Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 2013 CC 3.6 4motion P310B error
  1. #21
    rather than going to a third party "licensed professional", why should i not go straight to the dealer and have it squared away that way? i'm not fully understanding what you are trying to say.
    to ask the same question in further detail. the guy in that thread had them fix the issue and was charged for such. according to you, this should be covered under the EPA/CARB warranty. how would i go about going straight to the dealer, without third party involvement, and have them diagnose and fix the issue, be in intank pump, HPFP, etc., and have it covered under said warranty? what literature would i need to stand on to ensure that they cover the cost of this repair?
    Let me ask some more questions okay?
    Are you really going to trust a franchise dealer & to do the right thing here, consider consulting a lawyer yet?
    Hmm, let's see if you could be so kind & maybe post a picture of the data plate of this vehicle and the emissions group family, I suspect it might be something like this number in parentheses below?
    Example: ( Test Group: DVWXV03.6U46 ) ?
    so last night i got curious and pulled my HPFP to examine the follower and found this. appears to be some inconsistent wear on the roller. would this be enough to throw the code it is throwing?
    Interesting huh, is that making useful life warranty, now is it?
    HPP components and in tank FP components are indeed most likely listed as a comprehensive useful life warranty related item, are they not?
  2. #22
    Nov 2018
    thank you...as i asked before, is there any literature you can post that spells out what is and is not a part of this useful life warranty?
    14.2 liter's, 84 valve's, 24 cylinder's, 1 turbo
  3. #23
    Not to be a dick but did you ever think if you would answer my questions & so I can try to accurately point to information for you to answer your aforementioned alleged own questions, it would be helpful in the process, versus you just asking vague questions expecting me to just know?
    Indeed there are reasons I asked each question, wouldn't you think?
  4. #24
    Hey OP are you going to post a picture of the VIN number plate with SMOG test group of this POS?
    I didn't forget you!
    If you would be so kind as to let me help you find that compelling useful life SMOG warranty information?
  5. #25
    Nov 2018
    i actually haven't driven the car in like a week, so i didn't even think about it
    https://drive.google.com/open?id=144...rUZxJwFEsBlzEr
  6. #26
    United States
    Quote Originally Posted by zoidmk5 View Post
    so last night i got curious and pulled my HPFP to examine the follower and found this. appears to be some inconsistent wear on the roller. would this be enough to throw the code it is throwing?https://drive.google.com/open?id=1FU...N3x-C8oxgXtmS0
    I would not be extremely concerned about that wear as long as the camshaft is OK. The in-tank (low side) pump would be more likely in my option.
    Just make sure to replace the filter at the same time if you haven't already done so recently. If that's in-tank you'll get a new one with the replacement pump but I don't recall if this car has an external filter underneath that needs to be serviced separately.
  7. Likes Uwe, Jack@European_Parts liked this post
  8. #27
    United States
    P.S. This may not be extremely helpful (because your issue required a long drive to duplicate) but this is a 01-Engine map at idle from my husband's 2017 T'reg 3.6L UDS controller after we purchased it used certified @ Mileage: 13743km-8539miles on Sunday,25,March,2018:
    ;SW:03H-906-023-DD   HW:03H-907-309-E ---  Engine
    ;Component:VR6 3.6l FSI  H17 3178	 Coding:002A0012437600000000
    ;EV_ECM36FSI01103H906023DD	2001	EV_ECM36FSI01103H906023DD_002.rod
    ;Sunday	25	March	2018	11:24:46:04045
    ;VCDS Version: Release 18.2.0 (x64)  Data version: 20180316 DS287.1
    ;VCID: 6788B1F50FED28EFD32-8032
    Group	Description	Actual
    IDE00011	Vehicle Identification Number (VIN)	WVGRF7BP0HD004431
    IDE00019	Voltage terminal 30	14.559	 V
    IDE00020-ENG57549	Terminal 15 status-Bits 0-7	1
    IDE00021	Engine speed	696	 /min
    IDE00025	Coolant temperature	38	 C
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00076	Status of initial fuel filling	was not yet started
    IDE00078	Time since engine start	134	 s
    IDE00083	Throttle valve position (absolute)	12.5	 %
    IDE00084	Absolute load value	22	 %
    IDE00085	Normed load value	29	 %
    IDE00086	Accelerator position	15	 %
    IDE00090-ENG57549	selected gear-Bits 0-7	0
    IDE00094	Kick-down status	Not operated
    IDE00094-ENG127320	Kick-down status-Test_Program_Channel 284	167
    IDE00097	OBD - requirements for which this vehicle is designed	OBD + OBD II
    IDE00100	Engine torque	73.3	 Nm
    IDE00148	Median injection timing	1.289	 ms
    IDE00150	Pressure in brake booster	991.99	 hPa
    IDE00151	Oil fill level	48.988	 mm
    IDE00152	Oil warning threshold	28	 mm
    IDE00155	Timing angle retardation cylinder 1	0
    IDE00156	Timing angle retardation cylinder 2	0
    IDE00157	Timing angle retardation cylinder 3	0
    IDE00158	Timing angle retardation cylinder 4	0
    IDE00159	Timing angle retardation cylinder 5	0
    IDE00160	Timing angle retardation cylinder 6	0
    IDE00167	Exhaust temperature 1 bank 1	472.5	 C
    IDE00168	Exhaust temperature 1 bank 2	472.7	 C
    IDE00172	A/C compressor torque	20	 Nm
    IDE00173	Cruise Control System: specified speed	0
    IDE00174	Camshaft adjustment: exhaust: bank 1: specified value	-15
    IDE00175	Camshaft adjustment: exhaust: bank 1: actual value	-14.961
    IDE00178	Camshaft adjustment intake bank 1: specified value	18
    IDE00179	Camshaft adjustment intake bank 1: actual value	17.484
    IDE00182	Camshaft adaptation intake bank 1: phase position	0
    IDE00184	Camshaft adaptation exhaust bank 1: phase position	0
    IDE00186	Fuel low pressure: actual value	498.8	 kPa
    IDE00187	Coolant temperature at engine start	7.5	 C
    IDE00188	Fuel high pressure: actual value	5.0805	 MPa
    IDE00194	Coolant temperature at radiator output: specified value	104.2	 C
    IDE00196	Engine oil temperature	0.9	 C
    IDE00201	High fuel pressure: specified value	5.0855	 MPa
    IDE00202	Low fuel pressure: specified value	500	 kPa
    IDE00304	Fuel level	53	 l
    IDE00322	Status of basic setting	was not yet started
    IDE00323	Security Access: Number of invalid keys	0
    IDE00347	Air mass: actual value:	5.47	 g/s
    IDE00348	Intake air temperature	8	 C
    IDE00349	Throttle valve position: normed	3	 %
    IDE00350	Air mass: specified value	20	 kg/h
    IDE00354	Engine start: start synchronization	EPM_MODE_OK
    IDE00354-ENG127291	Engine start: start synchronization-Test_Program_Epm st Op Mode State t UBYTE	48
    IDE00355-ENG57549	Cruise Control System (CCS): status-Bits 0-7	20
    IDE00356-ENG57549	Cruise Control System (CCS): switch position-Bits 0-7	0
    IDE00357	Fuel temperature	16.5	 C
    IDE00358	Limitation: torque	469.9	 Nm
    IDE00360	Limitation: accelerator pedal	0	 Nm
    IDE00361	Ambient air pressure	991.99	 hPa
    IDE00371	Fuel consumption	1.65	 l/h
    IDE00375	Generator: load signal	99.99	 %
    IDE00380	Coolant fan 1: activation	10	 %
    IDE00392	Accelerator pedal: sensor voltage 1	732.4	 mV
    IDE00393	Accelerator pedal: sensor voltage 2	373.4	 mV
    IDE00405	Crankshaft speed (RPM)	700.5	 /min
    IDE00407-ENG57549	Rail pressure regulation: status-Bits 0-7	1
    IDE00412-ENG57549	Starter control: terminal 50-Bits 0-7	0
    IDE00413-ENG57549	Starter control: Interlock- or P/N-signal-Bits 0-7	0
    IDE00414-ENG57549	Starter control: relay 1-Bits 0-7	0
    IDE00416-ENG57549	Starter control: terminal 50 acknowledgment-Bits 0-7	4
    IDE00443-ENG57549	Accelerator pedal: switch positions-Bits 0-7	8
    IDE00445	Unlearning counter according OBD	255
    IDE00450	Operating Instructions	--no display--
    IDE00451	Currently running routine	0
    IDE00474	Ambient air pressure	99	 kPa abs
    IDE00477	Torque request: sum of auxiliary aggregate	15.2	 Nm
    IDE00496-ENG57549	Activation of oil pressure switch valve-Bits 0-7	0
    IDE00497-ENG57549	Status of oil pressure switches-Bits 0-7	1
    IDE00541	Acceleration	0	 m/s
    IDE00556	Outside air temperature	0	 C
    IDE00559	Current of oxygen sensor bank 1 sensor 1 (broadband sensor)	1.001 Lambda / -0.012 mA
    IDE00560-MAS04121	Oxygen sensor bank 1 sensor 2 (jump sensor)-Voltage	0.445	 V
    IDE00560-MAS04122	Oxygen sensor bank 1 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
    IDE00565	Current of oxygen sensor bank 2 sensor 1 (broadband sensor)	0.999 Lambda / -0.016 mA
    IDE00566-MAS04121	Oxygen sensor bank 2 sensor 2 (jump sensor)-Voltage	0.445	 V
    IDE00566-MAS04122	Oxygen sensor bank 2 sensor 2 (jump sensor)-Short term adaptation of mixture formation	99.2	 %
    IDE00582	Equivalence ratio target value	1	 Lambda
    IDE00583	Throttle valve specified value	3	 %
    IDE00584	Distance driven since erasing DTC memory	253	 km
    IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
    IDE00588	Fuel tank fill level	52.9	 %
    IDE00592	Oxygen sensor control status	Closed loop	  / using O2 sensors
    IDE00593	Ignition timing adjustment cylinder 1	10.5	 Degrees
    IDE00595	Allocation of oxygen sensors	B1S1 B1S2   / B2S1 B2S2
    IDE00597	Long term adaptation of mixture formation bank 1	-1.6	 %
    IDE00598	Long term adaptation of mixture formation bank 2	-0.8	 %
    IDE00601	Monitoring status since erasing DTC memory
    IDE00602	Monitoring status in current driving cycle
    IDE00603	Number of driving cycles since erasing DTC memory	11
    IDE00604	Short term adaptation of mixture formation bank 1	-0.8	 %
    IDE00605	Short term adaptation of mixture formation bank 2	-1.6	 %
    IDE00608	Type of fuel	Gasoline
    IDE00612	Target position of EVAP canister valve	0	 %
    IDE00699	ESI: minimum oil level in service interval	10.6	 mm
    IDE00700	ESI: maximum oil level in service interval	29.852	 mm
    IDE00727	Test steps still to be performed	0
    IDE00738	Test of oxygen sensors bank 1: Delta-Lambda	0
    IDE00739	Test of oxygen sensors bank 2: Delta-Lambda	0
    IDE00752	Test of oxygen sensor control.	Syst. OK
    IDE00752-ENG127302	Test of oxygen sensor control.-Test_Program_Channel 213	228
    IDE00787	Cause for cancellation	0
    IDE00949	Hide cylinder	not active
    IDE00949-ENG127318	Hide cylinder-Test_Program_cylinder 1	0
    IDE00949-ENG127309	Hide cylinder-Test_Program_cylinder 10	0
    IDE00949-ENG127308	Hide cylinder-Test_Program_cylinder 11	0
    IDE00949-ENG127307	Hide cylinder-Test_Program_cylinder 12	0
    IDE00949-ENG127306	Hide cylinder-Test_Program_cylinder 13	0
    IDE00949-ENG127305	Hide cylinder-Test_Program_cylinder 14	0
    IDE00949-ENG127304	Hide cylinder-Test_Program_cylinder 15	0
    IDE00949-ENG127303	Hide cylinder-Test_Program_cylinder 16	0
    IDE00949-ENG127317	Hide cylinder-Test_Program_cylinder 2	0
    IDE00949-ENG127316	Hide cylinder-Test_Program_cylinder 3	0
    IDE00949-ENG127315	Hide cylinder-Test_Program_cylinder 4	0
    IDE00949-ENG127314	Hide cylinder-Test_Program_cylinder 5	0
    IDE00949-ENG127313	Hide cylinder-Test_Program_cylinder 6	0
    IDE00949-ENG127312	Hide cylinder-Test_Program_cylinder 7	0
    IDE00949-ENG127311	Hide cylinder-Test_Program_cylinder 8	0
    IDE00949-ENG127310	Hide cylinder-Test_Program_cylinder 9	0
    IDE00973	Outside air temperature	-3	 C
    IDE01076	Time since ignition off	4481	 s
    IDE01098	Test of knock sensors: short trip result	Test off
    IDE01098-ENG127299	Test of knock sensors: short trip result-Test_Program_Channel 165	235
    IDE01196	Dynamic factor O2 sensors bank 1 or bank 3 before cat. conv.	1.1306
    IDE01236-ENG57549	Coolant recirculation pump-Bits 0-7	0
    IDE01260	Generator power	1093.27	 W
    IDE01266-ENG57549	Coolant shut-off valve-Bits 0-7	3
    IDE01267	Height correction	0.97925
    IDE01378	High fuel pressure: control deviation	0.035	 MPa
    IDE01385-ENG57549	Wear index-Bits 0-7	0
    IDE01386-ENG57549	Soot index-Bits 0-7	0
    IDE01405-ENG57549	Status of starter activation-Bits 0-7	2
    IDE01638	Result O2 sensor aging test bank 1 or 3 before cat. conv.	Test off
    IDE01638-ENG127368	Result O2 sensor aging test bank 1 or 3 before cat. conv.-Test_Program_Channel 951	235
    IDE01639	Dynamic factor O2 sensors bank 2 or bank 4 before cat. conv.	0.8696
    IDE01640	Result O2 sensor aging test bank 2 or 4 before cat. conv.	Test off
    IDE01640-ENG129411	Result O2 sensor aging test bank 2 or 4 before cat. conv.-Test_Program_Channel 1022	235
    IDE01641-ENG57549	Result of oxygen sensor test bank 1 after catalytic converter-Bits 0-7	0
    IDE01644	Oxygen sensor voltage bank 1 after catalytic converter	0.455	 V
    IDE01645	Oxygen sensor voltage bank 2 after catalytic converter	0.455	 V
    IDE01647	Result of O2 sensor aging test bank 2 after cat. conv.	Test off
    IDE01647-ENG129417	Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 379	235
    IDE01649	Throttle valve position 1	3.44	 %
    IDE01650	Throttle valve position 2	13	 %
    IDE01665	Result of test of camshaft adjustment intake bank 1	Test off
    IDE01665-ENG127298	Result of test of camshaft adjustment intake bank 1-Test_Program_Channel 140	235
    IDE01667	Result of test of camshaft adjustment outlet bank 1	Test off
    IDE01667-ENG127371	Result of test of camshaft adjustment outlet bank 1-Test_Program_Channel 619	235
    IDE01678	Result of O2 sensor test ready bank 2 after cat. conv.	Test off
    IDE01678-ENG129413	Result of O2 sensor test ready bank 2 after cat. conv.-Test_Program_Channel 114	235
    IDE01680	Result test Evap. Emission (EVAP) Canister Purge Reg. Valve	Test off
    IDE01680-ENG127300	Result test Evap. Emission (EVAP) Canister Purge Reg. Valve-Test_Program_Channel 195	235
    IDE01773	Misfire sum counter	0
    IDE01774	Status misfire recognition	activated
    IDE01774-ENG127319	Status misfire recognition-Test_Program_Channel 232	103
    IDE01775	Misfires per 1000 revolutions of cylinder 1	0
    IDE01776	Misfires per 1000 revolutions of cylinder 2	0
    IDE01777	Misfires per 1000 revolutions of cylinder 3	0
    IDE01778	Misfires per 1000 revolutions of cylinder 4	0
    IDE01834	Battery voltage	14580	 mV
    IDE01869	Long-term fuel trim bank 1 at idle	0.09	 %
    IDE01870	Oxygen sensor after catalytic converter: operating status	Test off
    IDE01870-ENG127295	Oxygen sensor after catalytic converter: operating status-Test_Program_Channel 113	235
    IDE01872	Result of oxygen sensor aging test after catalytic converter	Test off
    IDE01872-ENG127321	Result of oxygen sensor aging test after catalytic converter-Test_Program_Channel 378	235
    IDE01873	Test of catalytic converter: measured value	2.5256
    IDE01874	Test of catalytic converter: result	Test off
    IDE01874-ENG127322	Test of catalytic converter: result-Test_Program_Channel 486	235
    IDE01875	Required torque adjustment by idling regulator	-4.382	 %
    IDE01876	Adaptation of loss torque	-11.8	 Nm
    IDE01877-ENG57549	Operating condition of idle speed control-Bits 0-7	0
    IDE01878-ENG28465	Adaptation of throttle valve-Byte	100
    IDE01879	Adaptation of throttle valve: result	ADP is OK
    IDE01879-ENG127324	Adaptation of throttle valve: result-Test_Program_Channel 698	2
    IDE01880	Accelerator position 2	15	 %
    IDE01881	Adaptation of kick-down shifting point	3550	 mV
    IDE01884	Camshaft adjustment intake bank 1: activation	35.211	 %
    IDE01885	Shut off of oxygen sensor control	l-Reg.ON
    IDE01885-ENG127301	Shut off of oxygen sensor control-Test_Program_Channel 212	4
    IDE01887	Adaptation of Fuel Pump (FP)	-33.1	 kPa
    IDE01888	Cold start enrichment: adaptation area 1	1
    IDE01889	Cold start enrichment: adaptation area 2	1
    IDE01890	Cold start enrichment: adaptation area 3	1
    IDE01891	Cold start enrichment: adaptation area 4	1
    IDE01892	Cold start enrichment: adaptation area 5	1
    IDE01893	Fuel pump: specified value	23.988	 %
    IDE01899	Load value: corrected specified value	83.04	 %
    IDE01901	Lost torque adaptation: idle	-11.8	 Nm
    IDE01902	Lost torque adaptation A/C compressor	0	 Nm
    IDE01903	Lost torque adaptation driving mode	-8.8	 Nm
    IDE01904	Lost torque adaptation A/C compressor and driving mode	0	 Nm
    IDE01909	Short term adapt. throttle valve for mass air flow sensor	1.00793
    IDE01910	Long term adaptation of throttle valve for mass air flow sensor	0.97388
    IDE01911	Leakage air	3.6	 kg/h
    IDE01912	Oxygen sensor bank 1 sensor 1: specified value	1
    IDE01913	Number of oxygen sensor dynamic tests: bank 1 sensor 1	0
    IDE01914-ENG57549	Oxygen sensor wiring diagnosis: bank 1 sensor 1-Bits 0-7	168
    IDE01916	Leakage recognition from oxygen sensor control	0.9995
    IDE01917	Leakage after throttle valve	-1
    IDE01918	Leakage before throttle valve	-1
    IDE01919-ENG57549	Leakage recognition: status-Bits 0-7	212
    IDE01920	Oxygen sensor: mixture correction with active diagnosis	0
    IDE01921-ENG100991	O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Rel uw b200 UWORD Chann 295	100	 %
    IDE01921-ENG127296	O2 reg: evap. emiss. can. purge reg. valve w/ active diagn.-Test_Program_Bitregister	1
    IDE01922	Vehicle distance driven	13743	 km
    IDE01923	Control module distance driven	13720679	 m
    IDE01928	Close cam shaft angle at quantity control valve	43.5
    IDE01929	Open cam shaft angle at quantity control valve	-25.1
    IDE01930	High pressure regulation: adaptation value	0	 MPa
    IDE01932	High pressure pump injection volume	-6.36	 mm
    IDE01975	Numb.of misfir.: cylinder 1	556
    IDE01976	Numb.of misfir.: cylinder 2	2063
    IDE01977	Numb.of misfir.: cylinder 3	481
    IDE01978	Numb.of misfir.: cylinder 4	466
    IDE01986	Contact for tank leak test	Reed closed
    IDE01986-ENG130112	Contact for tank leak test-Test_Program_Channel 235	298
    IDE01987	Tank leak test	Cancel
    IDE01987-ENG130113	Tank leak test-Test_Program_Channel 236	231
    IDE01988	Tank leak: status	tbd
    IDE01988-ENG130114	Tank leak: status-Test_Program_Channel 237	0
    IDE01989	Tank leak: result	Test off
    IDE01989-ENG130115	Tank leak: result-Test_Program_Channel 238	235
    IDE02115-ENG57549	Adjustment requirements for basic setting-Bits 0-7	254
    IDE02116	Exhaust gas temperature before catalytic converter	285.65	 C
    IDE02117	Relative load value	19.95	 %
    IDE02118	Oxygen sensor bank 1 sensor 1: voltage	1.489	 V
    IDE02119	Long term adaptation of oxygen sensor control: bank 1	0	 %
    IDE02211	Brake pressure	0	 MPa
    IDE02540-ENG57549	Longitudinal acceleration sensor: status-Bits 0-7	0
    IDE02832	Coolant circulation pump: activation	0	 %
    IDE03108	Result of test of oxygen sensors bank 1	Test off
    IDE03108-ENG127369	Result of test of oxygen sensors bank 1-Test_Program_Channel 976	235
    IDE03189-ENG102843	Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Air Density	0	 counts
    IDE03189-ENG102547	Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Brake Boost	0	 counts
    IDE03189-ENG103808	Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Fuel Mixture Adaption	0	 counts
    IDE03189-ENG101159	Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Random	0	 counts
    IDE03189-ENG104187	Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Regeneration Mode	0	 counts
    IDE03189-ENG100165	Number of prevented stop processes (statistics)-SSEUI Counter Stop Prohibited By Start Behavior	0	 counts
    IDE03189-ENG99535	Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Air Density	0
    IDE03189-ENG103192	Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Brake Boost	0
    IDE03189-ENG99739	Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Fuel Mixture Adaption	0
    IDE03189-ENG100597	Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Random	0
    IDE03189-ENG101689	Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Regeneration Mode	0
    IDE03189-ENG100582	Number of prevented stop processes (statistics)-SSEUI Day Stop Prohibited By Start Behavior	0
    IDE03189-ENG101720	Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Air Density	0
    IDE03189-ENG100669	Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Brake Boost	0
    IDE03189-ENG100932	Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Fuel Mixture Adaption	0
    IDE03189-ENG101264	Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Random	0
    IDE03189-ENG102430	Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Regeneration Mode	0
    IDE03189-ENG101165	Number of prevented stop processes (statistics)-SSEUI Hours Stop Prohibited By Start Behavior	0
    IDE03189-ENG101829	Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Air Density	0	 km
    IDE03189-ENG99286	Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Brake Boost	0	 km
    IDE03189-ENG102800	Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Fuel Mixture Adaption	0	 km
    IDE03189-ENG102751	Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Random	0	 km
    IDE03189-ENG101356	Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Regeneration Mode	0	 km
    IDE03189-ENG99669	Number of prevented stop processes (statistics)-SSEUI Mileage Stop Prohibited By Start Behavior	0	 km
    IDE03189-ENG103828	Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Air Density	0
    IDE03189-ENG103959	Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Brake Boost	0
    IDE03189-ENG102465	Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Fuel Mixture Adaption	0
    IDE03189-ENG102710	Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Random	0
    IDE03189-ENG103568	Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Regeneration Mode	0
    IDE03189-ENG100877	Number of prevented stop processes (statistics)-SSEUI Minutes Stop Prohibited By Start Behavior	0
    IDE03189-ENG101280	Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Air Density	0
    IDE03189-ENG99226	Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Brake Boost	0
    IDE03189-ENG101471	Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Fuel Mixture Adaption	0
    IDE03189-ENG102877	Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Random	0
    IDE03189-ENG100198	Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Regeneration Mode	0
    IDE03189-ENG101676	Number of prevented stop processes (statistics)-SSEUI Month Stop Prohibited By Start Behavior	0
    IDE03189-ENG103694	Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Air Density	0
    IDE03189-ENG104142	Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Brake Boost	0
    IDE03189-ENG100353	Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Fuel Mixture Adaption	0
    IDE03189-ENG100878	Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Random	0
    IDE03189-ENG101433	Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Regeneration Mode	0
    IDE03189-ENG100557	Number of prevented stop processes (statistics)-SSEUI Year Stop Prohibited By Start Behavior:	0
    IDE03190-ENG100538	Number of requested start processes (statistics)-SSEUI Counter Start Desired By Brake Boost	0	 counts
    IDE03190-ENG100036	Number of requested start processes (statistics)-SSEUI Counter Start Desired By High Engine Temperature	0	 counts
    IDE03190-ENG103639	Number of requested start processes (statistics)-SSEUI Counter Start Desired By Low Engine Temperature	0	 counts
    IDE03190-ENG102427	Number of requested start processes (statistics)-SSEUI Day Start Desired By Brake Boost	0
    IDE03190-ENG99459	Number of requested start processes (statistics)-SSEUI Day Start Desired By High Engine Temperature	0
    IDE03190-ENG99665	Number of requested start processes (statistics)-SSEUI Day Start Desired By Low Engine Temperature	0
    IDE03190-ENG99329	Number of requested start processes (statistics)-SSEUI Hours Start Desired By Brake Boost	0
    IDE03190-ENG100944	Number of requested start processes (statistics)-SSEUI Hours Start Desired By High Engine Temperature	0
    IDE03190-ENG100535	Number of requested start processes (statistics)-SSEUI Hours Start Desired By Low Engine Temperature	0
    IDE03190-ENG102737	Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Brake Boost	0	 km
    IDE03190-ENG101377	Number of requested start processes (statistics)-SSEUI Mileage Start Desired By High Engine Temperature	0	 km
    IDE03190-ENG99682	Number of requested start processes (statistics)-SSEUI Mileage Start Desired By Low Engine Temperature	0	 km
    IDE03190-ENG102760	Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Brake Boost	0
    IDE03190-ENG103163	Number of requested start processes (statistics)-SSEUI Minutes Start Desired By High Engine Temperature	0
    IDE03190-ENG101771	Number of requested start processes (statistics)-SSEUI Minutes Start Desired By Low Engine Temperature	0
    IDE03190-ENG100816	Number of requested start processes (statistics)-SSEUI Month Start Desired By Brake Boost	0
    IDE03190-ENG104013	Number of requested start processes (statistics)-SSEUI Month Start Desired By High Engine Temperature	0
    IDE03190-ENG104020	Number of requested start processes (statistics)-SSEUI Month Start Desired By Low Engine Temperature	0
    IDE03190-ENG103223	Number of requested start processes (statistics)-SSEUI Year Start Desired By Brake Boost	0
    IDE03190-ENG103563	Number of requested start processes (statistics)-SSEUI Year Start Desired By High Engine Temperature	0
    IDE03190-ENG103316	Number of requested start processes (statistics)-SSEUI Year Start Desired By Low Engine Temperature	0
    IDE03262	Adapt of angle sensor 1 f throttle valve	0.49	 V
    IDE03263	Adapt of angle sensor 2 f throttle valve	4.498	 V
    IDE03264	Adaptation of angle sensor 1 throttle valve: emerg. air gap	0.758	 V
    IDE03265	Adaptation of angle sensor 2 throttle valve: emerg. air gap	4.232	 V
    IDE03362	Requested transmission torque	1000	 Nm
    IDE03363	Numb.of misfir.: cylinder 5	434
    IDE03364	Numb.of misfir.: cylinder 6	1911
    IDE03393-ENG57549	Selector lever position-Bits 0-7	8
    IDE03660	Longitudinal acceleration	0	 m/s
    IDE03664-ENG57549	Button for driving program-Bits 0-7	1
    IDE03692-ENG57549	Monitoring status Onboard Diagnosis camshaft and knock sensor-Bits 0-7	202
    IDE03693-ENG57549	Monitoring status of additional Onboard Diagnosis-Bits 0-7	161
    IDE03694-ENG57549	Result of test of fuel supply system partial throttle-Bits 0-7	0
    IDE03696-ENG57549	Result test of oxygen sensor heater after catalytic converter-Bits 0-7	0
    IDE03697-ENG57549	Result test of oxygen sensor heater before catalytic converter-Bits 0-7	4
    IDE03698-ENG57549	Result of dynamic test of oxygen sensor before cat. converter-Bits 0-7	32
    IDE03699-ENG57549	Result of test of oxygen sensor before catalytic converter-Bits 0-7	228
    IDE03700	Status adaptation dew point end	ADP is running
    IDE03700-ENG127325	Status adaptation dew point end-Test_Program_Channel 860	1
    IDE03703-ENG57549	Result catalytic converter diagnosis test-Bits 0-7	0
    IDE03707-ENG57549	Result of NPulse test-Bits 0-7	170
    IDE03708-ENG57549	Result of test 2 of oxygen sensor before catalytic converter-Bits 0-7	0
    IDE03709	Angle difference actual-specified camshaft adjuster	0.43
    IDE03710-ENG57549	Result of camshaft diagnostic test-Bits 0-7	0
    IDE03711	Mass flow through throttle valve	19.3	 kg/h
    IDE03767	Engine status	COENG_RUNNING
    IDE03767-ENG127290	Engine status-Test_Program_Co Eng st COMPU VERB UBYTE	3
    IDE03794	Long-term fuel trim bank 2 at idle	-0.14	 %
    IDE03795	Camshaft adjustment: exhaust: bank 1: activation	6.252	 %
    IDE03806-ENG57549	Oxygen sensor bank 1 sensor 1: status-Bits 0-7	7
    IDE03807-ENG57549	Oxygen sensor bank 1 sensor 2: status-Bits 0-7	0
    IDE03808-ENG57549	Oxygen sensor bank 2 sensor 1: status-Bits 0-7	7
    IDE03809-ENG57549	Oxygen sensor bank 2 sensor 2: status-Bits 0-7	0
    IDE03810	Oxygen sensor bank 2 sensor 1: specified value	1
    IDE03811	Test of oxygen sensors bank 2: Delta-Lambda: result	Test off
    IDE03811-ENG129422	Test of oxygen sensors bank 2: Delta-Lambda: result-Test_Program_Channel 977	235
    IDE03818-ENG99405	Heated oxygen sensor bank 1: sensor 2: resistance-R uw q2 UWORD Chann 120	0	 Ohm
    IDE03818-ENG127296	Heated oxygen sensor bank 1: sensor 2: resistance-Test_Program_Bitregister	0
    IDE03819	Heated oxygen sensor bank 1: sensor 2: activation	Htg.aC.OFF
    IDE03819-ENG127297	Heated oxygen sensor bank 1: sensor 2: activation-Test_Program_Channel 123	217
    IDE03820	Heated oxygen sensor bank 1: sensor 1: resistance	298.91	 Ohm
    IDE03821	Heated oxygen sensor bank 1: sensor 1: activation	35.88	 %
    IDE03822-ENG101533	Heated oxygen sensor bank 2: sensor 2: resistance-R uw q2 UWORD Chann 121	0	 Ohm
    IDE03822-ENG127296	Heated oxygen sensor bank 2: sensor 2: resistance-Test_Program_Bitregister	0
    IDE03823	Heated oxygen sensor bank 2: sensor 2: activation	Unknown
    IDE03823-ENG129414	Heated oxygen sensor bank 2: sensor 2: activation-Test_Program_Channel 125	0
    IDE03824	Heated oxygen sensor bank 2: sensor 1: resistance	300.94	 Ohm
    IDE03825	Heated oxygen sensor bank 2: sensor 1: activation	39.78	 %
    IDE03826	Conversion test Bank 2: measured value	2.1841
    IDE03827	Conversion test Bank 2: result	Test off
    IDE03827-ENG129418	Conversion test Bank 2: result-Test_Program_Channel 487	235
    IDE03830	Status of adaptation of on-demand fuel pump	ADP is OK
    IDE03830-ENG129410	Status of adaptation of on-demand fuel pump-Test_Program_Channel 1021	2
    IDE03832	Oxygen sensor bank 1 sensor 2: response time	0	 s
    IDE03833	Oxygen sensor bank 2 sensor 2: response time	0	 s
    IDE03836	Result of O2 sensor aging test bank 1 after cat. conv.	B1-S2 OK
    IDE03836-ENG129323	Result of O2 sensor aging test bank 1 after cat. conv.-Test_Program_Channel 2114	209
    IDE03837	Result of O2 sensor aging test bank 2 after cat. conv.	B2-S2 OK
    IDE03837-ENG129416	Result of O2 sensor aging test bank 2 after cat. conv.-Test_Program_Channel 2115	213
    IDE03876	Misfires per 1000 revolutions of cylinder 5	0
    IDE03877	Misfires per 1000 revolutions of cylinder 6	0
    IDE03953	Oxygen control: adaptation value at partial load: bank 1	0.98734
    IDE03966	Transmission neutral position sensor PWM signal	0	 %
    IDE03968-ENG57549	Camshaft adaptation results-Bits 0-7	0
    IDE04016	Fuel Pressure Regulation	FRP CMD:---/--- kPa / FRP ACT:4620/--- kPa
    IDE04083	Coolant temperatures	ECT 1:12 C / ECT 2:51 C
    IDE04234	Heat quantity f dew pt end before cat conv bank 1: modeled	1693.852181	 kJ
    IDE04235	Heat quantity f dew pt end before cat conv bank 2: modeled	1693.647347	 kJ
    IDE04236	Heat quantity f dew pt end behind fr cat conv bank 1: modeled	534.563792	 kJ
    IDE04237	Heat quantity f dew pt end behind fr cat conv bank 2: modeled	534.751556	 kJ
    IDE04238	Heat quantity f dew pt end behind main cat conv bank 1: modeled	613.663597	 kJ
    IDE04239	Heat quantity f dew pt end behind main cat conv bank 2: modeled	613.527042	 kJ
    IDE04240	Counter start bef dew pt end f O2 sensor bef cat conv bank1	0
    IDE04241	Counter start bef dew pt end f O2 sensor bef cat conv bank2	0
    IDE04242	Counter start bef dew pt end f O2 sensor beh fr cat conv bank1	0
    IDE04243	Counter start bef dew pt end f O2 sensor beh fr cat conv bank2	0
    IDE04244	Count start bef dew pt end f O2 sensor beh main cat conv bank1	2
    IDE04245	Count start bef dew pt end f O2 sensor beh main cat conv bank2	2
    IDE04324	Long term adaptation of oxygen sensor control: bank 2	0	 %
    IDE04414	Cat conv temp: modeled	415	 C
    IDE04604	Accelerator pedal travel	0	 %
    IDE04638	Transmission coolant valve	0
    IDE04651	Torque request: A/C compressor	0	 Nm
    IDE04654-ENG57549	CAN status - engine control module-Bits 0-7	0
    IDE04655-ENG57549	CAN status - transmission control module-Bits 0-7	0
    IDE04656-ENG57549	CAN status - brake control module 1-Bits 0-7	0
    IDE04657-ENG57549	CAN status - brake control module 2-Bits 0-7	0
    IDE04663-ENG57549	Cruise control switch-off: irreversible-Bits 0-7	255
    IDE04664-ENG57549	Cruise control switch-off: reversible-Bits 0-7	255
    IDE04665-ENG57549	Cruise control switch-off: irreversible w. brake intervention-Bits 0-7	0
    IDE04670	Crankshaft signal evaluation: status	GAPFOUND
    IDE04670-ENG127292	Crankshaft signal evaluation: status-Test_Program_Epm H Cr S st Sig Mode State t UBYTE	7
    IDE04685	Setpoint generation interior torque	65.4	 Nm
    IDE04689	Starter control: Start interruption status	Correct result
    IDE04689-ENG127289	Starter control: Start interruption status-Test_Program_B TRUE UBYTE	1
    IDE04691	Calculated reducing transmission intervention torque	1000	 Nm
    IDE04692	Reducing desired torque intervention of ESP	50000	 Nm
    IDE04693	Increasing desired torque intervention of ESP	-50000	 Nm
    IDE04695-ENG99946	Immobilizer snapshot A-Sia Error Snap A	00 00 00
    IDE04696-ENG102592	Immobilizer snapshot B-Sia Error Snap B	00 00 00
    IDE04706-ENG57549	ACC interface activation condition-Bits 0-7	0
    IDE04707-ENG57549	Status of reversible switch-off condition ACC_2-Bits 0-7	0
    IDE04708-ENG57549	Status of reversible switch-off condition ACC_3-Bits 0-7	0
    IDE04709-ENG57549	Status of ACC/CCS acceleration interface-Bits 0-7	0
    IDE04710-ENG57549	ACC control module received status-Bits 0-7	0
    IDE04711-ENG57549	Next status of ACC/CCS finite state machine-Bits 0-7	1
    IDE04712-ENG57549	Active brake system error status-Bits 0-7	0
    IDE04713-ENG57549	Active brake system status-Bits 0-7	0
    IDE04814	Transmission oil cooler valve	0
    IDE04820	Fuel content due to degassing of engine oil	0	 %
    IDE04858	Brake booster low pressure actual value	0	 hPa
    IDE04887	Powertrain target torque	-85.1	 Nm
    IDE04889	Target torque for combustion engine crankshaft level	-42.5	 Nm
    IDE04933	Number of fill level decreases	1
    IDE04934	Last odometer reading since fill level decrease	10752	 km
    IDE04935	Next to last odometer reading since fill level decrease	0	 km
    IDE04936	3. Last odometer reading since fill level decrease	0	 km
    IDE05128	Intake air temperature in intake manifold bank 1	8.3	 C
    IDE05134	ACC target acceleration	0	 m/s
    IDE05222	Number of ignitions at overspeed range 1	0
    IDE05223	Number of ignitions at overspeed range 2	0
    IDE05224	Number of ignitions at overspeed range 3	0
    IDE05225	Operating hours at overspeed range 1	0	 min
    IDE05226	Operating hours at overspeed range 2	0	 min
    IDE05227	Operating hours at overspeed range 3	0	 min
    IDE05228	Operating hour counter	13722	 min
    IDE05240-ENG57549	Request for A/C compressor power reduction-Bits 0-7	0
    IDE05241-ENG57549	A/C compressor release status-Bits 0-7	1
    IDE05261-ENG57549	Gear position sensor: last valid value-Bits 0-7	14
    IDE05327	Activation for electrical reserve coolant pump in HT circuit	0	 %
    IDE05332-ENG57549	Heat request from heater to thermal management-Bits 0-7	3
    IDE05436	Engine operating condition	Idling
    IDE05436-ENG127326	Engine operating condition-Test_Program_Channel 87	5
    IDE05437	Outside air temperature via CAN	-0.8	 C
    IDE05438	Rear cat conv temp main cat conv model value	417.32	 C
    IDE05439	Rear cat conv temp main cat conv bank 2 model value	417.39	 C
    IDE05440	ESI: Soot equiv 2 calculated from soot index	0
    IDE05441	ESI: Wear equivalent 2 calculated from wear index	0
    IDE05442	Roadway slope angle acceleration interface: calculated	0	 rad
    IDE05443	Acceleration interface braking torque specified value	0	 Nm
    IDE05444	Air filling: specified value	20.13	 %
    IDE05445	Pressure before throttle valve of pressure sensor	991.8	 hPa
    IDE05447	Leak recog from oxygen sensor control bank 2	0.9946
    IDE05448	Long term adaptation of mixture form bank 2 at partial load	1.00595
    IDE05449	Oxygen sensor 2 bank 1 internal resistance limit value	16632	 Ohm
    IDE05450	Oxygen sensor 2 bank 2 internal resistance limit value	16632	 Ohm
    IDE05451	Numb. of oxyg.sensor dynamic tests:bank 2:sen.1	0
    IDE05462	Oxy sensor 1 bank 1 char curve offset	0.00082
    IDE05463	Oxy sensor 1 bank 2 char curve offset	0.00146
    IDE05464	Oxygen sensor 1 bank 1 fast offset adaptation counter	0
    IDE05465	Oxygen sensor 1 bank 2 fast offset adaptation counter	0
    IDE05466	Oxy sensor 1 bank 1 offset spec value	0
    IDE05467	Oxy sensor 1 bank 2 offset spec value	0
    IDE05468	Oxygen sensor 1 bank 1 ceramic temp	780.55	 C
    IDE05469	Oxygen sensor 1 bank 2 ceramic temp	779.62	 C
    IDE05470	Cat converter oxygen storage capacity	0	 mg
    IDE05471	Cat converter oxygen storage capacity bank 2	0	 mg
    IDE05472	Cat converter oxygen storage capacity ref standardized	0
    IDE05473	Cat converter oxygen storage capacity ref standardized bank 2	0
    IDE05474	Main cat converter OSC age correction factor	1.063
    IDE05475	Main cat converter OSC age correction factor bank 2	1.094
    IDE05476	Cat converter oxygen storage capacity measured	0	 mg
    IDE05477	Cat converter oxygen storage capacity bank 2 measured	0	 mg
    IDE05478	Exh mss flw bef main cat conv bank 1 filtered	10.2	 kg/h
    IDE05479	Misfire recognition reference moment	14.206	 %
    IDE05480-ENG57549	Evap. emiss. can. purge reg. valve short trip result-Bits 0-7	0
    IDE05482	Tank venting adaptation factor	0.492
    IDE05483	Timer for Reed-Switch Closed Check	0	 s
    IDE05484	Power steering pump desired actual moment for idling control	0	 Nm
    IDE05485-ENG57549	Irregular shutdown of the counter control mod-Bits 0-7	0
    IDE05486	Current system status	SYC_DRIVE
    IDE05486-ENG127293	Current system status-Test_Program_Exe Con State 02 UBYTE	4
    IDE05487	Coolant temperature linearized value	14.083	 C
    IDE05488	Coolant temperature modeled value	9.8	 C
    IDE05489	Coolant temperature max value	12	 C
    IDE05490	Coolant temperature min value	6	 C
    IDE05491	Intake air temperature max value	14.3	 C
    IDE05492	Intake air temperature min value	6.8	 C
    IDE05508	Adaptation val cyl 1 with slow diagnosis	1
    IDE05509	Adaptation val cyl 3 with slow diagnosis	1
    IDE05510	Adaptation val cyl 4 with slow diagnosis	1
    IDE05511	Adaptation val cyl 2 with slow diagnosis	1
    IDE05512	Adaptation val cyl 1 with fast diagnosis	1
    IDE05513	Adaptation val cyl 3 with fast diagnosis	1
    IDE05514	Adaptation val cyl 4 with fast diagnosis	1
    IDE05515	Adaptation val cyl 2 with fast diagnosis	1
    IDE05797	Throttle valve adapter: specified value	3.261	 %
    IDE05810	Diagnosis limit for SCAN Tool mode 6 tank leak diagnosis pump	550
    IDE05811-ENG57549	Tank leak diagnosis pump tank ventilation conditions 1-Bits 0-7	0
    IDE05812-ENG57549	Tank leak diagnosis pump tank ventilation conditions 2-Bits 0-7	1
    IDE05812-ENG57549	Tank leak diagnosis pump tank ventilation conditions 2-Bits 0-7	0
    IDE05844	Pre-ignition counter cylinder 3	36
    IDE05928	Fuel consumption since DTC memory last erased	16.498	 l/100km
    IDE05947	Pre-ignition counter cylinder 1	7
    IDE05948	Pre-ignition counter cylinder 2	0
    IDE05949	Pre-ignition counter cylinder 4	3
    IDE06006	Idle speed specified value	700	 /min
    IDE06017	Camshaft position deviation from reference position	0
    IDE06023-ENG57549	BDE operating mode flag register-Bits 0-7	1
    IDE06039	Required RPM at idle speed	700	 /min
    IDE06040	High fuel pressure: regulator output value	-0.0385	 MPa
    IDE06041-ENG57549	PDTC drive cycle conditions status-Bits 0-7	36
    IDE06043	Cylinder head temperature: actual value	53	 C
    IDE06045-ENG57549	Output DTM status-Bits 0-7	0
    IDE06048	Drive time with activated exhaust malfunction indicator lamp	0	 s
    IDE06049	Pressure in brake booster: raw value	1235.27	 hPa
    IDE06050	Exhaust temp on O2 sensor behind cat conv from model: filtered	166.61	 C
    IDE06053-ENG57549	Test of mixture adaptation bank 1: status-Bits 0-7	0
    IDE06054-ENG57549	Test of mixture adaptation bank 2: status-Bits 0-7	0
    IDE06098	Sensor control factor: output value	0.98178
    IDE06192	Knock sensor: cylinder 2: voltage	0.61	 V
    IDE06193	Knock sensor: cylinder 3: voltage	0.786	 V
    IDE06194	Knock sensor: cylinder 4: voltage	0.371	 V
    IDE06195	Knock sensor: cylinder 1: voltage	1.118	 V
    IDE06255	Vehicle lateral acceleration	0	 g
    IDE06256	Vehicle lateral acceleration: raw value	0	 g
    IDE06257	Vehicle inclination acceleration angle: raw value	32.767	 m/s
    IDE06386	Oil level: static measurement	13.6	 mm
    IDE06387	Oil level: last valid dynamic value	24.48	 mm
    IDE06388	Oil level: condition for static measurement fulfilled	0
    IDE06392	Oil temperature sensor 2: raw value	0	 mV
    IDE06393	Oil level: dynamic average value	23.68	 mm
    IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
    IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
    IDE06434-ENG112927	Oxygen control: bank 1: sensor 1: release status-Blrnd A	1
    IDE06435	A/C compressor: refrigerant pressure	0	 hPa
    IDE06445	Longitudinal acceleration: raw value	0	 m/s
    IDE06446-ENG57549	Status: incline angle-Bits 0-7	1
    IDE06495	Results of testing of crankcase ventilation successful	9
    IDE06496	Results of testing of crankcase ventilation unsuccessful	0
    IDE06706-ENG57549	ACC variants-Bits 0-7	0
    IDE06708-ENG57549	Cruise control switch actuation-Bits 0-7	1
    IDE06708-ENG57549	Cruise control switch actuation-Bits 0-7	0
    IDE06709-ENG57549	ACC variants (coding)-Bits 0-7	3
    IDE06758	Air mass since engine start	1.46	 kg
    IDE06759	Cam shaft adaptation inlet: counter	5
    IDE06760	Camshaft adaptation: exhaust: counter	5
    IDE06761	Adaptation val cyl 5 with slow diagnosis	1
    IDE06762	Adaptation val cyl 5 with fast diagnosis	1
    IDE06763	Adaptation val cyl 6 with slow diagnosis	1
    IDE06764	Adaptation val cyl 6 with fast diagnosis	1
    IDE06800	A/C main switch status	1
    IDE06944	A/C compressor: load current: act. value	0	 A
    IDE06946-ENG57549	Brake actuated status-Bits 0-7	0
    IDE06956-ENG57549	Driver-side belt buckle status-Bits 0-7	2
    IDE06957	Unfiltered clutch input rpm	689	 /min
    IDE07050-ENG57549	Starter control: release conditions-Bits 0-7	98
    IDE07050-ENG57549	Starter control: release conditions-Bits 0-7	12
    IDE07051-ENG57549	Engaged gear: raw signal-Bits 0-7	0
    IDE07094	Correction factor injector cylinder 1	1
    IDE07095	Correction factor injector cylinder 2	1
    IDE07096	Correction factor injector cylinder 3	1
    IDE07097	Correction factor injector cylinder 4	1
    IDE07170	Clutch K0: torque	0	 Nm
    IDE07194	Calculated increasing transmission engagement torque	-3276.8	 Nm
    IDE07195	Correction factor injector cylinder 5	1
    IDE07196	Correction factor injector cylinder 6	1
    IDE07224-ENG57549	Overrun cut-off-Bits 0-7	0
    IDE07229	Pre-ignition counter cylinder 5	9
    IDE07230	Pre-ignition counter cylinder 6	0
    IDE07233-ENG57549	Bit string for status of oil level-Bits 0-7	4
    IDE07233-ENG57549	Bit string for status of oil level-Bits 0-7	6
    IDE07234	Status bid for valid static oil level	1
    IDE07235	Status bid for dynamic oil level	1
    IDE07238	Status of power transfer	0
    IDE07475	Throttle valve position 2	3.44	 %
    IDE07665	Accel. pedal kick-down recognition: voltage threshold	3792.4	 mV
    IDE07840-ENG57549	Status plausibility accelerator pedal to brake pedal-Bits 0-7	0
    IDE07904-ENG57549	Brake test switch status-Bits 0-7	0
    IDE07905-ENG57549	Brake light switch status-Bits 0-7	0
    IDE07906-ENG57549	Upper clutch switch: status-Bits 0-7	0
    IDE08562	Basic correction factor: Injector cyl. 1: filtered	1
    IDE08563	Basic correction factor: Injector cyl. 2: filtered	1
    IDE08564	Basic correction factor: Injector cyl. 3: filtered	1
    IDE08565	Basic correction factor: Injector cyl. 4: filtered	1
    IDE08566	Basic correction factor: Injector cyl. 5: filtered	1
    IDE08567	Basic correction factor: Injector cyl. 6: filtered	1
    IDE09572	O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich	0.08	 s
    IDE09573	O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich	0.1	 s
    IDE09574	O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean	0.05	 s
    IDE09575	O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean	0.05	 s
    IDE09576	O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich	0.02	 s
    IDE09577	O2 sen dwnstrm. of cat. bank 2: delay time transf. lean -> rich	0.02	 s
    IDE09578	O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean	0.08	 s
    IDE09579	O2 sens.dwnstrm. of cat. bank 2: delay time transf.rich -> lean	0.04	 s
    IDE09693-ENG57549	Charisma driving program: system status-Bits 0-7	1
    IDE09694-ENG57549	Charisma driving program: act. value-Bits 0-7	1
    IDE09695-ENG57549	Charisma driving program: target value from coordinator-Bits 0-7	0
    IDE09696-ENG57549	Charisma driving program: CAN output value-Bits 0-7	0
    IDE09925-ENG57549	Intake camshaft bank 1: adaption error cause-Bits 0-7	0
    IDE09926-ENG57549	Outlet camshaft bank 1: adaption error cause-Bits 0-7	0
    IDE10042	Outlet camshaft bank 1 status adaption	EPMCAS_STFULLADAP
    IDE10042-ENG127372	Outlet camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE	4
    IDE10043	intake camshaft bank 1 status adaption	EPMCAS_STFULLADAP
    IDE10043-ENG127372	intake camshaft bank 1 status adaption-Test_Program_Epm Ca S st Adap State UBYTE	4
    ENG105149	Air_mass_integral_for_thermostat_diagnosis_actual_value	0.58	 kg
    ENG105150	Air_mass_integral_for_thermostat_diagnosis_limit_value	17.56	 kg
    ENG101413	Calibration Identification	03H906023DDQ3178
    ENG99697	Calibration Verification Number	DB F4 29 58
    ENG111031-ENG57549	DFC_status_error_debounced_counter-Bits 0-7	0
    ENG111033-ENG57549	DFC_status_tested_counter-Bits 0-7	3
    ENG111033-ENG57549	DFC_status_tested_counter-Bits 0-7	63
    ENG111032-ENG57549	DFC_status_untested_counter-Bits 0-7	0
    ENG111032-ENG57549	DFC_status_untested_counter-Bits 0-7	158
    ENG100152-ENG104003	ECUNAME-ECU	ECM
    ENG100152	ECUNAME	EngineControl
    ENG111034	Engine_temperature_modelbased_substitute_value	33	 C
    ENG107045	Intake_manifold_model_air_mass_flow_filtered_value	19.4	 kg/h
    ENG100634	In-use Per Tr: 16 or 20 cou sec O2 Sens Mon Con Enc Cou B 1	01 D5 04 B7 01 EE 01 D5 01 EE 01 D5 02 55 01 D5 02 6A 01 D5 03 96 01 D5 00 00 00 00 00 D3 00 9A 01 68 01 D5 01 6C 01 D5
    ENG107236	Knock_sensor_cylinder_5_voltage	0.703	 V
    ENG107237	Knock_sensor_cylinder_6_voltage	0.605	 V
    ENG110574	Lambdacoordination_homogeneous_mode_range_limited_commanded_value	1
    ENG107964	Oxygen_sensor_bank_2_sensor_1_voltage	1.421	 V
    ENG109006	Spark_efficiency_deviation_at_idle_maximum	35.9	 %
    ENG109007	Spark_efficiency_deviation_at_part_load_maximum	93	 %
    ENG121093-ENG57549	State_of_cruise_control_or_speedlimiter-Bits 0-7	0
    Elapsed Time: 00:41
    One of these days I need to post all of that data in the Reference Scans and Maps of Non-Broken Cars section. On that note, you may be able to locate good baseline info from a CC in that section.
    Either way, I believe IDE01893 Fuel pump: specified value 23.988 % is the in-tank on-time of the electric fuel pump. If that's correct, the older CAN protocol "below 70%" notes on our Wiki page may not apply to UDS modules. For example,those CAN modules ran in the mid 40's on a brand new car in group 106.
  9. Likes Uwe, Jack@European_Parts liked this post
  10. #28
  11. #29
    Nov 2018
    i never doubted it, just don't know what to think about it with the lit in front of my face, which you have just provided, and i thank you very much for it
    so from what i understand, is that the parts list below are covered by this life warranty?
    https://drive.google.com/open?id=1Xn...ESvGOu1d9IKUjG
  12. #30
    Did you read the document, what does it say? .........
    If your MIL is ON and the car is under the miles or years of the useful life warranty and it is related to a listed AECD & that isn't required for a routine maintenance or if was & indeed was maintained such as an oil change for example & not damaged by outside influence, than isn't that respective system or component covered or any other failed component responsible for the failure of a listed AECD?
