Results 1 to 5 of 5
Thread: 2013 MK6 GTI - Keyless defective
    Mar 2019
    Hello guys, someone had this problem before and have any clue how can I fix this.
    The message is driving me crazy...
    1- I have both keys, and both are working , opening and close the car pushing the key fob, also push start work normal.
    Just the sensor in the handle is NOT working.
    2- I already change the battery in both key fobs.
    3- When I touch the handle sensor I can see the message saying KEYLESS DEFECTIVE, but nothing happen!
    3- I already check the antenna in the trunk behind the seat and pretty much it is connect properly .
    5 - I change the passenger door due a damage at the previous one! (all door)
    Thanks in advance for your help
    Best Regards
    Tuesday,02,April,2019,10:16:10:49137
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWHD7AJ8DW037226   License Plate: 2013GTI
    Mileage: 156980km-97542mi   Repair Order:
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 52 55
              56 62 72
    VIN: WVWHD7AJ8DW037226   Mileage: 156980km-97542miles
       Part No SW: 1K0 907 115 AT    HW: 1K0 907 115 AK
       Revision: E3H26---    Serial number:
       Coding: 040301081C070160
       VCID: 78FFADA20B6CBA8AE5-802C
    049493 - No Communication with Instrument Cluster
                   U0155 - 000 -  - Intermittent
                        Mileage: 156895 km
                        Date: 2013.08.10
                        Time: 00:12:29
                        Load: 0.0 %
                        Temperature: 91.0C
                        Temperature: 54.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 11.557 V
    005488 - Engine Start Blocked by Immobilizer
                   P1570 - 000 -  - Intermittent
                        Mileage: 130915 km
                        Date: 2018.02.16
                        Time: 00:07:00
                        RPM: 1165 /min
                        Load: 11.0 %
                        Temperature: 94.0C
                        Temperature: 40.0C
                        Voltage: 11.938 V
       Part No SW: 02E 300 058 P    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3509
       Revision: 05551213    Serial number: 00001206122246
       VCID: 275DBEDE9652E572BC-8072
       Revision: 00H31001
       Coding: 114B600C49250001880D06E6921F0041B70800
       VCID: 7DF1BCB6E44E9FA2B6-8028
       Part No SW: 5K0 959 434 B    HW: 5K0 959 434
       Revision: 00085000    Serial number: 0179551523
       Coding: 030C0C
       ROD: EV_KESSYPQ35G_A02_VW36.rod
       VCID: 346759929F849EEA09-8060
    1053195 - Touch Sensor on Exterior Door Grip; Passenger Side
              B116C 13 [009] - Open Circuit
                        Fault Frequency: 38
                        Reset counter: 126
    1057291 - Antenna for Keyless Entry System; Passenger Side
              B1170 13 [009] - Open Circuit
                        Reset counter: 119
                        Time: 00:00:00
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       VCID: 7BF5B2AEF25A919288-802E
       Part No SW: 1K0 937 086 T    HW: 1K0 937 086 T
       Component: BCM PQ35  M   111 0709
       Revision: AB111709
       Coding: 6F180A3AD8272EC4108802C170008DE44E852086474D8DB0E48420248040
       VCID: 41890046D8363B4292-8014
       Component: Wischer 12061  26  0512
       Coding: 009795
    01117 - Generator Terminal DF Load Signal
                        Reset counter: 165
                        Mileage: 156918 km
                        Date: 2013.08.18
                        Time: 16:22:55
                            Term 15 On
                        Voltage: 11.70 V
                            Term 50 On
       Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
       Component: AirbagVW10G   013 0724
       Serial number: 003GVRA2FZX0
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3F8D06BEA6C24DB2E4-806A
       Subsystem 1 - Part No SW: 5K0 959 339 B    HW: 5K0 959 339 B
       Component: BF-Gewichtss.  006 0001
       Serial number: ---0000R--00003B1500
       Serial number: 3572MSME50044567ZZZO
       Serial number: 3582MSME5676147DZZZ0
       Serial number: 3512QSME58391501ZZZN
       Serial number: 3522QSME54431817ZZZP
       Serial number: 35527SME3366002EZZZA
       Serial number: 35627SME6965012EZZZK
       Part No SW: 5K0 953 521 BR    HW: 5K0 953 569 E
       Revision: FF010041    Serial number: 20120619301028
       Coding: 101A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7DF1BCB6EC4E9FA2B6-8028
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0032
       Coding: 830000
       Part No SW: 5K6 920 973 C    HW: 5K6 920 973 C
       Component: KOMBI         H05 0705
       Coding: 270F01
       VCID: 377D6E9E8EF275F22C-8062
       Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
       Component: J533  Gateway H42 1632
       Revision:   H42       Serial number: 170612F1002721
       Coding: 350002
       VCID: 3F8D06BEAEC24DB2E4-806A
       Component: IMMO          H05 0705
       Coding: 000007
       VCID: 6ADB87EA8DC0181A63-803E
       Part No SW: 5K0 905 861 B    HW: 5K0 905 861 B
       Component: ELV-PQ35      H20 0240
       Revision: 00000000    Serial number: 12000141441002
       Coding: 4900000000000000
       ROD: EV_ELVMarquMPVW36X.rod
       VCID: 2F6D56FE76A2BD3274-807A
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H18 0530
       Revision: A1001003    Serial number: 7662875275
       Coding: 020100
       VCID: 2A5B47EA4540D81AA3-807E
       Part No SW: 1K0 035 274 D    HW: 1K0 035 274 D
       Component: RNS315-NAR    H53 0319
       Serial number: VWZAZ2M4233925
       Coding: 04050001010005000000100A
       ASAM Dataset: EV_RNS315NARV2UDS 001705
       ROD: EV_RNS315NARV2UDS_VW32.rod
       VCID: 2541B4D6245EF7628E-8070
       Subsystem 1 - Part No: 3AA 919 866 B
       Component: NAR_V3_(0037)  0037
    1048669 - Tuner for Satelite Radio
              B11CF 53 [008] - Deactivated
                        Reset counter: 165
                        Mileage: 156901 km
                        Date: 2019.03.21
                        Time: 16:23:12
       Part No SW: 5K0 959 701 H    HW: 5K0 959 701 H
       Component: Tuer-SG         009 2105
       Coding: 0001204
       VCID: 377D6E9E46F275F22C-8062
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 74     3305
       Revision: 00H22000
       Part No SW: 5K0 035 456 B    HW: 5K0 035 456 B
       Component: KonzernAmp 8K H07 0368
       Revision: --------    Serial number: EAA085A0032796
       VCID: 2959B8E64846D302AA-807C
    9462803 - Front Right Treble Speaker
              B1064 13 [009] - Open Circuit
                        Reset counter: 119
                        Mileage: 156901 km
                        Date: 2019.03.22
                        Time: 23:27:01
       Part No SW: 5K0 959 702 H    HW: 5K0 959 702 H
       Coding: 0001204
       VCID: 387F6DA24BEC7A8A25-806C
       Coding: 1446940
       VCID: 3467599257849EEA09-8060
       Component: AFS-Lst.-Modul l    0005
       Coding: 00000022
       Coding: 00000022
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 356164965CFE87E23E-8060
       Coding: 0001168
       VCID: 3663639A41F88CFA37-8062
    End-------------------------(Elapsed Time: 03:13)--------------------------
    [code]Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
    Coding: 030C0C
    Fault Frequency: 38
    Reset counter: 126
    Reset counter: 119
    Time: 00:00:00[code]
    This needs to be fixed.
  3. Likes Jack@European_Parts, rc2211 liked this post
    HQ
    Some plugs get mixed up when the door was apart?
    Jef
  5. Likes Uwe, rc2211 liked this post
    Mar 2019
    Thanks for the advise. Ill start trying to get everything from my previous door. (I bought this one complete ).
    I don't think any plug was mixed up, cause as I said, I just take one off and put this one back, the only thing that I really take from the previous one , was the small speaker (DYNAUDIO) and the door trim!
    Thank's again, you guys rock!!
    Mar 2019
    All set guys, get evething from the previous door and set to the new door also wires and handle!Everything working the way that suppose to be!!
    For sure the door that I bought from the other car didnt have the keyless pkg.
    Once again thank you very much all!
    best regards
  8. Likes Uwe liked this post
