Skoda Kodiaq infotainment retrofit
sasha
Australia
C?ID=287611
Hi all,
I'm repairing a Skoda Kodiaq 2017 and have a donor vehicle 2018 model with a larger display. Could someone please tell me if the screen/infotainment can be swapped from donor vehicle to the 2017 model by looking at the scans? Is it a matter of swapping hardware (screen/glovebox unit) and adjusting coding? or more work required?
Thanks in advance.
2017 model scan
Sunday,24,March,2019,10:49:29:15919
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86(VirtualBox)
VCDS Version 18.9.1.0
VIN: TMBMD9NS9H8030910   License Plate:
Mileage: 6619km-4112mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44
          47 52 55 5F 69 6C 6D A5 BB BC
VIN: TMBMD9NS9H8030910   Mileage: 6619km-4112miles
Address 01: Engine (J623-CZPA)       Labels:. 06L-907-115-V1.clb
   Part No SW: 5NA 907 115 D    HW: 06L 907 309 B
   Component: 2.0 R4 TFSI   H31 0003
   Revision: 1DH31000
   Coding: 042500322466050B34100000000000000000000000000000
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_ECM20TFS0115NA907115D 001004
   ROD: EV_ECM20TFS0115NA907115D.rod
   VCID: 3F8CC68AA64393B2E4-806B
9 Faults Found:
17167 - Databus
17156 - Databus
          U1123 00 [096] - Received Error Message
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
                    Engine speed: 698.50 /min
                    Vehicle speed: 23 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 12.740 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: -7.501 m/sІ
17158 - Databus
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 00:00:20
                    Engine speed: 899.50 /min
                    Normed load value: 4.3 %
                    Coolant temperature: 58 °C
                    Intake air temperature: 37 °C
                    Voltage terminal 30: 11.720 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/sІ
15671 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
5595 - Crash Shut-Down Activated
          P1609 00 [032] - -
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
4787 - Crash Shut-Down Activated
          P1609 00 [032] - -
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
4709 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [047] - -
                    Fault Frequency: 53
                    Time: 00:00:00
                    Engine speed: 975.00 /min
                    Normed load value: 3.5 %
                    Coolant temperature: 41 °C
                    Intake air temperature: 34 °C
                    Voltage terminal 30: 11.680 V
                    Com st X Set2 Val1-Bits 0-7: 0
                    Com st X Set2 Val2-Bits 0-7: 0
                    Com st X Set2 Val3-Bits 0-7: 24
                    Com st X Set2 Val3-Bits 0-7: 0
                    Com st X Set2 Val4-Bits 0-7: 0
                    Com st X Set2 Val5-Bits 0-7: 0
                    Com st X Set2 Val6-Bits 0-7: 0
                    Com st X Set2 Val7-Bits 0-7: 1
                    Com st X Set2 Val7-Bits 0-7: 0
26361 - Camshaft Adjuster B Cylinder 1
          P12C9 00 [032] - Self-Switching
   Part No SW: 0DL 300 012 G    HW: 0DE 927 711 B
   Component: GSG DQ500     H16 2006
   Revision: 00H16V33
   ROD: EV_TCMDQ500021.rod
   VCID: 2D508CC27C2F112246-8079
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 61187000000090
   Coding: 6007929F5423236C4780070162C34906492AC4E2E046927D384150B8E2AA4200002F641A1B13111435351919323200
   VCID: 79F86892F8E77D829A-802D
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 00:00:19
8192 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:56
8196 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:56
16404 - Multiple collision brake
          B13BC F1 [009] - triggered
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0443055822
   Coding: 032C0C0F03
   VCID: 3C76B186B75588AAC1-8069
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58031399
          U1400 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 179
                    Mileage: 6617 km
                    Date: 2018.08.04
                    Time: 10:14:31
                    ZAT_pressed: OFF
                    Control Module Voltage: 7.747 V
                    Vehicle speed: 0.0 km/h
                    Engine speed: 0.0 /min
                    Coding information: coded
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
133124 - Databus
                    Reset counter: 179
                    Mileage: 6617 km
                    Date: 2018.05.17
                    Time: 13:29:28
                    Terminal_15_Kessy_specified_value: OFF
                    Terminal_15_Kessy_actual_value: OFF
                    Terminal_15_central electric_actual_value: Timeout
                    Terminal_15red_Kessy_specified_value: OFF
                    Terminal_15red_Kessy_actual_value: OFF
                    Terminal_S_Kessy_specified_value: OFF
                    Terminal_S_Kessy_actual_value: OFF
                    Terminal_S_central electric_actual_value: Timeout
                    ZAT_pressed: OFF
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 11.747 V
                    Driver door: Open
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
14222592 - Databus
                    Reset counter: 179
                    Mileage: 6617 km
                    Date: 2018.05.10
                    Time: 11:06:31
                    ZAT_pressed: OFF
                    Control Module Voltage: 11.896 V
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QE317961
   Coding: 0014000000000500018281818181000000008181000000D400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide.rod
   Part No SW: 565 907 044 AB    HW: 565 907 044 AB
   Revision: 00001K00
   Coding: 1611000400010001110510080010110A
   Shop #: WSC 73430 790 00063
   VCID: 5BB4121A521BAF92E8-800F
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 60594476
          B10CD 00 [008] -  -
                    Reset counter: 179
                    Mileage: 5717 km
                    Date: 2018.02.25
                    Time: 11:47:51
                    Voltage terminal 30: 11.3 V
1048839 - Function limitation due to crash signal
          B1397 00 [008] -  -
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:42:10
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0223
   Revision: --------    Serial number: 865814051701VU
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 0108007290372542D2-8055
   Subsystem 1 - Part No SW: 567 955 119     HW: 567 955 119
   Component: WWS326 170104  051 0907
   Serial number: 887253F0401700400858
   Coding: 164DDD
   Component: RLHS  042 0105
   Serial number: S4Y17M05D13H04M09S09
   Coding: 00885D
   Serial number: 000000000ZY171142AEB
11 Faults Found:
569092 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:58
576516 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:58
568086 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:59
568342 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:59
9994 - Bulb for Right Parking Lamp
          B12E9 15 [008] - Open or Short to Plus
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:19:01
8714 - Bulb for Left Fog Lamp
          B121F 15 [009] - Open or Short to Plus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:19:01
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:19:01
8970 - Bulb for Right Fog Lamp
          B1220 15 [008] - Open or Short to Plus
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 15:55:19
15360256 - Component Protection
          U1101 00 [008] - Active
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [008] - No Release by Immobilizer
262936 - Sensor for anti-theft alarm system
          B1330 29 [008] - Signal Implausible
                    Reset counter: 40
                    Mileage: 3806 km
                    Date: 2018.01.28
                    Time: 13:10:01
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0021
   Serial number: 000905177478060
   Coding: 0331267A51
   Shop #: WSC 10000 002 1048576
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B74B29AB25B8F92C8-806F
8 Faults Found:
13637426 - Databus
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 00:00:20
12727553 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:57
13688835 - Databus
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 00:00:25
1113107 - Front Parking Aid Sensor(s)
          B10FC 13 [009] - Open Circuit
                    Fault Frequency: 55
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:55
1112305 - Parking Sensor; Front Left Center
          B10F8 F1 [008] - Reverberation Time too Long
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.16
                    Time: 09:22:04
1113328 - Parking Sensor(s); Front
          B10FC F0 [008] - Function Limitation due to External Factors
                    Fault Frequency: 20
                    Reset counter: 179
                    Mileage: 3574 km
                    Date: 2018.01.26
                    Time: 15:49:12
1080304 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
                    Fault Frequency: 21
                    Reset counter: 179
                    Mileage: 5849 km
                    Date: 2018.03.03
                    Time: 08:19:37
10494464 - Function Limitation due to Environmental Factors
          B2022 00 [008] -  -
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.16
                    Time: 09:22:04
Address 13: Auto Dist. Reg
   Serial number: 25041741350262
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 387EAD96836DA48A25-806D
   Part No SW: 3Q0 959 655 AP    HW: 3Q0 959 655 AP
   Component: Airbag VW21   004 0306
   Revision: --------    Serial number: 003RAP8R0WCF
   Coding: 98FCC0C0000000005C545000008800000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001010
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0C162146A775782AB1-8059
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 567857705A0132R00097
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 567857706A0125R00804
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 504 17
   Serial number: 3570000000046B89732M
   Subsystem 4 - Part No SW: -----------    HW: 454 000 505 17
   Serial number: 35800000000FC210A42J
   Subsystem 5 - Part No SW: -----------    HW: 454 800 705 17
   Serial number: 351008096E10F000000J
   Subsystem 6 - Part No SW: -----------    HW: 454 800 805 17
   Serial number: 352007562F50F000000M
   Subsystem 7 - Part No SW: -----------    HW: 454 801 011 17
   Serial number: 355001E8F6312000000K
18 Faults Found:
9437201 - Igniter for Driver's Airbag
          B1000 11 [136] - Short to Ground
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 07:24:19
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:52
9437713 - Igniter for Passenger's Airbag
          B1002 11 [136] - Short to Ground
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
9437723 - Igniter for Passenger's Airbag
          B1002 1B [137] - Resistance Too High
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:42:20
9440283 - Driver side knee airbag igniter
          B100C 1B [137] - Resistance Too High
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
9438993 - Igniter for Seat Belt Tensioner; Passenger's Side
          B1007 11 [136] - Short to Ground
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
          B1007 1B [137] - Resistance Too High
                    Mileage: 6616 km
                    Date: 2018.03.20
                    Time: 07:43:57
9439505 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 11 [136] - Short to Ground
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
9439515 - Seat Belt Tensioner Igniter; rear; driver's side
          B1009 1B [137] - Resistance Too High
                    Mileage: 6617 km
                    Date: 2018.04.06
                    Time: 07:12:45
9439259 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1B [137] - Resistance Too High
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
1050117 - Databus
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 00:00:21
1054464 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:55
9447424 - Front crash data stored
          B1028 00 [137] -  -
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:52
9634820 - Control Module for Front Left Belt Tensioner
          B1304 04 [009] - Internal System Fault
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
9635076 - Control Module for Front Right Belt Tensioner
          B1305 04 [009] - Internal System Fault
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
9682160 - Multiple collision brake
          B13BC F0 [009] - Crash data stored
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
9682161 - Multiple collision brake
          B13BC F1 [008] - triggered
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
   Part No SW: 3Q0 953 521 ED    HW: 5Q0 953 569 A
   Revision: FF036036    Serial number: 20170517400648
   Coding: 6414
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 76E263AEC9F912FAF7-8023
   Part No SW: 565 920 750     HW: 565 920 750
   Component: KOMBI         311 8311
   Coding: 27A4081CFF80000801886B0B5001000000000000
   Shop #: WSC 73430 031 00063
   VCID: 57BC0E2A2E334BF2CC-8003
16777028 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:19:04
16776960 - Databus
                    Fault Frequency: 55
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:55
16776961 - Databus
                    Fault Frequency: 55
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:55
   Component: GW MQB High   518 5286
   Serial number: 18051710803511
   Coding: 030100346F085900EB03225E9E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 2F6C96CA7623633274-807B
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000D2937190417
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Serial number: 75886100001705130051
131671 - No Communications with Cruise Control (Front) Distance Sensor
          U0235 00 [009] - -
                    Fault Frequency: 55
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:58
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
   Serial number: HA1-00023.03.17
   Coding: 0101
   VCID: 4A9AE75EED81261A43-801F
   Serial number: 17000116834015
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E850B2A09735C222-8025
   Serial number: Y0006QE327206
   Component: HRE_Master    H12 0071
   Serial number: 0440143547
   Coding: 02012203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0440313269
   Coding: 020122
338048 - Databus
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 00:00:24
   Serial number: 0000258310559
   Coding: 00158820DE01048000001100
   VCID: 479CDE6AFE93DB725C-8013
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 4580D462C49FC962AE-8011
16275 - Steering Angle Sensor
                    Reset counter: 144
                    Time: 00:00:00
                    Motor status: 00
                    Supply voltage: 12.25 V
                    Temperature: 28.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.30 V
                    uAdSensI_SwitchedKl30_xdu16: 12.31 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 C0
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
   Part No SW: 81A 035 223     HW: 81A 035 223
   Component: MIB2_amp_P_SK H10 0410
   Revision: 00000001    Serial number: SKZ8Z1HJE01UC05
   Coding: 0323160000AA002AAA0000000000
   ASAM Dataset: EV_AMPMst16C4Gen2ALPI 001003
   ROD: EV_AMPMst16C4Gen2ALPI.rod
   VCID: 59B8081258275D82FA-800D
   Serial number: 0000258684795
   Coding: 00158020DE01048000001100
   VCID: 4682D36EF999C27AA7-8013
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0070
   Coding: 03E602003D210901
   ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
   ROD: EV_HeadlRegulAFSMQBMAX_SK26.rod
   VCID: 4188C072D0B7E54292-8015
66672 - Control Module for Light Activation/Adjustment; Left
          U116E 00 [137] - No Communications
                    Reset counter: 139
                    Mileage: 6618 km
                    Date: 2018.10.09
                    Time: 19:13:25
131353 - Power Output Module for LED Headlamps; Left
          U1170 00 [009] - No Communications
                    Reset counter: 139
                    Mileage: 6618 km
                    Date: 2018.10.09
                    Time: 19:13:27
131080 - Databus Front Lights
          U1504 00 [137] - No Communications
                    Fault Frequency: 36
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:58
   Part No SW: 3V0 035 045 D    HW: 3V0 035 045
   Component: MU-H-N-RW     H50 0942
   Serial number: A692D0HS002638
   Coding: 032316080000000051510002000908232F0300E601208100DE
   VCID: 2E528BCE71296A3A7F-807B
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H50 8120
   Serial number: SKZ6ZHT1420460
   Subsystem 2 - Part No SW: V03 959 801 KB    HW: -----------
   Component: ROW 2017  --- 0062
   Component: Gracenote2---  --- 4009
3086 - Antenna for Telephone Mount
          B1564 01 [009] - Electrical Failure
                    Reset counter: 179
                    Mileage: 37 km
                    Date: 2017.10.23
                    Time: 16:57:21
                    Voltage terminal 30: 14.6 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): not selected
                    Status of telephone-Handset holder (cradle): not connected
          U1111 00 [009] - -
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:48:30
                    Voltage terminal 30: 14.4 V
                    BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:48:31
                    Voltage terminal 30: 14.0 V
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0204
   Revision: 8A001003    Serial number: 0438644978
   Coding: 0100000202000000
656138 - Bulb for Right Tail Light on Trailer
          C10F4 15 [008] - Open or Short to Plus
                    Reset counter: 40
                    Mileage: 2801 km
                    Date: 2018.01.18
                    Time: 16:42:48
656394 - Bulb for Left Tail Light on Trailer
          C10F5 15 [008] - Open or Short to Plus
                    Reset counter: 40
                    Mileage: 2801 km
                    Date: 2018.01.18
                    Time: 16:42:47
   Part No SW: 5Q0 907 556 B    HW: 5Q0 907 556
   Component: Areaview 2    H13 0607
   Serial number: C854707JG014422
   Coding: 04231601A70FA00000604094
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
9598995 - Video Signal Line for Front Surroundings Camera
          B1278 01 [009] - Electrical Failure
                    Fault Frequency: 29
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:19:01
13706029 - Voltage Supply for Camera; Front
          B1862 01 [009] - Electrical Failure
                    Fault Frequency: 38
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:55
   Part No SW: 5Q0 959 107 L    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31364356200000
   Coding: 1B88
   Shop #: WSC 60478 002 1048576
   ROD: EV_DeckLidCONTIAU736_VW41.rod
   Part No SW: 3Q0 980 654 G    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0231
   Serial number: 11051711K11896
   Coding: 020307060000010100022355C050A90088000E200000
9 Faults Found:
1122561 - Databus
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:57
                    Control Module temperature: 32 °C
                    Outside air temperature: 28.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 3.3 s
                    Voltage terminal 15: 11.8 V
                    mid: 01 AB
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1135140 - Databus
                    Fault Frequency: 21
                    Reset counter: 179
                    Mileage: 5849 km
                    Date: 2018.03.03
                    Time: 08:19:37
                    Control Module temperature: 44 °C
                    System run time: 660.2 s
                    mid: 02 65
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1135139 - Databus
                    Fault Frequency: 77
                    Reset counter: 139
                    Mileage: 3574 km
                    Date: 2018.01.26
                    Time: 15:49:14
                    Control Module temperature: 52 °C
                    Outside air temperature: 32.0 °C
                    System run time: 184.8 s
                    Voltage terminal 15: 13.5 V
                    mid: 02 64
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123173 - Databus
                    Reset counter: 179
                    Mileage: 37 km
                    Date: 2017.10.23
                    Time: 17:18:07
                    Control Module temperature: 43 °C
                    Outside air temperature: 22.0 °C
                    System run time: 458.7 s
                    Voltage terminal 15: 12.0 V
                    mid: 02 E0
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1123187 - Local Data Bus
          U116B 00 [008] - Received Malfunction Value
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:51
                    Control Module temperature: 29 °C
                    Outside air temperature: 23.5 °C
                    Vehicle speed: 5.36 km/h
                    System run time: 319.3 s
                    Voltage terminal 15: 12.1 V
                    mid: 02 C0
                    Status of camera: Crash status
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 139
                    Mileage: 6616 km
                    Date: 2018.03.19
                    Time: 09:18:57
                    mid: 01 42
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
0633 - Camera Interference
          C1104 00 [008] -  -
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
                    Vehicle speed: 27.38 km/h
                    System run time: 318.8 s
                    Voltage terminal 15: 12.6 V
                    mid: 02 4C
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
0635 - Camera Interference
          C1104 00 [008] -  -
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
                    mid: 02 4E
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
0629 - Camera Interference
          C1104 00 [008] -  -
                    Reset counter: 179
                    Mileage: 6616 km
                    Date: 2018.03.13
                    Time: 07:41:50
                    mid: 02 50
                    Software_Info_4: 1
                    Software_Info_3: 3
                    Software_Info_2: 2
                    Software_Info_1: 0
   Part No SW: 5Q4 959 595 E    HW: 5Q4 959 595 B
   Component: TSG HFS       011 0032
   Serial number: 0000253666241
   Coding: 001880208001048000001100
   ASAM Dataset: EV_DCURearDriveMAXCONT 006001
   VCID: 4998D852E8872D024A-801D
   Component: TSG HBFS      011 0032
   Serial number: 0000253666238
   ASAM Dataset: EV_DCURearPasseMAXCONT 006001
End-------------------------(Elapsed Time: 08:19)--------------------------
2018 donor vehicle scan
Wednesday,03,April,2019,19:21:25:15919
VIN: TMBMD9NS5J8053235   License Plate:
Mileage: 13031km-8097mi   Repair Order:
Chassis Type  NS-SK37 (3Q0)
          47 4B 52 5F 6C 6D A5 BB BC CA
VIN: TMBMD9NS5J8053235   Mileage: 13031km-8097miles
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CZPA)       Labels: None
   Part No SW: 5NA 907 115 E    HW: 06L 907 309 B
   Component: R4 2.0l TFSI  H31 0003
   Revision: 1DH31000
   Shop #: WSC 33361 790 00168
   ASAM Dataset: EV_ECM20TFS0115NA907115E 001005
   ROD: EV_ECM20TFS0115NA907115E.rod
   VCID: 408EC576DBBDEC4A9D-8015
7 Faults Found:
21605 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [175] - Malfunction
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
                    Engine speed: 1292.00 /min
                    Normed load value: 2.7 %
                    Coolant temperature: 31 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 11.520 V
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
17156 - Databus
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Engine speed: 1428.50 /min
                    Vehicle speed: 12 km/h
                    Coolant temperature: 93 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 12.800 V
                    Acceleration: -1.301 m/sІ
17158 - Databus
          U1123 00 [109] - Received Error Message
                    Fault Frequency: 25
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
                    Engine speed: 480.00 /min
                    Voltage terminal 30: 12.060 V
                    Acceleration: -5.988 m/sІ
          P1609 00 [032] - -
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
          P1609 00 [032] - -
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
          U0235 00 [047] - -
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
                    Engine speed: 1339.00 /min
                    Normed load value: 2.4 %
                    Voltage terminal 30: 11.500 V
                    Com st X Set2 Val1-Bits 0-7: 16
                    Com st X Set2 Val3-Bits 0-7: 1
18539 - Mass Air Flow Sensor (G70)
          P0100 00 [237] - Supply Voltage
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:19
                    Engine speed: 1316.00 /min
                    Intake air temperature: 31 °C
   Part No SW: 0DL 300 012 M    HW: 0DE 927 711 B
   Component: GSG DQ500     H16 2105
   Revision: 00H16V33
   VCID: 33649ABA9A0B47D210-8067
   Revision: 00000000    Serial number: 63027000000529
   Coding: 6007929F5425236F4779070362C84906492AC4E2E046927D384150B8E2A94200002F641A1B13111435351919323200
9 Faults Found:
0294 - Steering angle sensor
          B1168 16 [008] - Voltage Too Low
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:23:50
8192 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
8196 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
8291 - Databus
                    Reset counter: 183
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
16405 - Multiple collision brake
          B13BC F2 [009] - No function
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
16411 - Display for Tire Pressure Monitoring
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:30
32832 - Switch for Electric Parking Brake
          C100C 07 [008] - Mechanical Failure
                    Reset counter: 148
                    Mileage: 11696 km
                    Date: 2018.12.06
                    Time: 14:07:46
   Component: VWKESSYMQB    037 0907
   Revision: 00037000    Serial number: 0462894374
   Coding: 032C0C070F
   VCID: 3E72BB8EA1499ABAEF-806B
   Serial number: 58307646
   Part No SW: 5Q0 959 760 C    HW: 5Q0 959 760 C
   Component: Sitzmemory    H09 0023
   Serial number: Y0006QL428679
   VCID: 3D70BC82AC4F81A2F6-8069
   Part No SW: 565 907 044 BB    HW: 565 907 044 BB
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 1611000400010001110510080010112A
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   VCID: 5CB611065715A8AAE1-8009
   Serial number: 62392487
459527 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:24
          B1397 00 [008] -  -
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:49
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0245
   Revision: --------    Serial number: 865828111701SA
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0602136EB919027AE7-8053
   Component: WWS326 171013  051 0907
   Serial number: 887253F0401728600206
   Coding: 164DDD
   Component: RLHS  047 0105
   Serial number: S5Y17M12D01H11M45S57
   Coding: 00885D
   Subsystem 3 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY173135H65
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223973072725
   Subsystem 6 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V512 LLR1SLvL  H03 0012
   Serial number: L14DH29400739
   Subsystem 7 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V514 LLR1SKvL  H03 0012
   Serial number: L14DH29400226
   Subsystem 8 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V516 LLR1SLvR  H03 0012
   Serial number: L14DH29101485
   Subsystem 9 - Part No SW: 4M0 963 575     HW: 4M0 963 575
   Component: V518 LLR1SKvR  H03 0012
   Serial number: L14DH23900610
6 Faults Found:
569092 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:23
576516 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:23
137217 - Outside temperature sensor
          B103F 1B [137] - Resistance Too High
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 16:41:26
                    Reset counter: 169
                    Mileage: 12627 km
                    Date: 2018.12.23
                    Time: 22:28:02
197904 - Central Locking
          B140A 4B [008] - Over temperature
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 000811177478000
   Coding: 0331267851
13637426 - Databus
                    Fault Frequency: 30
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
12727553 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:22
13637888 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:25
13688835 - Databus
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:23:54
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:19
   Serial number: 10111741351241
452867 - Front Right Ride-Height Sensor
          C1035 07 [008] - Mechanical Failure
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PLQ1RFR
   VCID: 081E1D56B30D140A95-805D
   Serial number: 567857705A0328R00107
   Coding: 80000D
   Serial number: 567857706A0328R00159
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 001 711 17
   Serial number: 35700000000C1664AA2N
   Subsystem 4 - Part No SW: -----------    HW: 454 001 711 17
   Serial number: 3580000000019564AA2K
   Subsystem 5 - Part No SW: -----------    HW: 454 801 611 17
   Serial number: 351007F2E4912000000K
   Subsystem 6 - Part No SW: -----------    HW: 454 801 711 17
   Serial number: 3520009204912000000.
   Subsystem 7 - Part No SW: -----------    HW: 454 801 704 17
   Serial number: 355001999810F000000M
18 Faults Found:
9438491 - Igniter for Driver head airbag
          B1005 1B [137] - Resistance Too High
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
9438235 - Igniter for Front passenger's Head Curtain Airbag
          B1004 1B [137] - Resistance Too High
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
9440027 - Driver's side; side-airbag igniter
          B100B 1B [137] - Resistance Too High
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:31
9441563 - Rear; driver's side; side-airbag igniter
          B1011 1B [137] - Resistance Too High
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
9438737 - Igniter for Seat Belt Tensioner; Driver's Side
          B1006 11 [136] - Short to Ground
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:23:50
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
9439249 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 11 [136] - Short to Ground
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:31
9439258 - Igniter for Seat Belt Tensioner; Rear Passenger's Side
          B1008 1A [137] - Resistance Too Low
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 17:29:52
1054981 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
1050117 - Databus
                    Fault Frequency: 7
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
1054464 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
9447936 - Crash data stored; driver side
          B102A 00 [137] -  -
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:31
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
   Part No SW: 5Q0 953 521 GE    HW: 5Q0 953 569 A
   Revision: FF035035    Serial number: 20171125500310
   Coding: 6414
   VCID: 7BF4729AF2DB4F9288-802F
   Part No SW: 565 920 750 A    HW: 565 920 750 A
   Component: KOMBI         304 0312
   Coding: 27A4001CFF80000801886B0B5001000000000000
   Shop #: WSC 73430 031 00168
   VCID: 183E4D16E3AD848A05-804D
          U1110 00 [009] - -
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:28
16776960 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:19
16776961 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:19
13639936 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 16:41:26
   Component: GW MQB High   518 5323
   Serial number: 06121710804479
   Coding: 030100047F085900EB03227E9E0F00010001070000000000000000000000
   Serial number: 000000000A2814151117
   Serial number: 75886100001711200288
          U0235 00 [009] - -
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:23
                    Supply voltage: Terminal 30: 12.4 V
                    Terminal 15: On
8526363 - Unknown Error Code
          B189C F0 [009] - Unknown Error Elaboration
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
                    Supply voltage: Terminal 30: 13.5 V
                    Terminal 15: On
   Component: Haldex4Motion H52 7084
   Serial number: HA1-00003.10.17
   Coding: 0101
   VCID: 4C96E146E7F5382A71-8019
   Serial number: 17000340445006
   Serial number: Y0006QKR10672
          U1400 00 [008] - -
                    Reset counter: 157
                    Mileage: 12212 km
                    Date: 2018.12.15
                    Time: 08:02:20
   Component: HRE_Master    H12 0080
   Serial number: 0461963692
   Coding: 02011203
   Component: HRE_Slave  H12 0080
   Serial number: 0461625341
   Coding: 020112
338048 - Databus
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:23:52
   Serial number: 0000292611518
   Part No SW: 5Q0 909 144 AA    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  130 1081
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 73E45ABADA8B07D2D0-8027
16650 - Steering angle sensor
          B1168 29 [008] - Signal Implausible
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Motor status: 02
                    System status: Driving mode
                    Supply voltage: 11.50 V
                    Temperature: 64.0 °C
                    KFC: 41
                    KFA: 00 0A
                    uioUdNotFilt_xdu16: 11.58 V
                    uAdSensI_SwitchedKl30_xdu16: 11.52 V
                    NoInitCause_RackPos_Rohwert: 00 08
                    RP_VALCNTSAV: not activated
                    RP_INDEXPLAUSI: activated
                    RP_UNDERVOLT: not activated
                    RP_CNTERR: not activated
16141 - Steering Angle Sensor
                    Reset counter: 148
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Motor status: 02
                    KFC: 3F
                    KFA: 00 0D
                    uioUdNotFilt_xdu16: 11.66 V
                    uAdSensI_SwitchedKl30_xdu16: 11.59 V
                    NoInitCause_AsicSens: [0x01] ASC_CTRL_SAS_HL_ERR - Error discovered by the High level application
                    NoInitCause_RackPos_Rohwert: 00 09
                    RP_KMN_RACKPOS_SET: activated
22276 - Databus
                    Reset counter: 183
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:20
                    Motor status: 01
                    Temperature: 32.0 °C
                    KFC: 57
                    KFA: 00 04
   Revision: 00000001    Serial number: SKZ8Z1HJE03C6P8
Address 4B: Multifunc. Module
Interface not compatible.
   Serial number: 0000292459238
   Part No SW: 565 035 019 B    HW: 565 035 019
   Component: MU-H-LND-RW   H54 1163
   Serial number: A890K0HS013780
   Coding: 032316080000000041510202008908312F0100E601208500DF
   VCID: 14263926FF45A0EA69-8041
   Subsystem 1 - Part No SW: 565 919 606 D    HW: 565 919 606 D
   Component: ABT_High-2  H50 9130
   Serial number: SKZ6ZHT3402297
   Subsystem 2 - Part No SW: V03 959 801 KD    HW: -----------
   Component: ROW 2018  --- 0068
   Component: Gracenote2  --- 4012
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [009] - Open Circuit
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2018.03.09
                    Time: 12:48:49
                    Voltage terminal 30: 12.2 V
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 255 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [009] - Open Circuit
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2018.03.09
                    Time: 12:48:49
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
0013 - Antenna Amplifier 1 for Digital Radio
          B1270 13 [009] - Open Circuit
                    Reset counter: 2
                    Mileage: 29 km
                    Date: 2018.03.09
                    Time: 12:48:49
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Open circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
          U1111 00 [009] - -
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:44
                    Voltage terminal 30: 13.7 V
          U1111 00 [009] - -
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:44
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG022893
   Coding: 04231601A60FA00000604094
   VCID: 3978A892B867BD82DA-806D
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:25
                    Reset counter: 143
   Revision: --------    Serial number: 31688020700000
   Coding: 1B08
0066 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:22
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 1272
   Serial number: 21101741P20614
   Coding: 020307060000010100022354C150A90088000E200000
10 Faults Found:
1122561 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:22
                    Outside air temperature: 77.5 °C
                    mid: 01 A3
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1135139 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:22
                    System run time: 3.6 s
                    Voltage terminal 15: 12.3 V
                    mid: 02 64
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123173 - Databus
                    Fault Frequency: 29
                    Reset counter: 143
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
                    Control Module temperature: 74 °C
                    Outside air temperature: 34.0 °C
                    Vehicle speed: 0.33 km/h
                    System run time: 617.4 s
                    mid: 02 E0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123175 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:23
                    System run time: 3.8 s
                    Voltage terminal 15: 12.5 V
                    mid: 02 8D
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
1123184 - Databus
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:26
                    Vehicle speed: 1.29 km/h
                    System run time: 7.3 s
                    Voltage terminal 15: 14.3 V
                    mid: 02 E2
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:30
                    Vehicle speed: 0.48 km/h
                    System run time: 617.2 s
                    mid: 02 C0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
                    Reset counter: 143
                    Mileage: 13031 km
                    Date: 2019.03.23
                    Time: 17:04:22
                    mid: 01 43
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
          C1104 00 [008] -  -
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    Vehicle speed: 14.84 km/h
                    System run time: 616.7 s
                    Voltage terminal 15: 14.0 V
                    mid: 02 4C
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
          C1104 00 [008] -  -
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    mid: 02 4E
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
          C1104 00 [008] -  -
                    Reset counter: 183
                    Mileage: 13030 km
                    Date: 2018.12.30
                    Time: 16:12:29
                    mid: 02 50
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 1
   Component: TSG HFS       012 0032
   Serial number: 0000292069606
   Component: TSG HBFS      012 0032
   Serial number: 0000292069887
Address CA: Sunroof
End-------------------------(Elapsed Time: 08:03)--------------------------
darkchina811
ITALY
C?ID=333184
I did put a larger display in my Golf so I am pretty sure the screen can be swapped with no problems.
However the glove box unit is not a direct swap for sure. Why would you want to replace it?
PetrolDave
Westbury, UK
C?ID=1423
If the glove box unit is a MIB1 unit then it will not work with a MIB2 display (and vice versa) as the screen resolution is different.
darkchina811
ITALY
C?ID=333184
they're both MIB2, no doubt about that. Kodiaq did not exist when MIB1 was around.
icardiag
Europe
C?ID=113031
It's Kodiaq so all the MIB units are 2.5. Regarding the autoscan, the repaired car has Amundsen and the donor car has Columbus. Screen swapping is not possible as the 2.5 Columbus has different screen resolution.
You can only swap MIB1/MIB2 Columbus screen to MIB2/MIB2.5 Amundsen/Bolero.
Swapping Amundsen unit to Columbus won't be easy, as the FEC will not match and it won't work. Solution is to use a hacked Columbus unit with disabled component protection and FEC checking...
sasha
Australia
C?ID=287611
@icardiag thanks for the confirmation
:( for some reason i never got notifications about posts on my thread.. just read all the comments.. thanks to all that replied
