Results 11 to 20 of 30
Thread: 2013 CC 3.6 4motion P310B error
    If your car isn't modified it's under warranty!
    15/150?
  2. #12
    Nov 2018
    okay Jack, per your request...Mode's 5 and 6 were grayed out, so i couldn't gather any of that information. can you please explain why going through OBDII is giving me this separate code that is not given through an Autoscan or through the Engine Module? i have never used this function before, so i have trouble understanding it
    Monday,01,April,2019,16:18:51:37698
    VCDS Version: 18.9.1.0 (x64)
    VIN:    License Plate: MODE1
    VCDS Release 18.9.1 (x64):  Generic OBD2
    Mode 1:Read Data
    03:Fuel system 1/2 status     Closed loop,  using O2 sensors  Closed loop,  using O2 sensors
    23:Fuel Rail Press (rel)     4410 kPa rel
    Mode 03: Emission related fault codes
    Address 7E8: 1 Fault Found:
    P0089 - Valve for Fuel Metering (N290): Implausible Signal
    Address 7E9: No fault code found.
    Monday,01,April,2019,16:20:23:37698
    VIN:    License Plate: MODE3
    Monday,01,April,2019,16:20:49:37698
    VIN:    License Plate: MODE7
    Mode 07: Pending emission related fault codes
    Monday,01,April,2019,16:28:35:37698
    VIN: WVWGU7AN0DE509584   License Plate: MODE9
    Type 02 - VIN : WVWGU7AN0DE509584 (Address E8)
    Type 04 - Calibration ID : 03H906023R Q1811 (Address E8)
    Type 04 - Calibration ID : 09G927750MH 1961 (Address E9)
    Type 06 - Calibration Verification Number : F2D1C0C2 (Address E8)
    Type 06 - Calibration Verification Number : A994B632 (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 2714
        Ignition cycle count : 6247
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 4235 / 2714
             Catalyst monitor bank 2 : 4223 / 2712
             O2 Sensor monitor bank 1 : 4326 / 2714
             O2 Sensor monitor bank 2 : 4307 / 2712
             EGR-VVT monitor : 3872 / 2714
             AIR monitor : 0 / 0
             EVAP monitor : 489 / 627
             Secondary O2 Sensor monitor bank 1 : 4280 / 2714
             Secondary O2 Sensor monitor bank 2 : 4265 / 2712
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
    Monday,01,April,2019,16:33:57:37698
    VIN: WVWGU7AN0DE509584   License Plate: 04012019
    Mileage: 145620km-90484mi   Repair Order:
    Chassis Type: AN-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F
              52 53 55 56 61 62 6C 72 77
    VIN: WVWGU7AN0DE509584   Mileage: 145620km-90484miles
    Address 01: Engine (0-32-CNNA)       Labels: None
       Part No SW: 03H 906 023 R    HW: 03H 907 309 A
       Component: 3,6 FSI ULEV2 H04 1811
       Revision: MFH04---    Serial number: 00000000000000
       Coding: 001A0012242600000000
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_ECM36FSI01103H906023R 002003
       ROD: EV_ECM36FSI01103H906023AJ.rod
       VCID: 3162A48260BA18C262-8064
    Readiness: 1110 0101
       Part No SW: 09G 927 750 MH    HW: 09G 927 750 MH
       Component: AQ 250 6F           1961
       Revision: 00H90000    Serial number:
       Coding: 0000840
       Shop #: WSC 05311 000 00000
       VCID: 030E3E4A42865A52C0-8056
       Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
       Component: J104   C2 450M V43A 0023
       Revision: --H07---    Serial number: 00000005675232
       Coding: 0000411
       VCID: 71E26482683A58C222-8024
       Part No SW: 3AA 907 044 J    HW: 3AA 907 044 J
       Component: Climatronic   H03 0101
       Revision: 00001K03
       Coding: 0010001008
       VCID: 37769A9A8EDEC6F22C-8062
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 J    HW: 3AA 937 087 J
       Component: BCM PQ47 H++  421 0465
       Revision: BD421001
       Coding: 000800000000000000880281B400090C2055000861200D20E484462400C1
       Shop #: WSC 05311 123 12345
       VCID: 4182F442D81A884292-8014
       Subsystem 1 - Part No SW: 3C8 955 119 F    HW: 3C8 955 119 F  Labels: 1KX-955-119.CLB
       Component: WWS464 300312  010 0604
       Serial number: 300312
       Coding: 00B795
       Subsystem 2 - Part No SW: 7N0 955 559     HW: 7N0 955 559   Labels: 7N0-955-559.CLB
       Component: RLFS  021 0024
       Serial number: Y12M04D24h03m41s54S4
       Coding: 0280DD
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475 B    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0016
       Revision: --------    Serial number: 28261211903922
       Coding: 308104
       ASAM Dataset: EV_EPHVA18VW47X0000 001005
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 3E788FBEA1E4F7BAEF-806A
       Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
       Component: J234__714 VW10 HI   2118
       Revision: 24017000    Serial number: 003LDP8JK6WI
       Coding: 0012596
       VCID: 4E98DF7ED944673A1F-801A
       Subsystem 1 - Part No: 3C8 959 339 A
       Component: BF-Gewichtsens. 003 0001
       Subsystem 2 - Serial number: 000000000085BS
       Subsystem 3 - Serial number: 0020.03.12000030000063006563
       Subsystem 4 - Serial number: 6300656332MTS611130962 63
       Subsystem 5 - Serial number: 30962 6342MTS682710952 63
       Subsystem 6 - Serial number: 10952 6351HTS674E72BKR 63
       Subsystem 7 - Serial number: 72BKR 6361HTS6BE2U1BKJ 63
       Subsystem 8 - Serial number: U1BKJ 63727TS6AAIE1BKJ 63
       Subsystem 9 - Serial number: E1BKJ 63827TS66M5F1BKJ
       Subsystem 10 - Serial number: F1BKJ
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20120426100291
       Coding: 099A270000
       VCID: 6BDE76EA8216B21218-803E
       Component: E221__MFL-TK6  H07 0022
       Coding: E30000
       Part No SW: 3C8 920 980 T    HW: 3C8 920 980 T
       Component: KOMBI         H04 0407
       Coding: 240F00
       Shop #: WSC 05314 115 12345
       Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
       Component: J533  Gateway H41 1623
       Revision:   H41       Serial number: 210412F2003480
       Coding: 469006
       Shop #: WSC 05314 123 12345
       VCID: 3E788FBEA9E4F7BAEF-806A
                        Fault Status: 01110100
                        Reset counter: 0
                        Mileage: 144002 km
                        Date: 2013.07.08
                        Time: 09:40:03
       Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
       Component: Haldex 4Motion      4016
       Coding: 0000005
       VCID: 4688E75E3134AF7AA7-8012
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0400
       VCID: 37769A9A46DEC6F22C-8062
       Revision: A1001003    Serial number: 7662401608
       Shop #: WSC 05314 000 00000
       VCID: 29524CE2406A6002AA-807C
       Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
       Component: Sitzmemory    H02 1001
       Revision: 00H02000
       Coding: 000039
       Shop #: WSC 40022 666 40022
       VCID: 346CAD9697A82DEA09-8060
       Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
       Component: RNS-MID       H65 3696
       Revision: AB001001    Serial number: VWZ6Z7M9115083
       Coding: 04050002010000A6000F
       VCID: 2D5AB8F274827C2246-8078
                000 -  -
                        Fault Frequency: 109
                        Reset counter: 57
                        Mileage: 144008 km
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0551
       Revision: 12110009    Serial number: 0004824854
       Coding: 0015BF
       Shop #: WSC 05311 115 00000
       VCID: 6DDA78F2BC02BC2206-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002842171
       Coding: 010498
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.304 1002
       Revision: 1AH03734    Serial number: 00121050006901
       Coding: 0000258
       VCID: 3C7C85B67FF8E5AAC1-8068
       Component:    KSG PQ47 ELV 042 0634
       Coding: 1B910F8001860E763606141FF08A8F0E107801
    Address 47: Sound System        Labels: 3C0-035-456.clb
       Part No SW: 3C8 035 456 C    HW: 3C8 035 456 C
       Component: DSP 10 Kanal        0070
       Revision: 00H07001    Serial number: 75805005271911
       VCID: 285449E69B60590AB5-807C
    00876 - Treble Speaker Rear Left (R14)
                        Fault Status: 00101011
                        Reset counter: 96
                        Mileage: 145554 km
                        Date: 2013.08.14
                        Time: 18:37:19
       Component: EZE_2         H41 1623
       Coding: 01030108
       VCID: 6FE662FABE0E4E3234-803A
       Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
       Component: J245/J878  H04 0054
       Serial number: 215500015795
       Coding: 000006
       Subsystem 2 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0551
       Revision: 14110009    Serial number: 0004809238
       Coding: 0015BE
       ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
       VCID: 6ED87FFEB104473A3F-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000002862941
       Coding: 010498
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000158915
       Coding: 0022156
       VCID: 3668979E41D43FFA37-8062
       Coding: 071A00010B000400
       Shop #: WSC 05311 115 12345
       Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0007
       Coding: 350000
       Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0007
       Coding: 350000
                000 -  -
                        Reset counter: 57
                        Mileage: 144008 km
       Component: Batt.regelung H41 1623
       Coding: 03260172
       VCID: 71E26482A83A58C222-8024
       Subsystem 1 - Part No SW: 3AA 915 181 A    HW: 3AA 915 181 A
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970298947
       Part No SW: 3C8 907 441     HW: 3C8 907 441
       Revision: 00H11000    Serial number: 525PA8-J231719
       Coding: 0120008
       VCID: 67D60ADA56FE96727C-8032
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007662437720
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 27564ADA5E7E5672BC-8072
    End-------------------------(Elapsed Time: 04:04)--------------------------
    14.2 liter's, 84 valve's, 24 cylinder's, 1 turbo
  4. #13
    Strange huh, most likely the stack in the ECU is inconsistent but to get clarity from RT just in case a label file is an issue?
    • On some engines, the N276 may be refered to as the N290 in the factory wiring diagram.
    Well I'm led to believe that the HPP or cam follower are for shit and most likely under useful life warranty even if a bad pump in tank or regulator with filter & as an AECD aren't you?
    Does your maintenance manual require a filter with regulator to be changed as maintenance?
  5. #14
    Nov 2018
    thats the way it would seem. the HPFP on the 3.6 isn't nearly as easy to take apart to inspect as the 2.0T was in my MKV. and luckily the follower in these are a roller instead of a flat surface like the older versions. my new sensor should be here tomorrow and we'll see what that does. going out of town for the weekend and when i get back, might fool with the HPFP if time and weather permits.
  6. Likes Uwe liked this post
  7. #15
    Nov 2018
    sensor came in and i installed it last night. put about 15 miles on the car, and so far so good. lets hope this solved it
  8. Likes Uwe, Jack@European_Parts, Dana liked this post
  9. #16
    Are you going to get reimbursed for such a AECD failure part and repair & needed under useful life warranty, is the real question?
  10. #17
    Nov 2018
    well, took a road trip to my brothers house over the weekend, (2 hours each way), and the CEL came back on with the same code. i found a thread from about a year ago on VWVortex about someone having the same issue, and he took it to the dealer and they replaced the intank pump, which cost him close to $800 for parts and labor.
    how would YOU go about getting the dealer to either do the work under the useful life warranty, or submitting to be reimbursed for it?
  11. #18
    Wouldn't you see a professional that is licensed, which can verify diagnosis for the problem & that is indeed covered an or related to the warranty or TSB for reimbursement & further contact the OEM advocate email center to start a claim + dealer for such clarity of diagnosis again all in writing to start the attempt?
  12. #19
    Nov 2018
    rather than going to a third party "licensed professional", why should i not go straight to the dealer and have it squared away that way? i'm not fully understanding what you are trying to say.
    to ask the same question in further detail. the guy in that thread had them fix the issue and was charged for such. according to you, this should be covered under the EPA/CARB warranty. how would i go about going straight to the dealer, without third party involvement, and have them diagnose and fix the issue, be in intank pump, HPFP, etc., and have it covered under said warranty? what literature would i need to stand on to ensure that they cover the cost of this repair?
  13. #20
    Nov 2018
    so last night i got curious and pulled my HPFP to examine the follower and found this. appears to be some inconsistent wear on the roller. would this be enough to throw the code it is throwing?https://drive.google.com/open?id=1FU...N3x-C8oxgXtmS0
