Results 1 to 10 of 11
Thread: HOW to exchange rear doors modules control on a 2015 passat B8
    Verified VCDS User sam1754's Avatar
    Mar 2019
    France
    Hello, I'll change the two rear doors control modules 5Q0 959 395 by new 5Q0 959 595 which controls new features like ambient light.
    My question is how to proceed?
    Is it possible to not disconnect the battery, just switch off ignition, keyless far away?
    Are any adaptations needed after mounting new modules?
    Many thanks to anyone who answer!
    Moved from Tweaks to Retrofits.
    Mar 2019
    France
    Really? No one know how to proceed???
    Jul 2014
    Tallinn, Estonia
    Don’t overthink as rear door modules shouldnt be such sensitive modules that you should disconnect the battery. Simply erase the faults in other modules after doing the swap. Cant say anything about the coding/adp though.
    Mar 2019
    France
    Thanks, it's a good beginning!
    Mar 2019
    Serbia
    About coding, just copy old code in new control unit.
  7. #7
    Mar 2019
    France
    Ok, Thanks a lot, I'll do it. I copied all logs before changing anything.
  8. #8
    Mar 2019
    France
    I just worry about window adjustment... or it's controlled by window motor?
  9. #9
    Oct 2017
    Northwest UK
    Hi Sam
    This is a straightforward change, however make sure you copy the coding and any adaptations from the old modules. I'm not clear on what you question is about window adjustment, if it's about opening and closing then I wouldn't worry.
  10. #10
    Mar 2019
    France
    if it's about opening and closing YES
    So it's OK!
