AutoScan - 2019 VW GTI Rabbit Edition
Satyrnine
C?ID=365072
I'm new to VCDS. First Post. Here's the Autoscan I took. I noticed I can't code the "starting vibration reduction" in the ABS Module. Seems that's new to 2018 and 2019 GTI's per some other posts. Anyway, here's the Autoscan:
Note: I blew a horn fuse first 100 miles of buying the car. I see that listed. New fuse, no problems since. I also see some error messages for the lights, but they work great, maybe due to a new module for them? They are LED with the Rabbit Ed. Also a center electronics error. Not sure on that one. Any messages related to 02 sensor are due to my downpipe. Not tuned quite yet, so get CEL's now and then.
Tuesday,26,March,2019,20:37:44:47863
VIN: 3VW5T7AU5KM004727   License Plate:
Mileage: 3036km-1886mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 13 15 17 19 29 2B 32 39 3C 42 44 4B 52 5F A9
          BB BC D6 D7
VIN: 3VW5T7AU5KM004727   Mileage: 3036km-1886miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
BB-Door Rear Drv -- Status: Not registered 0001
Address 01: Engine (J623-DKFA)       Labels: None
   Part No SW: 5G0 906 259 Q    HW: 06K 907 425 J
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00012
   ASAM Dataset: EV_ECM20TFS0205G0906259Q 001003
   ROD: EV_ECM20TFS0205G0906259Q_VW37.rod
   VCID: 3C2135B176E00897825-8068
Readiness: 0010 0101
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 DC    HW: 5Q0 614 517 AB
   Component: ESC           H25 0324
   Revision: 00000000    Serial number: 62208000002014
   Coding: 01FA6BA154200970407E020260CA6880D62A90024006163610435051C089430B00000012121212B835351919323200
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 037009
   ROD: EV_Brake1UDSContiMK100ESP_037_VW37.rod
   VCID: 75B7E095154A99DFBDB-8020
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0489419091
   Coding: 132C0C0623
   VCID: 43D34E4D0B1E776FC3F-8016
   Part No SW: 5GM 907 426 G    HW: 5GM 907 426 G
   Component: AC Manuell    H03 2001
   Revision: 00001K05
   Coding: 00020004200110000000000000000006
   ASAM Dataset: EV_ACManueBHBVW37X 004134
   ROD: EV_ACManueBHBVW37X_004_VW37.rod
   VCID: 4CC165712640B817325-8018
   Part No SW: 5Q0 937 087 BA    HW: 5Q0 937 087 BA
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: C86416091801UE
   Shop #: WSC 00066 790 00245
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7BA3F6AD336ECFAFCBF-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    180708  043 0551
   Serial number: 97022066180810133319
   Subsystem 2 - Part No SW: 5Q0 955 559 B    HW: 5Q0 955 559 B  Labels: 5Q0-955-547.CLB
   Component: RLS  050 0105
   Serial number: SBY18M08D08H17M53S12
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0300221020180C201065
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 113
                    Mileage: 2023 km
                    Date: 2019.02.27
                    Time: 11:54:38
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 2D00008101FFC728949C810500401600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14D510E107057FA5-8010
   Serial number: 003GCR0AANL-
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5A5D3F265B4F1F7-8012
   Occupant Detection:
   Serial number: IBH00000000000AEK3FM
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 002 907 18
   Serial number: 35700000000C486CA23T
   Subsystem 3 - Part No SW: -----------    HW: 480 002 907 18
   Serial number: 3580000000041D19733E
   Subsystem 4 - Part No SW: -----------    HW: 480 400 507 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001C529E737534C7
   Subsystem 5 - Part No SW: -----------    HW: 480 401 007 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001122B6D2E1865$
   Subsystem 6 - Part No SW: -----------    HW: 480 400 509 18
   Component: FrontSensor_D  004 6149
   Serial number: 3550001122B7DBD343A8
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 509 18
   Component: FrontSensor_P  003 6149
   Serial number: 35600019B2A7AD22948G
   Part No SW: 5G1 920 856 D    HW: 5G1 920 856 D
   Component: KOMBI         351 2500
   Coding: 0BAD0912A988CF0502882A095000000000000000
   Shop #: WSC 00066 790 00072
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   VCID: 2F3B12FDB796E30F377-807A
16777020 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_TEL_0x28 keine Kommunikation]
                    Fault Frequency: 56
                    Reset counter: 147
                    Mileage: 284 km
                    Date: 2019.01.25
                    Time: 18:39:32
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 16091800840155
   Coding: 0101000830085900FB00002B080F00000001070000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D2738B56DFA019FB5B-8068
   Component: 1-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AD    HW: 5G0 959 442 AD  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002187940018385
   Coding: 28FFFF
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0033 - Supply voltage
          [Supply voltage - lower limit exceeded]
                    Reset counter: 146
                    Mileage: 2423 km
                    Date: 2019.03.11
                    Time: 16:25:20
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000268396003
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1485A1A2F5FF213-8064
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 P    HW: 0CQ 907 554 P
   Component: Quersperre    H52 8043
   Serial number: HA1-00019.06.18
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   VCID: 52FD7B09C464EEE7789-8006
                    Reset counter: 146
                    Mileage: 2423 km
                    Date: 2019.03.11
                    Time: 16:25:20
   Component: HRE_Master    H12 0081
   Serial number: 0493767434
   Coding: 01011103
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0493740703
   Coding: 010111
   Part No SW: 5Q4 959 593 M    HW: 5Q4 959 593 F
   Component: TSG FS        006 0247
   Serial number: 42038829300502
   Coding: 003E13200000040000000000
   VCID: 4FFB727DD756830F577-801A
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000000986357
   Coding: 011000
   Part No SW: 5QN 909 144 A    HW: 5QN 909 144 A
   Component: EPS_MQB_ZFLS  507 5081
   Coding: 810A0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 50F97101CA689CF74ED-8004
   Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
   Component: FCM MQB Low   002 0342
   Serial number: 26091800840649
   Coding: 000000050900210A01110F00030000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3537209555CAD9DF7DB-8060
   Part No SW: 5Q4 959 592 M    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0247
   Serial number: 46038828801002
   VCID: 4EC56F79D05C8A075C1-801A
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000000986685
   Coding: 091000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 5G6 035 868     HW: 5G6 035 868
   Component: MU-E--ER      695 8742
   Serial number: 13081800010727
   Coding: 02730000BE00000041220001001000009F0003D40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001041
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 70B9D1816A28BCF76ED-8024
   Part No SW: 5G0 907 159 G    HW: 4H0 907 159 A
   Serial number: 180627204398
   VCID: 323D1B89A4A4CEE7589-8066
Address BB: Door Rear Drv
Address BC: Door Rear Pass
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392F2CA579D23DBF993-806C
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 01:32, VBatt start/end: 12.4V/12.4V)-----------
If it were my car, I would clear all those faults, drive it some, and see what comes back.
The fault on 09-Cent.Elect may well be left over from your blown horn fuse.
Not sure about the low voltage codes from the lights. Is it possible your battery had a poor State-of-Charge that day?
Satyrnine
C?ID=365072
Ah, I did disconnect the battery for some time while installing a JB4. Could have possibly been around then. I'll clear them and see what comes back. Thanks! Excited to go deeper and make some adjustments/tweaks.
Satyrnine
C?ID=365072
Pardon my ignorance, how do I clear those faults? I found how to clear actual CEL faults, but not sure on these... Is there a FAQ or basics thread I should be reading? My apologies if so!
There is a [Clear All Fault Codes] button on the Auto-Scan screen.
Alternatively, you can access each control module that has a fault code individually, and click:
[Fault Codes]
[Clear Codes]
It's possible the VCDS product manual may be useful to you as well:
http://www.ross-tech.com/vcds/tour/main_screen.php
hadez16
C?ID=289891
A good example that unit 16 completely vanished for MY19 MQB Cars, except for having a steering wheel heater...
