Results 1 to 10 of 18
Thread: Dynaudio menu in Discover Media PQ
    I retrofitted dynaudio kit to my tiguan 2016.
    I activated sound system and I can hear music, but dynaudio settings is missing.
    How I can enable it?
    Adaptation channels here:
    https://drive.google.com/file/d/1GPQ...ew?usp=sharing
    Thank You!
    Dec 2016
    DE
    I am pretty sure this can not be enabled via VCDS, as it requires to upload the Dynaudio dataset.
    Could You explain ? Or what should I do? thank you
    May 2017
    TBAx is correct. In addition to change the 5F coding for external sound system, you also need to upload a dataset, means you need to flash correct parameters to audio system so that it physically enables correct outputs etc.
    Edit: hey hey hey, you have PQ platform car. That should go fine without datasets. Those are for mqb cars usually.
    Make sure your adaptations point to external amp and 5f long coding has sound system and external speakers set.
    Tartu, Estonia
    Discover Media PQ uses parameters
    But does it really have dynaudio menu? I thought just coding/adaption and done...
    The world is my oyster...
    Thank You.
    I found this coding info:
    Address 5F, long coding, byte 11 - change from 01 to 03 (or 05 for original Dynaudio amp)
    Address 5F, adaptations:
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ==> change to activated
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ==> change to "Databus Infotainment"
    MAS00950-Audio Parameter,0
    ENG117919-Startup_Screen_Sticker_HMI ==> 00 02 for Dynaudio
    Bolded
    works, I got volume working and sound quality is much better.
    Dynaudio logo will be on startup screen.
    Coding byte 11 > 05 is not working, only 03 works
    Only the settings the dynaudio menu is missing.
  7. #7
    Dec 2016
    DE
    Good question, but I guess yes Ż\_(ツ)_/Ż
  8. #8
    Tartu, Estonia
    Quote Originally Posted by tos View Post
    Well value 05 needs newer UDS amplifier:
    Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
       Part No SW: 3AA 035 466     HW: 3AA 035 466
       Component: KonzernAmp12K H03 6904
       Revision: --------    Serial number: A1108A00010730
       ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
       ROD: EV_AudioVerst12KanalSTT1.rod
       VCID: 6D84C329AD1DE4BFA9E-8038
    I'm not sure if this is described in label file for now, haven't done PQ MIB-s for a while.
    Yet I ask, are You sure there is menu for Dynaudio in PQ?
  9. #9
    Mar 2015
    Australia
    I remember playing around with this a few years ago.
    I was able to get the Dynaudio menu up on the Discover Media unit, however it didn't have any effect on the amplifier.
    From what I can tell the only support is for regular 3 band equalizer.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist
  10. #10
    That makes me wondering why there is a 8 channel ? 4 channels will be fine if there is no dsp.
    I had to install new wires to trebles...
    Complete scan log:
    https://drive.google.com/open?id=1K2...d0ELHdeRvOWkbk
