Results 11 to 20 of 25
Thread: How to enable Mirrors fold on keyfob lock and unlock (5K)
    Mar 2019
    India
    So i've managed to input the numbers as you have described but there is no action either for 90 or for 99 at all.
    My expectation is after coding this value i go back, exit VCDS, disconnect port side from car, disconnect computer side from USB, switch off engine, open door, exit vehicle, close door and lock using key fob (single click on the lock button on key fob).
    When the vehicle locks, the outboard rear view mirrors are supposed to fold in.
    They do not.
    The outboard rear view mirrors switch is set to the "0" position at all times.
    I also performed both these operations with windows rolled up. Could that be an issue?
    Sept.2013 VW Jetta TDI with DSG (RoW), "das große weiße".
  2. #12
    Dec 2016
    DE
    Keep holding the lock button on the keyfob for like three seconds. It's a comfort operation and is thus locked behind this 3 second delay.
  3. Likes derPoltergeist liked this post
  4. #13
    Mar 2019
    India
    nope. doesnt work. the lock button was pressed and held for 5 seconds. didnt work on 95.
    then the button was also locked once released and then again depressed for 5 seconds. no show.
    EDIT not checked for 99. Want 95 functionality only.
  5. #14
    Dec 2016
    DE
    Can the mirrors fold normally using the mirror selection knob?
    Adaption change is definitely correct?
  6. Likes derPoltergeist liked this post
  7. #15
    Mar 2019
    India
    Thanks for your inputs.
    The adaptations are correct and mirrors do fold and unfold using the switch.
    Is there a setting in MFD convinience that i have to set up using the mirror down function enabled / disabled or mirror movement individual or both?
  8. #16
    Dec 2016
    DE
    Not that I am aware of.
    Does someone else have an idea, what we are missing here?
  9. Likes derPoltergeist, Dana liked this post
  10. #17
    Mar 2019
    India
    Can Uwe / Dana please review this thread and let me know if i am doing some thing wrong here?
    Thanks TBAx for your inputs
  11. Likes Dana liked this post
  12. #18
    Quote Originally Posted by derPoltergeist View Post
    Uwe reads every post on this forum. But he does not claim to have answers to every question.
  13. Likes Dana liked this post
  14. #19
    Mar 2019
    India
    Ah Good to know! Thanks a lot anyway
  15. #20
    United States
    The steps TBAx provided should have worked. I don't have any other solid suggestions.. but I do wonder it it may be necessary to use the MFA, locate the comfort or convenience selection related to factory reset and see if that enables the function. (Mk6 Golfs after 2011 often required something similar before the number of comfort turn signals changed after the adaptation was set in 09)
    If that doesn't exist or help you might want to run another map with that SA code and link it so we can double check to make sure the modification was in the correct Byte.
  16. Likes Uwe, derPoltergeist liked this post
