Skoda Fabia 2018 rear parking sensors retrofit
naelraddad
IL
C?ID=239999
hi this my first post here i hope to get your help
i want to install rear parking sensors for Skoda Fabia 2018 i got full set with wiring
the rear parking module not installed yet i need to have the necessary coding modification before i install the set
the parking module part number is 5Qd919283F
so i hope that you can help me with new control modules coding
Wednesday,10,April,2019,16:53:03:54163
VCDS Version: 18.9.1.0
VIN: TMBER2NJ4JZ166351   License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 02 03 08 09 15 17 19 44 5F
VIN: TMBER2NJ4JZ166351   Mileage: 3168km-1968miles
Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 Q    HW: 04C 907 309 AE
   Component: R3 1.0l TFS   H26 3581
   Revision: W1H26---
   Coding: 01250012230411080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM10TFS01104C906026Q 002007
   ROD: EV_ECM10TFS01104C906026AH.rod
   VCID: 2F6D2CDF76CEDF3274-807A
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 0CW 300 042 C    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1602
   Revision: 00005008    Serial number: CU501803156247
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 366319BB8994EEFA37-8062
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
   Component: ESP9.0i       H04 0006
   Serial number: 08502942180311
   Coding: 41F5487D892933C61117106E0052821291CC8808000DCB098F00
   Shop #: WSC 13765 031 00000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 3E73019BA1A426BAEF-806A
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 C    HW: 6V0 820 045 C
   Component: AC Manuell    H01 0204
   Serial number:  1802231B-0611
   Coding: 100000001100000000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 326B25AB65FCF2DA1B-8066
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 E    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H10 0101
   Serial number: 006728135374
   Coding: 0C0018404215405B438040000007030810005800510A3514030000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMA0 006004
   ROD: EV_BCMA0_006_VW26.rod
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000008487924
   Coding: 011200
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 H    HW: 6C0 959 655 H
   Component: VW20Airbag744 002 0380
   Revision: --------    Serial number: 003TG002ZZH8
   Coding: 8800C00000000000400000CF000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 387F17838380188A25-806C
   Part No SW: 6V0 920 740 C    HW: 6V0 920 740 C
   Component: KOMBI         204 2318
   Coding: 072401082180000801080A001000000000000000
   Shop #: WSC 73430 031 12345
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 35611EB79492E5E23E-8060
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H10 0101
   Revision: --------    Serial number: 006728135374
   Coding: 030100042F0A570000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 2643C9FB59349E7A87-8072
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000D1191200318
   Subsystem 2 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Serial number: 4266527204
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AK    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  313 3250
   Serial number: CI3N0081
   Coding: 000700
   Shop #: WSC 03121 003 1048576
   ASAM Dataset: EV_SteerAssisUDSTRW 016134
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 71E9EAA7A07A89C222-8024
   Part No SW: 6V0 035 867 E    HW: 6V0 035 867 E
   Component: MU-E--ER      052 7200
   Serial number: 26021800010080
   Coding: 036200003C0000005011000101102800000000C40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001032
End-------------------------(Elapsed Time: 02:31)--------------------------
naelraddad
IL
C?ID=239999
this the new scan and the parking sensors installed and working ( only sound ) but did not appear in information screen
i need your help to modify coding
Wednesday,17,April,2019,16:02:24:54163
VCDS Version: 18.9.1.0 (x64)
Scan: 01 02 03 08 09 10 15 17 19 44 5F
VIN: TMBER2NJ4JZ166351   Mileage: 3833km-2381miles
   Revision: W1H26---
   CAN Converter 01:
   Coding: 011200
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 5QD 919 283 F    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0044
   Serial number: 000308419218005
   Coding: 0601150011
   Shop #: WSC 00078 790 00070
   ASAM Dataset: EV_EPHVA14AU3700000 009033
   ROD: EV_EPHVA14AU3700000.rod
   VCID: 50AF4F230B30A0CA0D-8004
12658704 - Databus
                    Reset counter: 164
                    Mileage: 3833 km
                    Date: 2019.04.17
                    Time: 15:26:05
12583936 - Data Bus for Suspension
          U10AC 00 [008] - No Communications
                    Reset counter: 204
12656926 - Databus
                    Reset counter: 164
                    Mileage: 3833 km
                    Date: 2019.04.17
                    Time: 15:26:06
   Coding: 072401082190000801080A001000000000000000
          U1014 00 [009] - -
                    Fault Frequency: 6
                    Reset counter: 164
                    Mileage: 3833 km
                    Date: 2019.04.17
                    Time: 15:37:28
16776980 - Databus
                    Reset counter: 164
                    Mileage: 3833 km
                    Date: 2019.04.17
                    Time: 15:37:28
   Coding: 000700
1062912 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 164
                    Mileage: 3833 km
                    Date: 2019.04.17
                    Time: 15:59:29
End-------------------------(Elapsed Time: 02:38)--------------------------
regards
