Audi A6 C7 SIDE ASSIST retrofit, problem
   #41
XPepino
Czech Republic
C?ID=91614
So, we used new (Offline) ELSA WIN 6.0 and check wirring and now we know, that for facelift ELSA is ok.
Now this side assist is working !!!
There was some problem with swap left and right mirror LED, but it was because there was not described for what side it is.
I used Vag Can Pro for dataset, and VCDS for coding and adaptations. Should be nice to make for all what to do list, but not time now :-/
   #42
d@ni3l
Romania
Why you need to use vcp? Modules were new? After reparametrization, recalibration is not needed?
   #43
XPepino
Czech Republic
C?ID=91614
No modules was from test cars. But not sure if A6 or A7, so i upload there dataset for A6
   #44
XPepino
Czech Republic
C?ID=91614
Calibration i did not made, and i am not sure, but there probably was not component protection ...
   #45
andyhud
C?ID=32695
SWA3.0 modules have CP. If these don't then they're SWA2.0 max.
Correct v3.0 have CP. v2.0 don't
I have fitted SWA to many MLBEvo cars and calibration is only needed if the modules are:
1. New
2. Left and right modules were not from same (old) car if the modules are second hand.
3. You flash the firmwares manually of the radar modules and not via SVM.
Even after you remove CP from them (you have to remove CP from both Master and Slave indivudally) if the modules came "as a pair" from another car, you do not need calibration (assuming they came from the same shape car!)
Otherwise you can calibrate at dealer or use VCP if they have a calibration set available.
   #46
downtime
C?ID=280813
Or build your own device and diy calibration like I did :)
   #48
downtime
C?ID=280813
I’ll post a picture here. Actually I think I’ve already did to one thread but I’ll do another here :)
Metallic table fan :)
   #49
downtime
C?ID=280813
Ok here goes, instead sharing pictures, here's a link to a Google shared album where you'll find some pictures from the setup :D
https://photos.app.goo.gl/Zeui64SwuteC7Sgy5
This setup works perfectly at least for SWA3.0 radars calibration. SWA3.0 calibrates as long as you will have enough reflection to calibrate to correct angle. Power will not be at the required level but for that the dynamic calibration does it's magic.
SWA2.0 requires both angle and reflected power in static calibration. Official calibration device has cylindrical fan inside the plastic box. Same fans are used in fridges. You can get those for less than £20 from eBay. So if you want to build your own professional device, that's not very expensive either :D
   #50
XPepino
Czech Republic
C?ID=91614
Hello guys
I made my second retrofit of Side Assist to A6 2015 FL and now i have the same problem like d@ni3l
Also i am note able to change coding of slave to 040311 - it write me Coding rejected - Error 31: Request out of range
I tried security code 20103, dit not help. I tried upload dataset via VCP to module 4G0907566M (but there is not dataset for 4G0907568M). Did not help.
There are different firmware in each radar, i tried flash 4G0907566M with firmware version 70 also with 60 via VCP (Vag Can Pro) but it make error Programming preconditions not fullfiled: General reject 129
There are errors and button side assist make error - Side Assist not available.
What do you think ?
Thursday,13,August,2020,11:26:33:12448
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ4G8FN09xxxx   License Plate:
Mileage: 137178km-85238mi   Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 28 3B 3C 42 44 46 52 53 5F 62
          6C 6D 72 8F 90 AC
17-Instruments -- Status: Cannot be reached 0100
Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 FQ    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 0655
   Revision: 85H23---
   Coding: 12254012232401080000
   ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
   ROD: EV_ECM20TDI01104L906021FQ_002.rod
   VCID: 79BA196AF8E9F24E54-802C
   Part No SW: 4G0 927 153 L    HW: 0CK 927 156 Q
   Component: 0CK 20TDI RdW H01 0008
   Revision: --H01---    Serial number: 0000000177
   Coding: 100001
   ASAM Dataset: EV_TCMDL382021 002024
   ROD: EV_TCMDL382021_VW51.rod
   VCID: 3228EE46651FC116D5-8066
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 H
   Component: V553 MTFP  HC4 0421
   Serial number: S2AG75.109_02 11
   Coding: 06A29E41604579829B00
   ROD: EV_ESP9BOSCHAU57X.rod
   VCID: 41CAB18AD0B96A8E5C-8014
   Part No SW: 4H0 907 064 FN    HW: 4H0 907 064 EN
   Component: BCM2 2.0      H36 0560
   Coding: 0189700E000000000000
   VCID: 7AB80666F5EFF9565D-802E
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Component: KLIMA 4 ZONEN H14 0112
   Serial number: 11051500040383
   Coding: 34020978210000
   VCID: 63865B026A65189E6E-8036
   Part No SW: 4H0 907 063 DH    HW: 4H0 907 063 AH
   Revision: 15020001    Serial number: 00001067128801
   Coding: 2600001401349FE08181408300001D0CCF9CC60826090201000008206101140200400034030000
   VCID: 71AA214AA899BA0EEC-8024
   Component: WWS57X 150416  H37 0080
   Serial number:         150427132246
   Coding: 0045F7
   Serial number: 23949561
   Coding: 02006D
   Component: E1 - LDS  H07 0044
   Serial number: 04 05 2015  00000658
   Serial number: 58B846A7000000000001
01800 - Light Switch (E1)
                    Reset counter: 244
                    Mileage: 137178 km
                    Date: 2020.08.13
                    Time: 07:09:29
03280 - Switch Position of Light-Switch Knob
                    Reset counter: 244
                    Mileage: 137178 km
                    Date: 2020.08.13
                    Time: 07:09:38
   Part No SW: 4H0 959 655 H    HW: 4H0 959 655 H
   Component: Airbag10.43   H82 0086
   Revision: --------    Serial number: 003P1004M9T7
   Coding: 30333130313630323633554A304C34473053
   VCID: 3B36C362B255005E06-806E
   Serial number: 3575HRB406736RT43GFN
   Serial number: 3585HRB405T36CAOAGQ6
   Serial number: 3515JRB400A54R1ELHAC
   Serial number: 3525JRB405L36OUMMOM/
   Serial number: 3554VRB401654R1CLI7K
   Serial number: 3564VRB401254R1CF9JE
   Revision: C0068538    Serial number: 90862OE2001BI
   Coding: 000015
   VCID: 3B36C362BA55005E06-806E
   Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
   Component: E221 - MFL  H09 0010
   Serial number: 18 04 2015  B0054266
   Part No SW: 4G8 920 933 Q    HW: 4G8 920 933 Q
   Component: TDieRdw       H08 0043
   Revision: 04001037    Serial number: 658060515596017
   Coding: 03A712000B410008080000
   ASAM Dataset: EV_RBD4K 004048
   ROD: EV_RBD4K_AU57.rod
   VCID: 3E30CA76A147157621-806A
   Part No SW: 4G8 907 468 F    HW: 4G8 907 468
   Component: J533--Gateway H14 0083
   Revision: --------    Serial number: 00000001839669
   Coding: C0CD074418
   ASAM Dataset: EV_GatewPkoUDS 001028
   Serial number: 5988226403
   Voltage stabilizer:
   Serial number: 150127000000000006B5
   Part No SW: 4G0 919 158 Q    HW: 4G0 919 158 Q
   Component: KLIMA FOND    H08 0112
   Serial number: 07051500041931
   Coding: 20
   VCID: 3D32CD7AAC410E6E38-8068
   Component: SARA 3D       H04 0056
   Revision: --------    Serial number: EJ1BPA720EP4FI
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3326EB429A05C81EDE-8066
   Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
   Component: SWA Master    H08 0060
   Serial number: 0388799085
   Coding: 040311
   VCID: 393AD96AB869324E14-806C
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
   Component: SWA Slave  H08 0070
   Serial number: 0422623730
   Coding: 040321
729358 - Internal Control Module Memory Check Sum Error
          B2000 00 [009] - -
          [Control unit 1 for side assist - defect]
                    Mileage: 43925 km
                    Date: 2019.01.09
                    Time: 15:07:28
4187662 - Internal Control Module Memory Check Sum Error
          B2000 00 [009] - -
                    Mileage: 43998 km
                    Date: 2019.01.15
                    Time: 06:51:04
   Coding: 011F16011C00628002080013
   VCID: 47DEAF92F69D54BE92-8012
   Part No SW: 4G0 909 144 S    HW: 4G0 909 144 G
   Component: RCEPS         H43 0012
   Revision: 00001000    Serial number: 0022742070
   Coding: 101000010001
   ASAM Dataset: EV_RCEPS 009013
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0367638403
   Coding: 013A1620A0B930008320090008010F470000000000000000000000000000
00984 - Left Tail Light (M4)
            012 - Electrical Fault in Circuit - MIL ON
                    Fault Status: 11101100
                    Reset counter: 204
                    Mileage: 137178 km
                    Date: 2020.08.13
                    Time: 07:21:44
00985 - Right Tail Light (M2)
                    Reset counter: 204
                    Mileage: 137178 km
                    Date: 2020.08.13
                    Time: 07:21:44
   Coding: 011F16014E00628002080002
   VCID: 46C0A296F1974DB669-8012
   Revision: --------    Serial number: 00000001457464
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2D12FD3A7C219EEE88-8078
Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
   Part No SW: 4G1 035 044 M    HW: 4G1 035 044
   Component: MU-H-LN-EU    041 1425
   Serial number: A589E0F7525659
   Coding: 017502010000000013110002000A00332F0006E5F1700100FF
   VCID: 291A092A48C982CE64-807C
   Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
   Component: ECE 2020  --- 0184
   Subsystem 2 - Part No SW: 4G1 919 605 A    HW: 4G1 919 605 A
   Serial number: AUZ8Z9FY8010DY
   Multimedia Operating Unit:
   Serial number: 90349OE500082
   Component: Gracenote2  --- 1012
   Coding: 010F14004000628002080002
   VCID: 49DAA9AAE089A2CE84-801C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-907-441.clb
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 027502010201000300
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 118500907
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
   VCID: 3620D2568977DD36F9-8062
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 312AE14A6019FA0EAC-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
   Part No SW: 4H0 907 355 D    HW: 4G0 907 355 B
   Component: SCR-Stg-G2    H10 0012
   Revision: 00000000    Serial number: 151050982
   ROD: EV_RDCMA00100.rod
End----(Elapsed Time: 01:53, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
   #51
d@ni3l
Romania
“ Internal Control Module Memory Check Sum Error“ - solved after i replace left&right modules with new one.
   #52
XPepino
Czech Republic
C?ID=91614
Hmm This is not good. Did you tried visit Audi?
