Hey Guys,
I have a 2006 Audi A8 that has a suspension issue. The front has dropped entirely and the rear has lifted up completely.
About 2 months ago we replaced both front air spring assemblies with used ones and the car was adapted and left without a problem. a month after that the owner called and complained that the front was completely down while the rear was unusually high (At maximum height)
The scan doesn't pick much apart from the basic setting not done fault (from a failed re-adaptation) and level lower limit reached faults.
Ive tried looking for leaks and cant see any, even removed the airsprings and tested them in water but no bubbles.
We've smoke tested the pipes and didnt see any leaks,
we replaced the valve block with a brand new one (worn plastic threads) and it behaves the same front down rear raised
the compressor does run when you try adaptation but immediately after i can only see like 4 bar
does anyone have any ideas? maybe a few workshop tests i could do? im hitting a wall now
did abit of data logging but the values dont make much sense. anyone see anything?
99.0 Front Left
98.0 Front Right
34.0 Rear Left
52.0 Rear Right
OFF Front Left
OFF Front Right
OFF Rear Left
OFF Rear Right
2.43 V front left [V]
2.45 V front right [V]
2.45 V rear [V]
99.0 Front Left
98.0 Front Right
34.0 Rear Left
52.0 Rear Right
OFF Front Left
OFF Front Right
OFF Rear Left
OFF Rear Right
2.45 V rear [V]
Monday,01,April,2019,16:28:37:54859
VCDS Version: 18.9.1.0 HEX-V2 CB: 0.4436.4
Dealer/Shop Name: Euro Tecnik Ltd
VIN: WAUZZZ4E97N010835 License Plate: SSDX 123
Mileage: 200330km-124479mi Repair Order: Jimmi A8
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 1E 28 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 6C 72 76
VIN: WAUZZZ4E97N010835 Mileage: 200330km-124479miles
0E-Media Player 1 -- Status: Malfunction 0010
Address 01: Engine Labels:. 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 HW: 4E1 907 560
Component: 4.2l V8/4V 0030
Revision: 71H16--- Serial number: AUX3Z0F9708724
Coding: 01060003190F0120
Shop #: WSC 63820 981 89739
VCID: 5F9A5548BB30F84FC77-800A
7 Faults Found:
008200 - Intake Manifold Flap; Bank 1
P2008 - 004 - Electrical Malfunction - MIL ON
Fault Status: 11100100
Mileage: 200339 km
Date: 2019.04.01
Time: 15:55:20
RPM: 635 /min
Load: 43.9 %
Temperature: 51.0°C
Temperature: 38.0°C
Absolute Pres.: 830.0 mbar
Voltage: 13.208 V
005495 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
Mileage: 200339 km
Date: 2019.04.01
Time: 15:55:20
RPM: 635 /min
Load: 43.9 %
Temperature: 51.0°C
Temperature: 38.0°C
Voltage: 13.081 V
001153 - Coolant Fan Control Circuit 2
P0481 - 004 - Electrical Malfunction
Mileage: 200339 km
Date: 2019.04.01
Time: 15:55:20
RPM: 635 /min
Load: 43.9 %
Temperature: 51.0°C
Temperature: 38.0°C
Voltage: 13.462 V
000872 - Camshaft Position Sensor B Bank 1 (G300)
P0368 - 001 - Signal too High - MIL ON
Fault Status: 11100001
Mileage: 200339 km
Date: 2019.04.01
Time: 15:55:21
RPM: 634 /min
Load: 44.3 %
Temperature: 51.0°C
Temperature: 38.0°C
Voltage: 12.573 V
000139 - Low Pressure Fuel System
P008B - 001 - Pressure too High
Fault Status: 01100001
Mileage: 200339 km
Date: 2019.04.01
Time: 15:55:24
RPM: 624 /min
Load: 43.9 %
Temperature: 52.0°C
Temperature: 38.0°C
Voltage: 13.462 V
012555 - Low Pressure Fuel regulation
P310B - 001 - Fuel Pressure Outside Specification - Intermittent
Fault Status: 00100001
Mileage: 200339 km
Date: 2019.04.01
Time: 15:55:24
RPM: 624 /min
Load: 43.9 %
Temperature: 52.0°C
Temperature: 38.0°C
Voltage: 13.081 V
000400 - Fuel Pressure Sensor (G247)
P0190 - 001 - Circuit Malfunction - MIL ON
Mileage: 200339 km
Date: 2019.04.01
Time: 16:08:19
Temperature: 107.0°C
Temperature: 46.0°C
Voltage: 12.319 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI RdW 0010
Revision: --H01--- Serial number: 4249228
Shop #: WSC 02313 785 00200
VCID: 231219B8D7D89CAFA3F-8076
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 221C1CBCC8C295A7A89-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F9708724
Coding: 0413184
Shop #: WSC 02311 785 00200
VCID: 58E87E54DE1E0F7786D-800C
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
VCID: 24101AA4D2D69B97DA5-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 731 Q HW: 4E0 035 729 A
Component: Interfacebox H43 1450
Revision: 00000000 Serial number: 347JJ067510031
Coding: 0000108
VCID: 2F3AE5888B1028CF377-807A
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000023423
Subsystem 3 - Serial number: 0127.10.060000000100010005ÿ
Subsystem 4 - Serial number: 010005ÿ
Reset counter: 131
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:02
Bin. Bits: 00000011
Bin. Bits: 0000000
Bin. Bits: 000
Bin. Bits: 00000000
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000107969
Coding: 0119505
VCID: 1C602244EAA6A357625-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO17102006065A000000000099ÿ†89
Subsystem 5 - Serial number: 000099ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO17102006065A00000000
Subsystem 7 - Serial number: 65A000000000085ÿ
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:01
00065 - Rear Left Footwell Heater (Z42)
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:02
Voltage: 13.10 V
00066 - Rear Right Footwell Heater (Z43)
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:02
Voltage: 13.10 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0143001
VCID: 3634D0EC744A1907741-8062
Subsystem 1 - Part No: 4E2 910 113 C
Component: Wischer WWS D3 H60 0440
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150573
Shop #: WSC 02313
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:52:55
Part No SW: 4E0 910 110 B HW: 4E0 035 110
Component: MP3-Changer H44 0350
Revision: 00044000 Serial number: AUZ5ZBF2020176
VCID: 176A3D681380C00F4F7-8042
02261 - Data Medium
014 - Defective
Fault Status: 01101110
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:58
Text: 00000000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 D HW: 4E0 959 655 H
Component: Airbag 9.41 H13 3710
Revision: 91H13371 Serial number: 0037P0G02X33
Coding: 0430707
VCID: 270A0DA8A3E0708FFF7-8072
Subsystem 1 - Serial number: 63328RB401B7595DT
Subsystem 2 - Serial number: 63428RB401B7597CV
Subsystem 3 - Serial number: 63528RB401B75979T
Subsystem 4 - Serial number: 63628RB401B758F4W
Subsystem 5 - Serial number: 637 RB4 8
Subsystem 6 - Serial number: 638 RB4 9
01738 - Crash Sensor for Front Airbag; Drivers Side (G283)
011 - Open Circuit - MIL ON
Fault Status: 11101011
Reset counter: 91
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:16
01739 - Crash Sensor for Front Airbag; Pass. Side (G284)
Reset counter: 91
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:16
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0112141
VCID: 659647A0996CA29F0DB-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 A HW: 4E0 920 901 A
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F9003266
Coding: 0032413
Shop #: WSC 12345 111 45725
VCID: 1E64284CFCBAB1478C1-804A
Reset counter: 131
Mileage: 200339 km
Date: 2019.04.01
Time: 16:08:21
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B06A16007C
Coding: F5F1DF7F70260E
VCID: 6C8032847A8693D7525-8038
Address 1E: Media Player 2 Labels: None
Part No SW: 4E0 910 121 HW: 4E0 035 121
Component: MD-Changer H42 0070
Revision: 00000001 Serial number: KE1059U7600167
VCID: 57EA7D68D300000F8F7-8002
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158 D
Component: KLIMA-STG. FOND 017 0230
Revision: 00000019 Serial number: 00000000047215
Coding: 0000000
VCID: 619E53B08D44CEBFF13-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0019910
Shop #: WSC 12233 123 45725
VCID: 28080E94AEFE7FF7F6D-807C
01437 - Control Position not Learned
Fault Status: 11100101
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:56:33
01400 - Suspension Level Control
Reset counter: 131
Mileage: 200339 km
Date: 2019.04.01
Time: 15:57:23
Component: Sitzmemory FS H02 0010
Coding: 4063338
Part No SW: 4E0 910 887 H HW: 4E0 919 887 B
Component: MNS JP H04 0570
Revision: 0000005S Serial number: AUZBZ7F0103870
VCID: 323CECFC98220527589-8066
Subsystem 1 - Part No: 4E1 910 336
Component: Interface Handy H08 0050
Subsystem 2 - Part No: 4F0 919 813 A
Component: Card reader H02 0080
Subsystem 3 - Part No: 4F0 035 503 B
Component: ETC-VICS-Ant. H01 0010
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H05 0090
Serial number: 00000626900048
Coding: 0036006
VCID: 1D662F40F1BCAA5F95B-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 802 D
Component: Türsteuer.FS BRM005 0180
Coding: 0032750
VCID: 201816B4C6CE87B7BED-8074
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040610240091
Coding: 0004840
VCID: 2A0CF49CB0F24DE7E09-807E
Component: Heckdeckel P14H06 0070
00984 - Left Tail Light (M4)
Reset counter: 91
Mileage: 193821 km
Date: 2017.12.23
Time: 15:52:01
00985 - Right Tail Light (M2)
Reset counter: 91
Mileage: 190097 km
Date: 2017.10.16
Time: 20:29:32
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 64
Mileage: 191603 km
Date: 2017.11.11
Time: 06:29:54
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 Q HW: 4E0 035 223 G
Component: DSP-High D3 H03 0110
Revision: PROD_01 Serial number: 00000000000654
Coding: 0000047
VCID: 2B02F198BF0854EF1BF-807E
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000096655
Coding: 0010101
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Reset counter: 91
Mileage: 200336 km
Date: 2019.04.01
Time: 16:01:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Reset counter: 91
Mileage: 200336 km
Date: 2019.04.01
Time: 16:01:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E2 959 801 D
Component: Türsteuer.BF BRM005 0180
Coding: 0032750
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000923
Shop #: WSC 04026 002 1048576
VCID: 1F1A1548FBB0B84F877-804A
02596 - Rear Brake Pads Worn
Fault Status: 01111000
Reset counter: 69
Voltage: 8.70 V
Count: 61
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000018
VCID: 290E0B90B5F446FFE93-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Part No SW: 4E0 910 541 N HW: 4E0 035 541 R
Component: TUNER Japan H42 0180
Revision: 00000000 Serial number: 325JM067528011
Coding: 0000003
00856 - Radio Antenna
Fault Frequency: 28
Reset counter: 90
Mileage: 193821 km
Date: 2017.12.23
Time: 14:17:13
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 F HW: 4E0 919 146 C
Component: TV analog TUNER H15 0290
Revision: 00000042 Serial number: 00000000001248
Coding: 0000016
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000021973
Shop #: WSC 07130 981 60669
Component: von VA0 2610110346
Coding: 344630393135313035442056413032363130313130333436
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 D
Component: Türsteuer.HL BRM005 0180
Coding: 0032750
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J69104Y
Coding: 1120502
VCID: 5CE06244AA26E357A25-8008
02283 - Video Connection to Output [End Unit]
Fault Status: 00100111
Reset counter: 90
Mileage: 200339 km
Date: 2019.04.01
Time: 15:57:51
Reverse ON
Count: 4
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 D
Component: Türsteuer.HR BRM005 0180
Coding: 0032750
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08730629706264
Coding: 0221008
End----------(Elapsed Time: 02:19, VBatt start/end: 13.1V/13.7V)-----------
