Results 1 to 10 of 14
Thread: 2019 vw polo powersteering crash data stored
    Mar 2019
    South Africa
    hi there all members. i used to have original vcds interface before it got lost, so i went for aftermarket one. but decided to get the new hex v2 interface. i have the following problem with power steering unit. i used several different log in access codes which is excepted by controller. after that i try and reset to factory settings. it shows RUNNING. and after about 6 seconds it shows STOP RUNNING. it needs to run at least for a few seconds to work successfully. vehicle has been in a left front smash. airbags did deploy. many thanks for assistance. keep well.
    Thursday,28,March,2019,15:39:07:62451
    VCDS Version: 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: AAVZZZAWZJU070769   License Plate:
    Chassis Type: AW-VW27 (2Q0)
    Scan: 01 03 08 09 15 17 19 44 5F
    VIN: AAVZZZAWZJU070769   Mileage: 7905km-4911miles
    Address 01: Engine (J623-CHZL)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 BD    HW: 04C 907 309 AT
       Component: R3 1.0l TFS   H21 5150
       Revision: WXH21---
       Coding: 01110012230411080000
       Shop #: WSC 31414 790 00200
       ASAM Dataset: EV_ECM10TFS01104C906026BD 002003
       ROD: EV_ECM10TFS01104C906026BF.rod
       VCID: 649058E3BED480171A5-8030
       CAN Converter 01:
              U0428 00 [039] - -
                        Mileage: 7905 km
                        Date: 2019.03.28
                        Time: 15:07:34
                        Coolant temperature: 86 C
                        Intake air temperature: 49 C
                        Voltage terminal 30: 12.321 V
                        Outside air temperature: 27 C
                        Absolute intake pressure: 100 kPa abs
                        Engine torque: 0.0 Nm
                        Fuel: tank fill level: 9.0 l
                        Oxygen sensor bank 1 sensor 1: specified value: 1.0000
    Readiness: 1110 0001
       Part No SW: 2Q0 614 517 AB    HW: 2Q0 614 517 L
       Component: ESC_base      H13 0223
       Serial number: 08502397180624
       Coding: 09034B64154890ADD203A81C24E342A649124D26224A242444541254452442659248B26444522424222A482AA23196421D8C6942B8
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004032
       ROD: EV_Brake1BOSCHESPMQBA0_VW27.rod
       VCID: 6E843ACB60183A477C1-803A
    1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
              U0428 00 [137] - -
              [Scl_LWI_Lenkradwinkel_Error]
                        Reset counter: 207
                        Mileage: 7905 km
                        Date: 2019.03.28
                        Time: 15:07:32
    Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
       Part No SW: 2G2 820 045 D    HW: 2G2 820 045 D
       Component: SG_AC_Manuell H50 0301
       Coding: 012100000800000001000400020000000000000000000000000000000000
       ASAM Dataset: EV_ACManuePrehMQBA0 001011
       ROD: EV_ACManuePrehMQBA0.rod
       VCID: 221C1EFBE440CE27A89-8076
       Part No SW: 2Q0 937 089     HW: 2Q0 937 089
       Component: BCM A0 Std    H98 0916
       Serial number: 08001818400493
       ASAM Dataset: EV_BCMA0 204001
       ROD: EV_BCMA0_204.rod
       VCID: 77AA1FAF1F427B8FAF7-8022
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 2Q2 959 881 C    HW: 2Q2 959 881 C
       Component: FHSG_DRV  001 0002
       Serial number: 00000000000021729029
       Coding: 1F0000
       Subsystem 2 - Part No SW: 2Q2 959 882     HW: 2Q2 959 882
       Component: FHSG_PSG  001 0001
       Serial number: 00000000000021430448
       Coding: 050000
       Serial number: 000000000ZY181343L7G
       Serial number: 00000000000099527694
       Part No SW: 2Q0 959 655 AG    HW: 2Q0 959 655 AG
       Component: VW22Airbag    010 0248
       Revision: --------
       Coding: 88CCC000000000005C0000CF008800000065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001010
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 025C7E7B44802E27889-8056
       Subsystem 1 - Part No SW: -----------    HW: 442 061 606 18
       Serial number: 3577Y22C3272ABA4E1BI
       Subsystem 2 - Part No SW: -----------    HW: 442 061 606 18
       Serial number: 3587Y22B32771D0511C
       Subsystem 3 - Part No SW: -----------    HW: 442 0B2 505 18
       Serial number: 35177839F29B22A2C28W
       Subsystem 4 - Part No SW: -----------    HW: 442 0B2 505 18
       Serial number: 35277839F29B22A3922P
       Subsystem 5 - Part No SW: -----------    HW: 442 131 109 18
       Component: FrontSensor_D  290 118A
       Serial number: 355AG11A92A3CAD512E3
    1050117 - Databus
              [NWD: 0x086 LWI_01 error value LWI_Lenkradwinkel]
                        Reset counter: 207
                        Mileage: 7905 km
                        Date: 2019.03.28
                        Time: 15:08:19
       Part No SW: 2G0 920 730 A    HW: 2G0 920 730 A
       Component: KOMBI         209 0461
       Coding: 24A0010021000008010800000000000000000000
       ASAM Dataset: EV_DashBoardVDDMQBA0 001023
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 1F1A170FD732E3CF877-804A
       Part No SW: 2Q0 909 901     HW: 2Q0 937 089
       Component: GW MQB A0     H98 0916
       Coding: 030000046F085600F8000048080E00010001070000000000000000000000
       ASAM Dataset: EV_GatewA0 013020
       ROD: EV_GatewA0.rod
       VCID: 6FBA27CF6712334F777-803A
       Subsystem 2 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
       Component: J367-BDMBOSCH  H02 2011
       Serial number: 1007BAB9
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q2 909 144 J    HW: 2Q2 909 144 F
       Component: TRW_G4L_MQBA0 620 6030
       Serial number: 0571200CB4J1603
       Coding: 00000000000000000101020101000101000001
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 009014
       ROD: EV_SteerAssisTRWG4LMQBA0_009.rod
       VCID: 3A2CC69B6CD0A6E7909-806E
    15788544 - Crash Shut-Down Activated
              P1609 00 [137] - -
              [DEM_FRONT_CRASH_FAULT]
                        Mileage: 7905 km
                        Date: 2019.03.28
                        Time: 15:35:28
                        Engine speed: 0 /min
                        Terminal 15 status: On
                        Voltage terminal 30: 12.35 V
                        Power steering current consumption: 0.5 A
                        max.value: 0.5 A
                        End stage temperature: 215 C
                        Steering assistance: engine output: 100 %
                        Engine angle: 65535
                        Electric motor speed: 45535 /min
                        Steering assistance: target engine torque: 0.0 Nm
                        Steering torque: 0.0 Nm
       Part No SW: 17A 035 869     HW: 17A 035 869
       Component: MU-E--ER      690 8740
       Serial number: 07061800011365
       Coding: 027200003C00000041110001000110001F0000C60000010001
       ASAM Dataset: EV_MUEnt4CGen2LGE 001041
       ROD: EV_MUEnt4CGen2LGE_VW27.rod
       VCID: 68884CD342FCE47736D-803C
    End----------(Elapsed Time: 01:14, VBatt start/end: 12.4V/12.3V)-----------
    Got Frikki Verfied. Moving to Car Repair Support.
  3. Likes Frikki liked this post
    Mar 2019
    South Africa
    Thanks. Any idea why I have this problem UWE. Many thanks.
    Quote Originally Posted by Frikki View Post
    Why? Because the car was crashed.
    But no, I do not have any specific advice or procedure for this newer TRW_G4L_MQBA0 steering rack, and it sounds like you've already tried the stuff documented for the previous generation EPS_TRW_ALow?
    Mar 2019
    South Africa
    Yes I have. And I have always succeeded with previous generation Polo. The new polo with chassis aw is a headache☺ thanks
    Mar 2019
    South Africa
    any idea why would RUNNING be interrupted in basic settings? could it be that the power steering unit is not happy with something, that's why it stops running. thanks.
    Jun 2019
    Birmingham, UK
    Hi frikki, did you find a solution for the new rack?
  9. #8
    Mar 2019
    South Africa
    Quote Originally Posted by Shuhel View Post
    Customer said some other mechanics did something to vehicle for powersteering to work. Cant tell me what exactly. But it did work. Problem still is to get g85 calibrated. I'm still waiting for customer to bring car back to me. To try calibrate g85 sensor. Thanks
  10. #9
    Jun 2019
    Birmingham, UK
    there is a guys up in manchester claiming he can do this with his vcds for 100 but wont give away the procedure, i offered him payment over the phone but didnt want to tell me :/
    seems like this new rack only a few people worked it out how to do it.
    i cant wait!!
  11. Likes Dana liked this post
  12. #10
    Jun 2020
    Belfast, UK
    Hi. I have same problem in 2016 Fabia cant calibrate G85. Was hoping you got a solution😬
    Many thanks
