Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: How to enable Mirrors fold on keyfob lock and unlock (5K)
    Mar 2019
    India
    Good day to you all.
    I would like to enable the following:
    1. Both Mirrors fold on keyfob lock
    2. Both Mirrors unfold on keyfob unlock
    3. Display Volume of diesel to be filled in diesel tank.
    I have enabled automatic window close on rain using RLS and it is working as intended.
    Here is an autoscan of the vehicle that is the base autoscan that i have done. The autoscan was not done after the enabling of automatic windows close on rain using RLS
    Friday,29,March,2019,17:49:12:39184
    VIN: WVWF13162DA550652   License Plate:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWF13162DA550652   Mileage: 61310km-38096miles
    Address 01: Engine (J623-CLCB)       Labels:. 03L-906-018-CFF.clb
       Part No SW: 03L 906 018 GJ    HW: 03L 907 309 R
       Component: R4 2,0L EDC   H25 9970
       Revision: 42H25---    Serial number: 00000000000000
       Coding: 001D0012042500080000
       Shop #: WSC 41103 938 00000
       ASAM Dataset: EV_ECM20TDI01103L906018GJ 003005
       ROD: EV_ECM20TDI01103L906018GJ.rod
       VCID: 78A9E9A6D25ADAC7A6D-802C
    4629 - ECM Power Relay Load Circuit
              P068A 00 [032] - Opens Too Early
       Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
       Component: GSG DSG AG6     512 3526
       Revision: 05651213    Serial number: 00001303080820
       Shop #: WSC 00047 000 00000
       VCID: 2411EDD632D26E27DA5-8070
       Revision: 00H31001
       Coding: A63B40F8092700FA651102E9901B0082211000
       VCID: 7DA7F8B2FDF8FFEFF5B-8028
       Part No SW: 7N0 907 426 BG    HW: 7N0 907 426 BG
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       Shop #: WSC 00047 000 00091
       VCID: 7AADF3AEEC56C8D7D09-802E
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0068
       Revision: BC021001
       Coding: 06000A3A983F00C040880080140081640771008850A081605C8000000040
       Shop #: WSC 12345 123 61029
       VCID: 3E253FBEB07E24F7AC1-806A
       Component: RLS 270213 05  54  0403
       Coding: 03300A
    Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
       Part No SW: 5C6 919 475     HW: 7E0 919 475 A
       Component: PARKHILFE 8K  H10 0005
       Revision: --------    Serial number: 07381302301190
       Coding: 108101
       ASAM Dataset: EV_EPHVA18VW3610000 001003
       ROD: EV_EPHVA18VW3610000.rod
       VCID: 71BFD482B1208B8F613-8024
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Serial number: 003G6M087RCF
       Coding: 00003241
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 323D1B8E74A6F097589-8066
       Serial number: 3572MSME442F6475ZZZ/
       Serial number: 3582MSME1B2B1674ZZZ.
       Serial number: 3516KSME10443423ZZZA
       Serial number: 3526KSME11443323ZZZB
       Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
       Revision: FF010041    Serial number: 20130312301263
       Coding: 0892140000
       Shop #: WSC 00047 000 00051
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 76B5E79ED84EACB7B41-8022
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0036
       Coding: 830000
       Part No SW: 5C6 920 872 A    HW: 5C6 920 872 A
       Component: KOMBI         H07 0705
       Coding: 171B00
       VCID: 2B0306EA538CA15F1BF-807E
       Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
       Component: J533  Gateway H52 1634
       Revision:   H52       Serial number: 030313F2000264
       Coding: 351003
       VCID: 74B1DD96CEB2BEA78A5-8020
       Component: IMMO          H07 0705
       VCID: 6A8DC3EE9CF67857209-803E
       Component: SG EXT.PLAYER H19 0550
       Revision: A1001003    Serial number: 7664196727
       Coding: 010100
       VCID: 2A0D03EE5CF6B857E09-807E
       Part No SW: 561 959 701 A    HW: 3C0 959 793 C
       Revision: 12110009    Serial number: 0006164002
       Coding: 0012B7
       Shop #: WSC 01383 790 50316
       VCID: 1C61D536062256E7625-8048
       Slave Driver:
       Component: J389__TSG-HR  008 1508
       Serial number: 00000007624393
       Coding: 000290
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       VCID: 372B2A9A934415BF6F7-8062
       Part No SW: 561 959 702 A    HW: 3C0 959 792 C
       Revision: 14110009    Serial number: 0006346595
       Coding: 0013B6
       VCID: 1D67D8321D385FEF95B-8048
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1508
       Serial number: 00000007601645
       Coding: 000290
       Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
       Component: Radio RCD510  005 0236
       Revision: 00000001    Serial number: VWZ1Z3N1973639
       Coding: 01000400040006
       VCID: 2411EDD63ED26E27DA5-8070
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Revision: 1B001001    Serial number: 00007663656741
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 392F2CA2A9D003CF993-806C
    End----------(Elapsed Time: 01:08, VBatt start/end: 13.9V/13.9V)-----------
    Thank you in advance.
    EDIT: Added one more list item.
    Last edited by derPoltergeist; 03-30-2019 at 08:44 AM. Reason: adding more information
    Sept.2013 VW Jetta TDI with DSG (RoW), "das große weiße".
    Jun 2017
    Send this german article through Google Translator:
    https://www.motor-talk.de/blogs/tbax...-t5465081.html
    You have GEN4 so adaptation channel is available...
  3. Likes derPoltergeist, Uwe, Dana liked this post
    Mar 2019
    India
    Thank youhadez16 i shall try this tomorrow
    Mar 2019
    India
    I tried to understand the google translation of the page but i am unable to know how to get to the described numbers @hadez16 also, is it only for driver side mirror? it appears so. i would like this for both the outboard rear view mirrors.
    Dec 2016
    DE
    No, no, the driver side mirror is the master of this function and thus only it needs to be adapted.
    Can you post an AdpMap from your module 42, so I can point you to the necessary change?
  7. Likes derPoltergeist, Dana, Uwe liked this post
    Mar 2019
    India
    Thanks so much TBAx how do i get an AdMap of my module 42? Sorry this is all new to me and so i'm at sea.
    Dec 2016
    DE
    It's documented here:
    http://www.ross-tech.com/vcds/tour/c...annels-map.php
    Use module: 42; login: 04354; function: adaptions; output: CSV file
  10. Likes derPoltergeist, Uwe, Dana liked this post
  11. #8
    Mar 2019
    India
    thanks here is the file in csv format thanks so much
    EDIT: sorry for the unformatted text i wrote it in the vehicle while i was connected to the computer and Ross tech application.
    This file was created with the engine running, doors unlocked, a/c on
    Here is the link to the blockmap
  12. Likes Dana liked this post
  13. #9
    Dec 2016
    DE
    There is this channel in your adpmap "ENG109279-System_Parameter_0", which has this value "7F BE 4F 34 00 04 C3 11 90 F2 07 E4 84 62 00 28".
    The bold part is interesting. Change the value to either
    7F BE 4F 34 00 04 C3 11 95 F2 07 E4 84 62 00 28 > to allow folding on keyfob with unfolding on ignition on
    7F BE 4F 34 00 04 C3 11 99 F2 07 E4 84 62 00 28 > to allow folding on keyfob with unfolding on driver door open
    Don't forget to login with the aforementioned 04354 prior to changing the value or else you will get an error (security access required).
  14. Likes derPoltergeist, Uwe liked this post
  15. #10
    Mar 2019
    India
    Thanks TBAx will do this in an hour.
    Just to be clear for me, how do i make this change using the VCDS software? do i need to edit a particular Byte number in 42 module (of which the corresponding bit is highlighted by you) or do i have to change the number in the text editor and then push that file up into the vehicle using VCDS?
    If the latter is correct, i'd need a bit of hand holding for this so if you have a pointer to a video or detailed textual instructions i'd appreciate it thank you!
