Results 1 to 9 of 9
Thread: Error unknown (0x00) Help!
    Verified VCDS User cilitkas's Avatar
    May 2016
    LT
    Trying to change the adaptation channel coding on new style 2017 audi a3 bcm and always get this error unknown 0x00
    Engine is not running, and it even wont accept the same coding.
    Il attach pic shortly.
    Please help.
    https://www.flickr.com/photos/147780147@N04/
    Tuesday,02,April,2019,17:39:20:52461
    VCDS Version: 18.9.1.0 (x64)
    VIN: WUAZZZ8V1GA906540   License Plate: RS3
    Mileage: 1824km-1133mi   Repair Order:
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 3C 42 44 47 52 55 5F
              6C BB BC
    VIN: WUAZZZ8V1GA906540   Mileage: 1824km-1133miles
    2B-Steer. Col. Lock -- Status: Malfunction 0010
    BB-Door Rear Drv -- Status: Malfunction 0010
    BC-Door Rear Pass -- Status: Malfunction 0010
    Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
       Part No SW: 8V0 907 404     HW: 07K 907 309 C
       Component: 2.5l R5/4V TF H52 0005
       Revision: NKH52---
       Coding: 12250032252601033600
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ECM25TFS0118V0907404 001006
       ROD: EV_ECM25TFS0118V0907404.rod
       VCID: 76E46A5CC90BD0FAF7-8022
    9 Faults Found:
    17158 - Databus
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:57:39
                        Coolant temperature: 35 °C
                        Intake air temperature: 9 °C
                        Voltage terminal 30: 12.740 V
                        Drivetrain coordinator: brake fault status-Bits 0-7: 5
                        Acceleration: 0.000 m/s²
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [175] - -
                        Fault Frequency: 15
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:56
                        Coolant temperature: 7 °C
                        Intake air temperature: 8 °C
                        Voltage terminal 30: 11.340 V
                        ACC variants-Bits 0-7: 0
                        CCS Switch-Bits 0-7: 1
                        Cruise control switch actuation-Bits 0-7: 0
                        Cruise control switch actuation-Bits 0-7: 49
                        ACC variants (coding)-Bits 0-7: 1
    28212 - Exhaust Pressure Control Valve 2
              P049F 00 [047] - Malfunction
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
                        Engine status: COENG_READY
    19305 - Exhaust Pressure Control Valve
              P0475 00 [047] - Electrical Malfunction
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
              U0428 00 [047] - -
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [172] - -
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:31
                        Engine speed: 1508.50 /min
                        Normed load value: 14.9 %
                        Coolant temperature: 6 °C
                        Intake air temperature: 7 °C
                        Voltage terminal 30: 10.380 V
                        selected gear-Bits 0-7: 0
    4716 - No Communications with Parking Brake Control Module
              U0128 00 [044] - -
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
    4651 - Implausible Data Received from ESP Control Module
              U0416 00 [032] - -
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
    7786 - Sensor for Ambient Air Temperature (G17)
              P0070 00 [036] - Malfunction
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
                        Vehicle speed: 255 km/h
                        Coolant temperature: 36 °C
                        Intake air temperature: 29 °C
                        Voltage terminal 30: 11.520 V
    Readiness: 1110 0001
       Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
       Component: GSG DQ500     H10 5210
       Revision: 00H10V01
       ROD: EV_TCMDQ500021.rod
       VCID: 295E71204835CF02AA-807C
    10680 - Databus
              U1121 00 [044] - Missing Message
                        Fault Frequency: 14
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        Engine speed: 1466.00 /min
                        Clutch: primary stat: New
                        selected gear: GANG_R
                        Driving position: P
                        Engine torque: 4 Nm
                        Control Module temperature: 9 °C
                        Accelerator position: 15.2 %
                        DTC memory status: 68
    10685 - Databus
                        Fault Frequency: 17
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:54:54
                        Engine speed: 1441.00 /min
                        Clutch: primary stat: Neutral
                        Driving position: P
                        Engine torque: 0 Nm
                        Control Module temperature: 12 °C
                        DTC memory status: 73
       Part No SW: 8V0 907 379 A    HW: 8V0 907 379 A
       Component: ESC           H42 0030
       Revision: 00000000    Serial number: 60956000000021
       Coding: 999CF08DBA9915AF40960068C391920644990F5DA80200C3496022
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 061006
       ROD: EV_Brake1UDSContiMK100IPB_061.rod
       VCID: 428CC68CD5433C5A8B-8016
    8 Faults Found:
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
    0270 - Lateral Acceleration Sensor
              C1079 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
    0279 - Brake Pressure Sensor 1
              C107A 54 [137] - Missing Calibration / Basic Setting
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
    0295 - Steering angle sensor
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
    8277 - Databus
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
    8309 - Engine Control Module Incorrectly Coded
              P1612 00 [009] - -
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
    16390 - Display for Tire Pressure Monitoring
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 19:30:51
    33000 - Longitudinal Acceleration
              C10B1 29 [137] - Signal Implausible
                        Reset counter: 53
                        Date: 2019.04.02
                        Time: 19:30:42
       Revision: 00021000    Serial number: 0347604164
       Coding: 030C0C
       VCID: 3A7CBE6CBD93749AD3-806E
    1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
              U1093 00 [008] - Short to GND
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:23:27
    12713984 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:37:02
       Part No SW: 8V0 820 043 Q    HW: 8V0 820 043 Q
       Component: AC Automat    H03 0110
       Revision: 20001000    Serial number: 00000001021564
       Coding: 03100014000000011000000000001100
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008021
       VCID: 4088CC84DB4F2E4A9D-8014
       Serial number: C6B84057000000000001
    131074 - Supply voltage
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:20
                        Voltage terminal 30: 8.9 V
                        Outside air temperature: 8 °C
    131076 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:22
                        Voltage terminal 30: 8.4 V
    459012 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:31
    459020 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:37:02
    459527 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
       Part No SW: 5Q0 937 084 CF    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H34 0236
       Serial number: 02001627500223
       Shop #: WSC 06745 128 28888
       ROD: EV_BCMBOSCH_017.rod
       VCID: 7EF4727CE13B98BAAF-802A
       Component: WWS371 140912  042 0585
       Serial number:         140924215426
       Coding: 0A47F7
       Serial number: 23250614
       Coding: 02006C
       Serial number: 26 05 2016  00000710
       Serial number: 00000000000060677680
       Sun Roof:
       Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
       Component: J245 PS73.014  H02 0007
       Serial number:     WOO32929111
       Coding: 101F00
    264452 - No Communications with Anti-Theft Sensor
              U10F4 00 [009] - -
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 19:31:40
    534549 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 19:31:41
    568836 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 19:31:39
       Part No SW: 5Q0 919 294 J    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0051
       Revision: --------    Serial number: 39331426305299
       Coding: 0030150011
    7 Faults Found:
    13635840 - Supply voltage
                        Reset counter: 93
              U1400 00 [008] - -
                        Fault Frequency: 7
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:21
    12658704 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
    12656913 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
    12656920 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
    13637426 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
    13637888 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
       Serial number: 003GCR00T9BL
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 479AD798FE6119725C-8012
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34178311B07101440487
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34178312B07101470723
       Coding: 333135
       Occupant Detection:
       Serial number: 6940000Y1400017NV00Y
       Coding: 303230
       Subsystem 4 - Part No SW: -----------    HW: 480 002 909 14
       Serial number: 35700000000F7A34F01R
       Subsystem 5 - Part No SW: -----------    HW: 480 002 909 14
       Serial number: 358000000007AA34F01N
       Subsystem 6 - Part No SW: -----------    HW: 480 402 909 14
       Serial number: 3510002BB175A90091B0
       Subsystem 7 - Part No SW: -----------    HW: 480 401 909 14
       Serial number: 3520002A9176A6C17230
       Subsystem 8 - Part No SW: -----------    HW: 480 400 311 12
       Serial number: 3550002B30CC5BF032AD
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 400 808 14
       Serial number: 35600029916FC22340B4
    16 Faults Found:
    9483008 - Seat Occupied Recognition
              B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                        Fault Frequency: 9
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:49
    9482752 - Seat Occupied Recognition
              B10B2 00 [008] - Function Restriction due to Missing Message(s)
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:49
              B13BC F2 [008] - No function
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:15:40
    9634838 - Control Module for Front Left Belt Tensioner
              B1304 16 [008] - Voltage Too Low
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:31
    9635094 - Control Module for Front Right Belt Tensioner
              B1305 16 [008] - Voltage Too Low
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:29
    1055232 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:34
    1054981 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:50:00
    1052928 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:34
    1049088 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:34
    1049093 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:58
    1052416 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:34
    1052672 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:34
    1050117 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
    1049094 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:58
    1049095 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:58
       Part No SW: 8V0 953 521 CP    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 03101408490168
       Coding: A018
       VCID: 0A1C2EACADF3A41A83-805E
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 790     HW: 8V0 920 790
       Component: FBenRDW       H11 0041
       Coding: 00AD1840EB9000080104EE001000000000000000
       Shop #: WSC 01531 128 28888
       ASAM Dataset: EV_DashBoardFPKAU37X 001023
       ROD: EV_DashBoardFPKAU37X.rod
       VCID: 79FE6160F815BF829A-802C
    10 Faults Found:
    10485835 - Internal Control Module Memory Check Sum Error
              B2000 41 [009] - General checksum failure
                        Mileage: 24 km
                        Date: 2016.03.17
                        Time: 00:00:01
              U1014 00 [009] - -
                        Fault Frequency: 6
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
    9582600 - Switch for Instrument Cluster
              B1893 13 [009] - Open Circuit
                        Fault Frequency: 18
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:44:50
    16776968 - Databus
                        Fault Frequency: 25
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:31
    16776969 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
    16776973 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:58
    16776980 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
    16777103 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:23:40
    13639936 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
       Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2265
       Revision: --------    Serial number: 11091610802548
       Coding: 01010008200860005B00022C180B00000001010000000000000000000000
       Shop #: WSC 33361 790 00114
       ROD: EV_GatewConti_013_VW37.rod
       VCID: 7CF07874F7278AAA81-8028
       Subsystem 2 - Part No SW: 4S0 951 523 E    HW: 4S0 951 523 E
       Component: J453 MFL  H06 0002
       Serial number: 20151222074848 RD132
    131598 - Body Control Module (Central Electric)
              U0140 00 [008] - No Communications
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:23:41
                        Terminal 15: OFF
    131603 - No Communication with ABS Brake Control Module
              U0121 00 [008] - -
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:19:09
                        Supply voltage: Terminal 30: 10.1 V
                        Terminal 15: OFF
    1282 - Supply voltage
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:58:53
                        Supply voltage: Terminal 30: 8.4 V
                        Terminal 15: On
    67072 - Local Databus
              U1125 00 [009] - Additional Installations Detected
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:08:01
                        Supply voltage: Terminal 30: 9.7 V
                        Terminal 15: OFF
              U1101 00 [009] - Active
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:11
                        Supply voltage: Terminal 30: 10.9 V
                        Terminal 15: On
       Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7754
       Serial number: HA1-00017.02.16
       Coding: 0601
       Shop #: WSC 06314 790 00021
       VCID: 4586DD90C46D0B62AE-8010
    10 Faults Found:
    16655 - Databus
                        Fault Frequency: 15
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17468 - Databus
                        Fault Frequency: 15
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17495 - Databus
                        Fault Frequency: 11
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17501 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:52:25
    17471 - Databus
                        Fault Frequency: 11
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:35
    17502 - Databus
                        Fault Frequency: 15
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17469 - Databus
                        Fault Frequency: 15
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17470 - Databus
                        Fault Frequency: 15
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17504 - Databus
                        Fault Frequency: 11
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:30
    17505 - Databus
                        Fault Frequency: 8
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:31:26
       Revision: 00000000    Serial number: 14000270884002
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 346090549FF782EA09-8060
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:57:45
                        ELV State: 04
                        Information Clamps: 77 60
                        CoCo State: E0 01
                        WFS State: 17 06
                        Vehicle speed: 655.34 km/h
                        Voltage: 47
                        AD-Value H-bridge: 23
                        Clamp15 flip flop: SSTx: button contacts: 06
                        CAN signals: 05
              U1400 00 [008] - -
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:20
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 17 06
                        Voltage: 4C
                        AD-Value H-bridge: 25
                        CAN signals: 05
    12665088 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:23:38
                        ELV State: 04
                        Information Clamps: 00 00
                        CoCo State: E0 01
                        WFS State: 00 06
                        Voltage: 67
                        AD-Value H-bridge: 33
                        CAN signals: 05
    12665089 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:23:38
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 00 06
                        Voltage: 66
                        CAN signals: 05
    12666370 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:33
                        ELV State: 04
                        CoCo State: E0 01
                        WFS State: 1F 06
                        Voltage: 72
                        AD-Value H-bridge: 37
                        CAN signals: 05
       Part No SW: 5Q0 907 566 A    HW: 8T0 907 566 B
       Serial number: 0346835485
       Coding: 030211
       VCID: 3878A464839F668A25-806C
       Subsystem 1 - Part No SW: 5Q0 907 568 A    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0346892700
       Coding: 030211
    336901 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:31
       Serial number: 19091406070881
       Coding: 005D1F205C00048000000002
    65548 - Supply voltage
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:46:47
    65571 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:37:02
    65573 - Local Data Bus
              U10BA 00 [008] - No Communication
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:37:02
    458776 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
       Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
       Component: EPS_MQB_ZFLS  503 5043
       Coding: 0002
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 3566AD50948D9BE23E-8060
    8 Faults Found:
    15873 - Steering angle sensor
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:53
                        Motor status: 00
                        Supply voltage: 11.25 V
                        Temperature: 15.0 °C
                        KFC: 3E
                        KFA: 00 01
                        Environmental conditions: 5B
                        uioUdNotFilt_xdu16: 11.30 V
                        uAdSensI_SwitchedKl30_xdu16: 11.29 V
    19200 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:54:54
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 11.00 V
                        Temperature: 17.0 °C
                        KFC: 4B
                        KFA: 00 00
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 11.27 V
                        uAdSensI_SwitchedKl30_xdu16: 11.27 V
    19712 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        Motor status: 01
                        Supply voltage: 10.50 V
                        Temperature: 8.0 °C
                        KFC: 4D
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 10.73 V
                        uAdSensI_SwitchedKl30_xdu16: 10.74 V
    20224 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        Motor status: 01
                        Temperature: 8.0 °C
                        KFC: 4F
                        KFA: 00 00
    20992 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        Motor status: 01
                        Temperature: 8.0 °C
                        KFC: 52
                        KFA: 00 00
    19456 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        Motor status: 01
                        Temperature: 8.0 °C
                        KFC: 4C
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 10.45 V
                        uAdSensI_SwitchedKl30_xdu16: 10.44 V
    20736 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        Motor status: 01
                        Temperature: 8.0 °C
                        KFC: 51
                        KFA: 00 00
    20480 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:36
                        Motor status: 02
                        Supply voltage: 14.00 V
                        Temperature: 8.0 °C
                        KFC: 50
                        KFA: 00 00
                        uioUdNotFilt_xdu16: 14.09 V
                        uAdSensI_SwitchedKl30_xdu16: 14.08 V
       Part No SW: 8V0 035 465 C    HW: 8V0 035 465
       Component: MIBAMP1ALPINE H11 0410
       Serial number: AUZ8ZAEN900QK6B
       Coding: 01030300AAAA2AAA01
    6693 - Databus
                        Fault Frequency: 14
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:36
                        Voltage terminal 30: 13.2 V
    1539 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:38:13
                        Voltage terminal 30: 8.0 V
       Serial number: 21091401100625
       Coding: 005D17205E00048000000002
       VCID: 3F8ACF78A6B151B2E4-806A
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:46:49
    65604 - Door Warning Lamp
              B1326 01 [009] - Electrical Failure
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 16:46:03
    458776 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
       Component: AFS-ECU       H01 0091
       Coding: 012E000123200400
    9 Faults Found:
    13705472 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:08
              U1014 00 [137] - -
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:54:58
    5276145 - Power Output Module for Left Headlamp
              C1081 F1 [137] - Incorrectly Coded
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:54:58
    5276401 - Power Output Module for Right Headlamp
              C1082 F1 [137] - Incorrectly Coded
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:54:58
    5545009 - LED Headlamp Power Output Stage; Left
              B149C 31 [137] - No Signal
                        Fault Frequency: 6
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:09
    5544753 - LED Headlamp Power Output Stage; Right
              B149B 31 [137] - No Signal
                        Fault Frequency: 6
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:09
    5275953 - Power Output Module for Left Headlamp
              C1081 31 [137] - No Signal
                        Fault Frequency: 6
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:08
    5276209 - Power Output Module for Right Headlamp
              C1082 31 [137] - No Signal
                        Fault Frequency: 6
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:08
    13705992 - Databus
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 18:25:08
    Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
       Part No SW: 8V1 035 035     HW: 8V1 035 035
       Component: MU-P-LND-EU   052 1168
       Serial number: A698G0G7505904
       Coding: 017351010000000011111102000A00332F0028E701700100DE
       VCID: 6FEA5F38B651E13234-803A
       Subsystem 1 - Part No SW: V03 959 801 FD    HW: -----------
       Component: ECE 2017/2018  --- 0161
       Component: DU High  H49 0013
       Serial number: AUZ8Z9EY201S6F
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BJ    HW: 8V0 919 614 BJ
       Component: ControlUnit_H  H85 0855
       Serial number: ALJAL131051600010388
       Component: Gracenote2  --- 1013
    11 Faults Found:
    1537 - Supply voltage
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:46:42
                        Voltage terminal 30: 8.7 V
              U1400 00 [008] - -
                        Fault Frequency: 13
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:43:24
              B201A 00 [009] -  -
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:50:01
                        Voltage terminal 30: 11.4 V
                        Status_Software_Version_Management-module_name: MFC2H37xE/HREU
    1556 - Internal Control Module Memory Check Sum Error
              B2000 87 [009] - Missing message
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:50:13
                        Software module: status-SW_Status_Consistency: 00 00 12
                        Software module: status-SW_Status_Device:
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:56
                        Voltage terminal 30: 11.5 V
    1637 - Interface for External Media
              U11B8 00 [009] - No Communications
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:56
                        Interface for external media: status-Status: Open circuit
    0012 - Digital Radio Antenna
              B1103 11 [009] - Short to Ground
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:56
                        Status of digital radio antenna 1-Antenna current: 0 mA
                        Status of digital radio antenna 1-Connection between radio and antenna amplifier: Short circuit
                        Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Not available
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 16.777215
                        Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 16.777215
    3077 - Telephone baseplate
              B1051 13 [009] - Open Circuit
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:55
    6702 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:40
                        Voltage terminal 30: 14.2 V
                        Network diagnosis-Status: Enabled
              U1111 00 [008] - -
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:58
                        BAP-BAP_Function_ID: 02
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:58
       Coding: 027300010201000300
       ROD: EV_2CamSysRearPASE_AU37.rod
       VCID: 30689C446BEFBECA6D-8064
    7 Faults Found:
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:54:09
                        CAN communication
    13705476 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        CAN communication
    13705491 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        CAN communication
    13705492 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:33
                        CAN communication
    13705493 - Databus
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        CAN communication
    9529428 - Steering angle sensor
                        Reset counter: 53
                        Mileage: 1824 km
                        Date: 2019.04.01
                        Time: 19:49:54
                        passive
    327936 - Vehicle Speed Sensor
              P0501 00 [008] - Implausible Signal
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 15:41:32
                        CAN communication
       Part No SW: 5Q0 959 395 B    HW: 5Q0 959 395 B
       Component: TSG HFS       020 0025
       Serial number: 01101402090316
       Coding: 004D17204000048000000002
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:46:50
       Component: TSG HBFS      020 0025
       Serial number: 01101401100323
                        Reset counter: 93
                        Mileage: 1824 km
                        Date: 2019.04.02
                        Time: 17:46:50
    End-------------------------(Elapsed Time: 05:21)--------------------------
    Try opening the car's hood.
    And please post an Auto-Scan from the car in question.
    May 2016
    LT
    Hood is open. Security access accepted...
    Il do the autoscan, but not sure how it will help?
    Quote Originally Posted by cilitkas View Post
    Context.
    May 2016
    LT
    here you go sir.
  6. #6
    May 2016
    LT
    Tried this with different bcm, still the same.
    Cant this be because of my early vcds cable?
  7. #7
    No guarantee we can fix this on the HEX-USB+CAN, but a measuring block map of your gateway (address 19) and a debug 1024 of the attempted recode would be what we need to start looking at the issue. Unless of course your BCM is just supposed to have all-zero coding and plain does not understand what VCDS is trying to do by recoding it
    https://forums.ross-tech.com/showthr...-not-supported
    https://forums.ross-tech.com/showthr...ding-all-Zeros
    https://forums.ross-tech.com/showthr...led-headlights
  8. Likes Uwe liked this post
  9. #8
    May 2016
    LT
    yes it should have zero coding, its 2017 facelift bcm. coding is moved to adaptations, and im unable to correct it...
  10. #9
    May 2016
    LT
    SORTED. early VCDS cable cant do it...
  11. Likes Uwe, Dana liked this post
