Results 1 to 3 of 3
Thread: VW Tiguan 2.0TDI MY2019
    Võru, Estonia
    Sunday,17,March,2019,17:20:09:21782
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4502.4
    Dealer/Shop Name: LeVWFreaks.eu
    VIN: WVGZZZ5NZKW   License Plate: TIGUAN EGON
    Mileage: 6433km-3997mi   Repair Order:
    Chassis Type: 5N-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 18 19 22 29 39 42 44 4B 52 5F
              6C 6D 75 A5 D6 D7
    VIN: WVGZZZ5NZKW   Mileage: 6433km-3997miles
    Address 01: Engine (J623-DFHA)       Labels: None
       Part No SW: 04L 906 026 RA    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 6580
       Revision: B4H25---
       Coding: 0125003A03661D083000
       ASAM Dataset: EV_ECM20TDI01104L906026RA 004004
       ROD: EV_ECM20TDI01104L906026RA_VW37.rod
       VCID: FAB879D77D8ACF9A13-80AE
    15733 - SCR NOx Catalyst Bank 1
              P20EE 00 [096] - Efficiency too Low
    5923 - Exhaust Pressure Control Valve
              P047F 00 [032] - Stuck Open
       Part No SW: 0DL 300 013 A    HW: 0GC 927 711 G
       Component: GSG DQ500     H06 3004
       Revision: 00H06V07
       ROD: EV_TCMDQ500021.rod
       VCID: A81C739FD3A68D0A35-80FC
       Part No SW: 5Q0 614 517 EF    HW: 5Q0 614 517 BP
       Component: ESC           H35 0107
       Revision: 00000000    Serial number: 62978000002021
       Coding: 0AEE6B9A50230B744778070362C44950D60AD0E2E046927538625078D22A4A0B00402F641A1B13111435351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD: EV_Brake1UDSContiMK100IPB_038_VW37.rod
       VCID: F9BA66DB788CC4821A-80AC
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0498973485
       Coding: 132C2C0723
       VCID: C3C6C4334AC04E5200-8096
       Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
       Component: GEB.F.Heckoef  H17 0906
       Serial number: 11284826
       Part No SW: 5NA 907 044 P    HW: 5NA 907 044 P
       Component: AC Automat    H35 4301
       Revision: 20K09000    Serial number: 00000B01135733
       Coding: 0002010420411101110510000010112A
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X_002_VW37.rod
       VCID: CCD4EF0F679E812AF1-8098
       Subsystem 2 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
       Component: E265KlimaHeck  H02 0201
       Serial number:       04031501850571
       Part No SW: 5Q0 937 084 DC    HW: 5Q0 937 084 CF
       Component: BCM MQBAB M+  H38 0273
       Serial number: 00001832002658
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: FCB47FCF77BEF1AA01-80A8
       Subsystem 1 - Part No SW: 5NB 955 119 A    HW: 5NB 955 119 A  Labels: 1KX-955-119.CLB
       Component: 326 LL 181009  033 0372
       Serial number: 00000001810040304911
       Component: RLHS  052 0107
       Serial number: S4Y18M11D15H14M59S17
       Coding: 00A8DD
       Serial number: 000000000ZY182843XE6
       Serial number: 00000000000045442975
       Steering Column Switch:
       Subsystem 5 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
       Component: Lenks.Modul  H03 0170
       Serial number: 0100241020180C301527
    558356 - Databus
              [Gateway_73 Datenbus empfangener Fehlerwert]
                        Reset counter: 123
                        Mileage: 2867 km
                        Date: 2019.02.15
                        Time: 17:45:12
       Part No SW: 3Q0 919 298 C    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0038
       Serial number: 002409187498050
       Coding: 0231563851
       ASAM Dataset: EV_EPHBO2CVW3260000 010019
       ROD: EV_EPHBO2CVW3260000.rod
       VCID: BD32B2CB2C2438A276-80E8
       Part No SW: 2Q0 907 572 Q    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0342
       Coding: 320467C358FF8728749C810580408700000000000000000000
       ASAM Dataset: EV_ACCMRRCONTIVW376 003015
       ROD: EV_ACCMRRCONTIVW376.rod
       VCID: C2C8C13755DA475A0B-8096
    196741 - Sensor for Automatic Distance Control
              [FCTSEN_BLOCKAGE]
                        Fault Frequency: 7
                        Reset counter: 133
                        Mileage: 1602 km
                        Date: 2019.02.04
                        Time: 10:07:33
                        Voltage terminal 15: 14.8 V
                        Control Module temperature: 18 °C
                        Velocity_vehicle_reference: 3.23 m/s
       Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
       Component: AirbagVW21    006 0403
       Serial number: 003FNR4RUB8J
       Coding: 98CCC0C00C0000005C5400CF004800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 936634737A201ED2F0-80C6
       Subsystem 1 - Part No SW: -----------    HW: 480 001 411 18
       Serial number: 357000000009EB34943T
       Subsystem 2 - Part No SW: -----------    HW: 480 001 611 18
       Serial number: 35800000000F0691D53P
       Subsystem 3 - Part No SW: -----------    HW: 480 401 411 18
       Component: SideSensor_Dr  003 6149
       Serial number: 3510001C32BC6C660284
       Subsystem 4 - Part No SW: -----------    HW: 480 401 411 18
       Component: SideSensor_Pr  003 6149
       Serial number: 35200019D2C6D4B5931D
       Subsystem 5 - Part No SW: -----------    HW: 480 401 311 18
       Component: FrontSensor_D  003 6149
       Serial number: 3550001AD2C62406631-
       Pedestrian Protection Driver:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 411 18
       Component: PedP_Sensor_D  003 6149
       Serial number: 2280001C72DA1EE2733F
       Subsystem 7 - Part No SW: -----------    HW: 480 401 411 18
       Component: PedP_Sensor_P  003 6149
       Serial number: 2290001C72DA1EE2924I
       Pedestrian Protection Center:
       Subsystem 8 - Part No SW: -----------    HW: 480 401 411 18
       Component: PedP_Sensor_C  003 6149
       Serial number: 2300001C52DA1EE6D5BQ
       Subsystem 9 - Part No SW: -----------    HW: 480 001 311 18
       Serial number: I0M000000001F5B0153
       Subsystem 10 - Part No SW: -----------    HW: 480 001 311 18
       Serial number: I0N000000002E401153S
       Part No SW: 5NA 920 790 D    HW: 5NA 920 790 D
       Component: KOMBI         506 1691
       Coding: 04A400086F840008018863031001000880000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001026
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
       Part No SW: 5Q0 963 272 J    HW: 5Q0 963 272 J
       Component: STH-MQB       008 0080
       Coding: 9309
       ASAM Dataset: EV_AuxilParkiHeateWOS 002018
       Component: R64 D208L  004 0402
       Serial number: 00000000000000588580
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4366
       Revision: --------    Serial number: 0008731336
       Coding: 030500045F087300FB17225A1A0F00010001070000000000000000000000
       ROD: EV_GatewNF_VW37.rod
       VCID: EE90458731C2933ABF-80BA
       Component: 0-00-00-00-00
       Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
       Component: E221__MFL-TAT  H06 0025
       Serial number: 3041806303900625FH2B
       Coding: 2D0000
       Serial number: 2848349604
    66304 - Databus
              U1124 00 [009] - Additional Installations Detected
              [Mehrverbau CAN]
                        Reset counter: 114
                        Mileage: 7 km
                        Date: 2019.01.16
                        Time: 14:41:52
                        Supply voltage: Terminal 30: 12.0 V
                        Terminal 15: On
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00012.10.18
       Coding: 0101
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: C5C2DA2B44F470622E-8090
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0287
       Serial number: YE007RHM26174
       Coding: 003F1A20D000040000001000
       VCID: C4C4C72F4FCE496A39-8090
       Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_DRV  006 0007
       Serial number: 00000000000025359543
       Part No SW: 5QF 909 144 B    HW: 5QF 909 144 A
       Component: EPS_MQB_ZFLS  507 5582
       Coding: 931F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: C9DAD61B68EC9402CA-809C
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 09111810800120
       Coding: 00000005090008CA01104F010A0000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW37.rod
       VCID: B522AAEB1414E0E2BE-80E0
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0287
       Serial number: YE007RHN22113
       Coding: 003F1020DC00040000001000
       Subsystem 1 - Part No SW: 5Q0 959 812 E    HW: 5Q0 959 812 E  Labels: 5QX-959-81X-V1.CLB
       Component: FOND_FHSG_PSG  006 0007
       Serial number: 00000000000025143031
       Coding: 090000
       Part No SW: 5NA 035 043 D    HW: 5NA 035 043
       Component: MU-H-N-EU     H55 1367
       Serial number: A848K0JS064815
       Coding: 02730601FF0000005111000100080A001F0100E4012004009E
       VCID: B73EA0E30E1812F2AC-80E2
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H52 9130
       Serial number: VWZ6ZJV3192068
       Subsystem 2 - Part No SW: V03 959 800 QT    HW: -----------
       Component: ECE 2018/2019  --- 0169
       Component: Gracenote2  --- 1017
    2562 - Navigation System
              B126C F0 [008] - Navigation Database Faulty
                        Reset counter: 116
                        Mileage: 4257 km
                        Date: 2019.02.28
                        Time: 22:07:06
                        Voltage terminal 30: 12.7 V
       Component: RVC Compact   H15 0231
       Coding: 0123060122002017000040
       VCID: B93AA6DB380C04825A-80EC
       Part No SW: 5Q0 959 107 Q    HW: 5Q0 959 107 C
       Component: HDSG-Modul    H12 0266
       Revision: --------    Serial number: 32192275300000
       Coding: 0A28
       ASAM Dataset: EV_DeckLidCONTIAU736 001016
       VCID: C6C0DD2779F27B7A27-8092
       Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Component: OCULowMQBLGE  H19 0824
       Revision: --------
       Coding: 02230601EA42180D3F1CBE020045400382E708
       ASAM Dataset: EV_OCULowMQBLGE 004049
       ROD: EV_OCULowMQBLGE_004_VW37.rod
       Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H09 0272
       Serial number: 01081815K22034
       Coding: 000307060000040100222344C150A90094000E200040
       VCID: BC34BFCF373E31AA41-80E8
    1275 - Unknown Error Code
              B182E F0 [008] - Unknown Error Elaboration
                        Reset counter: 95
                        Mileage: 2720 km
                        Date: 2019.02.14
                        Time: 18:14:04
                        Control Module temperature: 23 °C
                        Outside air temperature: 0.5 °C
                        Vehicle speed: 28.67 km/h
                        System run time: 49.4 s
                        Voltage terminal 15: 14.3 V
                        mid: 01 63
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
       Component: LED1L         H07 0008
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 804C0B3F1B56954A5D-80D4
       Component: LED1R         H07 0008
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----------(Elapsed Time: 02:27, VBatt start/end: 13.3V/13.4V)-----------
    What's up with this Addition Installation detected fault in Can-GW. I have another MY19 scan where same thing happes. Also this my19 GW seems to have some weird identification for alternator:
    https://forums.ross-tech.com/showthr...Y2019&p=160258
    A5 fault is also missing description:
    ADPmaps:
    01
    ;SW:04L-906-026-RA   HW:04L-907-309-P ---  Engine
    ;Component:R4 2.0l TDI   H25 6580, Coding:0125003A03661D083000
    ;EV_ECM20TDI01104L906026RA,004004,EV_ECM20TDI01104L906026RA_VW37.rod
    ;Sunday,17,March,2019,17:47:45:21782
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: FAB879D77D8ACF9A13-80AE
    IDE00263-Injector 1 correction value,8SH3GEC ,7
    IDE00264-Injector 2 correction value,CATSAWA ,7
    IDE00265-Injector 3 correction value,AAAIAS8 ,7
    IDE00266-Injector 4 correction value,7ZRIDI8 ,7
    IDE01096-Particulate Filter Statistics,0 ,1
    IDE01711-Blocking of particle filter regeneration,not active ,1
    IDE01945-Engine run-in oil pressure,not active ,1
    IDE02248-Individually adjustable maximum speed limit,300.0 km/h,2
    IDE02332-Deactivate production mode,00 00 00 ,3
    IDE02637-Adaptation for metering quantity measurement,4 ,1
    IDE04158-Activation of start-stop function,active ,1
    IDE04617-Protective function,OFF ,1
    IDE07903-Adaptation of ash mass,2.09 g,2
    IDE08287-Bleeding of coolant circuit,not active ,1
    IDE10309-Adaptation of oxidation catalytic converter ageing,148608 s,2
    ENG105853-MAS04051-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation for precontrol and damping,Not blocked ,1
    ENG105853-MAS04052-Disable_Adaption_Of_Turbo_Charger_Management-Adaptation of pressure sensor,Not blocked ,1
    Elapsed Time: 00:04
    02
    ;SW:0DL-300-013-A   HW:0GC-927-711-G ---  Auto Trans
    ;Component:GSG DQ500     H06 3004, Coding:0014
    ;EV_TCMDQ500021,001001,EV_TCMDQ500021.rod
    ;Sunday,17,March,2019,17:48:34:21782
    ;VCID: A81C739FD3A68D0A35-80FC
    IDE00001-Production mode,not activated ,3
    Elapsed Time: 00:01
    03
    ;SW:5Q0-614-517-EF   HW:5Q0-614-517-BP ---  ABS Brakes
    ;Component:ESC           H35 0107, Coding:0AEE6B9A50230B744778070362C44950D60AD0E2E046927538625078D22A4A0B00402F641A1B13111435351919323200
    ;EV_Brake1UDSContiMK100IPB,038007,EV_Brake1UDSContiMK100IPB_038_VW37.rod
    ;Sunday,17,March,2019,17:48:56:21782
    ;VCID: F9BA66DB788CC4821A-80AC
    IDE00001-Production mode,not active ,3
    IDE00252-Brake system vacuum pump,5 ,1
    IDE00820-Activating and deactivating all development messages,0 ,1
    IDE01763-Dimming,activated ,1
    IDE02332-Deactivate production mode,Deactivating ,3
    IDE03493-Driver door status,activated ,1
    IDE03659-Roller test bench mode,Manual activation: possible ,1
    IDE04456-Brake disk drying,Medium ,1
    IDE04508-Hydraulic brake booster,8 ,1
    IDE04643-Overboost in brake system,activated ,1
    IDE04645-Electromechanical parking brake,not activated ,1
    IDE04774-Vehicle and trailer stabilization,not activated ,1
    IDE04871-Dynamic starting assist,normal ,1
    IDE04939-Tire pressure monitoring display,2 ,1
    IDE04944-Brake pedal evaluation,activated ,1
    IDE04949-Engine drag torque control,activated ,1
    IDE04951-Brake booster,4 ,1
    IDE04952-Braking torque boost for distance regulation,3 ,1
    IDE05055-Hydraulic brake assistant,normal ,1
    IDE05057-Brake prefill,activated ,1
    IDE05161-Straight ahead brake stabilization,activated ,1
    IDE05263-AUTO HOLD functionality,not activated ,1
    IDE05264-AUTO HOLD increase threshold: reduced tensioning force,0 %,1
    IDE05265-AUTO HOLD increase threshold: full tensioning force,10 %,1
    IDE05286-Expanded electronic differential lock,Standard ,1
    IDE05711-Automatic application during engine stalling,activated ,1
    IDE06137-IDE04772-Monitoring of functional lights-Indicator light in the button for electromech. parking brake,7 ,2
    IDE06137-IDE05333-Monitoring of functional lights-Indicator light in AUTO HOLD button,7 ,2
    IDE06139-AUTO HOLD slippage recognition,activated ,1
    IDE06505-Electromechanical parking brake: delay level,6 ,1
    IDE07006-Tire pressure monitoring display: tire selection,2 ,1
    IDE07292-Brake pre-filling,not completed successfully ,1
    IDE07565-ABS in lower speed range,activated ,1
    IDE07848-Thresholds for brake performance,activated ,1
    IDE12030-Rough road optimization,activated ,1
    MAS00122-Electronic Stability Program,not activated ,1
    MAS00970-Running manufacturer number,activated ,1
    MAS01180-AUTO HOLD functional status,Last setting ,1
    MAS01299-Offroad,0 ,1
    MAS02080-XCP calibration protocol,not activated ,1
    MAS02138-Hill-start assistant,normal ,1
    MAS02666-Seat belt buckle scan,activated ,1
    MAS09008-MAS00988-Plausibility check-Reverse gear,activated ,3
    MAS09008-MAS09009-Plausibility check-Neutral gear sensor,activated ,3
    MAS09008-MAS10668-Plausibility check-Clutch movement,activated ,3
    MAS11606-Electromechanical parking brake: emergency braking,activated ,1
    ENG130301-Developer_Function_121,not activated ,1
    ENG122844-ENG101574-dimming_characteristic_1-X1,0 ,12
    ENG122844-ENG99557-dimming_characteristic_1-X2,10 ,12
    ENG122844-ENG102140-dimming_characteristic_1-X3,50 ,12
    ENG122844-ENG102936-dimming_characteristic_1-X4,100 ,12
    ENG122844-ENG103548-dimming_characteristic_1-X5,220 ,12
    ENG122844-ENG113992-dimming_characteristic_1-X6,253 ,12
    ENG122844-ENG99777-dimming_characteristic_1-Y1,6 ,12
    ENG122844-ENG100480-dimming_characteristic_1-Y2,6 ,12
    ENG122844-ENG100773-dimming_characteristic_1-Y3,8 ,12
    ENG122844-ENG100631-dimming_characteristic_1-Y4,12 ,12
    ENG122844-ENG102174-dimming_characteristic_1-Y5,80 ,12
    ENG122844-ENG113993-dimming_characteristic_1-Y6,100 ,12
    ENG122845-ENG101574-dimming_characteristic_2-X1,0 ,12
    ENG122845-ENG99557-dimming_characteristic_2-X2,10 ,12
    ENG122845-ENG102140-dimming_characteristic_2-X3,50 ,12
    ENG122845-ENG102936-dimming_characteristic_2-X4,100 ,12
    ENG122845-ENG103548-dimming_characteristic_2-X5,220 ,12
    ENG122845-ENG113992-dimming_characteristic_2-X6,253 ,12
    ENG122845-ENG99777-dimming_characteristic_2-Y1,6 ,12
    ENG122845-ENG100480-dimming_characteristic_2-Y2,6 ,12
    ENG122845-ENG100773-dimming_characteristic_2-Y3,8 ,12
    ENG122845-ENG100631-dimming_characteristic_2-Y4,12 ,12
    ENG122845-ENG102174-dimming_characteristic_2-Y5,80 ,12
    ENG122845-ENG113993-dimming_characteristic_2-Y6,100 ,12
    Elapsed Time: 00:19
    05
    ;SW:3Q0-959-435-L   HW:3Q0-959-435-L ---  Acc/Start Auth.
    ;Component:VWKESSYMQB    037 1204, Coding:132C2C0723
    ;EV_KessyHellaMQBAB,004046,EV_KessyHellaMQBAB_004_VW37.rod
    ;Sunday,17,March,2019,17:49:45:21782
    ;VCID: C3C6C4334AC04E5200-8096
    IDE00001-MAS12708-Production mode-Deactivation of automatic shutdowns of terminal 15,not active ,3
    IDE00001-MAS12709-Production mode-Deactivation of automatic rear lid opening,not active ,3
    IDE00001-MAS12710-Production mode-Deactivation of terminal 50 request,not active ,3
    IDE03251-Stop release for start-stop function,According to function requirements ,1
    IDE04159-Deactivation of start-stop function,not active ,1
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    IDE09735-CU tailgate opener: sensor 1: threshold value 1,69 ,1
    IDE09736-CU tailgate opener: sensor 1: threshold value 2,16 ,1
    IDE09737-CU tailgate opener: sensor 1: threshold value 3,16 ,1
    IDE09738-CU tailgate opener: sensor 1: threshold value 4,16 ,1
    IDE09739-CU tailgate opener: sensor 1: threshold value 5,16 ,1
    IDE09740-CU tailgate opener: sensor 2: threshold value 1,2 ,1
    IDE09741-CU tailgate opener: sensor 2: threshold value 2,31 ,1
    IDE09742-CU tailgate opener: sensor 2: threshold value 3,2 ,1
    IDE09743-CU tailgate opener: sensor 2: threshold value 4,31 ,1
    IDE09744-CU tailgate opener: sensor 2: threshold value 5,224 ,1
    IDE09745-CU tailgate opener: sensor 1: timer value 1,170 ,1
    IDE09746-CU tailgate opener: sensor 1: timer value 2,0 ,1
    IDE09747-CU tailgate opener: sensor 1: timer value 3,9 ,1
    IDE09748-CU tailgate opener: sensor 1: timer value 4,34 ,1
    IDE09749-CU tailgate opener: sensor 1: timer value 5,34 ,1
    IDE09750-CU tailgate opener: sensor 2: timer value 1,11 ,1
    IDE09751-CU tailgate opener: sensor 2: timer value 2,165 ,1
    IDE09752-CU tailgate opener: sensor 2: timer value 3,147 ,1
    IDE09753-CU tailgate opener: sensor 2: timer value 4,204 ,1
    IDE09754-CU tailgate opener: sensor 2: timer value 5,24 ,1
    IDE09755-CU tailgate opener: sensor 1: burst length,16 ,1
    IDE09756-CU tailgate opener: sensor 1: active screening,16 ,1
    IDE09757-CU tailgate opener: sensor 2: burst length,2 ,1
    IDE09758-CU tailgate opener: sensor 2: active screening,31 ,1
    IDE09759-CU for tailgate opener: reset all counters,Unknown (224),1
    IDE09760-CU for tailgate opener: check sum,170 ,1
    IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,2 ,1
    IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,31 ,1
    IDE09831-CU for tailgate opener: play protection increments,6 ,1
    IDE09832-CU for tailgate opener: play protection decrements,25 ,1
    IDE09833-CU for tailgate opener: play protection threshold active,255 ,1
    IDE09834-CU for tailgate opener: play protection threshold inactive,5 ,1
    IDE09835-CU for tailgate opener: play protection decrement interval,60 ,1
    IDE09836-CU tailgate opener: sensor 1: control parameter,16 ,1
    IDE09837-CU tailgate opener: sensor 2: control parameter,16 ,1
    IDE09838-CU tailgate opener: foot gestic recognition: evaluation,0 ,1
    IDE09839-CU for tailgate opener: parameter set version,30 ,2
    IDE10844-Control module rear lid opening: duration status query,4960 ms,1
    IDE10845-Control module rear lid opening: vehicle type,22 ,1
    ENG153713-ENG129122-Byte12_diverse-environment_scan_step1,not activated ,1
    ENG153713-ENG126978-Byte12_diverse-environment_scan_step2,not activated ,1
    ENG153713-ENG154598-Byte12_diverse-exeption_drivers_doors_interior_scan,activated ,1
    ENG153713-ENG154691-Byte12_diverse-interior_scan_clamp_15_new_concept,activated ,1
    ENG153713-ENG154710-Byte12_diverse-open_cabrio_canopy_interior_scan,not activated ,1
    ENG153713-ENG154787-Byte12_diverse-suppression_access_detection_for_remotestart,not activated ,1
    ENG244871-ENG245027-Byte13_vit_lf-lock_via_toggle_by_closed_vehicle_skin,not activated ,1
    ENG244871-ENG245033-Byte13_vit_lf-toggle_active,not activated ,1
    ENG244871-ENG245019-Byte13_vit_lf-toggle_at _open_door,not activated ,1
    ENG244871-ENG129126-Byte13_vit_lf-vit_evaluate_inversbit,not activated ,1
    ENG244871-ENG129125-Byte13_vit_lf-vit_exit,not activated ,1
    ENG126956-ENG126976-Byte9_VIP-active_vip,activated ,1
    ENG126956-ENG154580-Byte9_VIP-Coding_easyclose_locking,not activated ,1
    ENG126956-ENG154581-Byte9_VIP-Coding_kick and_close_function,not activated ,1
    ENG126956-ENG248655-Byte9_VIP-ECL_Start_ueber_ViP,not activated ,1
    ENG126956-ENG129121-Byte9_VIP-Hitch_trailer_installation,not activated ,1
    ENG126956-ENG142121-Byte9_VIP-vip_activation_on_clamp15,not activated ,1
    ENG126956-ENG126977-Byte9_VIP-vip_deactivation_on_running_engine,not activated ,1
    ENG129011-CAN_signal_transmitting_delay_of_car_roll _away_warning,1.00 s,1
    ENG126957-CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff,1.00 s,1
    ENG129010-CAN_signal_transmitting_duration_of_comfort_switch_off,10.00 s,1
    ENG105462-CAN-timeout service-key message,260 ms,1
    ENG105634-Correction value LED dimming,1.0 ,1
    ENG114301-Cycletime for voltage monitoring during sleepmode,100 ms,1
    ENG120046-Cyclic interior scan during clamp 15 on,10 s,1
    ENG126961-deactivation_time_vip_slidingdoor,15 s,1
    ENG126960-Debounce_time_detection,500 ms,2
    ENG126959-Debounce_time_driver_presence,200 ms,1
    ENG126948-delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle,300 ms,1
    ENG129004-delay_time_Terminal_15_S_Shut_down_by_BEM,60.00 s,1
    ENG105791-Delta value LED dimming curve first point 40 percent dimming,30.0 %,1
    ENG105792-Delta value LED dimming curve forth point 100 percent dimming,5.0 %,1
    ENG105793-Delta value LED dimming curve second point 60 percent dimming,15.0 %,1
    ENG105794-Delta value LED dimming curve third point 80 percent dimming,10.0 %,1
    ENG105809-ENG100524-DeveloperCoding: Passiv Go-GO only via antenna IN1 if sliding door open,not activated ,1
    ENG105809-ENG102049-DeveloperCoding: Passiv Go-GO only via antenna IN1 if tailgate open,not activated ,1
    ENG105809-ENG121990-DeveloperCoding: Passiv Go-Impairment go on a low key battery,not activated ,1
    ENG105809-ENG102152-DeveloperCoding: Passiv Go-Passive Go,activated ,1
    ENG105809-ENG99072-DeveloperCoding: Passiv Go-Passive Go: tailgate authorized to start,activated ,1
    ENG123038-ENG104126-DeveloperCoding: Proximity Sensor-AUDI doorknobs mounted,not activated ,1
    ENG123038-ENG102457-DeveloperCoding: Proximity Sensor-Detection of an repeated failed doorknob actuation,activated ,1
    ENG123038-ENG129119-DeveloperCoding: Proximity Sensor-energized_doorhandles_at_stateKL15on_when_opening_door,activated ,1
    ENG123038-ENG102353-DeveloperCoding: Proximity Sensor-No turn off for driver doorknob while passive,activated ,1
    ENG123038-ENG99826-DeveloperCoding: Proximity Sensor-Proximity Sensor: sensor stays active after fault detection,not activated ,1
    ENG123038-ENG102252-DeveloperCoding: Proximity Sensor-Suppress fault manager entry "Falschverbau aktiv",activated ,1
    ENG123036-ENG102436-DeveloperCoding: Search lights-Standardisation of ZAT,activated ,1
    ENG123036-ENG99363-DeveloperCoding: Search lights-ZAT active during clamp 58t on,activated ,1
    ENG123036-ENG120038-DeveloperCoding: Search lights-ZAT detecting open load,not activated ,1
    ENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xt,not activated ,1
    ENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xt,not activated ,1
    ENG123037-ENG98487-DeveloperCoding: vehicle environment-Convertible,not activated ,1
    ENG123037-ENG100924-DeveloperCoding: vehicle environment-Pre Catch for Trunk,not activated ,1
    ENG123037-ENG129114-DeveloperCoding: vehicle environment-reactivate_all_doorhandles,not activated ,1
    ENG123037-ENG103200-DeveloperCoding: vehicle environment-Steering wheel,left-hand drive ,1
    ENG105825-Diagnostic: wait time after power on,500 ms,1
    ENG126943-Display_duration_emergency_off,3000 ms,1
    ENG126944-Display_duration_error_mode_2_SPN,10 s,1
    ENG126941-Display_duration_please_engage_P,10 s,1
    ENG105898-Doorknob contact sensor disconnecting time,5400 min,1
    ENG244875-duration_A-CAN_wake_up_for_Engine_ECU_wake_up,2000 ms,1
    ENG126955-duration_to_ZAT_continuous_actuation_detection,1000 ms,1
    ENG129005-duration_to_ZAT_multi_actuation_detection,3000 ms,1
    ENG126950-duration_ZAT_debounce,50 ms,1
    ENG129029-ENG142128-Easy_close_alignment-max_threashold_reopen_EasyClose,10 %,9
    ENG129029-ENG142127-Easy_close_alignment-Max_time_IDGeber_rear,2.00 s,9
    ENG129029-ENG142129-Easy_close_alignment-max_time_reentry_EasyClose,7.00 s,9
    ENG129029-ENG142130-Easy_close_alignment-min_rssi_values_hysteresis_EasyClose,20 ,9
    ENG129029-ENG142126-Easy_close_alignment-Min_threashold_trunk,50 %,9
    ENG129029-ENG129138-Easy_close_alignment-RSSI_ sample_rate,400 ms,9
    ENG129029-ENG129139-Easy_close_alignment-Timeframe_scan_active,20.00 s,9
    ENG129028-ENG142124-Easy_close_detection_areas-Easy_close_antenna_current_step,04 ,5
    ENG129028-ENG142125-Easy_close_detection_areas-Easy_close_open_door_antenna_current_step,02 ,5
    ENG129028-ENG142032-Easy_close_detection_areas-Value_area_4,220 mV/m,5
    ENG129028-ENG142033-Easy_close_detection_areas-Value_area_leaving_area,40 mV/m,5
    ENG126966-environment_scan_cyclic_step1,700 ms,1
    ENG126967-environment_scan_cyclic_step2,2000 ms,1
    ENG126965-environment_scan_duration_step1,300 min,1
    ENG126971-environment_scan_duration_step2,24 H,1
    ENG126969-environment_scan_level_bem,2 ,1
    ENG126968-environment_scan_responselevel_reduction,500 ,1
    ENG126970-environment_scan_startdelay_time,5 s,1
    ENG126958-Ignition_For_Immobilizer,Default ,1
    ENG129016-Initialization_diagnostics_switching_terminal,not activated ,4
    ENG107050-Interior scan: deceleration after comfort closing,3200 ms,1
    ENG107051-Interior scan: max. engine speed for standing engine,10 km/h,1
    ENG107052-Interior scan: opening threshold sliding roof,1 %,1
    ENG107053-Interior scan: opening threshold window lifter,5.0 %,1
    ENG107054-Interior scan: Speed - threshold,20 km/h,1
    ENG153724-Interior_scans_clamp15_break_at_active_message,5000 ms,1
    ENG153725-Interior_scans_clamp15_retry_at_active_message,5 ,1
    ENG98656-internal,0 B,1
    ENG129022-ENG142120-internal_keyminder_byte1-aktivate_function_trigger_access_leaving_elv,not activated ,1
    ENG129022-ENG129115-internal_keyminder_byte1-allowa_remotestart_to_disable_keys,not activated ,1
    ENG129022-ENG120037-internal_keyminder_byte1-Cyclic interior scan during active warning message "Key not found",not activated ,1
    ENG129022-ENG100928-internal_keyminder_byte1-Seat Memory: scan after driver door opening,activated ,1
    ENG129022-ENG99649-internal_keyminder_byte1-Seat Memory: scan after driver door opening no KESSY unlocking,activated ,1
    ENG129022-ENG99417-internal_keyminder_byte1-Softtouch mounted,installed ,1
    ENG129023-ENG99123-internal_keyminder_byte2-Inhibit ID-transmitter for passive go,activated ,1
    ENG129023-ENG102581-internal_keyminder_byte2-Lock prevention tailgate,activated ,1
    ENG129023-ENG101018-internal_keyminder_byte2-No locking with ID-transmitter last used interior,activated ,1
    ENG129023-ENG103451-internal_keyminder_byte2-Re-open after passive comfort closing,activated ,1
    ENG129023-ENG99711-internal_keyminder_byte2-Re-open last handling,not activated ,1
    ENG129023-ENG103237-internal_keyminder_byte2-Re-open tailgate,activated ,1
    ENG129020-ENG121989-internal_passive_entry_exit_byte1-Impairment Entry / Exit key on low battery,not activated ,1
    ENG129020-ENG125240-internal_passive_entry_exit_byte1-lf_crc,not activated ,1
    ENG129020-ENG99763-internal_passive_entry_exit_byte1-Passive Exit: access door not open,activated ,1
    ENG129020-ENG103722-internal_passive_entry_exit_byte1-Passive Exit: all doors not open,not activated ,1
    ENG129020-ENG126975-internal_passive_entry_exit_byte1-passive_exit_door_slam_lock,not activated ,1
    ENG129021-ENG155267-internal_passive_entry_exit_byte2-lf_shutdown,activated ,1
    ENG129021-ENG155268-internal_passive_entry_exit_byte2-lf_shutdown_gotrigger,not activated ,1
    ENG129021-ENG100246-internal_passive_entry_exit_byte2-Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed,activated ,1
    ENG129021-ENG123039-internal_passive_entry_exit_byte2-Passive Entry Exit,activated ,1
    ENG129021-ENG103289-internal_passive_entry_exit_byte2-Passive Entry Exit: control by pulling door handle during active DSL,activated ,1
    ENG129021-ENG103620-internal_passive_entry_exit_byte2-Passive Entry Exit: retry with antennastep 1,not activated ,1
    ENG129021-ENG103529-internal_passive_entry_exit_byte2-Passive Entry: second control concept,not activated ,1
    ENG107211-Key Minder: delay reunlocking tailgate,500 ms,1
    ENG107212-Key Minder: p_keyless_eventsearch_holding_time,10 s,1
    ENG107213-Key Minder: p_keyless_eventsearch_retries,2 ,1
    ENG107363-LED dimming curve first point 20 percent dimming,40.0 %,1
    ENG153886-lf_shutdown_timeout_2nd_operation,5 s,1
    ENG107592-MCTX Pause,1 B,1
    ENG107593-MCTX pause for Go / Key Minder,20 ms,1
    ENG107594-MCTX pause for Go authentification,14 B,1
    ENG107595-MCTX settling phase,10 B,1
    ENG129013-min_receptiontime_vit,0 ms,1
    ENG126945-min_time_for_Terminal_50_request,200 ms,1
    ENG244880-Minimum_holdtime_ak,500 ms,1
    ENG129003-Number_of_Multiple_ZAT_activations_to_emergency_shutoff,2 ,1
    ENG126940-Number_of_ZAT_activations_to_DTC,10 ,1
    ENG129015-Passive Entry Exit: control by pulling the door handle during active DSL_timeout,2.00 s,1
    ENG108166-Passive Entry Exit: entry request e-sliding door active time,500 ms,1
    ENG108167-Passive Entry Exit: minimum activity time locking sensor,140 ms,1
    ENG108168-Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY,220 ms,1
    ENG108169-Passive Entry Exit: T_ACT_OP_2,5000 ms,1
    ENG108297-Proximity Sensor: Comfort Exit-Enlargement,200 ms,1
    ENG108298-Proximity Sensor: duration of proximity Signal,10 s,1
    ENG108299-Proximity Sensor: lower limit Impuls,2000 µs,1
    ENG108300-Proximity Sensor: lower limit proximity-Impuls,12200 µs,1
    ENG108301-Proximity Sensor: max Vehiclespeed for a standing vehicle,10.0 km/h,1
    ENG108302-Proximity Sensor: max. Impulslength,75 ms,1
    ENG108303-Proximity Sensor: max. Impulslength of proximity-Impuls,20400 µs,1
    ENG108304-Proximity Sensor: max. intermission-length Diagnostic,14 ms,1
    ENG108305-Proximity Sensor: max. length of Diagnosticimpuls,71 ms,1
    ENG108306-Proximity Sensor: max. length of Entryimpuls,10400 µs,1
    ENG108307-Proximity Sensor: max. length of Exitimpuls,40400 µs,1
    ENG108308-Proximity sensor: max. length of signal hall sensor,100 s,1
    ENG108309-Proximity Sensor: max. signal-length,120 s,1
    ENG108310-Proximity sensor: max. tolerance data bit length,200 µs,1
    ENG108311-Proximity Sensor: min Vehiclespeed for a driving vehicle,20.0 km/h,1
    ENG108312-Proximity Sensor: min. enginespeed for a running engine,300 /min,1
    ENG108313-Proximity Sensor: min. length of Diagnosticimpuls,42 ms,1
    ENG108314-Proximity Sensor: min. length of Entryimpuls,6200 µs,1
    ENG108315-Proximity Sensor: min. length of Exitimpuls,24200 µs,1
    ENG108316-Proximity sensor: min. tolerance data bit length,120 µs,1
    ENG108317-Proximity Sensor: SP_X2,10 min,1
    ENG108318-Proximity Sensor: SP_X3,1 ,1
    ENG108319-Proximity Sensor: SP_X4,80 ,1
    ENG108320-Proximity Sensor: SP_X5,1 ,1
    ENG108321-Proximity Sensor: SP_X6,30 min,1
    ENG108322-Proximity Sensor: SP_X7,1 ,1
    ENG108323-Proximity Sensor: Time Power On,1960 ms,1
    ENG123035-Proximity Sensor: Timervalue for ExitReverseOption,0 ms,1
    ENG108325-Proximity sensor: turn-off limit from battery-manager,2 ,1
    ENG108326-Proximity Sensor: upper limit intermission-length,10 ms,1
    ENG153707-IDE00047-Rear_lid_power_opening_control_unit_data_set_upload-Parameter set version,0 ,37
    ENG153707-IDE80001-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 1,1 ,37
    ENG153707-IDE80002-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 2,1 ,37
    ENG153707-IDE80003-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 3,0 ,37
    ENG153707-IDE80004-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 4,1 ,37
    ENG153707-IDE80005-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 5,16 ,37
    ENG153707-IDE80006-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 6,16 ,37
    ENG153707-IDE80007-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 7,16 ,37
    ENG153707-IDE80008-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 8,16 ,37
    ENG153707-IDE80009-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 9,2 ,37
    ENG153707-IDE80010-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 10,31 ,37
    ENG153707-IDE80011-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 11,2 ,37
    ENG153707-IDE80012-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 12,31 ,37
    ENG153707-IDE80013-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 13,224 ,37
    ENG153707-IDE80014-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 14,10 ,37
    ENG153707-IDE80015-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 15,10 ,37
    ENG153707-IDE80016-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 16,0 ,37
    ENG153707-IDE80017-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 17,0 ,37
    ENG153707-IDE80018-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 18,9 ,37
    ENG153707-IDE80019-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 19,0 ,37
    ENG153707-IDE80020-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 20,not active ,37
    ENG153707-IDE80021-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 21,active ,37
    ENG153707-IDE80022-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 22,not active ,37
    ENG153707-IDE80023-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 23,Bottom ,37
    ENG153707-IDE80024-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 24,Dynamic ,37
    ENG153707-IDE80025-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 25,3 ,37
    ENG153707-IDE80026-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 26,not active ,37
    ENG153707-IDE80027-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 27,Dynamic ,37
    ENG153707-IDE80028-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 28,5 ,37
    ENG153707-IDE80029-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 29,6 ,37
    ENG153707-IDE80030-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 30,active ,37
    ENG153707-IDE80031-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 31,19 ,37
    ENG153707-IDE80032-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 32,2 ,37
    ENG153707-IDE80033-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 33,12 ,37
    ENG153707-IDE80034-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 34,4 ,37
    ENG153707-IDE80035-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 35,Do not reset ,37
    ENG153707-IDE80036-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 36,16 ,37
    ENG153707-IDE80037-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 37,16 ,37
    ENG153707-IDE80038-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 38,16 ,37
    ENG153707-IDE80039-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 39,16 ,37
    ENG153707-IDE80040-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 40,2 ,37
    ENG153707-IDE80041-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 41,31 ,37
    ENG153707-IDE80042-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 42,2 ,37
    ENG153707-IDE80043-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 43,31 ,37
    ENG153707-IDE80044-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 44,224 ,37
    ENG153707-IDE80045-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 45,10 ,37
    ENG153707-IDE80046-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 46,10 ,37
    ENG153707-IDE80047-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 47,0 ,37
    ENG153707-IDE80048-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 48,0 ,37
    ENG153707-IDE80049-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 49,0 ,37
    ENG153707-IDE80050-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 50,0 ,37
    ENG153707-IDE80051-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 51,6 ,37
    ENG153707-IDE80052-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 52,25 ,37
    ENG153707-IDE80053-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 53,255 ,37
    ENG153707-IDE80054-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 54,5 ,37
    ENG153707-IDE80055-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 55,60 ,37
    ENG153707-IDE80056-Rear_lid_power_opening_control_unit_data_set_upload-Analysis 56,24 ,37
    ENG153707-MAS01078-Rear_lid_power_opening_control_unit_data_set_upload-Vehicle type,34 ,37
    ENG153707-MAS14087-Rear_lid_power_opening_control_unit_data_set_upload-time delay activation,Activation after 2s ,37
    ENG120045-Reduced current for transponder-ID request,0 Step,1
    ENG126939-rpm_threshold_engine_runnning,100 /min,1
    ENG108575-Scan Procedure: current limiting on undervoltage at Go-protocol,5 Step,1
    ENG108576-Scan Procedure: cycle convenience coverage limiting,65 ms,1
    ENG108577-Scan Procedure: Number of Repeats,1 ,1
    ENG108578-Scan Procedure: p_keyless_eventsuche_retries_pause,100 ms,1
    ENG108579-Scan Procedure: Timeout Authentification Result,150 ms,1
    ENG129017-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go,190 ms,1
    ENG129018-Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi,700 ms,1
    ENG108582-Scan Procedure: Timeout LF Repetition,100 ms,1
    ENG108585-ScanProcedure: Timeout Entry Response,260 ms,1
    ENG108586-ScanProcedure: Timeout Response,100 ms,1
    ENG126963-settime_trigger_entry_vehicle,500 ms,1
    ENG126962-settime_trigger_exit_vehicle,500 ms,1
    ENG129024-ENG120039-Sonstiges_byte1-Backdoor TSG,not activated ,1
    ENG129024-ENG103075-Sonstiges_byte1-Battery manager mounted,activated ,1
    ENG129024-ENG102728-Sonstiges_byte1-Diagnostic: service 86 - response on event,not activated ,1
    ENG129024-ENG98656-Sonstiges_byte1-internal,not activated ,1
    ENG129024-ENG102591-Sonstiges_byte1-Response extension for scan procedure,not activated ,1
    ENG129024-ENG99430-Sonstiges_byte1-Scan Procedure: Timeoutcontrol active,activated ,1
    ENG129024-ENG104010-Sonstiges_byte1-Use default antenna data,not activated ,1
    ENG129025-ENG129137-sonstiges_byte2-interiorscan_clamp15_reach_trashhold,not activated ,1
    ENG129025-ENG142122-sonstiges_byte2-sad_existing,not activated ,1
    ENG129025-ENG142123-sonstiges_byte2-trunk_ecu_existing,activated ,1
    ENG244883-Speed_ threshold_for_start_request_plausibilisation,10 km/h,1
    ENG129007-Speed_threshold_for_driving_cycle_detection,3.0 km/h,1
    ENG129006-Speed_threshold_for_moving_vehicle_detection,1.0 km/h,1
    ENG129008-Speed_threshold_for_terminal_15_emergency_shutoff,7.0 km/h,1
    ENG109053-Standard dimming value ZAT,80 %,1
    ENG126938-Terminal_15_adaption_body_control_module,Default ,1
    ENG126946-Terminal_S_Timeout,30 min,1
    ENG102207-Time Sensor Power Off Group 2,3600 min,1
    ENG129027-Time_frame_VIP_kick_forecast,5 ,1
    ENG126942-time_to_drive_cycle_detection,1.00 s,1
    ENG126947-time_to_ignore_ignition_trigger,35 s,1
    ENG126954-time_to_ZAT_Open_circuit_detection,1000 ms,1
    ENG126951-time_to_ZAT_Short_circuit_fault_detection,60 s,1
    ENG126949-time_ZAT_actuation_detection,3000 ms,1
    ENG126952-time_ZAT_lock_after emergency_shutoff,1000 ms,1
    ENG126953-time_ZAT_lock_after_normal_shutoff,500 ms,1
    ENG129009-Timeframe_request_immobilizer_terminal_approval,10000 ms,1
    ENG129019-timeout_convenience_coverage_limiting,75 s,1
    ENG129014-Timeout_trigger_terminal_deactivation_central_locking,1.00 s,1
    ENG244884-Toggle_offtime_other_doorhandle,2.00 s,1
    ENG244885-Toggle_offtime_same_doorhandle,2.00 s,1
    ENG109974-Voltage monitoring: overvoltage Delta,500 mV,1
    ENG109975-Voltage monitoring: overvoltage for KESSY ECU,16000 mV,1
    ENG109976-Voltage monitoring: overvoltage for Keyless Go,27000 mV,1
    ENG109977-Voltage monitoring: overvoltage Jumpstart 2 Delta,0 mV,1
    ENG109978-Voltage monitoring: undervoltage Delta,500 mV,1
    ENG109979-Voltage monitoring: undervoltage for KESSY ECU,9000 mV,1
    ENG109980-Voltage monitoring: undervoltage for Keyless Go,6000 mV,1
    ENG109981-Voltage monitoring: undervoltage Jumpstart 1 Delta,0 mV,1
    ENG120047-ZAT init value,0 %,1
    ENG110364-ZAT nominal voltage,13.0 V,1
    ENG110365-ZAT post-carridge during clamp 15 off,10 min,1
    ENG153750-ZAT_clamp58xt_signal_factor,0.200 ,1
    ENG153751-ZAT_clamp58xt_signal_offset,3.0 ,1
    ENG153752-ZAT_first_fall_time_high_low_state,900 ms,1
    ENG153753-ZAT_first_rise_time_low_high_state,100 ms,1
    ENG153754-ZAT_motor_signal_timer_1,3000 ms,1
    ENG153755-ZAT_motor_signal_timer_2,3000 ms,1
    ENG153756-ZAT_pwm_offset_1_lower_limit,5 %,1
    ENG153757-ZAT_pwm_offset_2_lower_limit,10 %,1
    ENG153758-ZAT_pwm_peak1_upper_limit,90 %,1
    ENG153759-ZAT_pwm_peak2_upper_limit,100 %,1
    ENG153760-ZAT_second_fall_time_high_low_state,2000 ms,1
    Elapsed Time: 01:10
    08
    ;SW:5NA-907-044-P   HW:5NA-907-044-P ---  Auto HVAC
    ;Component:AC Automat    H35 4301, Coding:0002010420411101110510400010112A
    ;EV_ACClimaPrehVW37X,002023,EV_ACClimaPrehVW37X_002_VW37.rod
    ;Sunday,17,March,2019,17:51:26:21782
    ;VCID: CCD4EF0F679E812AF1-8098
    IDE00001-Production mode,Deactivating ,3
    IDE01067-Retention of driver's seat heater level,active for 10 minutes ,1
    IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore ,1
    IDE01483-Blower voltage for voice operation,not activated ,1
    IDE01488-Retrofitting of parking heater without CAN,not installed ,1
    IDE01493-Air quality sensor sensitivity,Maximum ,1
    IDE01503-Runtime for compressor run-in basic setting,60 s,1
    IDE01536-Post-heating of parking heater,0 min,1
    IDE02155-Reset all counters,not activated ,1
    IDE03176-Duration of compressor run in,60 s,1
    IDE06097-Target temperature of A/C - heater function via remote control,22.0 °C,1
    IDE07108-Climate modes,Matching coding ,1
    IDE07302-Remote start function: interior climate control status,Remote start function with fixed rated temperature active ,1
    IDE07304-Remote start function: activation of seat ventilation,activated ,1
    IDE07305-Rem. start funct.: activat.temper. of seat heating,15 °C,1
    IDE07306-Rem. start funct.: activat.temper. of seat ventilation,20 °C,1
    IDE07307-Remote start function: activation stage of seat heating,level 2 ,1
    IDE07308-Remote start function: activation stage of seat ventilation,level 2 ,1
    IDE07398-Blower logic for manual adjustment,Matching coding ,1
    IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active ,1
    IDE07948-Retention of frt.pass. seat heater level,not active ,1
    IDE12229-Filtering of interior air: store,Service life-dependent store ,1
    IDE13676-Remote start function: rear window defogger,activated ,1
    IDE13677-Remote start function: seat climate control takeover,activated ,1
    MAS06564-Window condensation exterior reduction at high humidity,Matching coding ,1
    MAS14860-Remote start function: windshield defogger takeover,activated ,1
    MAS14861-Remote start function: windshield defogger,activated ,1
    MAS17226-Remote start function: windshield defogger can be activated,activated ,1
    ENG122844-ENG99557-dimming_characteristic_1-X2,6 ,12
    ENG122844-ENG102140-dimming_characteristic_1-X3,40 ,12
    ENG122844-ENG102936-dimming_characteristic_1-X4,60 ,12
    ENG122844-ENG103548-dimming_characteristic_1-X5,80 ,12
    ENG122844-ENG113992-dimming_characteristic_1-X6,100 ,12
    ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %,12
    ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %,12
    ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %,12
    ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %,12
    ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %,12
    ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %,12
    ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %,12
    ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %,12
    ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %,12
    ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %,12
    ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %,12
    ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %,12
    ENG122846-ENG101574-dimming_characteristic_3-X1,0 ,12
    ENG122846-ENG99557-dimming_characteristic_3-X2,10 ,12
    ENG122846-ENG102140-dimming_characteristic_3-X3,50 ,12
    ENG122846-ENG102936-dimming_characteristic_3-X4,100 ,12
    ENG122846-ENG103548-dimming_characteristic_3-X5,220 ,12
    ENG122846-ENG113992-dimming_characteristic_3-X6,253 ,12
    ENG122846-ENG99777-dimming_characteristic_3-Y1,2 %,12
    ENG122846-ENG100480-dimming_characteristic_3-Y2,2 %,12
    ENG122846-ENG100773-dimming_characteristic_3-Y3,5 %,12
    ENG122846-ENG100631-dimming_characteristic_3-Y4,10 %,12
    ENG122846-ENG102174-dimming_characteristic_3-Y5,85 %,12
    ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %,12
    ENG122847-ENG101574-dimming_characteristic_4-X1,0 ,12
    ENG122847-ENG99557-dimming_characteristic_4-X2,10 ,12
    ENG122847-ENG102140-dimming_characteristic_4-X3,50 ,12
    ENG122847-ENG102936-dimming_characteristic_4-X4,100 ,12
    ENG122847-ENG103548-dimming_characteristic_4-X5,220 ,12
    ENG122847-ENG113992-dimming_characteristic_4-X6,253 ,12
    ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %,12
    ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %,12
    ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %,12
    ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %,12
    ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %,12
    ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %,12
    ENG122848-ENG101574-dimming_characteristic_5-X1,0 ,12
    ENG122848-ENG99557-dimming_characteristic_5-X2,10 ,12
    ENG122848-ENG102140-dimming_characteristic_5-X3,50 ,12
    ENG122848-ENG102936-dimming_characteristic_5-X4,100 ,12
    ENG122848-ENG103548-dimming_characteristic_5-X5,220 ,12
    ENG122848-ENG113992-dimming_characteristic_5-X6,253 ,12
    ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %,12
    ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %,12
    ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %,12
    ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %,12
    ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %,12
    ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %,12
    ENG153708-Remotestart_window_heating_temperature,4 ,1
    Elapsed Time: 00:16
    09
    ;SW:5Q0-937-084-DC   HW:5Q0-937-084-CF ---  Cent. Elect.
    ;Component:BCM MQBAB M+  H38 0273, Coding:000000000000000000000000000000000000000000000000000000000000
    ;EV_BCMMQB,019001,EV_BCMBOSCH_019_VW37.rod
    ;Sunday,17,March,2019,17:52:47:21782
    ;VCID: FCB47FCF77BEF1AA01-80A8
    IDE01550-Service position,178.999822 °,2
    IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active ,10
    IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active ,10
    IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active ,10
    IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,short ,10
    IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active ,10
    IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,active ,10
    IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,active ,10
    IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active ,10
    IDE02269-ENG142248-Acknowledgement signals-ZV-Blinken_Abschluss_Dunkelzeit,200 ms,10
    IDE02269-ENG142247-Acknowledgement signals-ZV-Blinken_Dunkelzeit,200 ms,10
    IDE02269-ENG142246-Acknowledgement signals-ZV-Blinken_Hellzeit,200 ms,10
    IDE02488-DWA Interior monitoring,100 %,1
    IDE02711-ENG112304-Rear Window Wiper-Heckwischer,logikgesteuert ,8
    IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s,8
    IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s,8
    IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s,8
    IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s,8
    IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active ,8
    IDE02711-ENG154784-Rear Window Wiper-Spannungsanforderung_konfig_Wischer,Keine_Spannungsanforderung ,8
    IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,active ,8
    IDE02711-ENG154831-Rear Window Wiper-Zeit_wasch_min_heck,0 ms,8
    IDE03638-IDE04231-static AFS light-Steering wheel angle: offset,0.3 °,16
    IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit,50.0 %/s,16
    IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt,both sides ,16
    IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel,120 °,16
    IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel,80 °,16
    IDE03638-ENG116676-static AFS light-Upper speed threshold,40.0 km/h,16
    IDE03638-ENG116674-static AFS light-Vorschrift,ECE R119 ,16
    IDE04927-IDE01446-Window heater-Running time of heated front window,240 s,11
    IDE04927-ENG126845-Window heater-FSH Automatik,active ,11
    IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,320 s,11
    IDE04927-ENG246969-Window heater-HZG_Wischer_Ablage,not installed ,11
    IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,active ,11
    IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,active ,11
    IDE04927-ENG246996-Window heater-WAH_Temp_Wischer_aktiv,-2.0 °C,11
    IDE04927-ENG141962-Window heater-Waschduesenheizung,installed ,11
    IDE04927-ENG154810-Window heater-window heating front activation time pause,320 s,11
    IDE04928-MAS01577-Anti-theft device-Parking heater,installed ,8
    IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active ,8
    IDE04928-ENG141960-Anti-theft device-Anti-theft alarm system,active ,8
    IDE04928-ENG154588-Anti-theft device-Deaktivierung DWA-Sensoren via Doppelklick,not_active ,8
    IDE04928-ENG154589-Anti-theft device-Deaktivierung_DWA_Sensoren_HMI,activ ,8
    IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active ,8
    IDE04928-ENG142007-Anti-theft device-DWA_Einfachhorn_oder_Sounder,Sounder_verbaut ,8
    IDE04928-ENG142006-Anti-theft device-IRUE_NGS_Deaktivierungstaster_direkt_am BCM_verdrahtet,No ,8
    IDE04928-ENG142249-Anti-theft device-OBD Alarm,activ ,8
    IDE04928-ENG154722-Anti-theft device-RHF_Panikalarm,activ ,8
    IDE04928-ENG142009-Anti-theft device-Schliesszylinder in_Richtung Oeffnen_aktiv (Thatcham inaktiv),No ,8
    IDE04928-ENG142010-Anti-theft device-Sensor_fuer_Innenraumueberwachung,Yes ,8
    IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme ,8
    IDE04928-ENG142008-Anti-theft device-tilt_sensor,Yes ,8
    IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,2 sekunden verzoegerung ,8
    IDE05143-MAS02985-Writing parameter-Value,130 ,5
    IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00 ,5
    IDE05144-Read parameter address,FE 00 00 ,3
    IDE05145-Light configuration,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 36 00 1A 0B 0F 7F 00 00 00 00 00 00 00 00 00 05 40 00 1B 0C 0F 7F 00 00 00 00 00 00 00 00 00 05 44 00 4A 46 00 7F 08 0A 7F 00 00 00 00 00 00 05 3A 00 49 46 00 7F 08 09 7F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A 38 00 22 12 00 64 00 00 00 00 00 00 00 00 00 0A 42 00 23 13 00 64 00 00 00 00 00 00 00 00 00 ,224
    IDE05822-DWA Vehicle inclination sensor,100 %,1
    IDE05823-DWA Interior monitoring parameter set,01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 52 57 9B 25 44 3F 3A 69 58 95 2E 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 9B 05 34 3F 3A 69 58 93 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 9B 05 24 3F 3A 69 47 93 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 94 05 24 3F 3A 69 58 92 05 09 A3 05 34 26 19 15 0C 12 18 88 06 26 33 66 23 45 42 57 9B 25 24 0C FA 0A 34 95 2E 09 A3 21 03 00 02 02 02 02 02 02 B1 11 24 2A F1 ,172
    IDE06089-ENG246993-Seat heater level current consumption allocation-SIH_PWM_Teiler,0 ,30
    IDE06089-ENG141976-Seat heater level current consumption allocation-Sitzheitzung_CAN,Heizmatten am BCM ,30
    IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,1 s,30
    IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,0.00 °C,30
    IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,21.00 °C,30
    IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,20.00 °C,30
    IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,21.00 °C,30
    IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,20.00 °C,30
    IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,35.50 °C,30
    IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,36.00 °C,30
    IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,35.50 °C,30
    IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,53.00 °C,30
    IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,52.50 °C,30
    IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,53.00 °C,30
    IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,52.50 °C,30
    IDE06089-ENG154774-Seat heater level current consumption allocation-Sitzheizung.Aufheizphase HI,Keine_Spannungsanforderung ,30
    IDE06089-ENG154775-Seat heater level current consumption allocation-Sitzheizung.Regelbetrieb LO,Keine_Spannungsanforderung ,30
    IDE06089-ENG154785-Seat heater level current consumption allocation-Spannungsoffset SIH_75,15.7 V,30
    IDE06507-MAS13132-Button in center console-Function of button 3,not coded/not installed ,8
    IDE06507-ENG140243-Button in center console-Zusatzcodierung Fahrprofiltaster hat keine LED,LED installed ,8
    IDE07007-ENG142253-A/C heater function via remote control-Abbruch_d_Warnblinker_moeglich,active ,8
    IDE07007-ENG142255-A/C heater function via remote control-Aktivierung_Drehzahlanzeige,active ,8
    IDE07007-ENG142254-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Akustik,active ,8
    IDE07007-ENG128461-A/C heater function via remote control-Kombi_Fahrerhinweis_m_Uebernahme_RSt,active ,8
    IDE07007-ENG115720-A/C heater function via remote control-Remote Start,not installed ,8
    IDE07007-ENG246992-A/C heater function via remote control-Remotestart_externe_FFB_verbaut,not installed ,8
    IDE07007-ENG128460-A/C heater function via remote control-Rueckmeldung_bei_Aktivierung,active ,8
    IDE07356-Position during interval mode,40.999959 °,2
    IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten ueber Abschaltstufen des Energiemanagements oder nach der Nachlaufzeit ,6
    IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min,6
    IDE07470-ENG126843-After-run for park light-ZV verriegeln bei Klemme 15 Ein,active ,6
    IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,active ,9
    IDE08786-ENG141985-Assistance light functions-Regen_Lichtsensor,LIN_REGEN_LICHT_SENSOR ,9
    IDE08786-ENG124476-Assistance light functions-Sunlight Sensor,not installed ,9
    IDE09731-ENG154511-Int. light: 2nd generation-Ambiente_Fahrprofil_Individual,7 ,19
    IDE09731-ENG154512-Int. light: 2nd generation-Ambiente_Farbliste_HMI_mit_Farbtransformation,not active ,19
    IDE09731-ENG154513-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung,not active ,19
    IDE09731-ENG154514-Int. light: 2nd generation-Ambiente_Farbwahl_FPA_waehlbare_Kopplung_Status_hmi_default,active ,19
    IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.10 s,19
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1,2 ,19
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2,3 ,19
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3,1 ,19
    IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,0 %,19
    IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2 ,19
    IDE09731-ENG115822-Int. light: 2nd generation-Defaultwert Ambienteprofil Fussraum,50 %,19
    IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,50 %,19
    IDE09731-ENG116685-Int. light: 2nd generation-Defaultwert Ambienteprofil Tuer,50 %,19
    IDE09731-ENG115823-Int. light: 2nd generation-Defaultwert Ambienteprofil Vorn,50 %,19
    IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active ,19
    IDE09731-ENG142233-Int. light: 2nd generation-Helligkeit_Tuertafelbeleuchtung_nicht_berechnen,not active ,19
    IDE09731-ENG116596-Int. light: 2nd generation-Innenlicht bei offenem Heckdeckel einschalten,active ,19
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG98648-Int. light: 2nd generation-Interior light,Keine_Spannungsanforderung ,19
    IDE09731-ENG116597-Int. light: 2nd generation-KL30G ohne PWM,not active ,19
    IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,not active ,19
    IDE09731-ENG142184-Int. light: 2nd generation-Weckfaehigkeit_klemme_30G,installed ,19
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active ,19
    IDE09732-ENG154509-Interior light: light configuration-Ambience_light_colorlist_default,0 ,5
    IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI,not active ,5
    IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed ,5
    IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,installed ,5
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,active ,5
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,active ,5
    IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed ,5
    IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed ,5
    IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %,17
    IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,30 %,17
    IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %,17
    IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,30 %,17
    IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,50 %,17
    IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,50 %,17
    IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,50 %,17
    IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,50 %,17
    IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,75 %,17
    IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,75 %,17
    IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,80 %,17
    IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %,17
    IDE09761-ENG142024-Seat fan charac. curve-Sitzlueftung,not installed ,17
    IDE09761-ENG142183-Seat fan charac. curve-Sitzlueftung_reduzierbar,not installed ,17
    IDE10298-Alternating park position 1,19.999980 °,2
    IDE10299-Alternating park position 2,34.999965 °,2
    IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,1.00 ,256
    IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,1.00 ,256
    IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,0.20 ,256
    IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,1.00 ,256
    IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,1.00 ,256
    IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,1.00 ,256
    IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,0.00 ,256
    IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,0.60 ,256
    IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00000001  ,256
    IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00110000  ,256
    IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00000000  ,256
    IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00000000  ,256
    IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00000000  ,256
    IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00000000  ,256
    IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00000000  ,256
    IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00000000  ,256
    IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,0 %,256
    IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,70 %,256
    IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,0 %,256
    IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,96 %,256
    IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %,256
    IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %,256
    IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,70 %,256
    IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %,256
    IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %,256
    IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %,256
    IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,0 %,256
    IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,96 %,256
    IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %,256
    IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %,256
    IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,0 %,256
    IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %,256
    IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %,256
    IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %,256
    IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,0 %,256
    IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,0 %,256
    IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,0 %,256
    IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %,256
    IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %,256
    IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,0 %,256
    IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,127 %,256
    IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %,256
    IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %,256
    IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %,256
    IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %,256
    IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %,256
    IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,0 %,256
    IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %,256
    IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,127 %,256
    IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %,256
    IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %,256
    IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %,256
    IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %,256
    IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %,256
    IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %,256
    IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %,256
    IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,0 %,256
    IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,126 %,256
    IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %,256
    IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %,256
    IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,70 %,256
    IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %,256
    IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %,256
    IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %,256
    IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,0 %,256
    IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,96 %,256
    IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %,256
    IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %,256
    IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,0 %,256
    IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %,256
    IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %,256
    IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,70 %,256
    IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %,256
    IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %,256
    IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %,256
    IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %,256
    IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,0 %,256
    IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,96 %,256
    IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %,256
    IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %,256
    IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,70 %,256
    IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %,256
    IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %,256
    IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %,256
    IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %,256
    IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,0 %,256
    IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,96 %,256
    IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,200 ms,256
    IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,2.0 s,256
    IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0.5 s,256
    IDE11714-ENG126827-Ambient light color list-Blauwert Farbe 1,0 ,30
    IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10,0 ,30
    IDE11714-ENG126830-Ambient light color list-Blauwert Farbe 2,0 ,30
    IDE11714-ENG126833-Ambient light color list-Blauwert Farbe 3,0 ,30
    IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4,0 ,30
    IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5,0 ,30
    IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6,0 ,30
    IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7,0 ,30
    IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8,0 ,30
    IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9,0 ,30
    IDE11714-ENG126826-Ambient light color list-Gruenwert Farbe 1,0 ,30
    IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10,0 ,30
    IDE11714-ENG126829-Ambient light color list-Gruenwert Farbe 2,0 ,30
    IDE11714-ENG126832-Ambient light color list-Gruenwert Farbe 3,0 ,30
    IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4,0 ,30
    IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5,0 ,30
    IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6,0 ,30
    IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7,0 ,30
    IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8,0 ,30
    IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9,0 ,30
    IDE11714-ENG126825-Ambient light color list-Rotwert Farbe 1,0 ,30
    IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10,0 ,30
    IDE11714-ENG126828-Ambient light color list-Rotwert Farbe 2,0 ,30
    IDE11714-ENG126831-Ambient light color list-Rotwert Farbe 3,0 ,30
    IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4,0 ,30
    IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5,0 ,30
    IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6,0 ,30
    IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7,0 ,30
    IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8,0 ,30
    IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9,0 ,30
    IDE11944-ENG142014-Keyless access and start authorization-Elektische_Lenkradverriegelung,not installed ,3
    IDE11944-ENG141948-Keyless access and start authorization-Kessy,installed ,3
    IDE11944-ENG246971-Keyless access and start authorization-Kessy BewegungsüberwachungIDGeber,not active ,3
    IDE11944-ENG116654-Keyless access and start authorization-Kessy Komfort schliessen,active ,3
    IDE11944-ENG116655-Keyless access and start authorization-Kessy Komfortbedienung Reichweitenbegrenzung,active ,3
    IDE11944-ENG179142-Keyless access and start authorization-Kessy Protokollvariante EntryExit,not active ,3
    IDE11944-ENG179143-Keyless access and start authorization-Kessy Ruhephase EntryExit,not active ,3
    IDE11944-ENG116626-Keyless access and start authorization-Oeffnung Heckdeckel bei Wiederentriegelung,not active ,3
    IDE12302-SFT271873-Identification of sub-bus participant-Control Unit For Wiper Motor,Not available ,6
    IDE12302-SFT271874-Identification of sub-bus participant-Rain Light Recognition Sensor,Not available ,6
    IDE12302-SFT271875-Identification of sub-bus participant-Light switch,Not available ,6
    IDE12302-SFT271876-Identification of sub-bus participant-Garage door opener control module,Not available ,6
    IDE12302-SFT271877-Identification of sub-bus participant-Garage Door Opener Operating Unit,Not available ,6
    IDE12302-SFT271894-Identification of sub-bus participant-Sensor For Anti Theft Alarm System,Not available ,6
    IDE12302-SFT271896-Identification of sub-bus participant-Alarm horn,Not available ,6
    IDE12302-SFT271904-Identification of sub-bus participant-Sun Roof,Not available ,6
    IDE12302-SFT271910-Identification of sub-bus participant-Ceiling Light Module,Not available ,6
    IDE12302-SFT271928-Identification of sub-bus participant-Roof Blind,Not available ,6
    IDE12302-SFT271947-Identification of sub-bus participant-Relative Air Humidity Interior Sender,Not available ,6
    IDE12302-SFT271966-Identification of sub-bus participant-Neck Heating Left,Not available ,6
    IDE12302-SFT271967-Identification of sub-bus participant-Neck Heating Right,Not available ,6
    IDE12302-SFT272065-Identification of sub-bus participant-Seat Backrest Fan 1 Front Left,Not available ,6
    IDE12302-SFT272067-Identification of sub-bus participant-Seat Cushion Fan 1 Front Left,Not available ,6
    IDE12302-SFT272069-Identification of sub-bus participant-Seat Backrest Fan 1 Front Right,Not available ,6
    IDE12302-SFT272071-Identification of sub-bus participant-Seat Cushion Fan 1 Front Right,Not available ,6
    IDE12302-ENG246961-Identification of sub-bus participant-Remote_Control,Not available ,6
    IDE12302-ENG246960-Identification of sub-bus participant-steering_column_switch,Not available ,6
    IDE12412-ENG154526-LIN Ambient light color list-Blauwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154537-LIN Ambient light color list-Blauwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154557-LIN Ambient light color list-Blauwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154560-LIN Ambient light color list-Blauwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154561-LIN Ambient light color list-Blauwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154562-LIN Ambient light color list-Blauwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154563-LIN Ambient light color list-Blauwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154564-LIN Ambient light color list-Blauwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154565-LIN Ambient light color list-Blauwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154645-LIN Ambient light color list-Gruenwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154646-LIN Ambient light color list-Gruenwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154656-LIN Ambient light color list-Gruenwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154676-LIN Ambient light color list-Gruenwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154679-LIN Ambient light color list-Gruenwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154680-LIN Ambient light color list-Gruenwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154681-LIN Ambient light color list-Gruenwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154682-LIN Ambient light color list-Gruenwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154683-LIN Ambient light color list-Gruenwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154684-LIN Ambient light color list-Gruenwert_Farbe_9_lin,0 ,30
    IDE12412-ENG154733-LIN Ambient light color list-Rotwert_Farbe_1_lin,0 ,30
    IDE12412-ENG154734-LIN Ambient light color list-Rotwert_Farbe_10_lin,0 ,30
    IDE12412-ENG154744-LIN Ambient light color list-Rotwert_Farbe_2_lin,0 ,30
    IDE12412-ENG154764-LIN Ambient light color list-Rotwert_Farbe_3_lin,0 ,30
    IDE12412-ENG154767-LIN Ambient light color list-Rotwert_Farbe_4_lin,0 ,30
    IDE12412-ENG154768-LIN Ambient light color list-Rotwert_Farbe_5_lin,0 ,30
    IDE12412-ENG154769-LIN Ambient light color list-Rotwert_Farbe_6_lin,0 ,30
    IDE12412-ENG154770-LIN Ambient light color list-Rotwert_Farbe_7_lin,0 ,30
    IDE12412-ENG154771-LIN Ambient light color list-Rotwert_Farbe_8_lin,0 ,30
    IDE12412-ENG154772-LIN Ambient light color list-Rotwert_Farbe_9_lin,0 ,30
    MAS05055-lower turn position,42.999957 °,2
    MAS05056-upper turn position,178.999822 °,2
    MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle,0 lx,24
    MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,00 00 ,24
    MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell,2000 lx,24
    MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung,0 mV,24
    MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke,0 lx,24
    MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung,0 mV,24
    ENG153709-ENG154696-Aktivierung_Entwicklungsdiagnose-log_dtc_status,not active ,9
    ENG153709-ENG154697-Aktivierung_Entwicklungsdiagnose-log-dtc_DFCC,00 00 00 ,9
    ENG153709-ENG154714-Aktivierung_Entwicklungsdiagnose-Reaktion_LOG-DTC,First_dtc ,9
    ENG141683-ENG116672-Allwetterlicht_Spoiler-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,active ,4
    ENG141683-ENG116671-Allwetterlicht_Spoiler-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,active ,4
    ENG153710-ENG154516-Ambience_lightning_color_list_2-Blauwert Farbe 11,0 ,60
    ENG153710-ENG154517-Ambience_lightning_color_list_2-Blauwert Farbe 12,0 ,60
    ENG153710-ENG154518-Ambience_lightning_color_list_2-Blauwert Farbe 13,0 ,60
    ENG153710-ENG154519-Ambience_lightning_color_list_2-Blauwert Farbe 14,0 ,60
    ENG153710-ENG154520-Ambience_lightning_color_list_2-Blauwert Farbe 15,0 ,60
    ENG153710-ENG154521-Ambience_lightning_color_list_2-Blauwert Farbe 16,0 ,60
    ENG153710-ENG154522-Ambience_lightning_color_list_2-Blauwert Farbe 17,0 ,60
    ENG153710-ENG154523-Ambience_lightning_color_list_2-Blauwert Farbe 18,0 ,60
    ENG153710-ENG154524-Ambience_lightning_color_list_2-Blauwert Farbe 19,0 ,60
    ENG153710-ENG154525-Ambience_lightning_color_list_2-Blauwert Farbe 20,0 ,60
    ENG153710-ENG154539-Ambience_lightning_color_list_2-Blauwert_Farbe_21,0 ,60
    ENG153710-ENG154541-Ambience_lightning_color_list_2-Blauwert_Farbe_22,0 ,60
    ENG153710-ENG154543-Ambience_lightning_color_list_2-Blauwert_Farbe_23,0 ,60
    ENG153710-ENG154545-Ambience_lightning_color_list_2-Blauwert_Farbe_24,0 ,60
    ENG153710-ENG154547-Ambience_lightning_color_list_2-Blauwert_Farbe_25,0 ,60
    ENG153710-ENG154549-Ambience_lightning_color_list_2-Blauwert_Farbe_26,0 ,60
    ENG153710-ENG154551-Ambience_lightning_color_list_2-Blauwert_Farbe_27,0 ,60
    ENG153710-ENG154553-Ambience_lightning_color_list_2-Blauwert_Farbe_28,0 ,60
    ENG153710-ENG154555-Ambience_lightning_color_list_2-Blauwert_Farbe_29,0 ,60
    ENG153710-ENG154558-Ambience_lightning_color_list_2-Blauwert_Farbe_30,0 ,60
    ENG153710-ENG154635-Ambience_lightning_color_list_2-Gruenwert Farbe 11,0 ,60
    ENG153710-ENG154636-Ambience_lightning_color_list_2-Gruenwert Farbe 12,0 ,60
    ENG153710-ENG154637-Ambience_lightning_color_list_2-Gruenwert Farbe 13,0 ,60
    ENG153710-ENG154638-Ambience_lightning_color_list_2-Gruenwert Farbe 14,0 ,60
    ENG153710-ENG154639-Ambience_lightning_color_list_2-Gruenwert Farbe 15,0 ,60
    ENG153710-ENG154640-Ambience_lightning_color_list_2-Gruenwert Farbe 16,0 ,60
    ENG153710-ENG154641-Ambience_lightning_color_list_2-Gruenwert Farbe 17,0 ,60
    ENG153710-ENG154642-Ambience_lightning_color_list_2-Gruenwert Farbe 18,0 ,60
    ENG153710-ENG154643-Ambience_lightning_color_list_2-Gruenwert Farbe 19,0 ,60
    ENG153710-ENG154644-Ambience_lightning_color_list_2-Gruenwert Farbe 20,0 ,60
    ENG153710-ENG154658-Ambience_lightning_color_list_2-Gruenwert_Farbe_21,0 ,60
    ENG153710-ENG154660-Ambience_lightning_color_list_2-Gruenwert_Farbe_22,0 ,60
    ENG153710-ENG154662-Ambience_lightning_color_list_2-Gruenwert_Farbe_23,0 ,60
    ENG153710-ENG154664-Ambience_lightning_color_list_2-Gruenwert_Farbe_24,0 ,60
    ENG153710-ENG154666-Ambience_lightning_color_list_2-Gruenwert_Farbe_25,0 ,60
    ENG153710-ENG154668-Ambience_lightning_color_list_2-Gruenwert_Farbe_26,0 ,60
    ENG153710-ENG154670-Ambience_lightning_color_list_2-Gruenwert_Farbe_27,0 ,60
    ENG153710-ENG154672-Ambience_lightning_color_list_2-Gruenwert_Farbe_28,0 ,60
    ENG153710-ENG154674-Ambience_lightning_color_list_2-Gruenwert_Farbe_29,0 ,60
    ENG153710-ENG154677-Ambience_lightning_color_list_2-Gruenwert_Farbe_30,0 ,60
    ENG153710-ENG154723-Ambience_lightning_color_list_2-Rotwert Farbe 11,0 ,60
    ENG153710-ENG154724-Ambience_lightning_color_list_2-Rotwert Farbe 12,0 ,60
    ENG153710-ENG154725-Ambience_lightning_color_list_2-Rotwert Farbe 13,0 ,60
    ENG153710-ENG154726-Ambience_lightning_color_list_2-Rotwert Farbe 14,0 ,60
    ENG153710-ENG154727-Ambience_lightning_color_list_2-Rotwert Farbe 15,0 ,60
    ENG153710-ENG154728-Ambience_lightning_color_list_2-Rotwert Farbe 16,0 ,60
    ENG153710-ENG154729-Ambience_lightning_color_list_2-Rotwert Farbe 17,0 ,60
    ENG153710-ENG154730-Ambience_lightning_color_list_2-Rotwert Farbe 18,0 ,60
    ENG153710-ENG154731-Ambience_lightning_color_list_2-Rotwert Farbe 19,0 ,60
    ENG153710-ENG154732-Ambience_lightning_color_list_2-Rotwert Farbe 20,0 ,60
    ENG153710-ENG154746-Ambience_lightning_color_list_2-Rotwert_Farbe_21,0 ,60
    ENG153710-ENG154748-Ambience_lightning_color_list_2-Rotwert_Farbe_22,0 ,60
    ENG153710-ENG154750-Ambience_lightning_color_list_2-Rotwert_Farbe_23,0 ,60
    ENG153710-ENG154752-Ambience_lightning_color_list_2-Rotwert_Farbe_24,0 ,60
    ENG153710-ENG154754-Ambience_lightning_color_list_2-Rotwert_Farbe_25,0 ,60
    ENG153710-ENG154756-Ambience_lightning_color_list_2-Rotwert_Farbe_26,0 ,60
    ENG153710-ENG154758-Ambience_lightning_color_list_2-Rotwert_Farbe_27,0 ,60
    ENG153710-ENG154760-Ambience_lightning_color_list_2-Rotwert_Farbe_28,0 ,60
    ENG153710-ENG154762-Ambience_lightning_color_list_2-Rotwert_Farbe_29,0 ,60
    ENG153710-ENG154765-Ambience_lightning_color_list_2-Rotwert_Farbe_30,0 ,60
    ENG153711-ENG154528-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154529-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154530-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154531-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154532-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154533-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154534-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154535-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154536-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154538-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154540-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154542-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154544-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154546-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154548-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154550-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154552-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154554-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154556-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154559-Ambience_lightning_color_list_lin_2-Blauwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154647-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154648-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154649-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154650-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154651-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154652-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154653-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154654-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154655-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154657-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154659-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154661-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154663-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154665-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154667-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154669-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154671-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154673-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154675-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154678-Ambience_lightning_color_list_lin_2-Gruenwert_Farbe_30_lin,0 ,60
    ENG153711-ENG154735-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_11_lin,0 ,60
    ENG153711-ENG154736-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_12_lin,0 ,60
    ENG153711-ENG154737-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_13_lin,0 ,60
    ENG153711-ENG154738-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_14_lin,0 ,60
    ENG153711-ENG154739-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_15_lin,0 ,60
    ENG153711-ENG154740-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_16_lin,0 ,60
    ENG153711-ENG154741-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_17_lin,0 ,60
    ENG153711-ENG154742-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_18_lin,0 ,60
    ENG153711-ENG154743-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_19_lin,0 ,60
    ENG153711-ENG154745-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_20_lin,0 ,60
    ENG153711-ENG154747-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_21_lin,0 ,60
    ENG153711-ENG154749-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_22_lin,0 ,60
    ENG153711-ENG154751-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_23_lin,0 ,60
    ENG153711-ENG154753-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_24_lin,0 ,60
    ENG153711-ENG154755-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_25_lin,0 ,60
    ENG153711-ENG154757-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_26_lin,0 ,60
    ENG153711-ENG154759-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_27_lin,0 ,60
    ENG153711-ENG154761-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_28_lin,0 ,60
    ENG153711-ENG154763-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_29_lin,0 ,60
    ENG153711-ENG154766-Ambience_lightning_color_list_lin_2-Rotwert_Farbe_30_lin,0 ,60
    ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00 ,30
    ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00 ,30
    ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00 ,30
    ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00 ,30
    ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00 ,30
    ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00 ,30
    ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00 ,30
    ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00 ,30
    ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00 ,30
    ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00 ,30
    ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00 ,30
    ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00 ,30
    ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00 ,30
    ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00 ,30
    ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00 ,30
    ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door ,30
    ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door ,30
    ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door ,30
    ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door ,30
    ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door ,30
    ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door ,30
    ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door ,30
    ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door ,30
    ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door ,30
    ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door ,30
    ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door ,30
    ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door ,30
    ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door ,30
    ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door ,30
    ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door ,30
    ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed ,30
    ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0 ,60
    ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0 ,60
    ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0 ,60
    ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0 ,60
    ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
    ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0 ,60
    ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0 ,60
    ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0 ,60
    ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed ,60
    ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed ,60
    ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed ,60
    ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed ,60
    ENG153712-ENG154510-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Ambiente,Keine_Spannungsanforderung ,23
    ENG153712-ENG154602-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_0,1 ,23
    ENG153712-ENG154603-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_1,1 ,23
    ENG153712-ENG154604-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_10,1 ,23
    ENG153712-ENG154605-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_11,1 ,23
    ENG153712-ENG154606-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_12,1 ,23
    ENG153712-ENG154607-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_13,1 ,23
    ENG153712-ENG154608-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_14,1 ,23
    ENG153712-ENG154609-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_15,1 ,23
    ENG153712-ENG154610-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_2,1 ,23
    ENG153712-ENG154611-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_3,1 ,23
    ENG153712-ENG154612-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_4,1 ,23
    ENG153712-ENG154613-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_5,1 ,23
    ENG153712-ENG154614-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_6,1 ,23
    ENG153712-ENG154615-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_7,1 ,23
    ENG153712-ENG154616-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_8,1 ,23
    ENG153712-ENG154617-Ambientelicht Zuordnung der Farbe zum Fahrprofil-Fahrprofil_9,1 ,23
    ENG141649-ENG122212-Außenlicht_Blinker-ABBA_Blinken,not active ,10
    ENG141649-ENG122207-Außenlicht_Blinker-DWA_Alarm_Blinken,not active ,10
    ENG141649-ENG122206-Außenlicht_Blinker-DWA_Schaerfungsquittung,not active ,10
    ENG141649-ENG154601-Außenlicht_Blinker-Fahrerassistenz_Blinkenfunktionen,Warnblinke_zulaessig ,10
    ENG141649-ENG121967-Außenlicht_Blinker-Panic flashing,not active ,10
    ENG141649-ENG154711-Außenlicht_Blinker-PreCrash_RECAS,PreCrash_passiv ,10
    ENG141649-ENG122211-Außenlicht_Blinker-Richtungs_blinken_links,not active ,10
    ENG141649-ENG122210-Außenlicht_Blinker-Richtungs_blinken_rechts,not active ,10
    ENG141649-ENG122201-Außenlicht_Blinker-Schluessel_Anlern_Blinken,not active ,10
    ENG141649-ENG121968-Außenlicht_Blinker-Taxi alarm flashing,not active ,10
    ENG141649-ENG126629-Außenlicht_Blinker-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active ,10
    ENG141649-ENG122202-Außenlicht_Blinker-UGDO_ Anlern_Blinken,not active ,10
    ENG141649-ENG142029-Außenlicht_Blinker-Warnblinken_durch_Fahrerassistenz,not active ,10
    ENG141649-ENG246997-Außenlicht_Blinker-Warnblinken_TP_max,120 min,10
    ENG141649-ENG122214-Außenlicht_Blinker-Warnblinken_Zuendung_AUS,not active ,10
    ENG141649-ENG122213-Außenlicht_Blinker-Warnblinken_Zuendung_EIN,not active ,10
    ENG141649-ENG122204-Außenlicht_Blinker-ZV_Blinken_auf,not active ,10
    ENG141649-ENG122203-Außenlicht_Blinker-ZV_Blinken_zu,not active ,10
    ENG141647-ENG141986-Außenlicht_Front-Abblendlicht_Leuchtentyp,H7 ,9
    ENG141647-ENG246962-Außenlicht_Front-ABL Redundanz Check sperren,not active ,9
    ENG141647-ENG116705-Außenlicht_Front-Allwetterlicht Ausschaltgrenze,350 km/h,9
    ENG141647-ENG116704-Außenlicht_Front-Allwetterlicht Einschaltgrenze,350 km/h,9
    ENG141647-ENG142193-Außenlicht_Front-Geschwindigkeitsabhaengiges TFL,5 km/h,9
    ENG141647-ENG115861-Außenlicht_Front-Lichthupe bei Zuendung aus moeglich,active ,9
    ENG141647-ENG115832-Außenlicht_Front-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active ,9
    ENG141647-ENG142191-Außenlicht_Front-Signaturlicht HMI-default Anzeige im Kombiinstrument,not active ,9
    ENG141647-ENG142190-Außenlicht_Front-Signaturlicht_verbaut,not installed ,9
    ENG141647-ENG116592-Außenlicht_Front-Standlicht aktiviert zusaetzlich Tagfahrlicht,active ,9
    ENG141647-ENG116594-Außenlicht_Front-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich,active ,9
    ENG141647-ENG122184-Außenlicht_Front-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active ,9
    ENG141647-ENG115734-Außenlicht_Front-Tagfahrlicht nur in Schalterstellung AUTO,not active ,9
    ENG141647-ENG116593-Außenlicht_Front-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active ,9
    ENG141647-ENG115860-Außenlicht_Front-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen ,9
    ENG141648-ENG141987-Aussenlicht_Heck-Bremslicht_ist_auch_Blinklicht,No ,5
    ENG141648-ENG115782-Aussenlicht_Heck-Nebelschlusslicht Warngeschwindigkeit,0 km/h,5
    ENG141648-ENG116636-Aussenlicht_Heck-Notbremsanzeige NBA,active ,5
    ENG141648-ENG115831-Aussenlicht_Heck-Schlusslicht mit Bremslichtfunktion,active ,5
    ENG141656-ENG142020-Außenlicht_uebergreifend-All-weather lights,not installed ,18
    ENG141656-ENG133381-Außenlicht_uebergreifend-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG133380-Außenlicht_uebergreifend-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement ,18
    ENG141656-ENG246968-Außenlicht_uebergreifend-CHo_LHo_Nachlauf,0 ms,18
    ENG141656-ENG115656-Außenlicht_uebergreifend-Coming Home Leuchten,Low beam ,18
    ENG141656-ENG116601-Außenlicht_uebergreifend-Coming Home Verbaustatus,automatic ,18
    ENG141656-ENG130581-Außenlicht_uebergreifend-Fahrlicht_Hinweis_mehrfach,active ,18
    ENG141656-ENG126818-Außenlicht_uebergreifend-Fahrlichtwarnung_Hinweis_Konfig,Hinweis_in_LDS-Stellung_Null_und_SL ,18
    ENG141656-ENG137034-Außenlicht_uebergreifend-Faktor fuer Verfuegbarkeitstimer,Faktor fuer x5 Minuten ,18
    ENG141656-ENG154619-Außenlicht_uebergreifend-Fernlicht_LH,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG154177-Außenlicht_uebergreifend-Fog light,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG116608-Außenlicht_uebergreifend-Helligkeitsschwelle Forward-Messung,46400 lx,18
    ENG141656-ENG116605-Außenlicht_uebergreifend-Helligkeitsschwelle Infrarot-Messung,12 lx,18
    ENG141656-ENG115858-Außenlicht_uebergreifend-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung ,18
    ENG141656-ENG142185-Außenlicht_uebergreifend-LCM_blinker,false ,18
    ENG141656-ENG141991-Außenlicht_uebergreifend-LDS_mit_Nebel_Schlusslicht,Yes ,18
    ENG141656-ENG141990-Außenlicht_uebergreifend-LDS_mit_Nebellicht,Yes ,18
    ENG141656-ENG141989-Außenlicht_uebergreifend-Lichtdrehschalter (LDS),discrete ,18
    ENG141656-ENG142034-Außenlicht_uebergreifend-Light_Control_Module,installed ,18
    ENG141656-ENG98354-Außenlicht_uebergreifend-Low beam,Sollspannungsanforderung 13.5 ,18
    ENG141656-ENG115863-Außenlicht_uebergreifend-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren ,18
    ENG141656-ENG116603-Außenlicht_uebergreifend-Menueeinstellung Cominghome,10 seconds ,18
    ENG141656-ENG116607-Außenlicht_uebergreifend-Menueeinstellung Leaving-home Zeit per BAP,10 seconds ,18
    ENG141656-ENG115859-Außenlicht_uebergreifend-Parklicht ueber LSS aktiviert,One-sided ,18
    ENG141656-ENG115829-Außenlicht_uebergreifend-Standlichtreduzierung mit beidseitigem Parklicht,active ,18
    ENG141656-ENG133383-Außenlicht_uebergreifend-Standlicht-Verfügbarkeit,24 s,18
    ENG141656-ENG154174-Außenlicht_uebergreifend-Turn signal,Sollspannungsanforderung 13.5 ,18
    ENG246955-ENG246967-digital_key-central_locking_digital_key_general,not installed ,3
    ENG246955-ENG246972-digital_key-komfortbedienung_fh_oeffnen_ueber_btle,not active ,3
    ENG246955-ENG246973-digital_key-komfortbedienung_fh_oeffnen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246974-digital_key-komfortbedienung_fh_oeffnen_ueber_nfc_fahrertuer,not active ,3
    ENG246955-ENG246975-digital_key-komfortbedienung_fh_schliessen_ueber_btle,not active ,3
    ENG246955-ENG246976-digital_key-komfortbedienung_fh_schliessen_ueber_btle_sonderfunktion,not active ,3
    ENG246955-ENG246977-digital_key-komfortbedienung_fh_schliessen_ueber_nfc_fahrertuer,not active ,3
    ENG122925-DWA_Interior_Monitoring_Data_Set_Development,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,150
    ENG122934-erase_error_table,00 00 00 ,3
    ENG141650-ENG141973-Fernlicht_assistent-Erweiterte_Fernlichtsteuerung,AFS: FLA: Fernlicht (GLW:MDF) ,6
    ENG141650-ENG116639-Fernlicht_assistent-Fernlichtassistent Reset,active ,6
    ENG141650-ENG116637-Fernlicht_assistent-Menuesteuerung Fernlichtassistent,present ,6
    ENG141650-ENG116641-Fernlicht_assistent-Menuesteuerung Fernlichtassistent Werkseinstellung,present ,6
    ENG141685-Front_wash_function,10 ,2
    ENG141682-ENG115835-Front_wiper-Adaptives Nachwischen bei SRA,not active ,6
    ENG141682-ENG142250-Front_wiper-Anfahrzeit_servicestellung,800 ms,6
    ENG141682-ENG116614-Front_wiper-Frontwischer Referenzlauf,active ,6
    ENG141682-ENG154620-Front_wiper-Frontwischer Spannungsanforderung_konfig,Keine_Spannungsanforderung ,6
    ENG141682-ENG154706-Front_wiper-Mindestwaschzeit_Frontwischer,0 ms,6
    ENG141682-ENG115771-Front_wiper-Regensensor aktivieren,Deactivating ,6
    ENG141682-ENG154790-Front_wiper-Timer_DWP_SRA_delay,300 ms,6
    ENG141682-ENG116618-Front_wiper-Traenenwischen Front Status,not active ,6
    ENG141682-ENG115770-Front_wiper-Variable Regensensoraktivierung,not active ,6
    ENG141682-ENG116612-Front_wiper-Wischer stop bei KL15 aus,not active ,6
    ENG141682-ENG122185-Front_wiper-Wischer Stopp bei Oeffnen der Motorhaube,active ,6
    ENG99457-ENG98971-Head area heater-Temperature,-2 ,2
    ENG141645-MAS00212-HW_Verbau-Insufficient washer fluid,installed ,8
    ENG141645-MAS00214-HW_Verbau-Brake pad wear,installed ,8
    ENG141645-ENG142026-HW_Verbau-Druckklappe,not installed ,8
    ENG141645-ENG142186-HW_Verbau-Ladesteckerverriegelung,not installed ,8
    ENG141645-ENG115809-HW_Verbau-Signalhorn ohne KL15,active ,8
    ENG141645-ENG142003-HW_Verbau-Status_Tankdeckelverriegelung,not active ,8
    ENG141660-ENG115658-Kennlinie_sLWR_Soll-x0,100.00 %,30
    ENG141660-ENG101574-Kennlinie_sLWR_Soll-X1,100.00 %,30
    ENG141660-ENG99557-Kennlinie_sLWR_Soll-X2,100.00 %,30
    ENG141660-ENG102140-Kennlinie_sLWR_Soll-X3,100.00 %,30
    ENG141660-ENG102936-Kennlinie_sLWR_Soll-X4,83.00 %,30
    ENG141660-ENG103548-Kennlinie_sLWR_Soll-X5,67.00 %,30
    ENG141660-ENG113992-Kennlinie_sLWR_Soll-X6,50.00 %,30
    ENG141660-ENG115661-Kennlinie_sLWR_Soll-x7,33.00 ,30
    ENG141660-ENG115662-Kennlinie_sLWR_Soll-x8,17.00 %,30
    ENG141660-ENG115663-Kennlinie_sLWR_Soll-x9,-0.00 %,30
    ENG141660-ENG115659-Kennlinie_sLWR_Soll-y0,64.0 %,30
    ENG141660-ENG99777-Kennlinie_sLWR_Soll-Y1,64.0 %,30
    ENG141660-ENG100480-Kennlinie_sLWR_Soll-Y2,64.0 %,30
    ENG141660-ENG100773-Kennlinie_sLWR_Soll-Y3,64.0 %,30
    ENG141660-ENG100631-Kennlinie_sLWR_Soll-Y4,57.0 %,30
    ENG141660-ENG102174-Kennlinie_sLWR_Soll-Y5,50.0 %,30
    ENG141660-ENG113993-Kennlinie_sLWR_Soll-Y6,42.0 %,30
    ENG141660-ENG115665-Kennlinie_sLWR_Soll-y7,27.0 %,30
    ENG141660-ENG115666-Kennlinie_sLWR_Soll-y8,22.0 %,30
    ENG141660-ENG115667-Kennlinie_sLWR_Soll-y9,15.0 %,30
    ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,0 ,16
    ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0,00 ,16
    ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,00 ,16
    ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,not active ,16
    ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,not active ,16
    ENG141657-ENG116159-Leuchte 35 LED Warnblinktaster C48-Fehlerort mittleres Byte DTC-DFCC 15,63 ,16
    ENG141657-ENG116157-Leuchte 35 LED Warnblinktaster C48-Lasttyp 15,41 - LED Kleinleistung ,16
    ENG141657-ENG116160-Leuchte 35 LED Warnblinktaster C48-Lichtfunktion A 15,Warnblinktaster_Suchbeleuchtung ,16
    ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,0 ,16
    ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10,00 ,16
    ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,00 ,16
    ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,not active ,16
    ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,not active ,16
    ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100 ,16
    ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12,22 ,16
    ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38 ,16
    ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer ,16
    ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links ,16
    ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active ,16
    ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100 ,16
    ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13,23 ,16
    ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42 ,16
    ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer ,16
    ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts ,16
    ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active ,16
    ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,127 ,16
    ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16,2A ,16
    ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,1A ,16
    ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,37 - allgemeine LED bis 12W ,16
    ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always ,16
    ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parking light right ,16
    ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active ,16
    ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,127 ,16
    ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17,29 ,16
    ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,0A ,16
    ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,37 - allgemeine LED bis 12W ,16
    ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always ,16
    ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active ,16
    ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,127 ,16
    ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,38 - LED Blinkleuchten ,16
    ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active ,16
    ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,127 ,16
    ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,38 - LED Blinkleuchten ,16
    ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active ,16
    ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,0 ,16
    ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1,00 ,16
    ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,00 ,16
    ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,not active ,16
    ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,not active ,16
    ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,127 ,16
    ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0 ,16
    ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20,2B ,16
    ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09 ,16
    ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten ,16
    ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active ,16
    ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,not active ,16
    ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,127 ,16
    ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0 ,16
    ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21,2D ,16
    ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19 ,16
    ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten ,16
    ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active ,16
    ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,not active ,16
    ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100 ,16
    ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,42 - LED dritte Bremsleuchte ,16
    ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,Quittierungsfunktion 1 ,16
    ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,127 ,16
    ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,0 ,16
    ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23,35 ,16
    ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W ,16
    ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,only_if_closed ,16
    ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,not active ,16
    ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active ,16
    ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,127 ,16
    ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,0 ,16
    ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24,36 ,16
    ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W ,16
    ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,only_if_closed ,16
    ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right ,16
    ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,not active ,16
    ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active ,16
    ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,127 ,16
    ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,not active ,16
    ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,127 ,16
    ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26,2E ,16
    ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C ,16
    ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,43 - allgemeine LED ,16
    ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,only_if_closed ,16
    ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,minimize ,16
    ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,127 ,16
    ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27,36 ,16
    ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1A ,16
    ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,32 - allgemeine LED bis 12W ,16
    ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,only_if_closed ,16
    ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,Brake light ,16
    ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr ,16
    ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,127 ,16
    ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,32 - allgemeine LED bis 12W ,16
    ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always ,16
    ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,127 ,16
    ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,32 - allgemeine LED bis 12W ,16
    ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always ,16
    ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize ,16
    ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,0 ,16
    ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,0 ,16
    ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,0 ,16
    ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2,00 ,16
    ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,00 ,16
    ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,not active ,16
    ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,not active ,16
    ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,not active ,16
    ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active ,16
    ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,not active ,16
    ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active ,16
    ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,89 ,16
    ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,36 - LED Kleinleistung ,16
    ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,0 ,16
    ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31,00 ,16
    ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,not active ,16
    ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,0 ,16
    ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32,00 ,16
    ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,not active ,16
    ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,0 ,16
    ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33,00 ,16
    ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,not active ,16
    ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,0 ,16
    ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34,00 ,16
    ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,not active ,16
    ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize ,16
    ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,0 ,16
    ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,0 ,16
    ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,0 ,16
    ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3,00 ,16
    ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,00 ,16
    ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,not active ,16
    ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,not active ,16
    ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,not active ,16
    ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active ,16
    ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,not active ,16
    ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active ,16
    ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize ,16
    ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,0 ,16
    ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,0 ,16
    ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4,00 ,16
    ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,00 ,16
    ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,not active ,16
    ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,not active ,16
    ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,not active ,16
    ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,not active ,16
    ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active ,16
    ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize ,16
    ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,0 ,16
    ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,0 ,16
    ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5,00 ,16
    ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,00 ,16
    ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,not active ,16
    ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,not active ,16
    ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,not active ,16
    ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,not active ,16
    ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active ,16
    ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127 ,16
    ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,0 ,16
    ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,5 - LED Abblendlicht ,16
    ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell ,16
    ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,not active ,16
    ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127 ,16
    ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,0 ,16
    ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,5 - LED Abblendlicht ,16
    ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell ,16
    ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,not active ,16
    ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,127 ,16
    ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,127 ,16
    ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8,4A ,16
    ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,44 ,16
    ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,5 - LED Abblendlicht ,16
    ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,Versorgungsbedarf der LCM Module ,16
    ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active ,16
    ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,Parking light right ,16
    ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,127 ,16
    ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,127 ,16
    ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9,49 ,16
    ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,3A ,16
    ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,5 - LED Abblendlicht ,16
    ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,Versorgungsbedarf der LCM Module ,16
    ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active ,16
    ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) ,16
    ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,Parklicht links (beidseitiges Parklicht aktiviert li & re) ,16
    ENG141661-Leuchtenkonfiguration_Aussenlich_Heck,26 08 00 16 02 00 7F 00 00 00 00 00 00 00 00 00 26 18 00 18 04 00 7F 00 00 00 00 00 00 00 00 00 22 09 00 2B 18 00 7F 00 00 00 00 00 00 00 00 00 22 19 00 2D 18 00 7F 00 00 00 00 00 00 00 00 00 2A 29 00 2C 18 24 64 00 00 00 00 00 00 00 00 00 20 0A 00 35 08 09 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 08 0A FF 00 00 00 00 00 00 00 00 00 2B 28 00 30 08 00 7F 00 00 00 00 00 00 00 00 00 2B 0C 00 2E 1B 00 FF 00 00 00 00 00 00 00 00 00 20 1A 00 36 18 00 FF 1B 00 80 00 00 00 00 00 00 20 0B 00 31 19 00 7F 00 00 00 00 00 00 00 00 00 20 1B 00 32 19 00 7F 00 00 00 00 00 00 00 00 00 ,192
    ENG141662-Leuchtenkonfiguration_Sonstiges,25 1A 00 2A 08 0A 7F 00 00 00 00 00 00 00 00 00 25 0A 00 29 08 09 7F 00 00 00 00 00 00 00 00 00 24 00 00 02 2B 00 59 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 29 00 00 63 4C 00 64 00 00 00 00 00 00 00 00 00 ,128
    ENG141658-ENG142219-Leuchtweitenregulierung-Achsabstand_des_Fahrzeuges,0 mm,62
    ENG141658-ENG142201-Leuchtweitenregulierung-Aktivierung_LWR_Fehlerlampe,not active ,62
    ENG141658-ENG142211-Leuchtweitenregulierung-Ansteuerung_obere_grenze,90.0 %,62
    ENG141658-ENG142210-Leuchtweitenregulierung-Ansteuerung_untere_grenze,10.0 %,62
    ENG141658-ENG154591-Leuchtweitenregulierung-Delay_DC_Motor_Versorgung,-127.0 ms,62
    ENG141658-ENG142214-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_1,-8.00 mm/%,62
    ENG141658-ENG142216-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_2,-8.00 mm/%,62
    ENG141658-ENG154599-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_H_3,-8.00 mm/%,62
    ENG141658-ENG142213-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_1,-8.00 mm/%,62
    ENG141658-ENG142215-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_2,-8.00 mm/%,62
    ENG141658-ENG154600-Leuchtweitenregulierung-fac_Pwm_Zu_Hoehe_V_3,-8.00 mm/%,62
    ENG141658-ENG142198-Leuchtweitenregulierung-Fahrwerk_Variante,Variante_1 ,62
    ENG141658-ENG142204-Leuchtweitenregulierung-Fail_Safe_sLWR,0.0 %,62
    ENG141658-ENG142223-Leuchtweitenregulierung-fFiltEinf,0.00 Hz,62
    ENG141658-ENG142212-Leuchtweitenregulierung-Lineare_Abbildung,normal ,62
    ENG141658-ENG142202-Leuchtweitenregulierung-Logik_PWM_Signal,Negative ,62
    ENG141658-ENG154702-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_1,0 mm,62
    ENG141658-ENG154703-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_2,0 mm,62
    ENG141658-ENG154704-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_3,0 mm,62
    ENG141658-ENG154705-Leuchtweitenregulierung-lwr_lEinfOffsHFahrw_4,0 mm,62
    ENG141658-ENG142220-Leuchtweitenregulierung-lwr_lFzg_Sw_Abstand,0 mm,62
    ENG141658-ENG142221-Leuchtweitenregulierung-lwr_lFzg_Sw_Hoehe,0 mm,62
    ENG141658-ENG142225-Leuchtweitenregulierung-lwr_pwm_untere_schwelle,2.5 %,62
    ENG141658-ENG142227-Leuchtweitenregulierung-max_v_slwr,0 km/h,62
    ENG141658-ENG142224-Leuchtweitenregulierung-pa_fFiltSwNeigung,0.00 Hz,62
    ENG141658-ENG142200-Leuchtweitenregulierung-Quelle_Hoehenwerte,BCM ,62
    ENG141658-ENG142042-Leuchtweitenregulierung-sensor_headlight_range_control_installed,Rear ,62
    ENG141658-ENG142199-Leuchtweitenregulierung-sLWR_bei_Abblendlicht,active ,62
    ENG141658-ENG142208-Leuchtweitenregulierung-sLWR_Hysterese,20.0 %,62
    ENG141658-ENG154776-Leuchtweitenregulierung-sLWR_nach_Motorstart,not active ,62
    ENG141658-ENG142207-Leuchtweitenregulierung-sLWR_SW_Grad,0.0 %/s,62
    ENG141658-ENG142206-Leuchtweitenregulierung-sLWR_Touristenlicht,-100.0 %,62
    ENG141658-ENG142196-Leuchtweitenregulierung-sLWR_verbaut,not installed ,62
    ENG141658-ENG142205-Leuchtweitenregulierung-Zyklus_sLWR,0.00 s,62
    ENG246957-ENG246963-Lichttaster-Anzeigezeit_LTM_PopUp1,2.0 s,7
    ENG246957-ENG246964-Lichttaster-Anzeigezeit_LTM_PopUp1_lang,10 s,7
    ENG246957-ENG246965-Lichttaster-Beleuchtung_Auto_LED_bei_Nebelfunktion,active ,7
    ENG246957-ENG246966-Lichttaster-Beleuchtung_LTM_Auto_LED_58xt_logik,active ,7
    ENG246957-ENG246978-Lichttaster-Licht_anforderung_FAS,Nicht_verbaut ,7
    ENG246957-ENG246979-Lichttaster-Licht_anforderung_Pilopark,not active ,7
    ENG246957-ENG246980-Lichttaster-Licht_Reaktivierungs_grenze,100 m,7
    ENG246957-ENG246981-Lichttaster-Lichttastermodul,lds ,7
    ENG246957-ENG246982-Lichttaster-LTM_Anzeige_Config,00000001  ,7
    ENG246957-ENG246983-Lichttaster-LTM_Beleuchtung_Geschwindigkeits_Schwelle,30 km/h,7
    ENG246957-ENG246984-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246985-Lichttaster-LTM_BGL_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246986-Lichttaster-LTM_BGL_Wegabhängig,active ,7
    ENG246957-ENG246987-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig,not active ,7
    ENG246957-ENG246988-Lichttaster-LTM_GlobalOFF_Geschwindigkeitsabhängig_Parameter,active ,7
    ENG246957-ENG246989-Lichttaster-LTM_GlobalOFF_Wegabhängig,active ,7
    ENG246957-ENG246990-Lichttaster-LTM_GlobalOFF_Zündungsabhängig,not active ,7
    ENG153727-ENG154566-LIN-SMLS_konfig_1-blinker_entprellen,40 ms,27
    ENG153727-ENG154578-LIN-SMLS_konfig_1-blinker_gra_entprellen,40 ms,27
    ENG153727-ENG154579-LIN-SMLS_konfig_1-blinker_sperrzeit,100 ms,27
    ENG153727-ENG154597-LIN-SMLS_konfig_1-erkennung_fahrt,10 ms,27
    ENG153727-ENG154618-LIN-SMLS_konfig_1-fas_entprellen,40 ms,27
    ENG153727-ENG154624-LIN-SMLS_konfig_1-grahebel_entprellen,40 ms,27
    ENG153727-ENG154634-LIN-SMLS_konfig_1-grenze_v,1 km/h,27
    ENG153727-ENG154686-LIN-SMLS_konfig_1-hupe_entprellen,40 ms,27
    ENG153727-ENG154690-LIN-SMLS_konfig_1-hupe_indien_entprellen,500 ms,27
    ENG153727-ENG154692-LIN-SMLS_konfig_1-k_i,0.40 ,27
    ENG153727-ENG154693-LIN-SMLS_konfig_1-k_i_offset,5 °C,27
    ENG153727-ENG154694-LIN-SMLS_konfig_1-k_p,18.0 %,27
    ENG153727-ENG154695-LIN-SMLS_konfig_1-leistung_lrh,110 W,27
    ENG153727-ENG154699-LIN-SMLS_konfig_1-lrh_entprellen,40 ms,27
    ENG153727-ENG154713-LIN-SMLS_konfig_1-pwm_lrh,25 Hz,27
    ENG153727-ENG154773-LIN-SMLS_konfig_1-s_NWDF_spg,0 ,27
    ENG153727-ENG154777-LIN-SMLS_konfig_1-soll_0,34 °C,27
    ENG153727-ENG154778-LIN-SMLS_konfig_1-soll_1,39 °C,27
    ENG153727-ENG154779-LIN-SMLS_konfig_1-soll_2,44 °C,27
    ENG153727-ENG154786-LIN-SMLS_konfig_1-speedlimiter_entprellen,40 ms,27
    ENG153727-ENG154788-LIN-SMLS_konfig_1-temlenkradheizung_aus,50 °C,27
    ENG153727-ENG154804-LIN-SMLS_konfig_1-verriegelt_entprellen,0 ms,27
    ENG153727-ENG246995-LIN-SMLS_konfig_1-w_zss_direktansteuerung,0 ms,27
    ENG153727-ENG154811-LIN-SMLS_konfig_1-wischer_entprellen,40 ms,27
    ENG153727-ENG154823-LIN-SMLS_konfig_1-wischer_intervall_entprellen,40 ms,27
    ENG153727-ENG154824-LIN-SMLS_konfig_1-wischer_winterstellung,60 s,27
    ENG153727-ENG154830-LIN-SMLS_konfig_1-zeit_temperatur_statisch_lrh,30 s,27
    ENG153728-IDE00329-LIN-SMLS_konfig_2-Buttons for multi-function display,not installed ,2
    ENG153728-IDE02694-LIN-SMLS_konfig_2-Signal horn activation,Always ,2
    ENG153728-IDE02711-LIN-SMLS_konfig_2-Rear Window Wiper,installed ,2
    ENG153728-IDE02745-LIN-SMLS_konfig_2-Ignition key removal lock,not installed ,2
    ENG153728-MAS00128-LIN-SMLS_konfig_2-Distance Regulation,not installed ,2
    ENG153728-MAS00242-LIN-SMLS_konfig_2-Driver assistance systems button,not installed ,2
    ENG153728-MAS05091-LIN-SMLS_konfig_2-CCS Switch,not installed ,2
    ENG153728-MAS06090-LIN-SMLS_konfig_2-CCS on turn signal switch,not installed ,2
    ENG153728-MAS06091-LIN-SMLS_konfig_2-Contact bounce suppression for signal horn,not active ,2
    ENG153728-MAS08540-LIN-SMLS_konfig_2-reading P locked,not active ,2
    ENG153728-ENG154465-LIN-SMLS_konfig_2-diagnosis limitation,not active ,2
    ENG153728-ENG154623-LIN-SMLS_konfig_2-gra_grahebel_2_st,not installed ,2
    ENG153728-ENG154461-LIN-SMLS_konfig_2-speed_limiter_button,not installed ,2
    ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.0 %,12
    ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.0 %,12
    ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.0 %,12
    ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.0 ,12
    ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.5 ,12
    ENG141659-ENG115658-lwr_ofs_RSw_Ah1S-x0,-5.00 %,20
    ENG141659-ENG101574-lwr_ofs_RSw_Ah1S-X1,-5.00 %,20
    ENG141659-ENG99557-lwr_ofs_RSw_Ah1S-X2,-5.00 %,20
    ENG141659-ENG102140-lwr_ofs_RSw_Ah1S-X3,-5.00 %,20
    ENG141659-ENG102936-lwr_ofs_RSw_Ah1S-X4,-5.00 %,20
    ENG141659-ENG115659-lwr_ofs_RSw_Ah1S-y0,-5.00 ,20
    ENG141659-ENG99777-lwr_ofs_RSw_Ah1S-Y1,-5.00 ,20
    ENG141659-ENG100480-lwr_ofs_RSw_Ah1S-Y2,-5.00 ,20
    ENG141659-ENG100773-lwr_ofs_RSw_Ah1S-Y3,-5.00 ,20
    ENG141659-ENG100631-lwr_ofs_RSw_Ah1S-Y4,-5.00 ,20
    ENG122979-ENG141954-Networking-A/C electronics,installed ,8
    ENG122979-ENG141968-Networking-Anhaengeranschlussgeraet,not installed ,8
    ENG122979-ENG141974-Networking-Bremsen_Steuergeraet,installed ,8
    ENG122979-ENG141953-Networking-Getriebesteuergeraet,installed ,8
    ENG122979-ENG99457-Networking-Head area heater,not installed ,8
    ENG122979-ENG142040-Networking-Kunden_spezifisches_Funktions_SG,not installed ,8
    ENG122979-ENG141969-Networking-UGDO,not installed ,8
    ENG124714-ENG142044-OCU-DWA_push,active ,8
    ENG124714-ENG142260-OCU-Honk DWA_Ausgabe_Fanfare,active ,8
    ENG124714-ENG246970-OCU-IAA -Nutzer_management,not installed ,8
    ENG124714-OCU-,installed ,8
    ENG124714-ENG142261-OCU-Remote HuF Abbruch,20 km/h,8
    ENG124714-ENG142262-OCU-Remote HuF Hupfrequenz,3 Hz,8
    ENG124714-ENG133391-OCU-Remote Lock Unlock Timer s1,80 s,8
    ENG124714-ENG133392-OCU-Remote Lock Unlock Timer s3,2000 ms,8
    ENG124714-ENG125657-OCU-Remote_Unlock_Lock,Via BAP / Fazit ,8
    ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten,4 ,16
    ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG126848-Personalization-Personalisierung_aktiv,active ,16
    ENG98831-ENG141994-Personalization-Personalisierung_Profilfunkion,profiles_active ,16
    ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,active ,16
    ENG98831-ENG142030-Personalization-Profil_Variante,Konto (v. 1.x) ,16
    ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1,active ,16
    ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2,active ,16
    ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3,not active ,16
    ENG141646-MAS01065-Querschnitts_funktionen-Brand,VW ,5
    ENG141646-ENG116624-Querschnitts_funktionen-CAN Wecken bei Softtouchbetaetigung,active ,5
    ENG141646-ENG142028-Querschnitts_funktionen-Fahrgeschwindigkeit_aus_ESP_21,active ,5
    ENG141646-ENG142187-Querschnitts_funktionen-Hardware_Eingang_Drucktankklappenstatus,Pin A31 ,5
    ENG141646-ENG154685-Querschnitts_funktionen-Hupe,Sollspannungsanforderung 13.5 ,5
    ENG141646-ENG142015-Querschnitts_funktionen-Personalisierungsuebernahme,not_installed ,5
    ENG141646-ENG141964-Querschnitts_funktionen-Steering alignment,Left ,5
    ENG141646-ENG141965-Querschnitts_funktionen-Traffic side,Right ,5
    ENG122927-RLS_close_glazing,2.0 s,1
    ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off,120 s,3
    ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on,10 s,3
    ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off,65 km/h,3
    ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on,140 km/h,3
    ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_regenlichtschwelle,6000 lx,2
    ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high,12 ,2
    ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low,6 ,2
    ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht,30 s,2
    ENG122929-RLS_LIN_Communication,4 s,1
    ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn,200 lx,1
    ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day,500 lx,1
    ENG122930-RLS_tunel_gateway_recognize,5 s,1
    ENG122935-RLS_Washer_Front,15 s,1
    ENG122926-RLS_wiper_position_parking,15 s,1
    ENG115729-ENG116609-Scheinwerferreinigung-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10 ,10
    ENG115729-ENG141949-Scheinwerferreinigung-Headlamp washer system,not installed ,10
    ENG115729-ENG115769-Scheinwerferreinigung-SRA bei Waschwassermangel,active ,10
    ENG115729-ENG115767-Scheinwerferreinigung-SRA Einweichpausenzeit,2000 ms,10
    ENG115729-ENG115768-Scheinwerferreinigung-SRA Nachwaschzeit,800 ms,10
    ENG115729-ENG116611-Scheinwerferreinigung-SRA Pausenzeit,0 ms,10
    ENG115729-ENG116610-Scheinwerferreinigung-SRA Verzoegerungszeit,0 ms,10
    ENG115729-ENG115766-Scheinwerferreinigung-SRA Waschzeit,800 ms,10
    ENG115729-ENG154424-Scheinwerferreinigung-Waschen,Keine_Spannungsanforderung ,10
    ENG153742-ENG154567-SMLS_konfig_entw-blinker_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154568-SMLS_konfig_entw-blinker_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154569-SMLS_konfig_entw-blinker_err_fernlicht_haengt_aus,5000 ms,48
    ENG153742-ENG154570-SMLS_konfig_entw-blinker_err_fernlicht_haengt_ein,300 s,48
    ENG153742-ENG154571-SMLS_konfig_entw-blinker_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154572-SMLS_konfig_entw-blinker_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154573-SMLS_konfig_entw-blinker_err_lichthupe_haengt_aus,5000 ms,48
    ENG153742-ENG154574-SMLS_konfig_entw-blinker_err_lichthupe_haengt_ein,300 s,48
    ENG153742-ENG154575-SMLS_konfig_entw-blinker_err_unplausibel,200 ms,48
    ENG153742-ENG154576-SMLS_konfig_entw-blinker_err_weckkontakthaengt_aus,0 ms,48
    ENG153742-ENG154577-SMLS_konfig_entw-blinker_err_weckkontakthaengt_ein,0 ms,48
    ENG153742-ENG154594-SMLS_konfig_entw-entprellung_unplausibel,0 ms,48
    ENG153742-ENG154595-SMLS_konfig_entw-entprellzeit_ueberspannung,90000 ms,48
    ENG153742-ENG154596-SMLS_konfig_entw-entprellzeit_unterspannung,90000 ms,48
    ENG153742-ENG154622-SMLS_konfig_entw-gra_ea_error,200 ms,48
    ENG153742-ENG154625-SMLS_konfig_entw-grahebel_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154626-SMLS_konfig_entw-grahebel_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154627-SMLS_konfig_entw-grahebel_err_gra_haengt_aus,5000 ms,48
    ENG153742-ENG154628-SMLS_konfig_entw-grahebel_err_gra_haengt_ein,300 s,48
    ENG153742-ENG154629-SMLS_konfig_entw-grahebel_err_unplausibel,200 ms,48
    ENG153742-ENG154687-SMLS_konfig_entw-hupe_err_hinweis,2000 ms,48
    ENG153742-ENG154688-SMLS_konfig_entw-hupe_err_hupe_haengt_aus,5000 ms,48
    ENG153742-ENG154689-SMLS_konfig_entw-hupe_err_hupe_haengt_ein,60 s,48
    ENG153742-ENG154700-SMLS_konfig_entw-lrh_kurzschluss_entprellen,20 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 ms,48
    ENG153742-ENG154701-SMLS_konfig_entw-lrh_unterbrechung_entprellen,0 s,48
    ENG153742-ENG154707-SMLS_konfig_entw-n_fehler_verriegelt,0 ,48
    ENG153742-ENG154780-SMLS_konfig_entw-spannung_obere_schwelle,16.5 V,48
    ENG153742-ENG154781-SMLS_konfig_entw-spannung_obere_schwelle_funkt_einschr,15.5 V,48
    ENG153742-ENG154782-SMLS_konfig_entw-spannung_untere_schwelle,8.5 V,48
    ENG153742-ENG154783-SMLS_konfig_entw-spannung_untere_schwelle_funkt_einschr,8.5 V,48
    ENG153742-ENG154805-SMLS_konfig_entw-verriegelt_err_el_kurzschluss,0 ms,48
    ENG153742-ENG154806-SMLS_konfig_entw-verriegelt_err_unplausibel_aus,0 ms,48
    ENG153742-ENG154807-SMLS_konfig_entw-verriegelt_err_unplausibel_ein,0 ms,48
    ENG153742-ENG154808-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_aus,0 ms,48
    ENG153742-ENG154809-SMLS_konfig_entw-verriegelt_err_unplausibel_in_parkposition_ein,0 s,48
    ENG153742-ENG154812-SMLS_konfig_entw-wischer_err_el_kurzschluss,200 ms,48
    ENG153742-ENG154813-SMLS_konfig_entw-wischer_err_el_unterbrechung,1000 ms,48
    ENG153742-ENG154814-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_aus,0.0 s,48
    ENG153742-ENG154815-SMLS_konfig_entw-wischer_err_intervallpoti_haengt_ein,0 s,48
    ENG153742-ENG154816-SMLS_konfig_entw-wischer_err_mfa_haengt_aus,5000 ms,48
    ENG153742-ENG154817-SMLS_konfig_entw-wischer_err_mfa_haengt_ein,300 s,48
    ENG153742-ENG154818-SMLS_konfig_entw-wischer_err_unplausibel,200 ms,48
    ENG153742-ENG154819-SMLS_konfig_entw-wischer_err_waschen_haengt_aus,5000 ms,48
    ENG153742-ENG154820-SMLS_konfig_entw-wischer_err_waschen_haengt_ein,300 s,48
    ENG153742-ENG154821-SMLS_konfig_entw-wischer_err_wischen_haengt_aus,5000 ms,48
    ENG153742-ENG154822-SMLS_konfig_entw-wischer_err_wischen_haengt_ein,300 s,48
    ENG116588-ENG248517-Sonderfunktionen-Blinkerueberwachug Sonderfunktions-SG,not installed ,4
    ENG116588-ENG116589-Sonderfunktionen-Signalprioritaet fuer Blinker,MFG ,4
    ENG141635-ENG116658-Spiegelverstellung-Funk Spiegelanklappen,active ,5
    ENG141635-ENG116665-Spiegelverstellung-Funk Spiegelanklappung Modus,by look command via remote control key ,5
    ENG141635-ENG116660-Spiegelverstellung-Menuesteuerung Funk Spiegel anklappen,active ,5
    ENG141635-ENG116657-Spiegelverstellung-Menuesteuerung Spiegelabsenkung,active ,5
    ENG141635-ENG116659-Spiegelverstellung-Menuesteuerung synchrone Spiegelverstellung,active ,5
    ENG141635-ENG126841-Spiegelverstellung-Profilfunktion fuer Anklappung der Aussenspiegel,active ,5
    ENG141635-ENG116650-Spiegelverstellung-Spiegelabsenkung bei Rueckwaertsfahrt,active ,5
    ENG141635-ENG133411-Spiegelverstellung-Spiegelanklappen_bei_Wiederverriegelung,active ,5
    ENG141635-ENG116656-Spiegelverstellung-Spiegelverstellung Synchron,active ,5
    ENG153700-ENG154515-Steering Column Switch-Anzahl_fehler_P-verriegelt,250 ,10
    ENG153700-ENG154621-Steering Column Switch-Geschwindigkeitesschwele_erkennung_fahrt_P_plausibel,10 km/h,10
    ENG153700-ENG154803-Steering Column Switch-Verbauort_Lenkstockschalter,LIN ,10
    ENG153700-ENG154828-Steering Column Switch-Zeit_erkennung_fahrt_für_P_plausibel,2000 ms,10
    ENG153700-ENG154829-Steering Column Switch-Zeit_t_P-verriegelt_entprellen,40 ms,10
    ENG141666-ENG101574-Suchbeleuchtung_Abdimmen-X1,200 ms,22
    ENG141666-ENG115664-Suchbeleuchtung_Abdimmen-x10,2000 ms,22
    ENG141666-ENG99557-Suchbeleuchtung_Abdimmen-X2,400 ms,22
    ENG141666-ENG102140-Suchbeleuchtung_Abdimmen-X3,600 ms,22
    ENG141666-ENG102936-Suchbeleuchtung_Abdimmen-X4,800 ms,22
    ENG141666-ENG103548-Suchbeleuchtung_Abdimmen-X5,1000 ms,22
    ENG141666-ENG113992-Suchbeleuchtung_Abdimmen-X6,1200 ms,22
    ENG141666-ENG115661-Suchbeleuchtung_Abdimmen-x7,1400 ms,22
    ENG141666-ENG115662-Suchbeleuchtung_Abdimmen-x8,1600 ms,22
    ENG141666-ENG115663-Suchbeleuchtung_Abdimmen-x9,1800 ms,22
    ENG141666-ENG99777-Suchbeleuchtung_Abdimmen-Y1,100.0 %,22
    ENG141666-ENG100480-Suchbeleuchtung_Abdimmen-Y2,95.0 %,22
    ENG141666-ENG100773-Suchbeleuchtung_Abdimmen-Y3,80.0 %,22
    ENG141666-ENG100631-Suchbeleuchtung_Abdimmen-Y4,40.0 %,22
    ENG141666-ENG102174-Suchbeleuchtung_Abdimmen-Y5,20.0 %,22
    ENG141666-ENG113993-Suchbeleuchtung_Abdimmen-Y6,10.0 %,22
    ENG141666-ENG115665-Suchbeleuchtung_Abdimmen-y7,5.0 %,22
    ENG141666-ENG115666-Suchbeleuchtung_Abdimmen-y8,3.0 %,22
    ENG141666-ENG115667-Suchbeleuchtung_Abdimmen-y9,1.0 %,22
    ENG141663-ENG154582-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xs_PWM,0.00 s,21
    ENG141663-ENG154583-Suchbeleuchtung_allgemein-Daempfung_Abdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG154584-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xd_PWM,0.00 s,21
    ENG141663-ENG154585-Suchbeleuchtung_allgemein-Daempfung_Aufdimmen_KL_58xt_PWM,0.00 s,21
    ENG141663-ENG141988-Suchbeleuchtung_allgemein-Eingabemedium_Suchbeleuchtung,HMI ,21
    ENG141663-ENG142242-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Abdimmen,20.0 s,21
    ENG141663-ENG142241-Suchbeleuchtung_allgemein-Helligkeit_RLS_Daempfung_Aufdimmen,3.0 s,21
    ENG141663-ENG116599-Suchbeleuchtung_allgemein-KL58 Verriegelungsausschalten,not_active ,21
    ENG141663-ENG142243-Suchbeleuchtung_allgemein-pa_Hysterese_RLS,2 ,21
    ENG141663-ENG154712-Suchbeleuchtung_allgemein-PWM_Daempfung_Aufdimmen_KL58xs_PWM,0.00 s,21
    ENG141663-ENG115631-Suchbeleuchtung_allgemein-Suchbeleuchtung Festwert,100 %,21
    ENG141663-ENG115821-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Faktor,0.100 ,21
    ENG141663-ENG115820-Suchbeleuchtung_allgemein-Warnblinktastersuchbeleuchtung Grundwert,6.0 %,21
    ENG141667-ENG99777-Suchbeleuchtung_Fotosensor-Y1,50 lx,22
    ENG141667-ENG100480-Suchbeleuchtung_Fotosensor-Y2,100 lx,22
    ENG141667-ENG100773-Suchbeleuchtung_Fotosensor-Y3,200 ,22
    ENG141665-ENG101574-Suchbeleuchtung_Hochdimmen-X1,200 ms,22
    ENG141665-ENG115664-Suchbeleuchtung_Hochdimmen-x10,2000 ms,22
    ENG141665-ENG99557-Suchbeleuchtung_Hochdimmen-X2,400 ms,22
    ENG141665-ENG102140-Suchbeleuchtung_Hochdimmen-X3,600 ms,22
    ENG141665-ENG102936-Suchbeleuchtung_Hochdimmen-X4,800 ms,22
    ENG141665-ENG103548-Suchbeleuchtung_Hochdimmen-X5,1000 ms,22
    ENG141665-ENG113992-Suchbeleuchtung_Hochdimmen-X6,1200 ms,22
    ENG141665-ENG115661-Suchbeleuchtung_Hochdimmen-x7,1400 ms,22
    ENG141665-ENG115662-Suchbeleuchtung_Hochdimmen-x8,1600 ms,22
    ENG141665-ENG115663-Suchbeleuchtung_Hochdimmen-x9,1800 ms,22
    ENG141665-ENG99777-Suchbeleuchtung_Hochdimmen-Y1,1.0 %,22
    ENG141665-ENG100480-Suchbeleuchtung_Hochdimmen-Y2,3.0 %,22
    ENG141665-ENG100773-Suchbeleuchtung_Hochdimmen-Y3,5.0 %,22
    ENG141665-ENG100631-Suchbeleuchtung_Hochdimmen-Y4,11.0 %,22
    ENG141665-ENG102174-Suchbeleuchtung_Hochdimmen-Y5,22.0 %,22
    ENG141665-ENG113993-Suchbeleuchtung_Hochdimmen-Y6,40.0 %,22
    ENG141665-ENG115665-Suchbeleuchtung_Hochdimmen-y7,80.0 %,22
    ENG141665-ENG115666-Suchbeleuchtung_Hochdimmen-y8,95.0 %,22
    ENG141665-ENG115667-Suchbeleuchtung_Hochdimmen-y9,100.0 %,22
    ENG141668-ENG102140-Suchbeleuchtung_KL 58xs min-X3,510 lx,8
    ENG141677-ENG99557-Suchbeleuchtung_KL_58xd_PWM-X2,50 ,12
    ENG141677-ENG102140-Suchbeleuchtung_KL_58xd_PWM-X3,100 ,12
    ENG141677-ENG115659-Suchbeleuchtung_KL_58xd_PWM-y0,2.0 %,12
    ENG141677-ENG99777-Suchbeleuchtung_KL_58xd_PWM-Y1,2.0 %,12
    ENG141677-ENG100480-Suchbeleuchtung_KL_58xd_PWM-Y2,6.0 %,12
    ENG141677-ENG100773-Suchbeleuchtung_KL_58xd_PWM-Y3,10.0 %,12
    ENG141677-ENG100631-Suchbeleuchtung_KL_58xd_PWM-Y4,80.0 %,12
    ENG141680-ENG101574-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X1,10 lx,12
    ENG141680-ENG99557-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X2,100 lx,12
    ENG141680-ENG102140-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-X3,500 lx,12
    ENG141680-ENG99777-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y1,20 ,12
    ENG141680-ENG100480-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y2,80 ,12
    ENG141680-ENG100773-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y3,180 ,12
    ENG141680-ENG100631-Suchbeleuchtung_Regen_Licht_Sensor_Mapping_Kennlinie-Y4,300 ,12
    ENG141632-ENG116647-Sunroof-SAD Komfort oeffnen,not active ,4
    ENG141632-ENG116646-Sunroof-SAD Komfort schliessen,not active ,4
    ENG141632-ENG116645-Sunroof-SAD Richtung Komfortoeffnen,tilting ,4
    ENG141632-ENG141970-Sunroof-Schiebedachmodul_MD_1,not installed ,4
    ENG141632-ENG141972-Sunroof-Schiebedachmodul_MD_Rollo,not installed ,4
    ENG141632-ENG142022-Sunroof-Verortung Schiebedachmodule,LIN ,4
    ENG141634-ENG116716-Verdecksteuergeraet-Doppelpuls nur Verdeck,active ,9
    ENG141634-ENG128459-Verdecksteuergeraet-easycloselight_aktiv,active ,9
    ENG141634-ENG116718-Verdecksteuergeraet-Heckdeckel sperren bei Verdeckbetrieb,not active ,9
    ENG141634-ENG142259-Verdecksteuergeraet-Kick_and_close,not installed ,9
    ENG141634-ENG116711-Verdecksteuergeraet-Komfortbedienung Verdeck global,active ,9
    ENG141634-ENG122189-Verdecksteuergeraet-Komfortbedienung Verdeck oeffnen,active ,9
    ENG141634-ENG116712-Verdecksteuergeraet-Komfortbedienung Verdeck schließen,active ,9
    ENG141634-ENG125654-Verdecksteuergeraet-Nachsaven_nach_Verdecklauf,not active ,9
    ENG141634-ENG126630-Verdecksteuergeraet-Reichweitenbegrenzung fuer Servoheck schliessen,active ,9
    ENG141634-ENG125652-Verdecksteuergeraet-Servoheck Schlossansteuerung,nur wenn mind. 1 Raste zu ,9
    ENG141634-ENG126838-Verdecksteuergeraet-Softtouch-Betaetigung senden,Always ,9
    ENG141634-ENG142011-Verdecksteuergeraet-trunk_lid_conrol_unit,installed ,9
    ENG141634-ENG122191-Verdecksteuergeraet-Verdeck oeffnen via Funkfernbedienung,active ,9
    ENG141634-ENG122192-Verdecksteuergeraet-Verdeck oeffnen via Kessy,active ,9
    ENG141634-ENG122190-Verdecksteuergeraet-Verdeck oeffnen via Schliesszylinder,active ,9
    ENG141634-ENG116714-Verdecksteuergeraet-Verdeck schließen via Funkfernbedienung,active ,9
    ENG141634-ENG116715-Verdecksteuergeraet-Verdeck schließen via Kessy,active ,9
    ENG141634-ENG116713-Verdecksteuergeraet-Verdeck schließen via Schließzylinder,active ,9
    ENG141634-ENG115869-Verdecksteuergeraet-Virtuelles_Pedal,active ,9
    ENG141634-ENG126611-Verdecksteuergeraet-virtuelles_pedal_HMI_einstellbar,active ,9
    ENG141634-ENG142257-Verdecksteuergeraet-Virtuelles_Pedal_Verbau,installed ,9
    ENG141634-ENG246994-Verdecksteuergeraet-Virtuelles_Pedal_Version,Version_1_2 ,9
    ENG124901-Wischer_Fehlermaske_Mitsuba_Entw,0 bit,4
    ENG116832-ENG126852-Wischgeschwindigkeiten-Dauerwischen Stufe_1 Zyklen pro Minute,40 ,3
    ENG116832-ENG126853-Wischgeschwindigkeiten-Dauerwischen Stufe_2 Zyklen pro Minute,60 ,3
    ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute,30 ,3
    ENG141651-ENG126837-ZV allgemein-Entsafen mit autorisierte Klemme 15 Ein,active ,7
    ENG141651-ENG115754-ZV allgemein-Funk bei Klemme 15 ein,active ,7
    ENG141651-ENG141981-ZV allgemein-Lock_Unlock_Taster_direkt,not installed ,7
    ENG141651-ENG142019-ZV allgemein-Lock_Unlock_Toggle_Taster,not installed ,7
    ENG141651-ENG115755-ZV allgemein-Notschließfunktion,active ,7
    ENG141651-ENG141957-ZV allgemein-Radio freq.,434.42MHz ,7
    ENG141651-ENG141958-ZV allgemein-Tankschloss,Bidirectional ,7
    ENG141651-ENG133390-ZV allgemein-Wiederverriegelung_Laderaum,ZV_Wiederveriegelung ,7
    ENG141651-ENG116623-ZV allgemein-ZV Tuerentriegelung,Globale Entriegelung ,7
    ENG141651-ENG141996-ZV allgemein-ZV_ohne_Safe_Funktion,not installed ,7
    ENG141654-ENG115756-ZV Autolock-automatisches Verriegeln bei Geschwindigkeit,not active ,3
    ENG141654-ENG116706-ZV Autolock-Autounlock NAR,not active ,3
    ENG141654-ENG116622-ZV Autolock-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active ,3
    ENG141654-ENG116634-ZV Autolock-Menuesteuerung ZV Autolock-Unlock,adjustable ,3
    ENG141655-ENG116661-ZV Crash-SAD PreCrash Konturschliessen,not active ,4
    ENG141655-ENG116635-ZV Crash-ZV-Entriegelung nach Seitencrash,not active ,4
    ENG141653-ENG115759-ZV Heck-Direkter Auswurf des Heckdeckels,active ,7
    ENG141653-ENG142016-ZV Heck-Heckdeckelentriegelung_HDF_Innentaster,via_CAN ,7
    ENG141653-ENG133386-ZV Heck-Heckfreigabe_Ohne_Verzoegerung,not active ,7
    ENG141653-ENG142245-ZV Heck-Heckoeffnung_ueber_2_Bedienhandlungen,not active ,7
    ENG141653-ENG141998-ZV Heck-Heckschloss_mit_Vorraste,Yes ,7
    ENG141653-ENG141995-ZV Heck-Heckschloss_Steuerung,Kontaktsteuerung mit Mindestansteuerzeit ,7
    ENG141653-ENG137162-ZV Heck-Mindestbetaetigung_HDF_Innentaster,0.0 s,7
    ENG141653-ENG115761-ZV Heck-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active ,7
    ENG141681-IDE02022-ZV Komfort-Comfort opening,not active ,8
    ENG141681-ENG116663-ZV Komfort-Fahrertuerbedienung Fensterheber oeffnen,active ,8
    ENG141681-ENG116664-ZV Komfort-Fahrertuerbedienung Fensterheber schliessen,active ,8
    ENG141681-ENG116652-ZV Komfort-Funk Komfort oeffnen,active ,8
    ENG141681-ENG116651-ZV Komfort-Funk Komfort schliessen,active ,8
    ENG141681-ENG246991-ZV Komfort-pa_Two_Keys,not active ,8
    ENG141681-ENG116643-ZV Komfort-Schliesszylinder Komfort oeffnen,not active ,8
    ENG141681-ENG116644-ZV Komfort-Schliesszylinder Komfort schliessen,not active ,8
    ENG141652-ENG141999-ZV Türkonfiguration-Fond_Schloss,2-Motorenschloesser ,5
    ENG141652-ENG142000-ZV Türkonfiguration-Schlosstyp_NAR,No ,5
    Elapsed Time: 02:36
    10
    ;SW:3Q0-919-298-C   HW:3Q0-919-298 ---  Park/Steer Assist
    ;Component:PLA 3.0 12K   H09 0038, Coding:0231563851
    ;EV_EPHBO2CVW3260000,010019,EV_EPHBO2CVW3260000.rod
    ;Sunday,17,March,2019,17:55:45:21782
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: BD32B2CB2C2438A276-80E8
    IDE00001-Production mode,Deactivating ,3
    IDE00845-Wheel circ.,2233 mm,2
    IDE01165-Park assist activation tone,On ,1
    IDE01167-Convertible offset for volume level 1,20 ,1
    IDE01168-Increment for convertible volume levels,20 ,1
    IDE01169-Audio reduction request,On ,1
    IDE02328-Distance to curb,15 cm,1
    IDE02329-Allowance for vehicle fittings (width),0 cm,1
    IDE02333-Allowance for vehicle fittings (length),0 cm,1
    IDE03782-Switch-off speed for parking assist,15 km/h,1
    IDE03783-Switch-on speed for parallel parking assist,45 km/h,1
    IDE04159-Deactivation of start-stop function,Start-stop function in control module not active ,1
    IDE05274-Acoustic warning for rear lid assistant,Parking aid active ,1
    IDE11215-Automatic Activation,activated ,1
    IDE11217-Show parking space,not activated ,1
    MAS01426-Speaker volume for rear park assist,Stage 4 ,1
    MAS01427-Speaker frequency for rear park assist,Stage 1 ,1
    MAS01428-Speaker volume for front park assist,Stage 4 ,1
    MAS01429-Speaker frequency for front park assist,Stage 7 ,1
    MAS10106-MAS10103-ARA angle control parameter-Max. controllable corners,0.230 1/m,6
    MAS10106-MAS10104-ARA angle control parameter-Max. selectable corners,0.160 1/m,6
    MAS10106-MAS10105-ARA angle control parameter-Vehicle overhang,0.985 m,6
    MAS12129-Customer-oriented off-road trip,not activated ,1
    MAS12843-Maneuvering brake function,Parking aid active ,1
    Elapsed Time: 00:12
    13
    ;SW:2Q0-907-572-Q   HW:2Q0-907-572-B ---  Auto Dist. Reg
    ;Component:ACCCONTIMQB   H03 0342, Coding:320467C358FF8728749C810580408700000000000000000000
    ;EV_ACCMRRCONTIVW376,003015,EV_ACCMRRCONTIVW376.rod
    ;Sunday,17,March,2019,17:56:13:21782
    ;VCID: C2C8C13755DA475A0B-8096
    IDE00820-ENG132029-Activating and deactivating all development messages-Development Message ECU specific,OFF ,1
    IDE00820-ENG102778-Activating and deactivating all development messages-development message S100,OFF ,1
    IDE00820-ENG101934-Activating and deactivating all development messages-development message S101,OFF ,1
    IDE00820-ENG103391-Activating and deactivating all development messages-development message S102,OFF ,1
    IDE00820-ENG132030-Activating and deactivating all development messages-XCP on FlexRay,OFF ,1
    IDE01949-Distance basic setting option,On ,1
    IDE03642-Presentation mode,not active ,1
    IDE05815-Sail function,Deactivating ,1
    IDE08935-Expanded restart function,On ,1
    IDE09564-Distance change via speed adjustment,On ,1
    IDE09565-Prioritized target object display,OFF ,1
    IDE10280-Constant delay after transfer request,No ,1
    IDE13334-Reduced radar performance,38 ,1
    Elapsed Time: 00:06
    15
    ;SW:5Q0-959-655-BT   HW:5Q0-959-655-BT ---  Airbags
    ;Component:AirbagVW21    006 0403, Coding:98CCC0C00C0000005C5400CF004800000065
    ;EV_AirbaVW20SMEVW37X,002164,EV_AirbaVW20SMEVW37X.rod
    ;Sunday,17,March,2019,17:56:40:21782
    ;VCID: 936634737A201ED2F0-80C6
    IDE00820-MAS02165-Activating and deactivating all development messages-Group 1,not active ,1
    IDE00820-MAS02166-Activating and deactivating all development messages-Group 2,not active ,1
    IDE00820-MAS05859-Activating and deactivating all development messages-Group 3,not active ,1
    IDE00820-MAS05860-Activating and deactivating all development messages-Group 4,not active ,1
    IDE00820-MAS05861-Activating and deactivating all development messages-Group 5,not active ,1
    IDE00820-MAS05862-Activating and deactivating all development messages-Group 6,not active ,1
    IDE00820-MAS05863-Activating and deactivating all development messages-Group 7,not active ,1
    IDE00820-MAS05864-Activating and deactivating all development messages-Group 8,not active ,1
    IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,18
    IDE12055-IDE12258-Adaptation airbag 2-Assistance system monitor,activated ,8
    IDE12055-MAS00478-Adaptation airbag 2-Reserved,2 ,8
    MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined ,8
    MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined ,8
    MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated ,8
    MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated ,8
    MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated ,8
    MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated ,8
    MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined ,8
    MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined ,8
    MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated ,8
    MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated ,8
    MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated ,8
    MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined ,8
    MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated ,8
    MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated ,8
    MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,activated ,8
    MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,activated ,8
    MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined ,8
    MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated ,8
    MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed ,8
    MAS00975-MAS00478-Airbag adaptations-Reserved,2 ,8
    MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,activated ,8
    Elapsed Time: 00:04
    17
    ;SW:5NA-920-790-D   HW:5NA-920-790-D ---  Instruments
    ;Component:KOMBI         506 1691, Coding:04A500086F840008018873031001000880000000
    ;EV_DashBoardVDDMQBA0,001026,EV_DashBoardVDDMQBA0_VW37.rod
    ;Sunday,17,March,2019,17:43:58:21782
    ;VCID: C3C6C4334AC04E5200-8096
    IDE00001-Production mode,not active ,3
    IDE00295-Oil temperature display,On ,1
    IDE00342-ESI: Resetting ESI,no warning ,1
    IDE00343-Language version,estonian ,1
    IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible ,3
    IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset ,3
    IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset ,3
    IDE00345-MAS12879-MFA3-Reset-Electrical refueling detection,MFA3-Reset ,3
    IDE00499-Display correction of consumptions and operating range,100 %,1
    IDE00500-Hour,17 H,1
    IDE00501-Minute,43 min,1
    IDE00502-Year,2019 yr,2
    IDE00503-Month,3 mon,1
    IDE00504-Day,17 d,1
    IDE00510-ESI: distance driven from inspection,6426 km,3
    IDE00511-ESI: time from inspection,60 d,2
    IDE00512-ESI: minimum value km-driving distance/inspection,15000 km,2
    IDE00513-ESI: maximum value km-driving distance/inspection,30000 km,2
    IDE00514-ESI: maximum value of time between inspections,730 d,2
    IDE00515-ESI: oil quality,good oil quality ,1
    IDE00517-ESI: soot entry,10800 km,2
    IDE00518-ESI: thermal load,3500 km,2
    IDE00819-Day counter,110 d,2
    IDE00827-ESI: minimum value of time between inspections,365 d,2
    IDE01153-SIA: maximum value of distance to service,15000 km,2
    IDE01154-SIA: maximum value of time to service,365 d,2
    IDE02489-Display depiction,Version 1 ,1
    IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l,5
    IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l,5
    IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,-12.8 l,5
    IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l,5
    IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l,5
    IDE03329-Driving profiled for range remaining,6.4 l/100km,2
    IDE03346-IDE00301-Units adjusted-Distance,Kilometers ,3
    IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy ,3
    IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour ,3
    IDE03346-MAS02201-Units adjusted-Temperature,°C ,3
    IDE03346-MAS02957-Units adjusted-Time,24h ,3
    IDE03346-MAS03032-Units adjusted-Volume,Liter ,3
    IDE03346-MAS03034-Units adjusted-Pressure,bar ,3
    IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km ,3
    IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km ,3
    IDE03346-MAS05875-Units adjusted-Average consumption: electric drive,kWh per 100 km ,3
    IDE03346-MAS13665-Units adjusted-Trailer/support load ground,kilogram (kg) ,3
    IDE03348-MAS01456-Speed warning-Speed,0 ,2
    IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour ,2
    IDE03348-Speed warning-,not active ,2
    IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km,2
    IDE03350-FIX: Maximum time until next time-dependent inspection,730 d,2
    IDE03351-FIX: Distance covered since last mileage-dependent inspection,6400 km,2
    IDE03352-FIX: Time since last time-dependent inspection,60 d,2
    IDE03372-Source for synchronization of time,internal clock ,1
    IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On ,5
    IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s,5
    IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On ,5
    IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On ,5
    IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h,5
    IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s,5
    IDE03568-ENG104099-Service-key settings-p_write_distance,20 km,5
    IDE03867-Deactivate seat belt warning,No ,1
    IDE05930-Service notification in days,30 d,1
    IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km,2
    IDE05932-FIX: Reset value for next time-dependent inspections,365 d,2
    IDE05971-Vehicle Positioning System Interface Control Module,not installed ,1
    IDE06588-Ignition active message: actuator,No display ,1
    IDE06922-No-voltage display,Not available ,1
    IDE07221-Cylinder shut-off,Display ,1
    IDE11086-Service notification,30 d,1
    IDE11932-MAS01877-Display of colour adjustment-Red,0 ,3
    IDE11932-MAS01878-Display of colour adjustment-Green,0 ,3
    IDE11932-MAS01879-Display of colour adjustment-Blue,0 ,3
    IDE12211-China variant,No ,1
    IDE12467-Tubes illustration,Version 3 ,1
    IDE12722-Driving profile display,Yes ,1
    IDE13094-Tachometer end value,Version 0 ,1
    IDE13607-MAS16698-Lock display contents-Lock infotainment list,No ,9
    IDE13607-MAS16699-Lock display contents-Lock function lists,No ,9
    IDE13607-MAS16700-Lock display contents-Lock MFA displays,No ,9
    IDE13607-MAS16701-Lock display contents-Dynamic image lock,No ,9
    IDE13607-MAS16702-Lock display contents-Lock functional animation,No ,9
    IDE13607-MAS16703-Lock display contents-lock,No ,9
    IDE13607-MAS16704-Lock display contents-Lock system status animation,No ,9
    IDE13607-MAS16705-Lock display contents-Lock operating support animation,No ,9
    IDE13607-MAS16706-Lock display contents-List time out,0 s,9
    IDE13607-MAS17250-Lock display contents-Map locked,No ,9
    IDE13607-MAS17251-Lock display contents-Piloted driving locked,No ,9
    IDE13607-MAS17283-Lock display contents-Vehicle model locked,No ,9
    IDE13607-MAS17284-Lock display contents-Cover intensity locked,100 %,9
    IDE13607-MAS17285-Lock display contents-Number of list entries blocked,0 ,9
    IDE14184-Active participant personalization,No ,1
    IDE14220-Vehicle speed warning for India-,No ,1
    IDE14220-Vehicle speed warning for India-,0 s,1
    MAS01299-Offroad,No display ,1
    ENG114742-Activation of Development Messages,not active ,1
    ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF ,20
    ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF ,20
    ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF ,20
    ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF ,20
    ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF ,20
    ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF ,20
    ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF ,20
    ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF ,20
    ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF ,20
    ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF ,20
    ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF ,20
    ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF ,20
    ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF ,20
    ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF ,20
    ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF ,20
    ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF ,20
    ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF ,20
    ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF ,20
    ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF ,20
    ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF ,20
    ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF ,20
    ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF ,20
    ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF ,20
    ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF ,20
    ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF ,20
    ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF ,20
    ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF ,20
    ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF ,20
    ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF ,20
    ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF ,20
    ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF ,20
    ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF ,20
    ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF ,20
    ENG119875-defuel_threshold,12 l,1
    ENG119879-ENG101574-dimming_characteristic_curve_adjustment_bargraph_main_colour-X1,00 ,12
    ENG119879-ENG99557-dimming_characteristic_curve_adjustment_bargraph_main_colour-X2,14 ,12
    ENG119879-ENG102140-dimming_characteristic_curve_adjustment_bargraph_main_colour-X3,32 ,12
    ENG119879-ENG102936-dimming_characteristic_curve_adjustment_bargraph_main_colour-X4,64 ,12
    ENG119879-ENG103548-dimming_characteristic_curve_adjustment_bargraph_main_colour-X5,96 ,12
    ENG119879-ENG113992-dimming_characteristic_curve_adjustment_bargraph_main_colour-X6,FD ,12
    ENG119879-ENG99777-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y1,01 ,12
    ENG119879-ENG100480-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y2,01 ,12
    ENG119879-ENG100773-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y3,02 ,12
    ENG119879-ENG100631-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y4,04 ,12
    ENG119879-ENG102174-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y5,32 ,12
    ENG119879-ENG113993-dimming_characteristic_curve_adjustment_bargraph_main_colour-Y6,64 ,12
    ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,0A ,12
    ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,32 ,12
    ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,64 ,12
    ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,96 ,12
    ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,01 ,12
    ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,01 ,12
    ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,03 ,12
    ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,06 ,12
    ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,28 ,12
    ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
    ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
    ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,01 ,12
    ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,01 ,12
    ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,03 ,12
    ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,06 ,12
    ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,28 ,12
    ENG128744-ENG101574-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X1,00 00 ,24
    ENG128744-ENG99557-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X2,00 0A ,24
    ENG128744-ENG102140-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X3,00 32 ,24
    ENG128744-ENG102936-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X4,00 64 ,24
    ENG128744-ENG103548-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X5,00 96 ,24
    ENG128744-ENG113992-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-X6,00 FD ,24
    ENG128744-ENG99777-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y1,00 32 ,24
    ENG128744-ENG100480-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y2,00 32 ,24
    ENG128744-ENG100773-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y3,00 78 ,24
    ENG128744-ENG100631-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y4,00 E6 ,24
    ENG128744-ENG102174-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y5,01 F4 ,24
    ENG128744-ENG113993-Dimming_characteristic_curve_adjustment_fpk_indicator_lights-Y6,03 E8 ,24
    ENG128743-ENG101574-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X1,00 00 ,24
    ENG128743-ENG99557-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X2,00 0A ,24
    ENG128743-ENG102140-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X3,00 32 ,24
    ENG128743-ENG102936-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X4,00 64 ,24
    ENG128743-ENG103548-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X5,00 96 ,24
    ENG128743-ENG113992-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-X6,00 FD ,24
    ENG128743-ENG99777-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y1,00 0C ,24
    ENG128743-ENG100480-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y2,00 0C ,24
    ENG128743-ENG100773-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y3,00 23 ,24
    ENG128743-ENG100631-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y4,00 46 ,24
    ENG128743-ENG102174-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y5,01 F4 ,24
    ENG128743-ENG113993-Dimming_characteristic_curve_adjustment_fpk_middle_display_main_field-Y6,03 E8 ,24
    ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 FA ,20
    ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 28 ,20
    ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 50 ,20
    ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
    ENG153720-MAS03686-Display_longitudinal_coordinator-Automatic distance regulation,active ,1
    ENG153720-MAS05203-Display_longitudinal_coordinator-CCS,not active ,1
    ENG153720-MAS10720-Display_longitudinal_coordinator-Speed limiter,active ,1
    ENG119874-Gas_functionality,not active ,1
    ENG125906-ENG125912-Illumination_algorithm-Pointer_illumination_algorithim,terminal_58xd_log_bus_parkinglight ,1
    ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
    ENG119882-init_fuel_algorithm,No ,1
    ENG130585-Leaving_warning_delay,1.6 s,1
    ENG103063-Mileage,6433 km,3
    ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C,16
    ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C,16
    ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25 °C,16
    ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C,16
    ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 ,16
    ENG153765-Second_digital_speed,No display ,1
    ENG119876-Service_Key_Clear_All_Counter,Yes ,1
    ENG98918-Sport,No display ,1
    ENG130584-Statistic_phev_mileage,5 km,1
    ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,2.0 s,18
    ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,5 s,18
    ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,35 s,18
    ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,255 s,18
    ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,5 s,18
    ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,6 s,18
    ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,20 s,18
    ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,900 s,18
    ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,10 s,18
    ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,3 s,18
    ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,10 s,18
    ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.40 s,18
    ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,3 ,18
    ENG109442-ENG101663-time_parameter_display-tDD15_off,0.30 ,18
    ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 ,18
    ENG109442-ENG100026-time_parameter_display-tDDWUP,0.00 ,18
    ENG112418-ENG112412-total_range_gas-consumption_factor,0.000 ,4
    ENG112418-ENG112411-total_range_gas-consumption_profile,consumption_profile_calculation ,4
    ENG112418-ENG112410-total_range_gas-selection_consumption_factor,consumption_factor_CAN ,4
    ENG112418-ENG99298-total_range_gas-State,not active ,4
    Elapsed Time: 00:39
    18
    ;SW:5Q0-963-272-J   HW:5Q0-963-272-J ---  Aux. Heat
    ;Component:STH-MQB       008 0080, Coding:9309
    ;EV_AuxilParkiHeateWOS,002018,EV_AuxilParkiHeateWOS.rod
    ;Sunday,17,March,2019,17:57:01:21782
    IDE00470-Initial fuel filling,Yes ,1
    IDE06640-MAS01167-Transfer fuel pump-Actuation time,20 s,5
    IDE06640-MAS05078-Transfer fuel pump-Minimum tank level,127 l,5
    IDE06640-MAS05079-Transfer fuel pump-Fuel reserve amount,200 ml,5
    IDE06640-MAS05080-Transfer fuel pump-Maximum standing time,0.0 H,5
    IDE06640-MAS05689-Transfer fuel pump-Activation delay,10 s,5
    IDE06642-MAS05071-Coolant change-over valve-Temperature difference: engine/parking heater,5 °C,4
    IDE06642-MAS05072-Coolant change-over valve-Maximum engine rpm,2000 /min,4
    IDE06642-MAS05073-Coolant change-over valve-Residual heat: threshold,55 °C,4
    IDE06642-MAS05074-Coolant change-over valve-Note engine rpm,No ,4
    IDE06686-Insufficient voltage threshold,11.3 V,1
    IDE06687-CO2 adjustment,185 ,1
    IDE06688-Auxil. heater activation,active ,1
    IDE06689-Low voltage detection: time limit,20.0 s,1
    IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature,5.0 °C,11
    IDE06690-MAS05060-Auxil. heat control parameters-Upper temperature threshold: ambient temperature,12.0 °C,11
    IDE06690-MAS05061-Auxil. heat control parameters-Temperature hysteresis: ambient temperature for USA vehicle,3.0 °C,11
    IDE06690-MAS05062-Auxil. heat control parameters-Lower temperature threshold: coolant temperature via CAN,72 °C,11
    IDE06690-MAS05063-Auxil. heat control parameters-Upper temperature threshold: coolant temperature via CAN,88 °C,11
    IDE06690-MAS05064-Auxil. heat control parameters-Lower temperature threshold for partial load after full load,74 °C,11
    IDE06690-MAS05065-Auxil. heat control parameters-Lower temperature threshold for starting from control pause,76 °C,11
    IDE06690-MAS05066-Auxil. heat control parameters-Upper temperature threshold for full load after partial load,84 °C,11
    IDE06690-MAS05067-Auxil. heat control parameters-Upper temperature threshold for control pause,88 °C,11
    IDE06690-MAS05068-Auxil. heat control parameters-Temperature threshold for control mode,82 °C,11
    IDE06691-MAS05064-Parking heat control parameters-Lower temperature threshold for partial load after full load,58 °C,7
    IDE06691-MAS05065-Parking heat control parameters-Lower temperature threshold for starting from control pause,60 °C,7
    IDE06691-MAS05066-Parking heat control parameters-Upper temperature threshold for full load after partial load,82 °C,7
    IDE06691-MAS05067-Parking heat control parameters-Upper temperature threshold for control pause,88 °C,7
    IDE06691-MAS05068-Parking heat control parameters-Temperature threshold for control mode,82 °C,7
    IDE06691-MAS05069-Parking heat control parameters-Temperature threshold for activation of fresh air blower,45 °C,7
    IDE06691-MAS05070-Parking heat control parameters-Control behavior,Continuous ,7
    IDE06692-Note request for aux. heater from A/C system,Do not ignore ,1
    IDE06693-Evaluate air pressure via CAN,Yes ,1
    IDE06694-MAS05076-Minimum burn time-Time,300 s,2
    IDE06694-MAS05077-Minimum burn time-Temperature threshold offset,4 °C,2
    IDE07160-MAS04357-Control module switch-off: switch-off time-Time 1,140 min,2
    IDE07160-MAS04358-Control module switch-off: switch-off time-Time 2,20 min,2
    IDE11710-MAS03980-Heating time limitation-Maximum heating time,180 min,2
    IDE11710-MAS13122-Heating time limitation-Activation function heating time exceedance,active ,2
    MAS01488-MAS03873-recirc. pump-Duty cycle,not active ,5
    MAS01488-MAS05072-recirc. pump-Maximum engine rpm,12750 /min,5
    MAS01488-MAS06093-recirc. pump-Lowest temperature for request of exterior water pump,-20 °C,5
    MAS01488-MAS06094-recirc. pump-Lowest activation temperat. for request of exterior water pump,150 s,5
    MAS01488-MAS06095-recirc. pump-Maximum temperature for request of exterior water pump,180 s,5
    MAS05075-Evaluate ethanol content,Yes ,1
    MAS09096-Recirc. pump locking mechan.,1 ,1
    ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring,No ,1
    ENG119721-development_data_on_CAN,not active ,1
    Elapsed Time: 00:06
    19
    ;SW:3Q0-907-530-AA   HW:3Q0-907-530-C ---  CAN Gateway
    ;Component:GW MQB High   442 4366, Coding:030500045F087300FB17225A1A0F00010001070000000000000000000000
    ;EV_GatewNF,013025,EV_GatewNF_VW37.rod
    ;Sunday,17,March,2019,17:45:58:21782
    ;VCID: EE90458731C2933ABF-80BA
    IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
    IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
    IDE00002-Transport mode,not active ,1
    IDE01211-Static current measuring mode,not activated ,1
    IDE01457-Energy management deactivation stage,Mode not active ,1
    IDE01459-Energy management heat output control status,Mode not active ,1
    IDE01844-Increase idle speed request,Mode not active ,1
    IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
    IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
    IDE01860-Generator specified voltage value variable,10.6 V,1
    IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
    IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,coded ,32
    IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
    IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
    IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
    IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
    IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
    IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
    IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,coded ,32
    IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
    IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
    IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,Not coded ,32
    IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
    IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,coded ,32
    IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
    IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
    IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
    IDE01996-SFT00033-Installation list: specified installations-Battery Energy Control Module 2,Not coded ,32
    IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,coded ,32
    IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
    IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
    IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
    IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
    IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded ,32
    IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
    IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
    IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
    IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
    IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
    IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
    IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded ,32
    IDE01996-SFT00075-Installation list: specified installations-Multifunction module,coded ,32
    IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
    IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
    IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,Not coded ,32
    IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
    IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
    IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
    IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
    IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
    IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
    IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,coded ,32
    IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,coded ,32
    IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,coded ,32
    IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded ,32
    IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
    IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
    IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
    IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,coded ,32
    IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
    IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded ,32
    IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,coded ,32
    IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
    IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
    IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
    IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
    IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
    IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
    IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
    IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
    IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
    IDE01996-SFT00204-Installation list: specified installations-Starter / Generator Control Module,Not coded ,32
    IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
    IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
    IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
    IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
    IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
    IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
    IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
    IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
    IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
    IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
    IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
    IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
    IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
    IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
    IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
    IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
    IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
    IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
    IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
    IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
    IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
    IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
    IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
    IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
    IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
    IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
    IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
    IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
    IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
    IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
    IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
    IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
    IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
    IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
    IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
    IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
    IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
    IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
    IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
    IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
    IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
    IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
    IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
    IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
    IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
    IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
    IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
    IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
    IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
    IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
    IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
    IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
    IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
    IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
    IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
    IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
    IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
    IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
    IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
    IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
    IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
    IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
    IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
    IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
    IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
    IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
    IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
    IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
    IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
    IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
    IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
    IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
    IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
    IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
    IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
    IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
    IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
    IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
    IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
    IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
    IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
    IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
    IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
    IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
    IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
    IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
    IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
    IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
    IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
    IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
    IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
    IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
    IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
    IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
    IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
    IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
    IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
    IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
    IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
    IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
    IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
    IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
    IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
    IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
    IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
    IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
    IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
    IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
    IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
    IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
    IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
    IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
    IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
    IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
    IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
    IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
    IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
    IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
    IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
    IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
    IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
    IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
    IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
    IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
    IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
    IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
    IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
    IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
    IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
    IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
    IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
    IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
    IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
    IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
    IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
    IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
    IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
    IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
    IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
    IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
    IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
    IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
    IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
    IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
    IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
    IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
    IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
    IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
    IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
    IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
    IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
    IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
    IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
    IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
    IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
    IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
    IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
    IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
    IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
    IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
    IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
    IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
    IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
    IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
    IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
    IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
    IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
    IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
    IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
    IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
    IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
    IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
    IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
    IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
    IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
    IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
    IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
    IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
    IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
    IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
    IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
    IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
    IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
    IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
    IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
    IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
    IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
    IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
    IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
    IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
    IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
    IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
    IDE03256-MAS06105-Battery adaptation-Rated battery capacity,68 Ah,15
    IDE03256-MAS06106-Battery adaptation-Battery technology,Fleece ,15
    IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
    IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
    IDE03903-Production process data 1,00 00 ,2
    IDE04159-Deactivation of start-stop function,Mode not active ,1
    IDE04186-Battery terminal recognition,connected ,1
    IDE04330-Transfer of release code for a SWaP function,00 ,1
    IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
    IDE06541-Distance left for deactivation of transport mode,50 ,1
    IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
    IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
    IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
    IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
    IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
    IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
    IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4
    IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
    IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
    IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
    IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
    IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
    IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
    IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
    IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
    IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
    IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
    IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
    IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated ,4
    IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
    IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
    IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
    IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
    IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
    IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
    IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
    IDE06753-MAS19094-Efficiency program display-Rear A/C System blower convenience consumption,activated ,4
    IDE06753-MAS19095-Efficiency program display-Convenience consumption outer mirror heater dependency,Until temperature threshold: with after-run: with switch ,4
    IDE07838-Counter for inconsistent states,0 ,2
    IDE08348-Start/stop start voltage limit,7.8 V,1
    IDE08624-MKE Check box,activated ,1
    IDE10735-Number requests autonomous recharging,3 ,1
    IDE10736-Cyclization limitation request battery service,0 ,1
    IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
    IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
    IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
    IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
    IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
    IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
    IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
    IDE10748-MAS11269-Range gain-Range gain rear fog light,not activated ,3
    IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
    IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
    IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
    IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
    IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
    IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated ,3
    IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated ,3
    IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,not activated ,3
    IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,not activated ,3
    IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
    IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
    IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
    IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
    IDE10748-MAS19099-Range gain-Convenience consumption socket,activated ,3
    IDE10748-MAS19100-Range gain-A/C System blower manual convenience consumption,not activated ,3
    IDE10748-MAS19132-Range gain-Outer mirror heater consumption in rear window heating,not activated ,3
    IDE11689-48V-System: locking,regular operation ,1
    IDE13756-Diagnosis filter: activation,not active ,1
    IDE13757-MAS16868-Diagnosis filter: kilometer thresholds-Kilometer threshold: production,200 km,2
    IDE13757-MAS16869-Diagnosis filter: kilometer thresholds-Kilometer threshold: customer service,20 km,2
    MAS16372-Security version number,2 ,2
    SFT271921-IDE02583-Multi Function Steering Wheel Control Module-Steering wheel Tiptronic switch,installed ,3
    SFT271921-MAS04733-Multi Function Steering Wheel Control Module-Two-stage,not active ,3
    SFT271921-MAS06614-Multi Function Steering Wheel Control Module-Version,ACC ,3
    SFT271921-MAS09758-Multi Function Steering Wheel Control Module-Temperature sensor,not installed ,3
    SFT271921-MAS19102-Multi Function Steering Wheel Control Module-Dimming after-run,active ,3
    SFT271921-MAS19103-Multi Function Steering Wheel Control Module-Local data bus: wake-up function,not active ,3
    SFT271921-MAS19104-Multi Function Steering Wheel Control Module-Alarm horn wake-up function,not active ,3
    ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
    ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
    ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
    ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
    ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms,12
    ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
    ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,255000 ms,12
    ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
    ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,500 ms,12
    ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms,12
    ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
    ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
    ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
    ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
    ENG137075-EM_heating_power_quota_adjustment,1000 W,1
    ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
    ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
    ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
    ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
    ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
    ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
    ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
    ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
    ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
    ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
    ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
    ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
    ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
    ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
    ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
    ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
    ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
    ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
    ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
    ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
    ENG137058-SFT00033-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module 2,Enabled ,32
    ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
    ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
    ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
    ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
    ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
    ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
    ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
    ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
    ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
    ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
    ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
    ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
    ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
    ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
    ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
    ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
    ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
    ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
    ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
    ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
    ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
    ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
    ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
    ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
    ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
    ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
    ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
    ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
    ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
    ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
    ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
    ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
    ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
    ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
    ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
    ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
    ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
    ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
    ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
    ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
    ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
    ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
    ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
    ENG137058-SFT00204-GW_Enable_CAN_Timeout_DTC-Starter / Generator Control Module,Enabled ,32
    ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
    ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
    ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
    ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
    ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
    ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
    ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
    ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
    ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
    ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
    ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
    ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
    ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
    ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
    ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
    ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
    ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
    ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
    ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
    ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
    ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
    ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
    ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
    ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
    ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
    ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
    ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
    ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
    ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
    ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
    ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
    ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
    ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
    ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
    ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
    ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
    ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
    ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
    ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
    ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
    ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
    ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
    ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
    ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
    ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
    ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
    ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
    ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
    ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
    ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
    ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
    ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
    ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
    ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
    ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
    ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
    ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
    ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
    ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
    ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
    ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
    ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
    ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
    ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
    ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
    ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
    ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
    ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
    ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
    ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
    ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
    ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
    ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
    ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
    ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
    ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
    ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
    ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
    ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
    ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
    ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
    ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
    ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
    ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
    ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
    ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
    ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
    ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
    ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
    ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
    ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
    ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
    ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
    ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
    ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
    ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
    ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
    ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
    ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
    ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
    ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
    ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
    ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
    ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
    ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
    ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
    ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
    ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
    ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
    ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
    ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
    ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
    ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
    ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
    ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
    ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
    ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
    ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
    ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
    ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
    ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
    ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
    ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
    ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
    ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
    ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
    ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
    ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
    ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
    ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
    ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
    ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
    ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
    ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
    ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
    ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
    ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
    ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
    ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
    ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
    ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
    ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
    ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
    ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
    ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
    ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
    ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
    ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
    ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
    ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
    ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
    ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
    ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
    ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
    ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
    ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
    ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
    ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
    ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
    ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
    ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
    ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
    ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
    ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
    ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
    ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
    ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
    ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
    ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
    ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
    ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
    ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
    ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
    ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
    ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
    ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
    ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
    ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
    ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
    ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
    ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
    ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
    ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
    ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
    ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
    ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
    ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
    ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
    ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
    ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
    ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
    ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
    ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
    ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
    ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
    ENG152379-MV-EM_adaption_48V_zero_potential,regular operation ,1
    ENG137850-MVK_Warning,regular operation ,1
    ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
    ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,activated ,1
    ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,8
    ENG118773-ENG103057-WakeUpMonitor_Configuration-Max_Num_Logical_WakeUp_Events,20 ,8
    ENG118773-ENG104006-WakeUpMonitor_Configuration-Max_Num_Physical_WakeUp_Events,20 ,8
    ENG118773-ENG154846-WakeUpMonitor_Configuration-Open_Filter_Time,45 min,8
    ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,8
    ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,8
    Elapsed Time: 00:28
    22
    ;SW:0CQ-907-554-J   HW:0CQ-525-130 ---  AWD
    ;Component:Haldex4Motion H55 7084, Coding:0101
    ;EV_AllWheelContrHA1VW37X,004013,EV_AllWheelContrHA1VW37X_004.rod
    ;Sunday,17,March,2019,17:57:16:21782
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: CCD4EF0F679E812AF1-8098
    IDE07843-ENG142105-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_4,2000 ,8
    IDE07843-ENG142107-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_5,2000 ,8
    IDE07843-ENG142109-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_6,2000 ,8
    IDE07843-ENG142111-Acoustic measure: gasoline-Anti_hum_measure_benzin_gear_7_plus,2000 ,8
    IDE07843-ENG142104-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_4,1150 ,8
    IDE07843-ENG142106-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_5,1150 ,8
    IDE07843-ENG142108-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_6,1150 ,8
    IDE07843-ENG142110-Acoustic measure: gasoline-Anti_impact_driver_measure_benzin_gear_7_plus,1150 ,8
    IDE07844-ENG142113-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_4,2200 ,8
    IDE07844-ENG142115-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_5,2200 ,8
    IDE07844-ENG142117-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_6,2200 ,8
    IDE07844-ENG142119-Acoustic measure: diesel-Anti_hum_measure_diesel_gear_7_plus,2200 ,8
    IDE07844-ENG142112-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_4,1300 ,8
    IDE07844-ENG142114-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_5,1300 ,8
    IDE07844-ENG142116-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_6,1300 ,8
    IDE07844-ENG142118-Acoustic measure: diesel-Anti_impact_driver_measure_diesel_gear_7_plus,1300 ,8
    MAS06098-Acoustic measure: wiring logic,Standard ,1
    Elapsed Time: 00:04
    29
    ;SW:8V0-907-399-B   HW:8V0-907-399-B ---  Left Light
    ;Component:LCM_MLBevoH08 0014, Coding:
    ;EV_LCMLeftHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW37.rod
    ;Sunday,17,March,2019,17:57:27:21782
    ;VCID: C5C2DA2B44F470622E-8090
    IDE01550-Service position,not active ,1
    Elapsed Time: 00:01
    39
    ;SW:8V0-907-399-B   HW:8V0-907-399-B ---  Right Light
    ;EV_LCMRightHELLAAU736,001012,EV_LCMLeftHELLAAU736_VW37.rod
    ;Sunday,17,March,2019,17:57:36:21782
    Elapsed Time: 00:01
    42
    ;SW:5Q0-959-593-F   HW:5Q0-959-593-F ---  Door Elect, Driver
    ;Component:TSG FS001 0287, Coding:003F1A20D000040000001000
    ;EV_DCU2DriveSideMAXHKLO,001010,EV_DCU2DriveSideMAXHCONT_VW37.rod
    ;Sunday,17,March,2019,17:57:51:21782
    ;VCID: C4C4C72F4FCE496A39-8090
    IDE00001-MAS10864-Production mode-Reduce reverse threshold,Deactivating ,3
    IDE00001-MAS10865-Production mode-Power windows operable with terminal 15 off,Deactivating ,3
    IDE00001-MAS10866-Production mode-Reduce switch-on time of lighting,Deactivating ,3
    IDE00001-MAS10867-Production mode-Deactivate speed control for power windows,Deactivating ,3
    IDE00001-MAS10868-Production mode-Deactivate closing aid,Deactivating ,3
    IDE00001-MAS10869-Production mode-Activate test mode for the fold-in mirror,Deactivating ,3
    IDE00001-MAS10870-Production mode-Activate test mode for power windows,Deactivating ,3
    IDE00001-MAS17286-Production mode-Deactivation of actuation of opening assistance motor: e-lock,Deactivating ,3
    IDE00001-MAS17291-Production mode-Deactivation of CarWakeUp due to activation of seatbelt feeder,Deactivating ,3
    IDE09067-Side window shade: service mode,Deactivating ,1
    ENG117304-ENG148862-Patch_Code_Driver_Side_Rear-Parameter_1,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
    ENG117304-ENG148865-Patch_Code_Driver_Side_Rear-Parameter_2,FF FF ,128
    ENG117297-Reversing_Threshold_Driver_Side_Front,90 %,1
    ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %,1
    ENG117302-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_1,00 00 14 03 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 07 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 04 B0 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 10 00 00 0A 01 00 00 00 ,128
    ENG117302-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1-Parameter_2,BA 01 ,128
    ENG117303-ENG148862-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_1,03 20 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 32 04 12 19 0A 00 05 F1 32 1E 0F 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 24 20 FA D8 C4 F6 FB 28 1E 32 0A 1E 00 00 2D 04 19 0D 12 0E FA E2 CE F1 F6 1E 14 32 00 0D 00 01 0E 02 19 0F 18 14 FA D8 C4 F6 FB 28 1E 32 08 0F 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
    ENG117303-ENG148865-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2-Parameter_2,5B 1B ,128
    ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 64 1E 00 32 32 01 90 00 00 00 00 00 00 00 B4 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 33 41 30 31 01 00 00 00 00 00 00 00 00 00 7B A8 ,88
    Elapsed Time: 00:09
    44
    ;SW:5QF-909-144-B   HW:5QF-909-144-A ---  Steering Assist
    ;Component:EPS_MQB_ZFLS  507 5582, Coding:931F0000
    ;EV_SteerAssisMQB,015157,EV_SteerAssisMQB_015.rod
    ;Sunday,17,March,2019,17:58:11:21782
    ;VCID: C9DAD61B68EC9402CA-809C
    IDE03724-Straight line running,active ,1
    IDE03734-Support power,100% ,1
    IDE04130-Characteristic curve of steering assistance,Driving profile selection button ,1
    IDE04555-Activation of pwr steering asst without engine running,not active ,1
    IDE05162-Software end stop,active ,1
    IDE06419-Driving profile switchover,Incremental: controlled over time ,1
    IDE07540-Download without rest bus,not active ,1
    IDE09571-RPM monitoring,active ,1
    MAS02080-XCP calibration protocol,not active ,1
    Elapsed Time: 00:02
    4B
    ;SW:3Q0-907-338-C   HW:3Q0-907-338-C ---  Multifunc. Module
    ;Component:FCM MQB Low   002 0345, Coding:00000005090008CA01104F010A0000000000000000000000000000000000
    ;EV_MultiModulContiVW48X,002006,EV_MultiModulContiVW48X_002_VW37.rod
    ;Sunday,17,March,2019,17:58:27:21782
    ;VCID: B522AAEB1414E0E2BE-80E0
    IDE00001-Production mode,not active ,3
    IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection,Yes ,1
    IDE01996-SFT00041-Installation list: specified installations-Light Control Left,Yes ,1
    IDE01996-SFT00057-Installation list: specified installations-Light Control Right,Yes ,1
    IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Yes ,1
    IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,No ,1
    IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2,Yes ,1
    IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2,Yes ,1
    IDE01996-SFT33031-Installation list: specified installations-Antenna Control Module,No ,1
    IDE03641-Presentation run dynamic AFS light,active ,1
    IDE03642-Presentation mode,not active ,1
    IDE03679-Adaptive light functions,active ,1
    IDE08418-Matrix light: total dimming,0.0 %,1
    IDE09156-Matrix headlamp: function at standstill,not active ,1
    IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1,OFF ,12
    IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2,OFF ,12
    IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3,OFF ,12
    IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4,OFF ,12
    IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5,OFF ,12
    IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6,OFF ,12
    IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7,OFF ,12
    IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8,OFF ,12
    IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9,OFF ,12
    IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10,OFF ,12
    IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11,OFF ,12
    IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12,OFF ,12
    IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13,OFF ,12
    IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14,OFF ,12
    IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15,OFF ,12
    IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16,OFF ,12
    IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17,OFF ,12
    IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18,OFF ,12
    IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19,OFF ,12
    IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20,OFF ,12
    IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21,OFF ,12
    IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22,OFF ,12
    IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23,OFF ,12
    IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24,OFF ,12
    IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25,OFF ,12
    IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26,OFF ,12
    IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27,OFF ,12
    IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28,OFF ,12
    IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29,OFF ,12
    IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30,OFF ,12
    IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31,OFF ,12
    IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32,OFF ,12
    IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33,OFF ,12
    IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34,OFF ,12
    IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35,OFF ,12
    IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36,OFF ,12
    IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37,OFF ,12
    IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38,OFF ,12
    IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39,OFF ,12
    IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40,OFF ,12
    IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41,OFF ,12
    IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42,OFF ,12
    IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43,OFF ,12
    IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44,OFF ,12
    IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45,OFF ,12
    IDE09568-MAS11516-Bit pattern of individual segment activation: left headlight-LED 46,OFF ,12
    IDE09568-MAS11517-Bit pattern of individual segment activation: left headlight-LED 47,OFF ,12
    IDE09568-MAS11518-Bit pattern of individual segment activation: left headlight-LED 48,OFF ,12
    IDE09568-MAS11519-Bit pattern of individual segment activation: left headlight-LED 49,OFF ,12
    IDE09568-MAS11520-Bit pattern of individual segment activation: left headlight-LED 50,OFF ,12
    IDE09568-MAS11521-Bit pattern of individual segment activation: left headlight-LED 51,OFF ,12
    IDE09568-MAS11522-Bit pattern of individual segment activation: left headlight-LED 52,OFF ,12
    IDE09568-MAS11523-Bit pattern of individual segment activation: left headlight-LED 53,OFF ,12
    IDE09568-MAS11524-Bit pattern of individual segment activation: left headlight-LED 54,OFF ,12
    IDE09568-MAS11525-Bit pattern of individual segment activation: left headlight-LED 55,OFF ,12
    IDE09568-MAS11526-Bit pattern of individual segment activation: left headlight-LED 56,OFF ,12
    IDE09568-MAS11527-Bit pattern of individual segment activation: left headlight-LED 57,OFF ,12
    IDE09568-MAS11528-Bit pattern of individual segment activation: left headlight-LED 58,OFF ,12
    IDE09568-MAS11529-Bit pattern of individual segment activation: left headlight-LED 59,OFF ,12
    IDE09568-MAS11530-Bit pattern of individual segment activation: left headlight-LED 60,OFF ,12
    IDE09568-MAS11531-Bit pattern of individual segment activation: left headlight-LED 61,OFF ,12
    IDE09568-MAS11532-Bit pattern of individual segment activation: left headlight-LED 62,OFF ,12
    IDE09568-MAS11533-Bit pattern of individual segment activation: left headlight-LED 63,OFF ,12
    IDE09568-MAS11534-Bit pattern of individual segment activation: left headlight-LED 64,OFF ,12
    IDE09568-MAS11535-Bit pattern of individual segment activation: left headlight-LED 65,OFF ,12
    IDE09568-MAS11536-Bit pattern of individual segment activation: left headlight-LED 66,OFF ,12
    IDE09568-MAS11537-Bit pattern of individual segment activation: left headlight-LED 67,OFF ,12
    IDE09568-MAS11538-Bit pattern of individual segment activation: left headlight-LED 68,OFF ,12
    IDE09568-MAS11539-Bit pattern of individual segment activation: left headlight-LED 69,OFF ,12
    IDE09568-MAS11540-Bit pattern of individual segment activation: left headlight-LED 70,OFF ,12
    IDE09568-MAS11541-Bit pattern of individual segment activation: left headlight-LED 71,OFF ,12
    IDE09568-MAS11542-Bit pattern of individual segment activation: left headlight-LED 72,OFF ,12
    IDE09568-MAS11543-Bit pattern of individual segment activation: left headlight-LED 73,OFF ,12
    IDE09568-MAS11544-Bit pattern of individual segment activation: left headlight-LED 74,OFF ,12
    IDE09568-MAS11545-Bit pattern of individual segment activation: left headlight-LED 75,OFF ,12
    IDE09568-MAS11546-Bit pattern of individual segment activation: left headlight-LED 76,OFF ,12
    IDE09568-MAS11547-Bit pattern of individual segment activation: left headlight-LED 77,OFF ,12
    IDE09568-MAS11548-Bit pattern of individual segment activation: left headlight-LED 78,OFF ,12
    IDE09568-MAS11549-Bit pattern of individual segment activation: left headlight-LED 79,OFF ,12
    IDE09568-MAS11550-Bit pattern of individual segment activation: left headlight-LED 80,OFF ,12
    IDE09568-MAS11551-Bit pattern of individual segment activation: left headlight-LED 81,OFF ,12
    IDE09568-MAS11552-Bit pattern of individual segment activation: left headlight-LED 82,OFF ,12
    IDE09568-MAS11553-Bit pattern of individual segment activation: left headlight-LED 83,OFF ,12
    IDE09568-MAS11554-Bit pattern of individual segment activation: left headlight-LED 84,OFF ,12
    IDE09568-MAS11555-Bit pattern of individual segment activation: left headlight-LED 85,OFF ,12
    IDE09568-MAS11556-Bit pattern of individual segment activation: left headlight-LED 86,OFF ,12
    IDE09568-MAS11557-Bit pattern of individual segment activation: left headlight-LED 87,OFF ,12
    IDE09568-MAS11558-Bit pattern of individual segment activation: left headlight-LED 88,OFF ,12
    IDE09568-MAS11559-Bit pattern of individual segment activation: left headlight-LED 89,OFF ,12
    IDE09568-MAS11560-Bit pattern of individual segment activation: left headlight-LED 90,OFF ,12
    IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1,OFF ,12
    IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2,OFF ,12
    IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3,OFF ,12
    IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4,OFF ,12
    IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5,OFF ,12
    IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6,OFF ,12
    IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7,OFF ,12
    IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8,OFF ,12
    IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9,OFF ,12
    IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10,OFF ,12
    IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11,OFF ,12
    IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12,OFF ,12
    IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13,OFF ,12
    IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14,OFF ,12
    IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15,OFF ,12
    IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16,OFF ,12
    IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17,OFF ,12
    IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18,OFF ,12
    IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19,OFF ,12
    IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20,OFF ,12
    IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21,OFF ,12
    IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22,OFF ,12
    IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23,OFF ,12
    IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24,OFF ,12
    IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25,OFF ,12
    IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26,OFF ,12
    IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27,OFF ,12
    IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28,OFF ,12
    IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29,OFF ,12
    IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30,OFF ,12
    IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31,OFF ,12
    IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32,OFF ,12
    IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33,OFF ,12
    IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34,OFF ,12
    IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35,OFF ,12
    IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36,OFF ,12
    IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37,OFF ,12
    IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38,OFF ,12
    IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39,OFF ,12
    IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40,OFF ,12
    IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41,OFF ,12
    IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42,OFF ,12
    IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43,OFF ,12
    IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44,OFF ,12
    IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45,OFF ,12
    IDE09569-MAS11516-Bit pattern of individual segment activation: right headlight-LED 46,OFF ,12
    IDE09569-MAS11517-Bit pattern of individual segment activation: right headlight-LED 47,OFF ,12
    IDE09569-MAS11518-Bit pattern of individual segment activation: right headlight-LED 48,OFF ,12
    IDE09569-MAS11519-Bit pattern of individual segment activation: right headlight-LED 49,OFF ,12
    IDE09569-MAS11520-Bit pattern of individual segment activation: right headlight-LED 50,OFF ,12
    IDE09569-MAS11521-Bit pattern of individual segment activation: right headlight-LED 51,OFF ,12
    IDE09569-MAS11522-Bit pattern of individual segment activation: right headlight-LED 52,OFF ,12
    IDE09569-MAS11523-Bit pattern of individual segment activation: right headlight-LED 53,OFF ,12
    IDE09569-MAS11524-Bit pattern of individual segment activation: right headlight-LED 54,OFF ,12
    IDE09569-MAS11525-Bit pattern of individual segment activation: right headlight-LED 55,OFF ,12
    IDE09569-MAS11526-Bit pattern of individual segment activation: right headlight-LED 56,OFF ,12
    IDE09569-MAS11527-Bit pattern of individual segment activation: right headlight-LED 57,OFF ,12
    IDE09569-MAS11528-Bit pattern of individual segment activation: right headlight-LED 58,OFF ,12
    IDE09569-MAS11529-Bit pattern of individual segment activation: right headlight-LED 59,OFF ,12
    IDE09569-MAS11530-Bit pattern of individual segment activation: right headlight-LED 60,OFF ,12
    IDE09569-MAS11531-Bit pattern of individual segment activation: right headlight-LED 61,OFF ,12
    IDE09569-MAS11532-Bit pattern of individual segment activation: right headlight-LED 62,OFF ,12
    IDE09569-MAS11533-Bit pattern of individual segment activation: right headlight-LED 63,OFF ,12
    IDE09569-MAS11534-Bit pattern of individual segment activation: right headlight-LED 64,OFF ,12
    IDE09569-MAS11535-Bit pattern of individual segment activation: right headlight-LED 65,OFF ,12
    IDE09569-MAS11536-Bit pattern of individual segment activation: right headlight-LED 66,OFF ,12
    IDE09569-MAS11537-Bit pattern of individual segment activation: right headlight-LED 67,OFF ,12
    IDE09569-MAS11538-Bit pattern of individual segment activation: right headlight-LED 68,OFF ,12
    IDE09569-MAS11539-Bit pattern of individual segment activation: right headlight-LED 69,OFF ,12
    IDE09569-MAS11540-Bit pattern of individual segment activation: right headlight-LED 70,OFF ,12
    IDE09569-MAS11541-Bit pattern of individual segment activation: right headlight-LED 71,OFF ,12
    IDE09569-MAS11542-Bit pattern of individual segment activation: right headlight-LED 72,OFF ,12
    IDE09569-MAS11543-Bit pattern of individual segment activation: right headlight-LED 73,OFF ,12
    IDE09569-MAS11544-Bit pattern of individual segment activation: right headlight-LED 74,OFF ,12
    IDE09569-MAS11545-Bit pattern of individual segment activation: right headlight-LED 75,OFF ,12
    IDE09569-MAS11546-Bit pattern of individual segment activation: right headlight-LED 76,OFF ,12
    IDE09569-MAS11547-Bit pattern of individual segment activation: right headlight-LED 77,OFF ,12
    IDE09569-MAS11548-Bit pattern of individual segment activation: right headlight-LED 78,OFF ,12
    IDE09569-MAS11549-Bit pattern of individual segment activation: right headlight-LED 79,OFF ,12
    IDE09569-MAS11550-Bit pattern of individual segment activation: right headlight-LED 80,OFF ,12
    IDE09569-MAS11551-Bit pattern of individual segment activation: right headlight-LED 81,OFF ,12
    IDE09569-MAS11552-Bit pattern of individual segment activation: right headlight-LED 82,OFF ,12
    IDE09569-MAS11553-Bit pattern of individual segment activation: right headlight-LED 83,OFF ,12
    IDE09569-MAS11554-Bit pattern of individual segment activation: right headlight-LED 84,OFF ,12
    IDE09569-MAS11555-Bit pattern of individual segment activation: right headlight-LED 85,OFF ,12
    IDE09569-MAS11556-Bit pattern of individual segment activation: right headlight-LED 86,OFF ,12
    IDE09569-MAS11557-Bit pattern of individual segment activation: right headlight-LED 87,OFF ,12
    IDE09569-MAS11558-Bit pattern of individual segment activation: right headlight-LED 88,OFF ,12
    IDE09569-MAS11559-Bit pattern of individual segment activation: right headlight-LED 89,OFF ,12
    IDE09569-MAS11560-Bit pattern of individual segment activation: right headlight-LED 90,OFF ,12
    IDE12648-MAS09833-Headlights left: low beam segment actuation-LED 1,OFF ,3
    IDE12648-MAS09834-Headlights left: low beam segment actuation-LED 2,OFF ,3
    IDE12648-MAS09835-Headlights left: low beam segment actuation-LED 3,OFF ,3
    IDE12648-MAS09836-Headlights left: low beam segment actuation-LED 4,OFF ,3
    IDE12648-MAS09837-Headlights left: low beam segment actuation-LED 5,OFF ,3
    IDE12648-MAS09838-Headlights left: low beam segment actuation-LED 6,OFF ,3
    IDE12648-MAS09839-Headlights left: low beam segment actuation-LED 7,OFF ,3
    IDE12648-MAS09840-Headlights left: low beam segment actuation-LED 8,OFF ,3
    IDE12648-MAS09841-Headlights left: low beam segment actuation-LED 9,OFF ,3
    IDE12648-MAS09842-Headlights left: low beam segment actuation-LED 10,OFF ,3
    IDE12648-MAS09843-Headlights left: low beam segment actuation-LED 11,OFF ,3
    IDE12648-MAS09844-Headlights left: low beam segment actuation-LED 12,OFF ,3
    IDE12648-MAS09845-Headlights left: low beam segment actuation-LED 13,OFF ,3
    IDE12648-MAS09846-Headlights left: low beam segment actuation-LED 14,OFF ,3
    IDE12648-MAS09847-Headlights left: low beam segment actuation-LED 15,OFF ,3
    IDE12648-MAS09848-Headlights left: low beam segment actuation-LED 16,OFF ,3
    IDE12648-MAS09849-Headlights left: low beam segment actuation-LED 17,OFF ,3
    IDE12648-MAS09850-Headlights left: low beam segment actuation-LED 18,OFF ,3
    IDE12648-MAS09851-Headlights left: low beam segment actuation-LED 19,OFF ,3
    IDE12648-MAS09852-Headlights left: low beam segment actuation-LED 20,OFF ,3
    IDE12649-MAS09833-Headlights right: low beam segment actuation-LED 1,OFF ,3
    IDE12649-MAS09834-Headlights right: low beam segment actuation-LED 2,OFF ,3
    IDE12649-MAS09835-Headlights right: low beam segment actuation-LED 3,OFF ,3
    IDE12649-MAS09836-Headlights right: low beam segment actuation-LED 4,OFF ,3
    IDE12649-MAS09837-Headlights right: low beam segment actuation-LED 5,OFF ,3
    IDE12649-MAS09838-Headlights right: low beam segment actuation-LED 6,OFF ,3
    IDE12649-MAS09839-Headlights right: low beam segment actuation-LED 7,OFF ,3
    IDE12649-MAS09840-Headlights right: low beam segment actuation-LED 8,OFF ,3
    IDE12649-MAS09841-Headlights right: low beam segment actuation-LED 9,OFF ,3
    IDE12649-MAS09842-Headlights right: low beam segment actuation-LED 10,OFF ,3
    IDE12649-MAS09843-Headlights right: low beam segment actuation-LED 11,OFF ,3
    IDE12649-MAS09844-Headlights right: low beam segment actuation-LED 12,OFF ,3
    IDE12649-MAS09845-Headlights right: low beam segment actuation-LED 13,OFF ,3
    IDE12649-MAS09846-Headlights right: low beam segment actuation-LED 14,OFF ,3
    IDE12649-MAS09847-Headlights right: low beam segment actuation-LED 15,OFF ,3
    IDE12649-MAS09848-Headlights right: low beam segment actuation-LED 16,OFF ,3
    IDE12649-MAS09849-Headlights right: low beam segment actuation-LED 17,OFF ,3
    IDE12649-MAS09850-Headlights right: low beam segment actuation-LED 18,OFF ,3
    IDE12649-MAS09851-Headlights right: low beam segment actuation-LED 19,OFF ,3
    IDE12649-MAS09852-Headlights right: low beam segment actuation-LED 20,OFF ,3
    IDE13611-Cornering lamp in operation,not active ,1
    IDE13612-Matrix head lamps: steering angle,9600.00 °,2
    ENG124608-Order_Reference_Run_Activation_Effect,No dependency ,1
    ENG124607-Reference_Run_Activation_Effect,Activation effect disabled ,1
    ENG103979-Reference_Run_Start_Condition,Engine start ,1
    Elapsed Time: 00:11
    52
    ;SW:5Q0-959-592-F   HW:5Q0-959-592-F ---  Door Elect, Pass.
    ;Component:TSG BFS001 0287, Coding:003F1020DC00040000001000
    ;EV_DCU2PasseSideMAXHKLO,001010,EV_DCU2PasseSideMAXHCONT_VW37.rod
    ;Sunday,17,March,2019,17:58:49:21782
    ;VCID: C3C6C4334AC04E5200-8096
    ENG117308-ENG148862-Patch_Code_Passenger_Side_Rear-Parameter_1,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,128
    ENG117308-ENG148865-Patch_Code_Passenger_Side_Rear-Parameter_2,FF FF ,128
    ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %,1
    ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %,1
    ENG117306-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_1,00 00 14 03 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 07 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 04 B0 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 ,128
    ENG117306-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1-Parameter_2,D4 3D ,128
    ENG117307-ENG148862-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_1,03 20 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 32 04 12 19 0A 00 05 F1 32 1E 0F 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 1E 00 19 1E 24 20 FA D8 C4 F6 FB 28 1E 32 0A 1E 00 00 2D 04 19 0D 12 0E FA E2 CE F1 F6 1E 14 32 00 0D 00 01 0E 02 19 0F 18 14 FA D8 C4 F6 FB 28 1E 32 08 0F 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,128
    ENG117307-ENG148865-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2-Parameter_2,5B 1B ,128
    ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 64 1E 00 32 32 01 90 00 00 00 00 00 00 00 B4 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 33 41 30 31 01 00 00 00 00 00 00 00 00 00 76 2E ,88
    Elapsed Time: 00:09
    5F
    ;SW:5NA-035-043-D   HW:5NA-035-043 ---  Information Electr.
    ;Component:MU-H-N-EU     H55 1367, Coding:02730601FF0000005111000100080A001F0100E4012004009E
    ;EV_MUHig4CGen2HBAS,001001,EV_MUHig4CGen2HBAS_VW37.rod
    ;Sunday,17,March,2019,17:59:43:21782
    ;VCID: B73EA0E30E1812F2AC-80E2
    IDE00346-Summertime-automatic,manual ,1
    IDE00768-Country identification: country of sale,-- ,2
    IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE00845-Wheel circ.,0 mm,2
    IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
    IDE01996-MAS00839-Installation list: specified installations-TV Tuner,No ,3
    IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3
    IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
    IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
    IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
    IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
    IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
    IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
    IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
    IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
    IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
    IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
    IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
    IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
    IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
    IDE02502-Confirmation of installation change,27 F0 ,2
    IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
    IDE02506-MAS03230-Copy multimedia data-Optical drive,On ,1
    IDE02607-Wheel pulse,0 ,2
    IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
    IDE03471-ENG142146-Vehicle configuration-allow_message_editing,On ,30
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On ,30
    IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
    IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
    IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
    IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
    IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
    IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
    IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
    IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
    IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On ,30
    IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On ,30
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On ,30
    IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
    IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
    IDE03471-ENG130246-Vehicle configuration-LTE_modul,Deactivated ,30
    IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
    IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
    IDE03471-ENG142141-Vehicle configuration-map_sms_support,On ,30
    IDE03471-ENG142152-Vehicle configuration-Map_Style,1 ,30
    IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
    IDE03471-ENG138662-Vehicle configuration-Mirror_link,On ,30
    IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
    IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB888 ,30
    IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
    IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
    IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
    IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
    IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
    IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
    IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
    IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
    IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
    IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
    IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
    IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
    IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
    IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
    IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
    IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
    IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
    IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
    IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,REGION_EU ,30
    IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,present ,30
    IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,On ,30
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,1 ,30
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On ,30
    IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
    IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
    IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
    IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
    IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
    IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
    IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
    IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,On ,30
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
    IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
    IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
    IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
    IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,5 ,2
    IDE05111-Fee-based traffic information (TMC),32768 ,2
    IDE06697-Audio management mute function,Muting of audio sources ,1
    IDE07399-ENG142045-Engine type-Engine_type_adaption_1,Petrol ,1
    IDE07399-ENG142046-Engine type-Engine_type_adaption_2,Petrol ,1
    IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,On ,1
    IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
    IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,On ,1
    IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,On ,1
    IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,On ,1
    IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
    IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
    IDE10082-MAS09813-Telephone functions configuration-Entering Access Point Name,On ,1
    IDE10082-MAS09814-Telephone functions configuration-Call Center Function,On ,1
    IDE10082-MAS13846-Telephone functions configuration-Internet access via WiFi,Available ,1
    IDE10082-MAS13847-Telephone functions configuration-Call center function on MIB: roadside assistance call,On ,1
    IDE10082-MAS13848-Telephone functions configuration-Call center function on MIB: POI call,On ,1
    IDE10082-MAS16726-Telephone functions configuration-Call center function on MIB: POI call regions,OFF ,1
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated ,4
    IDE10604-Menu entries for mobile online services,activated ,1
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
    IDE11105-Brand-specific display of connect application, ,256
    IDE11122-Country identification: country of sale HMI,EE ,2
    IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
    IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
    IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
    IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
    IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
    IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
    IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
    IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
    IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
    IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked ,21
    IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked ,21
    IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked ,21
    IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked ,21
    IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked ,21
    IDE11524-ENG142156-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42,not activated ,192
    IDE11524-ENG142157-Vehicle function list BAP 2nd generation: expansion-climate_mastet_0x42_msg_bus,not activated ,192
    IDE11524-ENG142158-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47,not activated ,192
    IDE11524-ENG142159-Vehicle function list BAP 2nd generation: expansion-connection_manager_0x47_msg_bus,not activated ,192
    IDE11524-ENG152529-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51,not activated ,192
    IDE11524-ENG152530-Vehicle function list BAP 2nd generation: expansion-daf_profile_0x51_msg_bus,not activated ,192
    IDE11524-ENG137043-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45,activated ,192
    IDE11524-ENG137044-Vehicle function list BAP 2nd generation: expansion-display_configuration_0x45_msg_bus,Comfort data bus ,192
    IDE11524-ENG185772-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D,not activated ,192
    IDE11524-ENG185773-Vehicle function list BAP 2nd generation: expansion-engine_functions_0x5D_msg_bus,not activated ,192
    IDE11524-ENG142168-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D,not activated ,192
    IDE11524-ENG142169-Vehicle function list BAP 2nd generation: expansion-fas_profile_0x4D_msg_bus,not activated ,192
    IDE11524-ENG142154-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41,not activated ,192
    IDE11524-ENG142155-Vehicle function list BAP 2nd generation: expansion-front_traffic_assist_0x41_msg_bus,not activated ,192
    IDE11524-ENG152535-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50,not activated ,192
    IDE11524-ENG152536-Vehicle function list BAP 2nd generation: expansion-infotainmentsettings_profile_0x50_msg_bus,not activated ,192
    IDE11524-ENG185787-Vehicle function list BAP 2nd generation: expansion-mascot_0x83,not activated ,192
    IDE11524-ENG185788-Vehicle function list BAP 2nd generation: expansion-mascot_0x83_msg_bus,not activated ,192
    IDE11524-ENG152569-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E,not activated ,192
    IDE11524-ENG152570-Vehicle function list BAP 2nd generation: expansion-remote_services_profile_0x4E_msg_bus,not activated ,192
    IDE11524-ENG139202-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44,not activated ,192
    IDE11524-ENG139203-Vehicle function list BAP 2nd generation: expansion-Soundcontrol_0x44_msg_bus,not activated ,192
    IDE11524-ENG127678-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40,not activated ,192
    IDE11524-ENG127679-Vehicle function list BAP 2nd generation: expansion-spoiler_0x40_msg_bus,not activated ,192
    IDE11524-ENG142162-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A,not activated ,192
    IDE11524-ENG142163-Vehicle function list BAP 2nd generation: expansion-statistic_0x4A_msg_bus,not activated ,192
    IDE11524-ENG142164-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B,not activated ,192
    IDE11524-ENG142165-Vehicle function list BAP 2nd generation: expansion-sunroof_front_0x4B_msg_bus,not activated ,192
    IDE11524-ENG142166-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C,not activated ,192
    IDE11524-ENG142167-Vehicle function list BAP 2nd generation: expansion-sunroof_rear_0x4C_msg_bus,not activated ,192
    IDE11524-ENG185817-Vehicle function list BAP 2nd generation: expansion-vas_0x54,not activated ,192
    IDE11524-ENG185818-Vehicle function list BAP 2nd generation: expansion-vas_0x54_msg_bus,not activated ,192
    IDE11524-ENG142160-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48,not activated ,192
    IDE11524-ENG142161-Vehicle function list BAP 2nd generation: expansion-wireless_charging_0x48_msg_bus,not activated ,192
    IDE11638-Bluetooth Audio Codec,FF ,1
    IDE12353-Configuration of traffic light online functions,On ,1
    IDE12434-ENG152495-Vehicle menu operation: second generation: extension-menu_connection_manager,not activated ,60
    IDE12434-ENG152499-Vehicle menu operation: second generation: extension-menu_connection_manager_after_disclaimer,not activated ,60
    IDE12434-ENG152496-Vehicle menu operation: second generation: extension-menu_connection_manager_clamp_15_off,not activated ,60
    IDE12434-ENG152497-Vehicle menu operation: second generation: extension-menu_connection_manager_over_threshold_high,not activated ,60
    IDE12434-ENG152498-Vehicle menu operation: second generation: extension-menu_connection_manager_standstill,not activated ,60
    IDE12434-ENG152548-Vehicle menu operation: second generation: extension-menu_daf_profile,not activated ,60
    IDE12434-ENG152549-Vehicle menu operation: second generation: extension-menu_daf_profile_after_disclaimer,not activated ,60
    IDE12434-ENG152550-Vehicle menu operation: second generation: extension-menu_daf_profile_clamp_15_off,not activated ,60
    IDE12434-ENG152551-Vehicle menu operation: second generation: extension-menu_daf_profile_over_threshold_high,not activated ,60
    IDE12434-ENG152552-Vehicle menu operation: second generation: extension-menu_daf_profile_stillstand,not activated ,60
    IDE12434-ENG185793-Vehicle menu operation: second generation: extension-menu_engine_functions,not activated ,60
    IDE12434-ENG185794-Vehicle menu operation: second generation: extension-menu_engine_functions_after_disclaimer,not activated ,60
    IDE12434-ENG185795-Vehicle menu operation: second generation: extension-menu_engine_functions_clamp_15_off,not activated ,60
    IDE12434-ENG185796-Vehicle menu operation: second generation: extension-menu_engine_functions_over_threshold_high,not activated ,60
    IDE12434-ENG185797-Vehicle menu operation: second generation: extension-menu_engine_functions_stillstand,not activated ,60
    IDE12434-ENG152515-Vehicle menu operation: second generation: extension-menu_fas_profile,not activated ,60
    IDE12434-ENG152519-Vehicle menu operation: second generation: extension-menu_fas_profile_after_disclaimer,not activated ,60
    IDE12434-ENG152516-Vehicle menu operation: second generation: extension-menu_fas_profile_clamp_15_off,not activated ,60
    IDE12434-ENG152517-Vehicle menu operation: second generation: extension-menu_fas_profile_over_threshold_high,not activated ,60
    IDE12434-ENG152518-Vehicle menu operation: second generation: extension-menu_fas_profile_standstill,not activated ,60
    IDE12434-ENG185798-Vehicle menu operation: second generation: extension-menu_fod,not activated ,60
    IDE12434-ENG185799-Vehicle menu operation: second generation: extension-menu_fod_after_disclaimer,not activated ,60
    IDE12434-ENG185800-Vehicle menu operation: second generation: extension-menu_fod_clamp_15_off,not activated ,60
    IDE12434-ENG185801-Vehicle menu operation: second generation: extension-menu_fod_over_threshold_high,not activated ,60
    IDE12434-ENG185802-Vehicle menu operation: second generation: extension-menu_fod_stillstand,not activated ,60
    IDE12434-ENG184478-Vehicle menu operation: second generation: extension-menu_mascot,not activated ,60
    IDE12434-ENG184479-Vehicle menu operation: second generation: extension-menu_mascot_after_disclaimer,not activated ,60
    IDE12434-ENG184480-Vehicle menu operation: second generation: extension-menu_mascot_clamp_15_off,not activated ,60
    IDE12434-ENG184481-Vehicle menu operation: second generation: extension-menu_mascot_over_threshold_high,not activated ,60
    IDE12434-ENG184482-Vehicle menu operation: second generation: extension-menu_mascot_stillstand,not activated ,60
    IDE12434-ENG152562-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile,not activated ,60
    IDE12434-ENG152563-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_after_disclaimer,not activated ,60
    IDE12434-ENG152564-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_clamp_15_off,not activated ,60
    IDE12434-ENG152565-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_over_threshold_high,not activated ,60
    IDE12434-ENG152566-Vehicle menu operation: second generation: extension-menu_mobile_device_key_profile_stillstand,not activated ,60
    IDE12434-ENG152505-Vehicle menu operation: second generation: extension-menu_statistic,not activated ,60
    IDE12434-ENG152509-Vehicle menu operation: second generation: extension-menu_statistic_after_disclaimer,not activated ,60
    IDE12434-ENG152506-Vehicle menu operation: second generation: extension-menu_statistic_clamp_15_off,not activated ,60
    IDE12434-ENG152507-Vehicle menu operation: second generation: extension-menu_statistic_over_threshold_high,not activated ,60
    IDE12434-ENG152508-Vehicle menu operation: second generation: extension-menu_statistic_standstill,not activated ,60
    IDE12434-ENG152510-Vehicle menu operation: second generation: extension-menu_sunroof,not activated ,60
    IDE12434-ENG152514-Vehicle menu operation: second generation: extension-menu_sunroof_after_disclaimer,not activated ,60
    IDE12434-ENG152511-Vehicle menu operation: second generation: extension-menu_sunroof_clamp_15_off,not activated ,60
    IDE12434-ENG152512-Vehicle menu operation: second generation: extension-menu_sunroof_over_threshold_high,not activated ,60
    IDE12434-ENG152513-Vehicle menu operation: second generation: extension-menu_sunroof_standstill,not activated ,60
    IDE12434-ENG185803-Vehicle menu operation: second generation: extension-menu_vas,not activated ,60
    IDE12434-ENG185804-Vehicle menu operation: second generation: extension-menu_vas_after_disclaimer,not activated ,60
    IDE12434-ENG185805-Vehicle menu operation: second generation: extension-menu_vas_clamp_15_off,not activated ,60
    IDE12434-ENG185806-Vehicle menu operation: second generation: extension-menu_vas_over_threshold_high,not activated ,60
    IDE12434-ENG185807-Vehicle menu operation: second generation: extension-menu_vas_stillstand,not activated ,60
    IDE12434-ENG152500-Vehicle menu operation: second generation: extension-menu_wireless_charging,not activated ,60
    IDE12434-ENG152504-Vehicle menu operation: second generation: extension-menu_wireless_charging_after_disclaimer,not activated ,60
    IDE12434-ENG152501-Vehicle menu operation: second generation: extension-menu_wireless_charging_clamp_15_off,not activated ,60
    IDE12434-ENG152502-Vehicle menu operation: second generation: extension-menu_wireless_charging_over_threshold_high,not activated ,60
    IDE12434-ENG152503-Vehicle menu operation: second generation: extension-menu_wireless_charging_standstill,not activated ,60
    IDE13183-Deactivation/activation of the pop-up for active tracking services,00 00 00 00 ,4
    MAS00951-Bluetooth,On ,1
    MAS03782-WLAN,On ,1
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,OFF ,12
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,0.00 ms,12
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,OFF ,12
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,0.00 ms,12
    ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,activated ,60
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,activated ,60
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated ,60
    ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,activated ,60
    ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,activated ,60
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated ,60
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated ,60
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,activated ,60
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,activated ,60
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,activated ,64
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated ,64
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,not activated ,64
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated ,64
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
    ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,activated ,64
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
    ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
    ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus ,64
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated ,64
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
    ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
    ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,10
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_3 ,10
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming ,10
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,On ,10
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
    ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed ,1
    ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed ,1
    ENG167428-ENG167502-nhtsa_properties-limitation_dependency,Speed_threshold ,5
    ENG167428-ENG167510-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_limit_displayed_message_length,activated ,5
    ENG167428-ENG167511-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_setup_configuration,activated ,5
    ENG167428-ENG167512-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_text_input,not activated ,5
    ENG167428-ENG167513-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_video_playback,activated ,5
    ENG167428-ENG167514-nhtsa_properties-nhtsa_limitation_switches_for_androidauto_no_voice _input,not activated ,5
    ENG167428-ENG167515-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_musicLists,not activated ,5
    ENG167428-ENG167516-nhtsa_properties-nhtsa_limitation_switches_for_carplay_limit_nonMusicLists,not activated ,5
    ENG167428-ENG167517-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_japanMaps,not activated ,5
    ENG167428-ENG167518-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softKeyboard,not activated ,5
    ENG167428-ENG167519-nhtsa_properties-nhtsa_limitation_switches_for_carplay_no_softPhoneKeypad,not activated ,5
    ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 28 02 50 02 50 02 28 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 48 ,40
    ENG117808-p_HMI_Display,13 %,1
    ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
    Elapsed Time: 01:00
    6C
    ;SW:5Q0-980-556-B   HW:5Q0-980-556-B ---  Back-up Cam.
    ;Component:RVC Compact   H15 0231, Coding:0123060122002017000040
    ;EV_CamSysRVRVCPANAMQBAB,006009,EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
    ;Sunday,17,March,2019,18:00:49:21782
    ;VCDS Version: Release 18.9.1 (x64)  Data version: 20190114 DS296.0
    ;VCID: B93AA6DB380C04825A-80EC
    IDE02709-Actuator: PWM signal,100 %,1
    IDE03531-Wheel/tire description,1950 mm,2
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min,2
    MAS02209-Image contrast,50 %,1
    MAS02851-Brightness,50 %,1
    ENG119212-camera_off,35.00 km/h,2
    ENG119211-camera_on,30.00 km/h,2
    ENG119200-color,50 %,1
    ENG119218-debounce_time_for_reverse_gear,0 ms,2
    ENG119215-display_position,0 px,1
    ENG119216-engine_restart_timer,0 ms,2
    ENG119209-Frequency_Swinging_Logo,100 Hz,2
    ENG119221-FSG_control_state,On ,1
    ENG119220-ENG119101-grafic_element_setting-setting_1_color_value,FF FF ,128
    ENG119220-ENG119099-grafic_element_setting-setting_1_HMI_mode,FF ,128
    ENG119220-ENG119100-grafic_element_setting-setting_1_pallet_ID,255 ,128
    ENG119220-ENG119128-grafic_element_setting-setting_10_color_value,FF FF ,128
    ENG119220-ENG119126-grafic_element_setting-setting_10_HMI_mode,FF ,128
    ENG119220-ENG119127-grafic_element_setting-setting_10_pallet_ID,255 ,128
    ENG119220-ENG119131-grafic_element_setting-setting_11_color_value,FF FF ,128
    ENG119220-ENG119129-grafic_element_setting-setting_11_HMI_mode,FF ,128
    ENG119220-ENG119130-grafic_element_setting-setting_11_pallet_ID,255 ,128
    ENG119220-ENG119134-grafic_element_setting-setting_12_color_value,FF FF ,128
    ENG119220-ENG119132-grafic_element_setting-setting_12_HMI_mode,FF ,128
    ENG119220-ENG119133-grafic_element_setting-setting_12_pallet_ID,255 ,128
    ENG119220-ENG119137-grafic_element_setting-setting_13_color_value,FF FF ,128
    ENG119220-ENG119135-grafic_element_setting-setting_13_HMI_mode,FF ,128
    ENG119220-ENG119136-grafic_element_setting-setting_13_pallet_ID,255 ,128
    ENG119220-ENG119140-grafic_element_setting-setting_14_color_value,FF FF ,128
    ENG119220-ENG119138-grafic_element_setting-setting_14_HMI_mode,FF ,128
    ENG119220-ENG119139-grafic_element_setting-setting_14_pallet_ID,255 ,128
    ENG119220-ENG119143-grafic_element_setting-setting_15_color_value,FF FF ,128
    ENG119220-ENG119141-grafic_element_setting-setting_15_HMI_mode,FF ,128
    ENG119220-ENG119142-grafic_element_setting-setting_15_pallet_ID,255 ,128
    ENG119220-ENG119146-grafic_element_setting-setting_16_color_value,FF FF ,128
    ENG119220-ENG119144-grafic_element_setting-setting_16_HMI_mode,FF ,128
    ENG119220-ENG119145-grafic_element_setting-setting_16_pallet_ID,255 ,128
    ENG119220-ENG119149-grafic_element_setting-setting_17_color_value,FF FF ,128
    ENG119220-ENG119147-grafic_element_setting-setting_17_HMI_mode,FF ,128
    ENG119220-ENG119148-grafic_element_setting-setting_17_pallet_ID,255 ,128
    ENG119220-ENG119152-grafic_element_setting-setting_18_color_value,FF FF ,128
    ENG119220-ENG119150-grafic_element_setting-setting_18_HMI_mode,FF ,128
    ENG119220-ENG119151-grafic_element_setting-setting_18_pallet_ID,255 ,128
    ENG119220-ENG119155-grafic_element_setting-setting_19_color_value,FF FF ,128
    ENG119220-ENG119153-grafic_element_setting-setting_19_HMI_mode,FF ,128
    ENG119220-ENG119154-grafic_element_setting-setting_19_pallet_ID,255 ,128
    ENG119220-ENG119104-grafic_element_setting-setting_2_color_value,FF FF ,128
    ENG119220-ENG119102-grafic_element_setting-setting_2_HMI_mode,FF ,128
    ENG119220-ENG119103-grafic_element_setting-setting_2_pallet_ID,255 ,128
    ENG119220-ENG119158-grafic_element_setting-setting_20_color_value,FF FF ,128
    ENG119220-ENG119156-grafic_element_setting-setting_20_HMI_mode,FF ,128
    ENG119220-ENG119157-grafic_element_setting-setting_20_pallet_ID,255 ,128
    ENG119220-ENG119161-grafic_element_setting-setting_21_color_value,FF FF ,128
    ENG119220-ENG119159-grafic_element_setting-setting_21_HMI_mode,FF ,128
    ENG119220-ENG119160-grafic_element_setting-setting_21_pallet_ID,255 ,128
    ENG119220-ENG119164-grafic_element_setting-setting_22_color_value,FF FF ,128
    ENG119220-ENG119162-grafic_element_setting-setting_22_HMI_mode,FF ,128
    ENG119220-ENG119163-grafic_element_setting-setting_22_pallet_ID,255 ,128
    ENG119220-ENG119167-grafic_element_setting-setting_23_color_value,FF FF ,128
    ENG119220-ENG119165-grafic_element_setting-setting_23_HMI_mode,FF ,128
    ENG119220-ENG119166-grafic_element_setting-setting_23_pallet_ID,255 ,128
    ENG119220-ENG119170-grafic_element_setting-setting_24_color_value,FF FF ,128
    ENG119220-ENG119168-grafic_element_setting-setting_24_HMI_mode,FF ,128
    ENG119220-ENG119169-grafic_element_setting-setting_24_pallet_ID,255 ,128
    ENG119220-ENG119173-grafic_element_setting-setting_25_color_value,FF FF ,128
    ENG119220-ENG119171-grafic_element_setting-setting_25_HMI_mode,FF ,128
    ENG119220-ENG119172-grafic_element_setting-setting_25_pallet_ID,255 ,128
    ENG119220-ENG119176-grafic_element_setting-setting_26_color_value,FF FF ,128
    ENG119220-ENG119174-grafic_element_setting-setting_26_HMI_mode,FF ,128
    ENG119220-ENG119175-grafic_element_setting-setting_26_pallet_ID,255 ,128
    ENG119220-ENG119179-grafic_element_setting-setting_27_color_value,FF FF ,128
    ENG119220-ENG119177-grafic_element_setting-setting_27_HMI_mode,FF ,128
    ENG119220-ENG119178-grafic_element_setting-setting_27_pallet_ID,255 ,128
    ENG119220-ENG119182-grafic_element_setting-setting_28_color_value,FF FF ,128
    ENG119220-ENG119180-grafic_element_setting-setting_28_HMI_mode,FF ,128
    ENG119220-ENG119181-grafic_element_setting-setting_28_pallet_ID,255 ,128
    ENG119220-ENG119185-grafic_element_setting-setting_29_color_value,FF FF ,128
    ENG119220-ENG119183-grafic_element_setting-setting_29_HMI_mode,FF ,128
    ENG119220-ENG119184-grafic_element_setting-setting_29_pallet_ID,255 ,128
    ENG119220-ENG119107-grafic_element_setting-setting_3_color_value,FF FF ,128
    ENG119220-ENG119105-grafic_element_setting-setting_3_HMI_mode,FF ,128
    ENG119220-ENG119106-grafic_element_setting-setting_3_pallet_ID,255 ,128
    ENG119220-ENG119188-grafic_element_setting-setting_30_color_value,FF FF ,128
    ENG119220-ENG119186-grafic_element_setting-setting_30_HMI_mode,FF ,128
    ENG119220-ENG119187-grafic_element_setting-setting_30_pallet_ID,255 ,128
    ENG119220-ENG119191-grafic_element_setting-setting_31_color_value,FF FF ,128
    ENG119220-ENG119189-grafic_element_setting-setting_31_HMI_mode,FF ,128
    ENG119220-ENG119190-grafic_element_setting-setting_31_pallet_ID,255 ,128
    ENG119220-ENG119194-grafic_element_setting-setting_32_color_value,FF FF ,128
    ENG119220-ENG119192-grafic_element_setting-setting_32_HMI_mode,FF ,128
    ENG119220-ENG119193-grafic_element_setting-setting_32_pallet_ID,255 ,128
    ENG119220-ENG119110-grafic_element_setting-setting_4_color_value,FF FF ,128
    ENG119220-ENG119108-grafic_element_setting-setting_4_HMI_mode,FF ,128
    ENG119220-ENG119109-grafic_element_setting-setting_4_pallet_ID,255 ,128
    ENG119220-ENG119113-grafic_element_setting-setting_5_color_value,FF FF ,128
    ENG119220-ENG119111-grafic_element_setting-setting_5_HMI_mode,FF ,128
    ENG119220-ENG119112-grafic_element_setting-setting_5_pallet_ID,255 ,128
    ENG119220-ENG119116-grafic_element_setting-setting_6_color_value,FF FF ,128
    ENG119220-ENG119114-grafic_element_setting-setting_6_HMI_mode,FF ,128
    ENG119220-ENG119115-grafic_element_setting-setting_6_pallet_ID,255 ,128
    ENG119220-ENG119119-grafic_element_setting-setting_7_color_value,FF FF ,128
    ENG119220-ENG119117-grafic_element_setting-setting_7_HMI_mode,FF ,128
    ENG119220-ENG119118-grafic_element_setting-setting_7_pallet_ID,255 ,128
    ENG119220-ENG119122-grafic_element_setting-setting_8_color_value,FF FF ,128
    ENG119220-ENG119120-grafic_element_setting-setting_8_HMI_mode,FF ,128
    ENG119220-ENG119121-grafic_element_setting-setting_8_pallet_ID,255 ,128
    ENG119220-ENG119125-grafic_element_setting-setting_9_color_value,FF FF ,128
    ENG119220-ENG119123-grafic_element_setting-setting_9_HMI_mode,FF ,128
    ENG119220-ENG119124-grafic_element_setting-setting_9_pallet_ID,255 ,128
    ENG119201-image_delay_timer,0.0 s,1
    ENG119219-Minimal_time_to_stay_in_bus_sleep_before_ECU_off,20000 ms,2
    ENG119214-rv_dark_off,10.00 km/h,2
    ENG119213-rv_dark_on,15.00 km/h,2
    ENG119203-RV_Last_Mode,90° parking spot ,1
    ENG102898-RV_Start_Mode,90° parking spot ,1
    ENG119205-Time_to_open_Swinging_Logo,750 ms,2
    Elapsed Time: 00:07
    6D
    ;SW:5Q0-959-107-Q   HW:5Q0-959-107-C ---  Trunk Elect.
    ;Component:HDSG-Modul    H12 0266, Coding:0A28
    ;EV_DeckLidCONTIAU736,001016,EV_DeckLidCONTIAU736_VW37.rod
    ;Sunday,17,March,2019,18:01:08:21782
    ;VCID: C6C0DD2779F27B7A27-8092
    IDE00001-IDE03415-Production mode-Tone sensor,not active ,3
    IDE00001-IDE10408-Production mode-Opening height in production mode,not active ,3
    IDE00001-MAS10733-Production mode-Activation due to excessive pressure on rear lid,not active ,3
    IDE00001-MAS10734-Production mode-Activation of rear lid with reduced speed,not active ,3
    IDE00001-MAS10735-Production mode-Calibration,not active ,3
    IDE00001-MAS10736-Production mode-Checking the rear lid button,not active ,3
    IDE00001-MAS10738-Production mode-Opening and closing rear lid,not active ,3
    IDE02158-Program opening stop,1532 ,2
    IDE03435-Detection area upper,20 ,2
    IDE03776-Offset for maximum programmable opening stop,10 ,2
    IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,0 min,2
    IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,4 min,2
    IDE09510-IDE02111-Tailgate reverse path-Reverse path when opening,1 ,4
    IDE09510-IDE02113-Tailgate reverse path-Reverse path when closing,287 ,4
    IDE09511-Minimum opening height of tailgate,200 ,2
    IDE09512-Deactivation of tailgate,active ,1
    IDE09514-MAS01871-Deactivation of tailgate while in trailer operation-Rear lid lock button in luggage compartment,active ,2
    IDE09514-MAS06265-Deactivation of tailgate while in trailer operation-Release button in rear lid handle,active ,2
    IDE09514-MAS09010-Deactivation of tailgate while in trailer operation-Sensor for rear lid opening,active ,2
    IDE09514-MAS09042-Deactivation of tailgate while in trailer operation-Using button to close lock. mechanism in tailgate handle,active ,2
    IDE09514-MAS09043-Deactivation of tailgate while in trailer operation-Remote ctrl: opening with button for tailgate unlock. mechan.,not active ,2
    IDE09514-MAS09044-Deactivation of tailgate while in trailer operation-Remote ctrl: closing with button for tailgate unlock. mechan.,not active ,2
    IDE09514-MAS09045-Deactivation of tailgate while in trailer operation-Using sensor to open tailgate,not active ,2
    IDE09514-MAS09046-Deactivation of tailgate while in trailer operation-Using sensor to close tailgate,not active ,2
    IDE09514-MAS09063-Deactivation of tailgate while in trailer operation-Opening with button for remote unlocking of tailgate,not active ,2
    IDE09514-MAS09064-Deactivation of tailgate while in trailer operation-Closing with remote unl.button of tailgate when using a trailer,not active ,2
    IDE09514-MAS11625-Deactivation of tailgate while in trailer operation-Button for opening rear lid in luggage compartment,active ,2
    IDE09514-MAS13754-Deactivation of tailgate while in trailer operation-Opening with button 2 for remote unlocking of rear lid,not active ,2
    IDE09514-MAS13755-Deactivation of tailgate while in trailer operation-Closing with remote unlock.butt.2 of rear lid when using trail.,not active ,2
    IDE09520-Offset for opening height after basic setting,0 ,2
    IDE10408-Opening height in production mode,60 %,2
    IDE10695-Dectivation of the luggage compartment cover,not active ,1
    IDE10703-Luggage compartment cover: tolerance of the block counter,0 ,2
    IDE10704-Luggage compartment cover: maximum no. of block drives,0 ,2
    IDE10705-Luggage compartment cover: number bloom drives,0 ,2
    IDE10706-MAS01875-Luggage compartment cover: reverse path after obstacle recogn.-Open,0 ,4
    IDE10706-MAS01876-Luggage compartment cover: reverse path after obstacle recogn.-Close,0 ,4
    IDE10707-IDE03434-Luggage compartment cover: detection area-Detection area lower,0 ,4
    IDE10707-IDE03435-Luggage compartment cover: detection area-Detection area upper,0 ,4
    IDE10708-Luggage compartment cover: adjust. track tolerance,0 ,2
    IDE10709-Luggage compartment cover: excess limitation in exclusion area,not active ,1
    ENG131232-MAS01911-Ausstattungen aktivieren-Tone sensor,active ,2
    ENG131232-MAS01947-Ausstattungen aktivieren-Clamping strip 1,not active ,2
    ENG131232-MAS01948-Ausstattungen aktivieren-Clamping strip 2,not active ,2
    ENG131232-MAS01949-Ausstattungen aktivieren-Clamping strip 3,not active ,2
    ENG131232-MAS01950-Ausstattungen aktivieren-Clamping strip 4,not active ,2
    ENG131232-MAS04266-Ausstattungen aktivieren-Temperature sensor 1,active ,2
    ENG131232-MAS04267-Ausstattungen aktivieren-Temperature sensor 2,active ,2
    ENG131232-MAS08212-Ausstattungen aktivieren-Engine 2,active ,2
    ENG131232-MAS09001-Ausstattungen aktivieren-Closing Assist Motor,active ,2
    ENG131232-MAS11624-Ausstattungen aktivieren-Motor 2: sensor system,active ,2
    Elapsed Time: 00:06
    75
    ;SW:5NA-035-284-C   HW:5NA-035-284-C ---  Telematics
    ;Component:OCULowMQBLGE  H19 0824, Coding:02230601EA42180D3F1CBE020045400382E708
    ;EV_OCULowMQBLGE,004049,EV_OCULowMQBLGE_004_VW37.rod
    ;Sunday,17,March,2019,18:01:35:21782
    ;VCID: BD32B2CB2C2438A276-80E8
    IDE00608-MAS00713-Type of fuel-Petrol,not installed ,1
    IDE00608-MAS00716-Type of fuel-Diesel,installed ,1
    IDE00608-MAS00717-Type of fuel-Petroleum gas,not installed ,1
    IDE00608-MAS00718-Type of fuel-Natural gas,not installed ,1
    IDE00608-MAS00720-Type of fuel-Battery / electric,not installed ,1
    IDE00608-MAS03131-Type of fuel-Hydrogen,not installed ,1
    IDE00761-MAS08397-After-run time-Long term energy budget,3600 mAh,14
    IDE00761-MAS08398-After-run time-Short term energy budget,2000 mAh,14
    IDE00761-MAS08399-After-run time-Waiting period from sleep to standby mode,5 min,14
    IDE00761-MAS08400-After-run time-Waiting period from standby to stop mode,336 H,14
    IDE00761-MAS08950-After-run time-Time period for cyclic stop mode in operating mode,0 min,14
    IDE00761-MAS08951-After-run time-Time period for cyclic standby mode in operating mode,0 min,14
    IDE00761-MAS08952-After-run time-Time period for operating mode,0 d,14
    IDE00761-MAS08953-After-run time-Cyclic time after the operating mode,0 H,14
    IDE00761-MAS08954-After-run time-Connection after T. 15 on,Yes ,14
    IDE00761-MAS08955-After-run time-Time period for connection after T. 15 on,15 min,14
    IDE00765-Delay of audio output,1.0 s,1
    IDE00766-Reference channel delay,0 ms,1
    IDE00769-Number 1 for Info call, ,15
    IDE00770-Number 1 for roadside assistance, ,15
    IDE01630-ENG154630-Button lighting in control unit for phone-green_led_Active_call,1000 ms,16
    IDE01630-ENG154631-Button lighting in control unit for phone-green_led_Disable,5000 ms,16
    IDE01630-ENG154632-Button lighting in control unit for phone-green_led_Error_enable,5000 ms,16
    IDE01630-ENG154633-Button lighting in control unit for phone-green_led_Service_mode,500 ms,16
    IDE01630-ENG154708-Button lighting in control unit for phone-off_Active_call,1000 ms,16
    IDE01630-ENG154709-Button lighting in control unit for phone-off_Disable,1000 ms,16
    IDE01630-ENG154715-Button lighting in control unit for phone-red_led_Error_enable,1000 ms,16
    IDE01630-ENG154825-Button lighting in control unit for phone-yellow_Service_mode,500 ms,16
    IDE02067-Antenna for telephone status,emergency_switch ,1
    IDE02330-Number 2 for Info call,+4953612771600 ,15
    IDE02331-Number 2 for roadside assistance,+37253470000 ,15
    IDE03481-Emergency telephone number,112 ,15
    IDE04307-MAS00688-Vehicle function list BAP-Multifunction indicator,activated ,2
    IDE04307-MAS02444-Vehicle function list BAP-Central locking,activated ,2
    IDE04307-MAS04219-Vehicle function list BAP-Parking heater,activated ,2
    IDE04307-MAS06654-Vehicle function list BAP-Charge manager,not activated ,2
    IDE04307-ENG117726-Vehicle function list BAP-service_interval_display_0x12,activated ,2
    IDE07699-Mobile network operator,apn3.vwg-connect ,63
    IDE09244-Fuel tank volume,58 l,1
    IDE11106-ENG98714-Remote door locking functionality-lock,activated ,1
    IDE11106-ENG98998-Remote door locking functionality-unlock,activated ,1
    IDE11109-Remote door locking status update delay,0 s,1
    IDE11138-Certificate,MBB_EU (CA0D) ,1
    IDE11280-eCall timeout time,10 min,1
    IDE11281-MAS01632-eCall SMS message-Status,not activated ,16
    IDE11281-MAS04226-eCall SMS message-Telephone number, ,16
    IDE11306-ENG154717-Vehicle status remote query-Remote_Vehicle_Status_BEM_Alert_Changed,not activated ,5
    IDE11306-ENG154718-Vehicle status remote query-Remote_Vehicle_Status_Bussleep,activated ,5
    IDE11306-ENG154719-Vehicle status remote query-Remote_Vehicle_Status_Bussleep_Delay,5 s,5
    IDE11306-ENG123302-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_Off_Delay,5 s,5
    IDE11306-ENG123301-Vehicle status remote query-Remote_Vehicle_Status_Clamp_15_On_Delay,1275 s,5
    IDE11306-ENG154720-Vehicle status remote query-Remote_Vehicle_Status_Trigger_Relock,1275 s,5
    IDE12154-Center distance,2200 mm,2
    IDE12155-MAS08451-Lane width-Front axle,1850 mm,4
    IDE12155-MAS08452-Lane width-Rear axle,1850 mm,4
    MAS02926-Maximum wait time,10 s,1
    MAS07467-Speed warning maximum speed,0 km/h,2
    MAS08170-User profile name,vodafone ,25
    MAS08171-User profile password,vodafone ,25
    MAS08172-Mobile Online services: first host name,er-cgw-ca0d-mbbservices.audi-connect.de/mbb/vehicles/v1_cai/ ,512
    MAS08173-Mobile Online services: second host name,er-cgw-ca0d-mbbservices.audi-connect.de/mbb/vehicles/v1_cai/ ,512
    MAS08174-Fallback DNS Server, ,39
    MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation,0 min,3
    MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation,0 km,3
    MAS08176-Test tel. number for roadside assistance, ,15
    MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1,0 ,12
    MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2,10 ,12
    MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3,50 ,12
    MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4,100 ,12
    MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5,150 ,12
    MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6,253 ,12
    MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1,1 %,12
    MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2,1 %,12
    MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3,2 %,12
    MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4,4 %,12
    MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5,80 %,12
    MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6,100 %,12
    MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1,0 ,12
    MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2,10 ,12
    MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3,50 ,12
    MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4,100 ,12
    MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5,150 ,12
    MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6,253 ,12
    MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1,1 %,12
    MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2,1 %,12
    MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3,2 %,12
    MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4,4 %,12
    MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5,80 %,12
    MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6,100 %,12
    MAS08983-Dimming coefficient of red function illumination,60 %,1
    MAS08984-Dimming coefficient of green function illumination,40 %,1
    MAS09650-Threshold for vehicle movement recognition,5 km/h,2
    MAS11232-Base volume of external emergency call speaker,30 %,1
    MAS13395-Transmission_status_activation-,activated ,5
    MAS13395-MAS13397-Transmission_status_activation-No transmission after OTVreques,1000 d,5
    MAS13395-MAS13398-Transmission_status_activation-Number of days prior to service schedule_before display combi,30 d,5
    MAS13395-MAS13399-Transmission_status_activation-Number of days before service reminder,0 d,5
    MAS13396-MAS13392-Remote BatteryCharging Management_Battery Status Report-threshold,95 %,3
    MAS13396-MAS13394-Remote BatteryCharging Management_Battery Status Report-Steps Above Threshold,1 %,3
    MAS13396-MAS13442-Remote BatteryCharging Management_Battery Status Report-StepsBelowThreshold,5 %,3
    MAS13822-Call auto response time,20 min,2
    MAS13824-Test mode end distance,300 m,2
    MAS13825-Emergency call test number, ,15
    MAS13826-Internal memory transmission interval,60 min,2
    MAS13827-Internal memory transmission attempts,10 ,2
    MAS13832-Emergency call dial duration,5 min,2
    MAS13836-Emergency call auto selection attempts,1 ,2
    MAS13837-Emergency call manual selection attempt,1 ,2
    MAS13839-Test log on duration,5 min,2
    MAS13840-Gnss data transmission rate,1 Hz,2
    MAS13841-Gnss min height,5 °,2
    MAS16952-ENG101574-Dimming characteristics of pushbutton module-X1,0 ,6
    MAS16952-ENG99557-Dimming characteristics of pushbutton module-X2,45 ,6
    MAS16952-ENG102140-Dimming characteristics of pushbutton module-X3,100 ,6
    MAS16952-ENG99777-Dimming characteristics of pushbutton module-Y1,0 %,6
    MAS16952-ENG100480-Dimming characteristics of pushbutton module-Y2,100 %,6
    MAS16952-ENG100773-Dimming characteristics of pushbutton module-Y3,100 %,6
    MAS17427-MAS00220-Door configuration-Left rear door,installed ,1
    MAS17427-MAS00221-Door configuration-Right rear door,installed ,1
    MAS17427-SFT271922-Door configuration-Left rear door control module,installed ,1
    MAS17427-SFT271923-Door configuration-Right rear door control module,installed ,1
    MAS18271-Acoustic return message for breakdown assistance call system,activated ,1
    MAS18272-Breakdown assistance call: protocol version,Generation_20 ,1
    ENG244869-Background_Scan_time_interval,3 min,1
    ENG137852-Backup_Power_Threshold,30 %,1
    ENG153714-Callback_Time_Dropped_Call,1 s,2
    ENG153715-Can_Timeout_Trigger,100 ms,2
    ENG153716-Cancel_eCall_by_Button,not activated ,1
    ENG153717-Cancel_Manual_eCall_Timer,12 s,1
    ENG123200-Driving_Follow_Up_Time,5 min,1
    ENG153721-eCall_Call_Back_Delay,4 s,1
    ENG153723-Field_Test_Mode_Time,10 min,1
    ENG123187-MAS01424-Geofencing_Area_First_Radius-max.value,4294967294 m,8
    ENG123187-MAS01425-Geofencing_Area_First_Radius-min.value,1 m,8
    ENG123190-MAS01424-Geofencing_Area_Highth-max.value,4294967294 m,8
    ENG123190-MAS01425-Geofencing_Area_Highth-min.value,1 m,8
    ENG123192-MAS01424-Geofencing_Area_Latitude-max.value,+2.147.483.648 ,28
    ENG123192-MAS01425-Geofencing_Area_Latitude-min.value,-2.147.483.648 ,28
    ENG123191-MAS01424-Geofencing_Area_Longitude-max.value,+2.147.483.648 ,28
    ENG123191-MAS01425-Geofencing_Area_Longitude-min.value,-2.147.483.648 ,28
    ENG123188-MAS01424-Geofencing_Area_Second_Radius-max.value,4294967294 m,8
    ENG123188-MAS01425-Geofencing_Area_Second_Radius-min.value,1 m,8
    ENG123189-MAS01424-Geofencing_Area_Width-max.value,4294967294 m,8
    ENG123189-MAS01425-Geofencing_Area_Width-min.value,1 m,8
    ENG153692-GSM_Antenna_Switch_Speed_Delay,45 s,1
    ENG153690-GSM_Antenna_Switch_Speed_Limit,15 km/h,1
    ENG153691-GSM_Antenna_Switch_Time_Limit,60 min,1
    ENG153726-Invalid_Position_Threshold,500 m,2
    ENG153729-Low_Confidence_Threshold,150 m,2
    ENG153730-Manual_eCall Cancellation_Time,0 ms,2
    ENG153731-Manual_eCall_Trigger_Time,200 ms,2
    ENG123186-Manual_Emergency_Call,OFF ,1
    ENG153732-ENG154791-MSD_Timers-Timer_T1,0 s,16
    ENG153732-ENG154792-MSD_Timers-Timer_T10,43200 s,16
    ENG153732-ENG154793-MSD_Timers-Timer_T2,3600 s,16
    ENG153732-ENG154794-MSD_Timers-Timer_T3,2 s,16
    ENG153732-ENG154795-MSD_Timers-Timer_T5,5 s,16
    ENG153732-ENG154796-MSD_Timers-Timer_T6,5 s,16
    ENG153732-ENG154797-MSD_Timers-Timer_T7,20 s,16
    ENG153732-ENG154798-MSD_Timers-Timer_T9,3600 s,16
    ENG123194-ENG123350-Online_Services_Communication_Protocol-GSM_Automatic_Operator,automatic ,10
    ENG123194-ENG123354-Online_Services_Communication_Protocol-Keep_Connection_Alive_If_Event_Expected_Within,10 min,10
    ENG123194-ENG123356-Online_Services_Communication_Protocol-PDP_Grace_Time,120 s,10
    ENG123194-ENG123351-Online_Services_Communication_Protocol-PDP_Type,IPv4 ,10
    ENG123194-ENG123352-Online_Services_Communication_Protocol-TCP_Max_Receive_Window,65535 B,10
    ENG123194-ENG123353-Online_Services_Communication_Protocol-TCP_Max_Transmit_Window,65535 B,10
    ENG123194-ENG123355-Online_Services_Communication_Protocol-TCPMS,532 B,10
    ENG123196-ENG123362-Online_Services_Data_Roaming-Core_Service_Management,activated ,3
    ENG123196-ENG125484-Online_Services_Data_Roaming-Core_Service_Telephony,activated ,3
    ENG123196-ENG123286-Online_Services_Data_Roaming-Geofencing,activated ,3
    ENG123196-ENG125485-Online_Services_Data_Roaming-JobMechanism,activated ,3
    ENG123196-ENG123288-Online_Services_Data_Roaming-POI_Address_Import,activated ,3
    ENG123196-ENG154716-Online_Services_Data_Roaming-Remote_Auxiliary_Heating,activated ,3
    ENG123196-ENG123215-Online_Services_Data_Roaming-Remote_Battery_Charging_Management,activated ,3
    ENG123196-ENG123293-Online_Services_Data_Roaming-Remote_Departure_Time_Programming,activated ,3
    ENG123196-ENG123287-Online_Services_Data_Roaming-Remote_Door_Unlock,activated ,3
    ENG123196-ENG123216-Online_Services_Data_Roaming-Remote_Honking_and_Flashing,activated ,3
    ENG123196-ENG123214-Online_Services_Data_Roaming-Remote_Pre_Trip_Climatisation,activated ,3
    ENG123196-ENG123289-Online_Services_Data_Roaming-Remote_Speed_Alert,activated ,3
    ENG123196-ENG123292-Online_Services_Data_Roaming-Remote_Trip_Statistics,activated ,3
    ENG123196-ENG123290-Online_Services_Data_Roaming-Remote_Vehicle_Disabling,not activated ,3
    ENG123196-ENG123183-Online_Services_Data_Roaming-Remote_Vehicle_Status,activated ,3
    ENG123196-ENG123291-Online_Services_Data_Roaming-Remote_Vehicle_Tracking,activated ,3
    ENG123196-ENG123363-Online_Services_Data_Roaming-Roadside_Assistance,activated ,3
    ENG123196-ENG123193-Online_Services_Data_Roaming-Vehicle_Health_Report,activated ,3
    ENG123195-ENG123358-Online_Services_Timeouts-HTTP_Timeout,125 s,9
    ENG123195-ENG123361-Online_Services_Timeouts-Network_Timeout,120 s,9
    ENG123195-ENG123360-Online_Services_Timeouts-PDP_Timeout,120 s,9
    ENG123195-ENG123359-Online_Services_Timeouts-Secure_Connection_Timeout,120 s,9
    ENG123195-ENG123357-Online_Services_Timeouts-Transport_Protocol_Timeout,120 s,9
    ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance,500 m,12
    ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Driving direction,30 °,12
    ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed,30 km/h,12
    ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height,50 m,12
    ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time,60 s,12
    ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce,10 m,12
    ENG153733-Position_Distance,50 m,1
    ENG153734-Post_Test_Registration_Time,120 s,2
    ENG153736-Redial_Time_Call_Initiation,3 s,1
    ENG153737-Redial_Time_Dropped_Call,120 s,2
    ENG153738-Redial_Time_Free_Line,60 s,1
    ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-max.value,65535 m,4
    ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-min.value,0 m,4
    ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-max.value,65535 s,4
    ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-min.value,0 s,4
    ENG123184-Roof_Crash_Detection_Speed_Limit,30 km/h,1
    ENG153739-Scan_Error_Time,30 min,1
    ENG153740-Scan_Velocity_Threshold,10 km/h,1
    ENG153741-Service_Range,300 m,2
    ENG153743-SMS_Call_Delay,3 s,1
    ENG153744-supress_climatisation_settings,not activated ,1
    ENG153745-supress_climatisation_temperature,not activated ,1
    ENG153746-ENG154698-Temperature_Threshold-lower_threshold,-45 °C,3
    ENG153746-ENG99298-Temperature_Threshold-State,not activated ,3
    ENG153746-ENG154802-Temperature_Threshold-upper_threshold,120 °C,3
    ENG153747-Terminate_Ongoing_Manual_eCall,activated ,1
    ENG153748-Test_Mode_Trigger_Time,3000 ms,2
    ENG153749-Trigger_CAN_Speed,30 km/h,1
    ENG123193-Vehicle_Health_Report,5000 km,1
    ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer,30 s,6
    ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts,0 ,6
    ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer,2 s,6
    ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer,20 s,6
    ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer,30 s,6
    Elapsed Time: 00:40
    A5
    ;SW:3Q0-980-654-H   HW:3Q0-980-654-A ---  Frt Sens. Drv. Assist
    ;Component:MQB_B_MFK     H09 0272, Coding:000307060000040100222344C150A90094000E200040
    ;EV_MFKBoschMQBB,001001,EV_MFKBoschMQBB_001_VW36.rod
    ;Sunday,17,March,2019,18:02:51:21782
    ;VCID: BC34BFCF373E31AA41-80E8
    IDE00001-Production mode,Deactivating ,3
    IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR,not activated ,1
    IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane,not activated ,1
    IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state,not activated ,1
    IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal,not activated ,1
    IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane,not activated ,1
    IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved,not activated ,1
    IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR,not activated ,1
    IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA,not activated ,1
    IDE04160-Direct. stab. assist speed threshold during towing mode,300 km/h,2
    IDE04733-Road sign detection fusion mode,Road sign fusion ,1
    IDE07358-Distance to calibration field,1500 mm,2
    IDE09375-IDE05717-Axle offset-Front axle transverse position,-11 mm,4
    IDE09375-IDE05718-Axle offset-Rear axle transverse position,-11 mm,4
    IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge,783 mm,8
    IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge,783 mm,8
    IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge,805 mm,8
    IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge,805 mm,8
    IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate,2460 mm,24
    IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate,742 mm,24
    IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate,1597 mm,24
    IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate,2460 mm,24
    IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate,-742 mm,24
    IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate,1597 mm,24
    IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate,2460 mm,24
    IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate,742 mm,24
    IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate,1003 mm,24
    IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate,2460 mm,24
    IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate,-742 mm,24
    IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate,1003 mm,24
    IDE10407-Personalization of intervention moment at T. 15 on,Last setting ,1
    IDE10870-Switch-on condition: lane depart. warn.,on (setting via menu) ,1
    IDE10872-Warning intensity: lane depart. warning,Medium ,1
    IDE10873-BAP personalization,activated ,1
    IDE10924-MAS02479-Initial calibration: result-Yaw angle,0.085 °,8
    IDE10924-MAS05286-Initial calibration: result-Roll angle,0.301 °,8
    IDE10924-MAS05287-Initial calibration: result-Pitch angle,0.378 °,8
    IDE10924-MAS10678-Initial calibration: result-Camera height,1483 mm,8
    ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR,0 ,3
    ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF,0 ,3
    ENG130776-ENG130838-Adaptation_tsr-Par_country_mode,automatic ,3
    ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode,Enabled ,3
    ENG120319-Mask_error_reactions_for_development,not activated ,1
    ENG107577-Masked_fault_classes-,255 ,4
    ENG130777-standstill_mode,not activated ,1
    ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active,1 ,5
    ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive,20 ,5
    ENG130779-Xcp_interface,not activated ,1
    Elapsed Time: 00:07
    D6
    ;SW:7P5-941-572-AG   HW:7P5-941-572-A ---  Light Ctrl Left 2
    ;Component:LED1L         H07 0008, Coding:
    ;EV_LEDMinMaxL_KEBODAVW481,001003,EV_LEDMinMaxL_KEBODAVW481.rod
    ;Sunday,17,March,2019,18:03:06:21782
    ;VCID: 804C0B3F1B56954A5D-80D4
    IDE00036-Vehicle equipment code,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    IDE00047-Parameter set version,---- ,4
    IDE00048-Parameter set part number,----------- ,11
    Elapsed Time: 00:01
    D7
    ;SW:7P5-941-572-AG   HW:7P5-941-572-A ---  Light Ctrl Right 2
    ;Component:LED1R         H07 0008, Coding:
    ;EV_LEDMinMaxR_KEBODAVW481,001003,EV_LEDMinMaxR_KEBODAVW481.rod
    ;Sunday,17,March,2019,18:03:15:21782
    Elapsed Time: 00:01
    The world is my oyster...
  2. Likes Uwe liked this post
  3. #2
    A5 fault is also missing description:
    1275 - Unknown Error Code
              B182E F0 [008] - Unknown Error Elaboration
    Should be covered in Beta 19.1:
    Front Sensors for Driver Assist: Function Restriction due to Environmental Influences
    Võru, Estonia
    Seems like I've missed this one.
    Downloading now.
  5. Likes Uwe liked this post
