Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: 2013 CC 3.6 4motion P310B error
    Nov 2018
    i have been getting this error for several months in my 2013 CC 3.6 4motion. sometimes the CEL comes on, sometimes it doesn't. often times, the car will also die, sometimes when stopped at a stop light, or even while driving at slow(er) speeds. i have also always noticed a knocking sound coming from the rear for about a year now when stopped and when shutting off the car. a friend told me to replace the below part, which i have twice now:
    https://www.pelicanparts.com/cgi-bin...ion=06j906051c
    when i replace it and clear the code, the car doesn't die at all, but i may or may not still get the light after a day or so of driving. i also have this part on the way right now:
    https://www.pelicanparts.com/More_In...EaAgYvEALw_wcB
    perhaps this will fix the issue??? i'm really curious about the knocking noise i am getting from the rear as well, thinking maybe something is going on with one of the pumps?
    here are my logs from VAGCOM
    Sunday,31,March,2019,15:44:37:37698
    VCDS Version: 18.9.1.0 (x64)
    VIN: WVWGU7AN0DE509584   License Plate: 03312019
                    Address 01: Engine       Labels: None
    Control Module Part Number: 03H 906 023 R    HW: 03H 907 309 A
      Component and/or Version: 3,6 FSI ULEV2 H04 1811
               Software Coding: 001A0012242600000000
                Work Shop Code: WSC 00015 115 00000
                  ASAM Dataset: EV_ECM36FSI01103H906023R 002003 (VW46)
                           ROD: EV_ECM36FSI01103H906023AJ.rod
                          VCID: 3162A48260BA18C262-8064
    2636 - Low Pressure Fuel regulation
              P310B 00 [236] - Fuel Pressure Outside Specification
                        Mileage: 145579 km
                        Date: 2078.14.19
                        Time: 15:21:33
                        Engine speed: 646.00 /min
                        Normed load value: 23.1 %
                        Coolant temperature: 90 C
                        Intake air temperature: 30 C
                        Voltage terminal 30: 14.300 V
                        Fuel pump: specified value: 43.329 %
                        Low fuel pressure: specified value: 437.8 kPa
                        Fuel temperature: 78.8 C
                        Adaptation of Fuel Pump (FP): 76.6 kPa
                        High fuel pressure: specified value: 4.5000 MPa
                        Fuel low pressure: actual value: 277.0 kPa
                        High pressure regulation: adaptation value: 0.0000 MPa
    2637 - Low Pressure Fuel regulation
              P310B 00 [237] - Fuel Pressure Outside Specification
                        Mileage: 145579 km
                        Date: 2078.14.19
                        Time: 15:19:34
                        Engine speed: 647.50 /min
                        Normed load value: 27.5 %
                        Intake air temperature: 23 C
                        Voltage terminal 30: 14.159 V
                        Fuel pump: specified value: 49.664 %
                        Low fuel pressure: specified value: 371.0 kPa
                        Fuel temperature: 70.5 C
                        Fuel low pressure: actual value: 366.0 kPa
    Readiness: 0000 0100
    this is all of the fuel values while sitting idle in my driveway:
    Sunday,31,March,2019,15:48:32:37698
    VIN: WVWGU7AN0DE509584   License Plate: 03312019 VALUES
                    Address 01: Engine  (03H 906 023 R)
    15:48:22
      IDE00186   Fuel low pressure: actual value 521.2 kPa
      IDE00188   Fuel high pressure: actual value 4.5105 MPa
      IDE00201   High fuel pressure: specified value 4.5000 MPa
      IDE00202   Low fuel pressure: specified value 509.2 kPa
      IDE00407-ENG57549   Rail pressure regulation: status-Bits 0-7 00000001
      IDE00589   Fuel pressure 4370 kPa rel
      IDE01378   High fuel pressure: control deviation 0.0080 MPa
      IDE01887   Adaptation of Fuel Pump (FP) 11.8 kPa
      IDE01893   Fuel pump: specified value 59.500 %
      IDE01930   High pressure regulation: adaptation value 0.0000 MPa
      IDE01932   High pressure pump injection volume -3.47 mm
      IDE06040   High fuel pressure: regulator output value -0.0240 MPa
    14.2 liter's, 84 valve's, 24 cylinder's, 1 turbo
    A full Auto-Scan might be helpful too, not just a small edited section.
    Nov 2018
    this wasn't edited, just a scan straight from the Engine module. everything else in an autoscan is fine
    Vehicle Identification No. WVWGU7AN0DE509584
    Model Passat CC 4Motion
    CC
    Date of production 10.05.2012
    Year 2012
    Sales type 3584UQ
    Engine Code CNNA
    Transmission Code KFD
    Emission standard 7GB Emission standard ULEV 2
    VIN: WVWGU7AN0DE509584 Mileage: 145579 km <<<<<<<<<<<<< Car under warranty?
    Control Module Part Number: 03H 906 023 R HW: 03H 907 309 A <<<<<<<<<<<<<< NOT FOD!
    A full auto-scan as aforementioned and OBD2 MODE's 1,3,7 & 9 please.
    Did you read this OP & JPPSG?
    https://forums.ross-tech.com/showthr...l=1#post156577
    Nov 2018
    no existing warranty. i know 2.0T CC's have the fuel pump recall, but nothing seems to correlate to the 3.6
    here is an autoscan from January i have on my work computer which has the same code:
    Sunday,27,January,2019,17:23:59:37698
    VCDS Version: 18.9.0.2
    Mileage: 143170km-88961mi   Repair Order:
    Chassis Type: AN-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 22 25 2E 36 37 42 44 46 47 4F
              52 53 55 56 61 62 65 6C 72 77
    VIN: WVWGU7AN0DE509584   Mileage: 143170km-88961miles
    65-Tire Pressure -- Status: Cannot be reached 1100
    Address 01: Engine (0-32-CNNA)       Labels: None
       Part No SW: 03H 906 023 R    HW: 03H 907 309 A
       Component: 3,6 FSI ULEV2 H04 1811
       Revision: MFH04---    Serial number: 00000000000000
       Shop #: WSC 00015 115 00000
       VCID: 3162A48260BA18C26A-8064
              P310B 00 [172] - Fuel Pressure Outside Specification
                        Mileage: 143114 km
                        Date: 2019.01.27
                        Time: 13:52:50
                        Engine speed: 647.00 /min
                        Normed load value: 25.1 %
                        Coolant temperature: 88 C
                        Intake air temperature: 41 C
                        Voltage terminal 30: 14.206 V
                        Fuel pump: specified value: 53.131 %
                        Low fuel pressure: specified value: 407.5 kPa
                        Fuel temperature: 75.0 C
                        Adaptation of Fuel Pump (FP): 198.8 kPa
                        Fuel low pressure: actual value: 402.9 kPa
       Part No SW: 09G 927 750 MH    HW: 09G 927 750 MH
       Component: AQ 250 6F           1961
       Revision: 00H90000    Serial number:
       Coding: 0000840
       Shop #: WSC 05311 000 00000
       VCID: 030E3E4A42865A52C8-8056
       Part No SW: 3AA 614 109 AF    HW: 3AA 614 109 AF
       Component: J104   C2 450M V4DF 0023
       Revision: --H07---    Serial number: 00000005675232
       Coding: 0000411
       VCID: 71E26482683A58C22A-8024
       Part No SW: 3AA 907 044 J    HW: 3AA 907 044 J
       Component: Climatronic   H03 0101
       Revision: 00001K03
       Coding: 0010001008
       VCID: 37769A9A8EDEC6F224-8062
              B10AB F0 [009] - Too Low
                        Reset counter: 131
                        Mileage: 139856 km
                        Date: 2018.10.12
                        Time: 15:05:33
    Address 09: Cent. Elect.        Labels: None
       VCID: 55AA3012BC9214E2D6-FFFE
    No Faults Found
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475 B    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0016
       Revision: --------    Serial number: 28261211903922
       Coding: 308104
       ASAM Dataset: EV_EPHVA18VW47X0000 001005
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 3E788FBEA1E4F7BAE7-806A
       Part No SW: 5N0 959 655 T    HW: 5N0 959 655 T
       Component: J234__714 VW10 HI   2118
       Revision: 24017000    Serial number: 003LDP8JK6WI
       Coding: 0012596
       VCID: 4E98DF7ED944673A17-801A
       Subsystem 1 - Part No: 3C8 959 339 A
       Subsystem 2 - Serial number: 000000000085BS
       Subsystem 3 - Serial number: 0020.03.120000300000630065†63
       Subsystem 4 - Serial number: 630065†6332MTS611130962 †63
       Subsystem 5 - Serial number: 30962 †6342MTS682710952 †63
       Subsystem 6 - Serial number: 10952 †6351HTS674E72BKR †63
       Subsystem 7 - Serial number: 72BKR †6361HTS6BE2U1BKJ †63
       Subsystem 8 - Serial number: U1BKJ †63727TS6AAIE1BKJ †63
       Subsystem 9 - Serial number: E1BKJ †63827TS66M5F1BKJ
       Subsystem 10 - Serial number: F1BKJ
       Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
       Revision: FF010041    Serial number: 20120426100291
       Coding: 099A270000
       VCID: 6BDE76EA8216B21210-803E
       Coding: E30000
       Part No SW: 3C8 920 980 T    HW: 3C8 920 980 T
       Component: KOMBI         H04 0407
       Coding: 240F01
       Shop #: WSC 05314 115 12345
    12658432 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                        Reset counter: 124
                        Mileage: 139135 km
                        Date: 2018.10.05
                        Time: 14:24:50
       Part No SW: 7N0 907 530 Q    HW: 1K0 907 951
       Component: J533  Gateway H41 1623
       Revision:   H41       Serial number: 210412F2003480
       Coding: 469006
       Shop #: WSC 05314 000 00000
       VCID: 3E788FBEA9E4F7BAE7-806A
                        Reset counter: 124
                        Mileage: 139135 km
                        Date: 2013.02.25
                        Time: 14:24:56
       Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
       Component: Haldex 4Motion      4016
       Coding: 0000005
       VCID: 4688E75E3134AF7AAF-8012
       Part No SW: 3AA 959 433 A    HW: 3AA 959 433 A
       Component:    IMMO         042 0400
       Revision: 00042000    Serial number: VWZCZ000000000
       VCID: 37769A9A46DEC6F224-8062
       Revision: A1001003    Serial number: 7662401608
       VCID: 29524CE2406A6002A2-807C
    Address 36: Seat Mem. Drvr (J810)       Labels: 3C0-959-760.lbl
       Part No SW: 3C8 959 760 B    HW: 3C8 959 760 B
       Component: Sitzmemory    H02 1001
       Revision: 00H02000
       Coding: 000039
       Shop #: WSC 40022 666 40022
       VCID: 346CAD9697A82DEA01-8060
       Part No SW: 3C8 035 684 E    HW: 3C8 035 684 E
       Component: RNS-MID       H65 3696
       Revision: AB001001    Serial number: VWZ6Z7M9115083
       Coding: 04050002010000A6000F
       VCID: 2D5AB8F274827C224E-8078
                        Fault Frequency: 242
                        Reset counter: 223
                        Mileage: 139128 km
       Part No SW: 3C8 959 701     HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0551
       Revision: 12110009    Serial number: 0004824854
       Coding: 0015BF
       Shop #: WSC 05311 115 00000
       VCID: 6DDA78F2BC02BC220E-8038
       Slave Driver:
       Subsystem 1 - Part No SW: 3C8 959 703 D    HW: 3C8 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0501
       Serial number: 00000002842171
       Coding: 010498
       Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.304 1002
       Revision: 1AH03734    Serial number: 00121050006901
       Coding: 0000258
       VCID: 3C7C85B67FF8E5AAC9-8068
       Component:    KSG PQ47 ELV 042 0634
       Coding: 1B910F8001860E763606141FF08A8F0E105801
       Shop #: WSC 05311 123 12345
       Part No SW: 3C8 035 456 C    HW: 3C8 035 456 C
       Component: DSP 10 Kanal        0070
       Revision: 00H07001    Serial number: 75805005271911
       VCID: 285449E69B60590ABD-807C
                        Fault Status: 00101011
                        Reset counter: 2
                        Mileage: 142862 km
                        Date: 2013.06.01
                        Time: 15:51:37
       Component: EZE_2         H41 1623
       Coding: 01030108
       VCID: 6FE662FABE0E4E323C-803A
       Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
       Component: J245/J878  H04 0054
       Serial number: 215500015795
       Coding: 000006
       Subsystem 2 - Part No SW: 3C8 919 204 A    HW: 3C8 919 204 A
       Component: Analoguhr  005 0003
       Part No SW: 3C8 959 702     HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0551
       Revision: 14110009    Serial number: 0004809238
       Coding: 0015BE
       ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
       VCID: 6ED87FFEB104473A37-803A
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C8 959 704 D    HW: 3C8 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0501
       Serial number: 00000002862941
       Coding: 010498
    Address 53: Parking Brake
       Component: AFS-ECU       H04 0111
       Coding: 071A00010B000400
       Subsystem 1 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H06 0007
       Coding: 350000
       Subsystem 2 - Part No SW: 1T0 941 329     HW: 1T0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H06 0007
       Coding: 350000
                        Reset counter: 223
                        Mileage: 139128 km
       Component: Batt.regelung H41 1623
       Coding: 03260172
       VCID: 71E26482A83A58C22A-8024
       Subsystem 1 - Part No SW: 3AA 915 181 A    HW: 3AA 915 181 A
       Component: J367-BDM  H08 0181
       Serial number: 00000000004970298947
    Address 65: Tire Pressure
       Part No SW: 3C8 907 441     HW: 3C8 907 441
       Revision: 00H11000    Serial number: 525PA8-J231719
       Coding: 0120008
       VCID: 67D60ADA56FE967274-8032
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007662437720
       Coding: 0A10040000010110
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 27564ADA5E7E5672B4-8072
    End---------------------(Elapsed Time: 04:22, udsna)-----------------------
  7. Likes Dana liked this post
    Nov 2018
    is this autoscan above good enough to get some sort of input?
    If a P code is demonstrated with an illuminated MIL for a system that is interrelated with useful life, is it not under warranty under EPA and CARB?
    Are you sure because this warranty is extended for 10-120 and 15-150K?
    Please post the data I requested for OBD2 MODE 1,3-7 & 9
    Then reset the fault memory and re-post a fresh new auto-scan........
    Been here?
    http://wiki.ross-tech.com/wiki/index.php/P310B/012555
  10. #8
    United States
    Quote Originally Posted by zoidmk5 View Post
    Yes it is. P310B is specific to the low-side so making sure G410 is OK followed by checking the in-tank fuel pump would be the best place to start. Ideally, you would want to check low side measuring blocks and the actual low-side pressure with a gauge when the car is acting up (which could be difficult).
    Edit, although this is an issue with early FSI engines, and the noise in the rear of the car sounds like an in-tank issue worth chasing, make sure the replacement sensors are the correct part numbers:
    https://forums.ross-tech.com/showthr...s-a-difference!
  11. Likes Jack@European_Parts, Uwe liked this post
  12. #9
    Nov 2018
    Been here?
    yes, i have been to that link, but was seeking more clarity here.
    as for the warrenty, i more so meant that there isn't any existing warranty on the car, thats not to say that any individual part warranty, TSB or recall isn't in effect. last i checked, there are no recalls on my car other than the Takata airbag
  13. #10
    Nov 2018
    when this new sensor comes in the mail, hopefully by Wednesday, we will see what result that give me. its often hard to tell if a sensor change gives me a good result, as this other sensor has shown, the physical issues disappear (shutting off, stuttering, etc.) and MIL, but the code often reappears after a day or so of driving
  14. Likes Dana liked this post
