Results 11 to 20 of 25
Thread: Programming new battery for 2011 Audi A4
    Quote Originally Posted by PinoySaMI View Post
    Just the SN # and not the PN#?
    Yes, if the battery's specifications are the same (and it appears they are), then just changing a single digit in the serial number will tell the car that you've installed a new battery.
  2. #12
    Jul 2014
    MI
    I did change just one digit of the serial #. From original stored value “8K0915105D. MLA 101124OA1T”, I changed the serial# to 101125OA1T or 101124OA2T but neither changes work. The previous value still came up when I hit TEST.
    One thing I took note is that after the first change in the serial #, when I exit and went back to try again...the stored value block is empty.
    Just to clarify. The step I took were;
    Select
    Common
    19-CAN Gateway
    Function
    Cloud function
    Adaptation-10
    Battery Information/Replacement-4
  3. #13
    OK, we've been able confirm that there's something in VCDS-Mobile that's not working quite correctly with this.
    If you want an immediate fix, beg/borrow/steal a PC, install VCDS, and use that; it will work. If you're unable or unwilling to do that, I'm confident we'll get a fix for VCDS-Mobile implemented in the foreseeable future.
  4. #14
    Jul 2014
    MI
    I have a Mac laptop. Is VCDS already compatible with Mac?
  5. #15
    VCDS is Windows only, so you need to use something like Boot Camp.
  6. Likes Uwe liked this post
  7. #16
    Jul 2014
    MI
    So I'll just use my VCDS mobile and wired it to a Windows laptop with VCDS?
  8. #17
    Your HEX-NET can be user with the full (Windows) version of VCDS via USB or via WiFi.
  9. Likes PetrolDave liked this post
  10. #18
    Ok this should be fixed now in VCDS-Cloud. Feel free to try this again with VCDS-Mobile, if you haven't already done it with the PC software.
  11. Likes Eric, Uwe liked this post
  12. #19
    Jul 2014
    MI
    Had the battery information changed using a windows based VCDS. Thank you.
  13. #20
    Jul 2014
    MI
    Quote Originally Posted by Shaun View Post
    I didn’t see this post right away, I already changed the battery information using a windows based VCDS but will try it with my wireless hex-net.
  14. Likes Uwe liked this post
