C4243846249000608224F00041F072C002
   VCID: 4BD690AFE232AD1278-801E
   Part No SW: 5E0 907 044 J    HW: 5E0 907 044 J
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02010104004101011005000100100000
   Shop #: WSC 73430 031 00063
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2C14F33347FC8A2A51-8078
   Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0095
   Revision: --------    Serial number: 86582311130149
   Coding: 0C001A66424722FB47E04000001C07080400000000000000000000000000
   Shop #: WSC 73430 790 00140
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_012.rod
   VCID: 48DCAFA3F344460A55-801C
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131121  041 0570
   Serial number:         131123061618
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M11D23H03M23S17S2
   Coding: 07805D
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131330601892
   Coding: 0031061051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 3D32CE77AC8613A2F6-8068
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 14041476510638
   Coding: 00001000FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3620D15B89B0C0FA37-8062
1058 - Databus
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 54
                    Mileage: 147704 km
                    Date: 2019.04.05
                    Time: 17:22:20
                    Control Module temperature: 41 °C
                    Voltage terminal 15: 13.8 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s˛
1039 - Databus
          [FAULT_CIS_QDISACC_FAIL]
                    Reset counter: 54
                    Mileage: 147704 km
                    Date: 2019.04.05
                    Time: 17:22:20
1807 - No Enable Indentifications Active
          B2032 00 [009] -  -
          [FAULT_SWAP_NO_FSID_ACTIVE]
                    Fault Frequency: 10
                    Reset counter: 56
                    Mileage: 147704 km
                    Date: 2019.04.05
                    Time: 17:22:20
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PQ40QM6
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F4EF47FE60AC1B2A4-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 001 611 13
   Serial number: 3576U0000009A6654E0J
   Subsystem 2 - Part No SW: -----------    HW: 454 001 511 13
   Serial number: 3586U0000004AC454E0J
   Subsystem 3 - Part No SW: -----------    HW: 454 801 511 13
   Serial number: 3516RF4613B02000000+
   Subsystem 4 - Part No SW: -----------    HW: 454 801 511 13
   Serial number: 3526R74B25502000000-
   Subsystem 5 - Part No SW: -----------    HW: 454 801 410 13
   Serial number: 3556VCE050002000000/
   Part No SW: 5Q0 953 507 DF    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 29111304221381
   Coding: 6C10
   Shop #: WSC 00046 000 00000
   ROD: EV_SMLSKLOMQB_012_AU37.rod
   VCID: 7DB20E77EC06D3A2B6-8028
   Part No SW: 5E0 920 861 E    HW: 5E0 920 861 E
   Component: KOMBI         204 3410
   Coding: 07A50A082D90000801087A00040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 291A0A27480E9F02AA-807C
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000756124
   Revision: --------    Serial number: 0001332028
   Coding: 030100040F087300EF00064A1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_010.rod
   VCID: 3FCEB47FA68A01B2E4-806A
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000B1655141113
   Serial number: 4040921903
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000084183768
   Coding: 001401208000040000001100
   VCID: 42C8BD8BD5786C5A8B-8016
   Serial number: 00000000000001121700
   Coding: 010200
   Coding: 0303
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41CAB287D07E774292-8014
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000084130407
   Serial number: 00000000000001248391
   Coding: 190200
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 03CA02003F000000
   Coding: 3E0000
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    041 0435
   Serial number: S7F03008140384
   Coding: 03730201FF0000001111120100A800002F0000840100010046
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2600011B5910B07A87-8072
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H50 0022
   Serial number: SKZ8Z9NK800TBY
   Subsystem 2 - Part No SW: 5E0 051 236 G    HW: -----------
   Component:  ECE 2019  --- 0078
End----------(Elapsed Time: 01:19, VBatt start/end: 14.7V/14.7V)-----------
downtime
C?ID=280813
You can’t SWaP is a feature protection scheme that needs factory connection to enable. And the enabling is not possible if your car did not have acc from factory.
There are some who claim to have the means to enable SWaP functions but I don’t know how that goes. Easiest way is to get round faced radar from pre 2015 car which does not have SWaP yet, only component protection. That works great.
vastechnics
C?ID=143747
There are couple people who can do this by remote. Exactly what Downtime says normally is controlled by factory enabeling.
downtime
C?ID=280813
^ But we don't know for how long these will last. VAG will find a way to block these and nullify the FeC when the car is taken in for a service. And they will at some point.
