Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Thread: Audi A4 DPF issue
    Mar 2019
    France
    Audi A4 DPF issue
    My friend has an A4 B7 3.0 TDI BKN.
    He was having issues with his dpf being clogged and was getting limp mode and the code P242F. He took his car to a local garage to who dismounted the dpf and sent it to get a chemical cleaning procedure. They then remounted it on the car and started the engine. However the error code is still there.
    The differential pressure across the dpf is now low and the calculated soot mass is low (4g ish), but the actual soot mass is still showing as very high (76g or so).
    The garage said that they don't have the software to tell the car that the dpf has been cleaned, and there is nothing more they can do. The owner of the car has ordered a VCDS cable which is due to arrive tomorrow. I understand that I need to provide a serial number or something to get my account here verified, I will do that as soon as I have the code.
    He's not computer literate so I will be using the cable and sorting it out.
    In order to initiate the adaptation procedure I think that I have to go into security access and put in a code. Will that code be supplied by the software/cable, or do I have to look elsewhere?
    I'm trying to get a drop on things so I can get going as soon as the cable arrives. Does the software come with the cable, or do I download it from your website?
    Any help would be much appreciated! Thanks!
    You can download the software from this page.
    Once you get running, the first thing to do is post an Auto-Scan.
    Jun 2014
    Swansea, UK
    Ooops - typo in that first URL:
    It should be http://www.ross-tech.com/vcds/download/current.php
    Apparently I should put something witty or profound in here...
  4. Likes Uwe liked this post
    Quote Originally Posted by Mike@Gendan View Post
    Fixed. Somehow that got a spurious carriage return in it.
  6. Likes Mike@Gendan liked this post
    Mar 2019
    France
    Right, made some progress. Got the cable, installed the software, and scanned the car. Results below.
    Friday,29,March,2019,18:15:19:44102
    VIN: WAUZZZ8E66A012073   License Plate:
              67 69 75 76 77
    VIN: WAUZZZ8E66A012073   Mileage: 251440km-156237miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 8E0 910 401 E    HW: 8E0 907 401 AJ
       Component: 3.0L V6TDI  G001AG  0010
       Revision: --H01---    Serial number:
       Coding: 0011171
       Shop #: WSC 80093 222 69422
       VCID: 211FE4A98DC32E6FB13-8074
    004120 - Intake Manifold Runner (Bank 2)
                   P1018 - 001 - Lower limit not reached - Intermittent
                        Fault Status: 00100001
                        Fault Frequency: 11
                        Mileage: 251441 km
                        Torque: 167.7 Nm
                        Voltage: 12.39 V
                        Duty Cycle: 20.5 %
                        Duty Cycle: 88.8 %
                        Duty Cycle: 20.5 %
    009263 - Diesel Particulate Filter (Bank 1)
                   P242F - 001 - Restricted/Clogged - Intermittent
                        Mileage: 251441 km
                        RPM: 756 /min
                        Torque: 66.3 Nm
    001026 - EGR System
                   P0402 - 001 - Excessive Flow
                        Fault Status: 01110001
                        Mileage: 251447 km
                        RPM: 1449 /min
                        Torque: 113.1 Nm
                        Speed: 11.2 km/h
                        Duty Cycle: 80.7 %
                        Duty Cycle: 80.7 %
                        Mass Air / Rev.: 11.8 mg/str
                        Duty Cycle: 39.5 %
    Readiness: 0 1 0 0 0
       Part No SW: 8E1 910 156 D    HW: 09L 927 156 B
       Component: AG6 09L 3.0lTDI RdW 0010
       Revision: --H01---    Serial number:        4034968
       Shop #: WSC 06325 000 00000
       VCID: 2809F98DEEF9DF27F6D-807C
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
       Component: ESP8 quattro    H04 0120
       Coding: 0004426
       VCID: 290FFC89F5F3E62FE93-807C
                000 -  -  - Intermittent
                        Fault Frequency: 7
                        Reset counter: 30
                        Hex Value: 0x0000
                        Hex Value: 0x0202
                        Hex Value: 0x0024
                        Hex Value: 0x0198
                        Hex Value: 0x0001
       Part No: 8E0 820 043 AK
       Component:   A4 Klimaautomat   2831
       Coding: 00000
       VCID: 6A8DC38535652D37209-50F4
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  ECE 0504
       Coding: 11041
       Shop #: WSC 06335
       VCID: 3B2336C10A7F64BF8BF-4AA4
                80-00 - Single-Wire Operation
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H11 3530
       Revision: 91H1135    Serial number: 0036M0050U6T
       Coding: 0033622
       VCID: 3B2336C10F6F64BF8BF-806E
       Subsystem 1 - Serial number: 6332DRB40158CE35V
       Subsystem 2 - Serial number: 6342DRB401589026F
       Subsystem 3 - Serial number: 6352ARB40068F857V
       Subsystem 4 - Serial number: 6362ARB4006A3A41H
       Subsystem 5 - Serial number: 63729RB400746B05G
       Subsystem 6 - Serial number: 63829RB40074A650G
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 04042
       Shop #: WSC 06325
       VCID: 41DF442968930E6FD13-4AA4
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 931 P    HW: 8E0 920 931 P
       Component: KOMBI+WFS 4     H12 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0007041
       Shop #: WSC 73249 020 01196
       VCID: 353720F9295BB2CF7DB-5118
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0007041
    Address 37: Navigation        Labels: 4B0-919-887-BNS4.lbl
       Part No: 4B0 919 887 E
       Component: BNS 4.2 H05    BNO 0050
       VCID: 353720F92C6BB2CF7DB-4B00
    65535 - Internal Control Module Memory Error
                00-00 -  -
       Part No: 8E0 959 433 BR
       Component: Komfortgerát T23    3332
       Coding: 07024
       Shop #: WSC 06325
       VCID: 025D8B252D15D577889-4AA4
       Component: Tőrsteuer.FS BRM 0406
       Subsystem 2 - Part No: 8E1959802B
       Component: Tőrsteuer.BF BRM 0205
       Subsystem 3 - Part No: 8E0959801A
       Component: Tőrsteuer.HL BRM 0205
       Subsystem 4 - Part No: 8E0959802A
       Component: Tőrsteuer.HR BRM 0205
    00955 - Key 1
                35-10 -  -  - Intermittent
       Part No: 8P0 907 357 B
       Component: Dynamische LWR  H01 0020
       Coding: 0000005
       VCID: 392F2CC9055356AF993-806C
       Part No: 8E0 035 152 F
       Component: chorus II   GRO    0004
       Coding: 01077
       Shop #: WSC 06325
       VCID: 2313EEA192FF3C7FA3F-4B1E
    00852 - Loudspeaker(s); Front
       Part No SW: 8P0 862 335 C    HW: 8P0 862 335 C
       Component: FSE_255x BT     H18 0160
       Revision: 00000001    Serial number: 00000000238373
       Coding: 0001611
       VCID: 363527F5345DB9D7741-50D0
    End----------(Elapsed Time: 04:51, VBatt start/end: 12.2V/12.2V)-----------
    This is measure blocks 102, 103 and 104
    This is what happens if I try to do the DPF replacement in adaptations. The pop up window says to enter 0001, but the option to save is greyed out.
    Lastly, this is a graph showing DPF differential pressure and engine rpm. The engine is in limp mode and won't really go above 2k rpm. The peaks on the graph are me flooring the pedal. No power, but also very little differential pressure. I think that what is happening is that because the soot has gone above the threshold where the car won't regen due to fire risk, the engine now is remaining in limp mode and won't regen until the adaptation is done. Even though the differential pressure is now low again. But I could be wrong, any help would be much appreciated!
    Thanks!
    p.s. the software said that I have 15 uses until I have to activate or register it, how do I go about doing that?
  8. Likes Dana liked this post
  9. #6
    I suggest correcting the the EGR and IMR problems first.
  11. #7
    Mar 2019
    France
    The IMR issue has been there for a while now. It pops up but doesn't trigger the engine light until it's appeared something like 8 times. I'll deal with it at some point, but once everything else is up and running.
    For the EGR, I will deal with that soon. The car is currently parked at another friend's house (it's a bit confusing. I live at A, I can do repairs at B, the car is parked at C, and the owner lives at D).
    I want to avoid driving the car from C to B if possible, as it's up the side of a mountain and I'm not sure limp mode would do it. I also don't want to risk clogging the cleaned DPF by driving if the ECU won't allow a regen to occur until the adaptation is performed. The owner is also renting a car at present, so the sooner the limp issue can be resolved the better. Even if that means driving with an engine light/egr issue for a few days until a new part arrives.
    Based on the scan and data, does it look like the dpf has indeed been successfully cleaned, and would doing the adaptation get past the limp mode and allow the regens to occur again?
  12. #8
    If you've typed in a value (as opposed to using the Up/Dn buttons), you must click [Test] before you can [Save]
  13. #9
    Mar 2019
    France
    I will try that in the next couple of days.
    Thank you for the quick responses, I appreciate it!
  14. #10
    Jul 2014
    I doubt it will do a DPF regen with an EGR fault logged.
    Regards HMC
  15. Likes Uwe, Jack@European_Parts liked this post
