Today I completed my Dynaudio amp setup with Discover Media dab+
I changed the adaptation settings according the above
Address 5F, adaptations:
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ==> change to activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ==> change to "Databus Infotainment"
MAS00950-Audio Parameter,0
ENG117919-Startup_Screen_Sticker_HMI ==> 00 02 for Dynaudio
Also in longcoding Byte 11 coded 03 as mentioned instead of 05
after that I rebooted the DM and was suprised with the noise.
I could not turn on/off the DM, totally no controls. Music very loud.
I had to change Byte 11 back to 05 and reboot of the DM. After that system worked fine again.
Why should I have to change code to 03?
Also I couldn't notice any change in sound quality.
Mileage: 371870km-231069mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 36 42 44 46 47 4F 52 53
5F 62 69 72
VIN: WVWZZZ3CZ8E231165 Mileage: 371870km-231069miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 CN HW: 03L 907 309
Component: R4 2,0L EDC F001AG 6220
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 66565 257 00032
VCID: 73EFF525127D28D2D0-8026
Part No SW: 02E 300 050 D HW: 02E 927 770 AL
Component: GSG DSG AG6 511 1464
Revision: 51112 Serial number: 00000902190468
Shop #: WSC 12345 123 12345
VCID: 132F95A532BD88D270-8046
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 698 109 E HW: 3C0 614 109 AF
Component: J104 C4 440 V3 0017
Revision: --025--- Serial number: 00000104023403
Coding: 0024854
VCID: 2C5D2E598FC3372A51-8078
Part No SW: 35D 907 044 B HW: 35D 907 044 B
Component: Climatronic H03 0303
Revision: 00001K02
Coding: 0600004A02
ROD: EV_ACClimaBHBVW411_VW46.rod
VCID: 2649DC71592F0D7A87-8072
13701424 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 174
Mileage: 371870 km
Date: 2019.04.08
Time: 16:17:28
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Revision: 00H54000 Serial number: 01000008249495
Coding: F5888F3510041A1147000F000F00000080195D436400010C000000000000
VCID: 71E3FF2D68611AC222-8024
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 070308 003 0205
Coding: 00049077
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 150408 046 0204
Coding: 00995365
Shop #: WSC 12345
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 56D 919 475 A HW: 56D 919 475
Component: PARKHILFE 8K H02 0006
Revision: -------- Serial number: 35821333801492
Coding: 118101
ASAM Dataset: EV_EPHVA18VW4110000 001007
ROD: EV_EPHVA18VW4110000.rod
VCID: 336F35259AFD68D210-8066
Address 13: Auto Dist. Reg Labels: 3C0-907-567.clb
Part No SW: 3C0 907 567 M HW: 3AA 907 567
Component: AC201 RDW A 036 0243
Revision: 00036000 Serial number: 00000000507894
Coding: 0010000
VCID: 356B0B3D5C8976E23E-8060
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DP7DDMR3
Coding: 0012341
Shop #: WSC 05311 000 00000
VCID: 3B7F1D057AADA092C8-806E
Subsystem 1 - Serial number: 6333FTS679040708
Subsystem 2 - Serial number: 6343FTS643870708
Subsystem 3 - Serial number: 6353ETS6T8U1TVNP
Subsystem 4 - Serial number: 6363ETS6VSJ1TVNP
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0201822
VCID: 72E1F0216D6721DADB-8026
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Coding: 00000131
Part No SW: 3C8 920 880 T HW: 3C8 920 880 T
Component: KOMBI H04 1008
Coding: 160D000000
VCID: 3D7B131DACB9AEA2F6-8068
Part No SW: 7N0 907 530 BC HW: 1K0 907 951
Component: J533 Gateway H41 1663
Revision: H41 Serial number: 260112F2002064
Coding: 462006
VCID: 72E1F021AD6721DADB-8026
Part No SW: 3AA 959 433 F HW: 3AA 959 433 E
Component: IMMO 042 0429
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 43138 001 1048576
VCID: 3C7D1E197FA3A7AAC1-8068
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 HW: 3C8 959 760
Component: J810 0801
Revision: 00002000 Serial number: 00000000000000
Coding: 0000001
Part No SW: 3C0 959 701 A HW: 3C0 959 793 A
Component: TUER-SG FT 002 0321
Revision: 12101005 Serial number: 0000886354
Coding: 0011F7
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0307
Serial number: 00000000331050
Coding: 0000D0
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
Component: KSG PQ47 ELV 042 0714
Coding: 1891020051034E7F00021C1F7008CFCE707801
Component: Neigungssensor 004 0611
Address 47: Sound System Labels: 3C0-035-456.clb
Part No SW: 3C0 035 456 J HW: 3C0 035 456 J
Component: DSP 10 Kanal
Revision: 00H05001 Serial number: 75815000315901
VCID: 2757D17596251472BC-8072
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1663
Coding: 00000009
VCID: 6FE7F955BE550C3234-803A
Subsystem 1 - Part No SW: 3C8 919 204 A HW: 3C8 919 204 A
Component: Analoguhr 005 0004
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0006086936
Coding: 0011F6
ROD: EV_TSGBPQ35BRFVW46X_VW46.rod
VCID: 36690C31898F7DFA37-8062
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0307
Serial number: 00000000340928
Coding: 0000D0
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000055708
Coding: 0000057
Shop #: WSC 12346 987 64321
VCID: 2855D2499B3B1B0AB5-807C
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: VWZAZ2R8029459
Coding: 027312010000000011111105018808001F0106C4002001008F
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 2143CF6D3001EA42F2-8074
Subsystem 1 - Part No SW: 5NA 919 866 R HW: -----------
Component: ECE AS 19/20 --- 1115
7194 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 174
Mileage: 371870 km
Date: 2019.04.08
Time: 16:17:30
Voltage terminal 30: 13.9 V
BAP-BAP_Function_ID: 02
Part No SW: 1K0 907 383 D HW: 1K0 907 383 B
Component: Anhaenger H16 0070
Revision: 3A002001 Serial number: 00000110888610
Coding: 0100000200000000
Shop #: WSC 05314 000 00000
VCID: 2E59245179DF453A7F-807A
End-------------------------(Elapsed Time: 03:16)--------------------------
