Error unknown (0x00) Help!
cilitkas
LT
Trying to change the adaptation channel coding on new style 2017 audi a3 bcm and always get this error unknown 0x00
Engine is not running, and it even wont accept the same coding.
Il attach pic shortly.
Please help.
https://www.flickr.com/photos/147780147@N04/
Tuesday,02,April,2019,17:39:20:52461
VCDS Version: 18.9.1.0 (x64)
VIN: WUAZZZ8V1GA906540   License Plate: RS3
Mileage: 1824km-1133mi   Repair Order:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
          6C BB BC
VIN: WUAZZZ8V1GA906540   Mileage: 1824km-1133miles
2B-Steer. Col. Lock -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Malfunction 0010
BC-Door Rear Pass -- Status: Malfunction 0010
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0005
   Revision: NKH52---
   Coding: 12250032252601033600
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM25TFS0118V0907404 001006
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76E46A5CC90BD0FAF7-8022
9 Faults Found:
17158 - Databus
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:57:39
                    Coolant temperature: 35 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 12.740 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 15
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Coolant temperature: 7 °C
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 11.340 V
                    ACC variants-Bits 0-7: 0
                    CCS Switch-Bits 0-7: 1
                    Cruise control switch actuation-Bits 0-7: 0
                    Cruise control switch actuation-Bits 0-7: 49
                    ACC variants (coding)-Bits 0-7: 1
28212 - Exhaust Pressure Control Valve 2
          P049F 00 [047] - Malfunction
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
                    Engine status: COENG_READY
19305 - Exhaust Pressure Control Valve
          P0475 00 [047] - Electrical Malfunction
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
          U0428 00 [047] - -
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
4713 - No Communication with ABS Brake Control Module
          U0121 00 [172] - -
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
                    Engine speed: 1508.50 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 6 °C
                    Intake air temperature: 7 °C
                    Voltage terminal 30: 10.380 V
                    selected gear-Bits 0-7: 0
4716 - No Communications with Parking Brake Control Module
          U0128 00 [044] - -
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [036] - Malfunction
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
                    Vehicle speed: 255 km/h
                    Coolant temperature: 36 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 11.520 V
Readiness: 1110 0001
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5210
   Revision: 00H10V01
   ROD: EV_TCMDQ500021.rod
   VCID: 295E71204835CF02AA-807C
10680 - Databus
          U1121 00 [044] - Missing Message
                    Fault Frequency: 14
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Engine speed: 1466.00 /min
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: 4 Nm
                    Control Module temperature: 9 °C
                    Accelerator position: 15.2 %
                    DTC memory status: 68
10685 - Databus
                    Fault Frequency: 17
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:54:54
                    Engine speed: 1441.00 /min
                    Clutch: primary stat: Neutral
                    Driving position: P
                    Engine torque: 0 Nm
                    Control Module temperature: 12 °C
                    DTC memory status: 73
   Part No SW: 8V0 907 379 A    HW: 8V0 907 379 A
   Component: ESC           H42 0030
   Revision: 00000000    Serial number: 60956000000021
   Coding: 999CF08DBA9915AF40960068C391920644990F5DA80200C3496022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061006
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 428CC68CD5433C5A8B-8016
8 Faults Found:
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
0295 - Steering angle sensor
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
8277 - Databus
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
16390 - Display for Tire Pressure Monitoring
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:30:51
33000 - Longitudinal Acceleration
          C10B1 29 [137] - Signal Implausible
                    Reset counter: 53
                    Date: 2019.04.02
                    Time: 19:30:42
   Revision: 00021000    Serial number: 0347604164
   Coding: 030C0C
   VCID: 3A7CBE6CBD93749AD3-806E
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:27
12713984 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
   Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
   Component: AC Automat    H03 0110
   Revision: 20001000    Serial number: 00000001021564
   Coding: 03100014000000011000000000001100
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
   VCID: 4088CC84DB4F2E4A9D-8014
   Serial number: C6B84057000000000001
131074 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:20
                    Voltage terminal 30: 8.9 V
                    Outside air temperature: 8 °C
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:22
                    Voltage terminal 30: 8.4 V
459012 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
459020 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
459527 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
   Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
   Component: BCM MQBAB M+  H34 0236
   Serial number: 02001627500223
   Shop #: WSC 06745 128 28888
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7EF4727CE13B98BAAF-802A
   Component: WWS371 140912  042 0585
   Serial number:         140924215426
   Coding: 0A47F7
   Serial number: 23250614
   Coding: 02006C
   Serial number: 26 05 2016  00000710
   Serial number: 00000000000060677680
   Sun Roof:
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.014  H02 0007
   Serial number:     WOO32929111
   Coding: 101F00
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:31:40
534549 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:31:41
568836 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 19:31:39
   Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0051
   Revision: --------    Serial number: 39331426305299
   Coding: 0030150011
7 Faults Found:
13635840 - Supply voltage
                    Reset counter: 93
          U1400 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:21
12658704 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
12656913 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
12656920 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
13637426 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
13637888 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
   Serial number: 003GCR00T9BL
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 479AD798FE6119725C-8012
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34178311B07101440487
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34178312B07101470723
   Coding: 333135
   Occupant Detection:
   Serial number: 6940000Y1400017NV00Y
   Coding: 303230
   Subsystem 4 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 35700000000F7A34F01R
   Subsystem 5 - Part No SW: -----------    HW: 480 002 909 14
   Serial number: 358000000007AA34F01N
   Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
   Serial number: 3510002BB175A90091B0
   Subsystem 7 - Part No SW: -----------    HW: 480 401 909 14
   Serial number: 3520002A9176A6C17230
   Subsystem 8 - Part No SW: -----------    HW: 480 400 311 12
   Serial number: 3550002B30CC5BF032AD
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 480 400 808 14
   Serial number: 35600029916FC22340B4
16 Faults Found:
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Fault Frequency: 9
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:49
9482752 - Seat Occupied Recognition
          B10B2 00 [008] - Function Restriction due to Missing Message(s)
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:49
          B13BC F2 [008] - No function
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:15:40
9634838 - Control Module for Front Left Belt Tensioner
          B1304 16 [008] - Voltage Too Low
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:31
9635094 - Control Module for Front Right Belt Tensioner
          B1305 16 [008] - Voltage Too Low
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:29
1055232 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1054981 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:50:00
1052928 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1049088 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1049093 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
1052416 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1052672 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:34
1050117 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
1049094 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
1049095 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
   Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 03101408490168
   Coding: A018
   VCID: 0A1C2EACADF3A41A83-805E
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
   Part No SW: 8V0 920 790     HW: 8V0 920 790
   Component: FBenRDW       H11 0041
   Coding: 00AD1840EB9000080104EE001000000000000000
   Shop #: WSC 01531 128 28888
   ASAM Dataset: EV_DashBoardFPKAU37X 001023
   ROD: EV_DashBoardFPKAU37X.rod
   VCID: 79FE6160F815BF829A-802C
10 Faults Found:
10485835 - Internal Control Module Memory Check Sum Error
          B2000 41 [009] - General checksum failure
                    Mileage: 24 km
                    Date: 2016.03.17
                    Time: 00:00:01
          U1014 00 [009] - -
                    Fault Frequency: 6
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
9582600 - Switch for Instrument Cluster
          B1893 13 [009] - Open Circuit
                    Fault Frequency: 18
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:44:50
16776968 - Databus
                    Fault Frequency: 25
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
16776969 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
16776973 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
16776980 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
16777103 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:40
13639936 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 11091610802548
   Coding: 01010008200860005B00022C180B00000001010000000000000000000000
   Shop #: WSC 33361 790 00114
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 7CF07874F7278AAA81-8028
   Subsystem 2 - Part No SW: 4S0 951 523 E    HW: 4S0 951 523 E
   Component: J453 MFL  H06 0002
   Serial number: 20151222074848 RD132
131598 - Body Control Module (Central Electric)
          U0140 00 [008] - No Communications
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:41
                    Terminal 15: OFF
131603 - No Communication with ABS Brake Control Module
          U0121 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:19:09
                    Supply voltage: Terminal 30: 10.1 V
                    Terminal 15: OFF
1282 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:58:53
                    Supply voltage: Terminal 30: 8.4 V
                    Terminal 15: On
67072 - Local Databus
          U1125 00 [009] - Additional Installations Detected
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:08:01
                    Supply voltage: Terminal 30: 9.7 V
                    Terminal 15: OFF
          U1101 00 [009] - Active
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:11
                    Supply voltage: Terminal 30: 10.9 V
                    Terminal 15: On
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00017.02.16
   Coding: 0601
   Shop #: WSC 06314 790 00021
   VCID: 4586DD90C46D0B62AE-8010
10 Faults Found:
16655 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17468 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17495 - Databus
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17501 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:52:25
17471 - Databus
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:35
17502 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17469 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17470 - Databus
                    Fault Frequency: 15
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17504 - Databus
                    Fault Frequency: 11
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:30
17505 - Databus
                    Fault Frequency: 8
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:31:26
   Revision: 00000000    Serial number: 14000270884002
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346090549FF782EA09-8060
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:57:45
                    ELV State: 04
                    Information Clamps: 77 60
                    CoCo State: E0 01
                    WFS State: 17 06
                    Vehicle speed: 655.34 km/h
                    Voltage: 47
                    AD-Value H-bridge: 23
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 05
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:20
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 17 06
                    Voltage: 4C
                    AD-Value H-bridge: 25
                    CAN signals: 05
12665088 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:38
                    ELV State: 04
                    Information Clamps: 00 00
                    CoCo State: E0 01
                    WFS State: 00 06
                    Voltage: 67
                    AD-Value H-bridge: 33
                    CAN signals: 05
12665089 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:23:38
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 00 06
                    Voltage: 66
                    CAN signals: 05
12666370 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:33
                    ELV State: 04
                    CoCo State: E0 01
                    WFS State: 1F 06
                    Voltage: 72
                    AD-Value H-bridge: 37
                    CAN signals: 05
   Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
   Serial number: 0346835485
   Coding: 030211
   VCID: 3878A464839F668A25-806C
   Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
   Component: SWA Slave  H05 0071
   Serial number: 0346892700
   Coding: 030211
336901 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:31
   Serial number: 19091406070881
   Coding: 005D1F205C00048000000002
65548 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:47
65571 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
65573 - Local Data Bus
          U10BA 00 [008] - No Communication
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:37:02
458776 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 0002
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3566AD50948D9BE23E-8060
8 Faults Found:
15873 - Steering angle sensor
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:53
                    Motor status: 00
                    Supply voltage: 11.25 V
                    Temperature: 15.0 °C
                    KFC: 3E
                    KFA: 00 01
                    Environmental conditions: 5B
                    uioUdNotFilt_xdu16: 11.30 V
                    uAdSensI_SwitchedKl30_xdu16: 11.29 V
19200 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:54:54
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 11.00 V
                    Temperature: 17.0 °C
                    KFC: 4B
                    KFA: 00 00
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 11.27 V
                    uAdSensI_SwitchedKl30_xdu16: 11.27 V
19712 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Supply voltage: 10.50 V
                    Temperature: 8.0 °C
                    KFC: 4D
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 10.73 V
                    uAdSensI_SwitchedKl30_xdu16: 10.74 V
20224 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 4F
                    KFA: 00 00
20992 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 52
                    KFA: 00 00
19456 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 4C
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 10.45 V
                    uAdSensI_SwitchedKl30_xdu16: 10.44 V
20736 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    Motor status: 01
                    Temperature: 8.0 °C
                    KFC: 51
                    KFA: 00 00
20480 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:36
                    Motor status: 02
                    Supply voltage: 14.00 V
                    Temperature: 8.0 °C
                    KFC: 50
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 14.09 V
                    uAdSensI_SwitchedKl30_xdu16: 14.08 V
   Part No SW: 8V0 035 465 C    HW: 8V0 035 465
   Component: MIBAMP1ALPINE H11 0410
   Serial number: AUZ8ZAEN900QK6B
   Coding: 01030300AAAA2AAA01
6693 - Databus
                    Fault Frequency: 14
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:36
                    Voltage terminal 30: 13.2 V
1539 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:38:13
                    Voltage terminal 30: 8.0 V
   Serial number: 21091401100625
   Coding: 005D17205E00048000000002
   VCID: 3F8ACF78A6B151B2E4-806A
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:49
65604 - Door Warning Lamp
          B1326 01 [009] - Electrical Failure
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 16:46:03
458776 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
   Component: AFS-ECU       H01 0091
   Coding: 012E000123200400
9 Faults Found:
13705472 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
          U1014 00 [137] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:58
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:58
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:58
5545009 - LED Headlamp Power Output Stage; Left
          B149C 31 [137] - No Signal
                    Fault Frequency: 6
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:09
5544753 - LED Headlamp Power Output Stage; Right
          B149B 31 [137] - No Signal
                    Fault Frequency: 6
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:09
5275953 - Power Output Module for Left Headlamp
          C1081 31 [137] - No Signal
                    Fault Frequency: 6
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
5276209 - Power Output Module for Right Headlamp
          C1082 31 [137] - No Signal
                    Fault Frequency: 6
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
13705992 - Databus
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 18:25:08
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 8V1 035 035     HW: 8V1 035 035
   Component: MU-P-LND-EU   052 1168
   Serial number: A698G0G7505904
   Coding: 017351010000000011111102000A00332F0028E701700100DE
   VCID: 6FEA5F38B651E13234-803A
   Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Component: DU High  H49 0013
   Serial number: AUZ8Z9EY201S6F
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
   Component: ControlUnit_H  H85 0855
   Serial number: ALJAL131051600010388
   Component: Gracenote2  --- 1013
11 Faults Found:
1537 - Supply voltage
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:42
                    Voltage terminal 30: 8.7 V
          U1400 00 [008] - -
                    Fault Frequency: 13
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:43:24
          B201A 00 [009] -  -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:50:01
                    Voltage terminal 30: 11.4 V
                    Status_Software_Version_Management-module_name: MFC2H37xE/HREU
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:50:13
                    Software module: status-SW_Status_Consistency: 00 00 12
                    Software module: status-SW_Status_Device:
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Voltage terminal 30: 11.5 V
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Interface for external media: status-Status: Open circuit
0012 - Digital Radio Antenna
          B1103 11 [009] - Short to Ground
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:56
                    Status of digital radio antenna 1-Antenna current: 0 mA
                    Status of digital radio antenna 1-Connection between radio and antenna amplifier: Short circuit
                    Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                    Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
3077 - Telephone baseplate
          B1051 13 [009] - Open Circuit
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:55
6702 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:40
                    Voltage terminal 30: 14.2 V
                    Network diagnosis-Status: Enabled
          U1111 00 [008] - -
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
                    BAP-BAP_Function_ID: 02
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:58
   Coding: 027300010201000300
   ROD: EV_2CamSysRearPASE_AU37.rod
   VCID: 30689C446BEFBECA6D-8064
7 Faults Found:
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:54:09
                    CAN communication
13705476 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
13705491 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
13705492 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:33
                    CAN communication
13705493 - Databus
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
9529428 - Steering angle sensor
                    Reset counter: 53
                    Mileage: 1824 km
                    Date: 2019.04.01
                    Time: 19:49:54
                    passive
327936 - Vehicle Speed Sensor
          P0501 00 [008] - Implausible Signal
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 15:41:32
                    CAN communication
   Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0025
   Serial number: 01101402090316
   Coding: 004D17204000048000000002
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:50
   Component: TSG HBFS      020 0025
   Serial number: 01101401100323
                    Reset counter: 93
                    Mileage: 1824 km
                    Date: 2019.04.02
                    Time: 17:46:50
End-------------------------(Elapsed Time: 05:21)--------------------------
Try opening the car's hood.
And please post an Auto-Scan from the car in question.
cilitkas
LT
147780147@N04
Hood is open. Security access accepted...
Il do the autoscan, but not sure how it will help?
cilitkas
LT
here you go sir.
cilitkas
LT
Tried this with different bcm, still the same.
Cant this be because of my early vcds cable?
Eric
HC800000
No guarantee we can fix this on the HEX-USB+CAN, but a measuring block map of your gateway (address 19) and a debug 1024 of the attempted recode would be what we need to start looking at the issue. Unless of course your BCM is just supposed to have all-zero coding and plain does not understand what VCDS is trying to do by recoding it :)
https://forums.ross-tech.com/showthread.php?7549-New-car-some-modules-not-supported
https://forums.ross-tech.com/showthread.php?17827-BCM-Coding-all-Zeros
https://forums.ross-tech.com/showth...2018-Golf-R-with-Full-adaptive-led-headlights
cilitkas
LT
yes it should have zero coding, its 2017 facelift bcm. coding is moved to adaptations, and im unable to correct it...
cilitkas
LT
SORTED. early VCDS cable cant do it...
