HOW to exchange rear doors modules control on a 2015 passat B8
sam1754
France
C?ID=324989
Hello, I'll change the two rear doors control modules 5Q0 959 395 by new 5Q0 959 595 which controls new features like ambient light.
My question is how to proceed?
Is it possible to not disconnect the battery, just switch off ignition, keyless far away?
Are any adaptations needed after mounting new modules?
Many thanks to anyone who answer!
:D
Moved from Tweaks to Retrofits.
sam1754
France
C?ID=324989
Really? No one know how to proceed???:confused:
siLc
Tallinn, Estonia
C?ID=330192
Don’t overthink as rear door modules shouldnt be such sensitive modules that you should disconnect the battery. Simply erase the faults in other modules after doing the swap. Cant say anything about the coding/adp though.
sam1754
France
C?ID=324989
Thanks, it's a good beginning!
CuturiloD
Serbia
C?ID=361908
About coding, just copy old code in new control unit.
sam1754
France
C?ID=324989
Ok, Thanks a lot, I'll do it. I copied all logs before changing anything.:thanks:
sam1754
France
C?ID=324989
I just worry about window adjustment... or it's controlled by window motor?
myounus
Northwest UK
C?ID=321059
Hi Sam
This is a straightforward change, however make sure you copy the coding and any adaptations from the old modules. I'm not clear on what you question is about window adjustment, if it's about opening and closing then I wouldn't worry.
sam1754
France
C?ID=324989
if it's about opening and closing YES
So it's OK!
sam1754
France
C?ID=324989
Well, job done!
I just had to put the right code but nothing really important.
After that, I had to run up and down the window to set basic setting.
Thanks for all!
