Results 1 to 6 of 6
Thread: 2013 Audi Allroad B8 - intermittent hard start
    Sep 2016
    US
    The past two days I've had three intermittent occurrences of a hard start while all other starts were normal, on a B8 2013 Audi Allroad.
    1) Press Ignition Button : car fires and immediately stalls
    2) Press Ignition Button Second Time: car continually cranks for ~5s before starting, after which it seems to run normally
    I ran a scan and received the following. I'm looking at fault 4106 - Bank 1; System too Rich at Idle, since it gives a date when it occurred, although this wasn't the date of the most recent occurrence for some reason. I was thinking the N80 valve might be faulty but wasn't sure if that could lead to an intermittent hard start I'm experiencing. Any help is appreciated.
    Sunday,31,March,2019,16:07:42:02305
    VIN: WA1UFAFL0DA069272   License Plate:
    Mileage: 83230km-51716mi   Repair Order:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
              6C 6D 72
    VIN: WA1UFAFL0DA069272   Mileage: 83230km-51716miles
    Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0008
       Revision: ECH09---
       Coding: 722A0013242600062000
       Shop #: WSC 54964 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
       ROD: EV_ECM20TFS0118K5907115F.rod
       VCID: 3537DC2F05C1E6BF7DB-8060
              P0456 00 [096] - Very Small Leak Detected
              P2188 00 [096] - -
                        Mileage: 83212 km
                        Date: 2019.03.29
                        Time: 10:48:43
                        Engine speed: 794.00 /min
                        Normed load value: 20.4 %
                        Coolant temperature: 85 °C
                        Intake air temperature: 54 °C
                        Voltage terminal 30: 14.182 V
                        Median injection timing: 0.990 ms
       Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
       Component: 0BK 20TFSIUSA H16 1006
       Revision: --H16---
       Coding: 000002
       VCID: 74B1212B4E3BBFB78A5-8020
       Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
       Coding: 0E1D18
       Shop #: WSC 06334 000 00000
       VCID: 4CC199CB76CB8777325-8018
       Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H10 0602
       Coding: 0D820000000000000000
       Shop #: WSC 06335 000 00000
       VCID: 035372F71B15880F83F-8056
       Serial number: 2312000100185014
       Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
       Revision: C1000000    Serial number: 01110520121266
       Coding: 6480208000
       VCID: 3333E2370B35F88F53F-8066
       Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
       Component: BCM1 1.0      H14 0103
       Revision: 08014001    Serial number: 00000030437701
       Coding: 26000091863CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
       Shop #: WSC 08185 444 103375
       VCID: 78A9151B52D3DBD7A6D-802C
       Component: WWS 110512  H07 0070
       Serial number: SWF12050115803
       Coding: 00FD11
       Serial number: 20271225
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000305120151
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R1NZ702
       Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 2908C126000000000001
       Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
       Component: AirbagVW-AU10 H46 0610
       Serial number: 003KEDA014G
       Coding: 303844354A32303030304A55304C384B3053
       Shop #: WSC 00040 002 1048576
       VCID: 47CBA6E76F2D642F1F7-8012
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R1200008MMA
       Serial number: 6334MSME6E514072C
       Serial number: 6344MSME6F222D3BS
       Serial number: 6352QSME441653628
       Serial number: 6362QSME4F15014CK
       Serial number: 63732SME6D14325A0
       Serial number: 63832SME4C145162Z
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20120514001084
       Coding: 000017
       VCID: 4FFB8EC787DDBC6F577-801A
       Component: E221 - MFL  H03 0003
       Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
       Component: KOMBIINSTR.   H35 0540
       Revision: 00000000    Serial number: NTC23475D
       Coding: 8B3629020301D705020000
       VCID: 323DE733F42FF187589-8066
       Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H10 0025
       Revision: 1Y030014    Serial number: 1441Y125030368
       Coding: 00C303FF00
       VCID: 3FDBBE07377D2CEFA77-806A
       Serial number: 8175957401
    00384 - Optical Databus
                        Fault Status: 00101011
                        Reset counter: 173
                        Mileage: 82983 km
                        Date: 2019.03.24
                        Time: 11:57:15
                        Bin. Bits:    10000
                        Voltage: 11.90 V
                        Count: 11
                        Bin. Bits:    00000
                000 -  -  - Intermittent
                        Reset counter: 174
                        Mileage: 83002 km
                        Date: 2019.03.24
                        Time: 15:14:24
                        Bin. Bits:    10000
                        Voltage: 11.60 V
                        Count: 10
       Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000029145580
       Coding: 00581B00000000000000
       VCID: 3B23CA17236530CF8BF-806E
       Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
       Component: TSG FA        H02 0506
       Revision:             Serial number: 0000029908343
       Coding: 011C13205E00410001
       VCID: 4DC794CF8DD18E7F25B-8018
       Component: RCEPS         H36 0507
       Revision: 00001000    Serial number: 0020526803
       Coding: 100000000001
       Shop #: WSC 08185 444 122181
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3431E12B0EBBFFB74A5-8060
       Revision: 00002001    Serial number: 0176517259
       Coding: 0126023A20BA709580B0023200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000519778
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS150  H08 0043
       Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J394 PS240  H08 0043
       Component: DSP Prem      H04 0030
       Revision: 00004001    Serial number: 94814003201301
       VCID: 2D07F44FED11AE7F05B-8078
       Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
       Component: TSG BF        H02 0506
       Revision:             Serial number: 0000029772602
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 00000000048809
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3829D51B12D31BD766D-806C
       Part No SW: 4G0 035 080 G    HW: 4G0 035 080
       Component: Radio U SIRIU H60 0133
       Revision: AB001007    Serial number: 158H10E7505942
       Coding: 020007010000000001
       Shop #: WSC 01238 002 1048576
       VCID: 221D1773A4CF6107A89-8076
       Part No SW: 8R1 035 746 G    HW: 8R1 035 746 A
       Component: H-BNT-NA      H42 0901
       Revision: --------    Serial number: 096E 0C7510836
       Coding: 010200050006A1EF41028B4E00000403140000000000000000
       Component: NAR 2011  0505
       Component: DU7 High  H41 0104
       Serial number: A130EG0CS169387
       Serial number: 00000001153298
       Component: CD-Database  3371
    02067 - Optical Databus; Unpermitted Wake-Up Request
                        Reset counter: 173
                        Mileage: 82983 km
                        Date: 2019.03.24
                        Time: 11:47:26
                        Voltage: 11.90 V
    01043 - Control Module; Incorrect Software Version
                        Reset counter: 152
                        Mileage: 83234 km
                        Date: 2019.03.30
                        Time: 15:42:55
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00000001
       Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
       Revision:             Serial number: 0000030049731
       Coding: 010C13204000210001
       VCID: 43D3B2F75B95480FC3F-8016
       Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
       Component: J772__Rearview      0140
       Revision: --H06---    Serial number: 525PA8-J229325
       Coding: 1000007
       VCID: 392FD01F255902DF993-806C
       Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
       Revision: --------    Serial number: 8K9827851A
       VCID: 3C21C90B266B37F7825-8068
       Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
       Serial number: 8K9827852A
       Revision:             Serial number: 0000030050712
    End----(Elapsed Time: 02:08, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
    Car is under warranty still?
    Vehicle Identification No. WA1UFAFL0DA069272
    Model Audi A4 Av. Allroad
    quattro 2.0
    A4AR
    Date of production 23.05.2012
    Year 2013
    Sales type 8KH52A
    Engine Code CPMA
    Transmission Code NGR
    Emission standard 7GB Emission standard ULEV 2
    Part No SW: 8K5 907 115 F HW: 8K2 907 115 L<<<<<<<<<<<<<<<<<<<<<< Firmware appears to be up to date!
    Revision: ECH09---
    P2188 00 [096] - -
    Mileage: 83212 km
    Date: 2019.03.29
    Time: 10:48:43
    OP:
    Can you please post the following MODE's of the OBD2?
    In VCDS MODE's : 1, 3, 7 & 9.
    Absolutely check N80 & sump for gasoline contamination from injector leak down or HPP failure too!
    Is car modified in anyway?
    Did you JPPSG?
    https://forums.ross-tech.com/showthr...l=1#post156577
    You may find this thread link helpful......
    https://forums.ross-tech.com/showthr...ou!-Air-leaks!
    Thank you
  3. Likes DrPeter liked this post
    Sep 2016
    US
    Hi! Car is not under warranty. It is stock w/ no mods. Here are the ODBII modes:
    Tuesday,02,April,2019,21:31:08:02305
    VCDS Release 18.9.1 (x64):  Generic OBD2
    Mode 01 - PID 01 : Readiness  --  Address 7E8
    Number of DTCs stored: 0  --  MIL Status: MIL OFF
    Misfire monitoring:  Passed
    Fuel System:  Passed
    Comprehensive Components:  Passed
    Catalyst monitoring:  Failed or Incomplete
    Heated catalyst monitoring: Not installed.
    Evaporative system monitoring:  Failed or Incomplete
    Secondary air system monitoring: Not installed.
    A/C system refrigerant monitoring: Not installed.
    Oxygen sensor monitoring:  Failed or Incomplete
    Oxygen sensor heater monitoring:  Failed or Incomplete
    Exhaust Gas Recirculation:  Failed or Incomplete
    Tuesday,02,April,2019,21:31:23:02305
    Mode 03: Emission related fault codes
    Address 7E8: No fault code found.
    Address 7E9: No fault code found.
    Tuesday,02,April,2019,21:31:36:02305
    Mode 07: Pending emission related fault codes
    Tuesday,02,April,2019,21:31:54:02305
    Mode 9 : Calibration Identification
    Type 02 - VIN : WA1UFAFL0DA069272 (Address E8)
    Type 04 - Calibration ID : 8K5115F 0008AVBB (Address E8)
    Type 04 - Calibration ID : 8K1158  100622   (Address E9)
    Type 06 - Calibration Verification Number : 511D777D (Address E8)
    Type 06 - Calibration Verification Number : 59BB2F44 (Address E9)
    Type 08 - In-use performance tracking :
        OBD Monitoring Conditions Encountered count : 359
        Ignition cycle count : 1964
        Conditions completion count / Specified conditions encountered count
             Catalyst monitor bank 1 : 684 / 353
             Catalyst monitor bank 2 : 0 / 0
             O2 Sensor monitor bank 1 : 588 / 359
             O2 Sensor monitor bank 2 : 0 / 0
             EGR-VVT monitor : 1524 / 359
             AIR monitor : 0 / 0
             EVAP monitor : 55 / 53
             Secondary O2 Sensor monitor bank 1 : 531 / 353
             Secondary O2 Sensor monitor bank 2 : 0 / 0
    Type 0A - Controller Name : ECM-EngineControl (Address E8)
    Type 0A - Controller Name : TCM-TransmisCtrl (Address E9)
    Tuesday,02,April,2019,21:33:41:02305
    Mode 1:Read Data
    06:Short Term Trim - Bank 1     0.0 %
    07:Long Term Trim - Bank 1     4.7 %
    15:Bank 1 Sensor 2 Status     0.455 V
    34:Bank 1 Sensor 1 Status     1.013 Lambda  0.016 mA
    I think the N80 and PCV investigation would be a good start.
    Sep 2016
    US
    Will do. Thanks much for the insight and advice!
    Yeah maybe a siphon effect gong on with N80 so observe if this happens at all during fill ups with fuel.
    Verify sump for fuel from HPP or fuel injector leak by or down to oil.
  8. Likes Uwe liked this post
