Results 1 to 6 of 6
Thread: Skoda Fabia 2018 rear parking sensors retrofit
    Mar 2019
    IL
    hi this my first post here i hope to get your help
    i want to install rear parking sensors for Skoda Fabia 2018 i got full set with wiring
    the rear parking module not installed yet i need to have the necessary coding modification before i install the set
    the parking module part number is 5Qd919283F
    so i hope that you can help me with new control modules coding
    Wednesday,10,April,2019,16:53:03:54163
    VCDS Version: 18.9.1.0
    VIN: TMBER2NJ4JZ166351   License Plate:
    Chassis Type: NJ-SK26 (6C0)
    Scan: 01 02 03 08 09 15 17 19 44 5F
    VIN: TMBER2NJ4JZ166351   Mileage: 3168km-1968miles
    Address 01: Engine (J623-CHZC)       Labels:. 04E-907-309-V1.clb
       Part No SW: 04C 906 026 Q    HW: 04C 907 309 AE
       Component: R3 1.0l TFS   H26 3581
       Revision: W1H26---
       Coding: 01250012230411080000
       Shop #: WSC 73430 031 00000
       ASAM Dataset: EV_ECM10TFS01104C906026Q 002007
       ROD: EV_ECM10TFS01104C906026AH.rod
       VCID: 2F6D2CDF76CEDF3274-807A
       CAN Converter 01:
    Readiness: 1110 0001
       Part No SW: 0CW 300 042 C    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1602
       Revision: 00005008    Serial number: CU501803156247
       ROD: EV_TCMDQ200021_VW31.rod
       VCID: 366319BB8994EEFA37-8062
       Part No SW: 6C0 907 379 R    HW: 6R0 907 379 BA
       Component: ESP9.0i       H04 0006
       Serial number: 08502942180311
       Coding: 41F5487D892933C61117106E0052821291CC8808000DCB098F00
       Shop #: WSC 13765 031 00000
       ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
       VCID: 3E73019BA1A426BAEF-806A
    Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
       Part No SW: 6V0 820 045 C    HW: 6V0 820 045 C
       Component: AC Manuell    H01 0204
       Serial number:  1802231B-0611
       Coding: 100000001100000000
       ROD: EV_ACManueKMMValeoPQ26.rod
       VCID: 326B25AB65FCF2DA1B-8066
    Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
       Part No SW: 6C0 937 089 E    HW: 6C0 937 089
       Component: BCM PQ26 Hi4R H10 0101
       Serial number: 006728135374
       Coding: 0C0018404215405B438040000007030810005800510A3514030000000000
       Shop #: WSC 73430 790 00000
       ASAM Dataset: EV_BCMA0 006004
       ROD: EV_BCMA0_006_VW26.rod
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
       Component: FHSG DRV  007 0001
       Serial number: 00000000000008487924
       Coding: 011200
    Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
       Part No SW: 6C0 959 655 H    HW: 6C0 959 655 H
       Component: VW20Airbag744 002 0380
       Revision: --------    Serial number: 003TG002ZZH8
       Coding: 8800C00000000000400000CF000800000000
       ROD: EV_AirbaVW20BPAVW26X.rod
       VCID: 387F17838380188A25-806C
       Part No SW: 6V0 920 740 C    HW: 6V0 920 740 C
       Component: KOMBI         204 2318
       Coding: 072401082180000801080A001000000000000000
       Shop #: WSC 73430 031 12345
       ROD: EV_DashBoardVDDMQBAB_SK25.rod
       VCID: 35611EB79492E5E23E-8060
    Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
       Part No SW: 6C0 909 901 A    HW: 6C0 937 089
       Component: GW MQB A0     H10 0101
       Revision: --------    Serial number: 006728135374
       Coding: 030100042F0A570000000000000000010001050000000000000000000000
       ASAM Dataset: EV_GatewA0Lear 013020
       ROD: EV_GatewA0Lear_013_SK25.rod
       VCID: 2643C9FB59349E7A87-8072
       Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
       Component: E221__MFL-PR6  H02 0160
       Serial number: 000000000D1191200318
       Subsystem 2 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
       Serial number: 4266527204
       Part No SW: 6C1 909 144 AK    HW: 6C1 909 144 D
       Component: EPS_TRW_ALow  313 3250
       Serial number: CI3N0081
       Coding: 000700
       Shop #: WSC 03121 003 1048576
       ASAM Dataset: EV_SteerAssisUDSTRW 016134
       ROD: EV_SteerAssisUDSTRW.rod
       VCID: 71E9EAA7A07A89C222-8024
       Part No SW: 6V0 035 867 E    HW: 6V0 035 867 E
       Component: MU-E--ER      052 7200
       Serial number: 26021800010080
       Coding: 036200003C0000005011000101102800000000C40000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
    End-------------------------(Elapsed Time: 02:31)--------------------------
    Aug 2016
    The Hague, NL
    5Qd919283F = made in china?
    Mar 2019
    IL
    yes it made in china
    it is PDC 4 Kanal 5QA919283
    regards
    Aug 2016
    The Hague, NL
    Mar 2019
    IL
    thanks for your reply and there is good info but still need more information that link is for polo and different from mine
    king regards
    Mar 2019
    IL
    this the new scan and the parking sensors installed and working ( only sound ) but did not appear in information screen
    i need your help to modify coding
    Wednesday,17,April,2019,16:02:24:54163
    VCDS Version: 18.9.1.0 (x64)
    Scan: 01 02 03 08 09 10 15 17 19 44 5F
    VIN: TMBER2NJ4JZ166351   Mileage: 3833km-2381miles
       Revision: W1H26---
       CAN Converter 01:
       Coding: 011200
    Address 10: Park/Steer Assist (J446)       Labels:* None
       Part No SW: 5QD 919 283 F    HW: 5QA 919 283
       Component: PDC 4 KanalH07 0044
       Serial number: 000308419218005
       Coding: 0601150011
       Shop #: WSC 00078 790 00070
       ASAM Dataset: EV_EPHVA14AU3700000 009033
       ROD: EV_EPHVA14AU3700000.rod
       VCID: 50AF4F230B30A0CA0D-8004
    12658704 - Databus
                        Reset counter: 164
                        Mileage: 3833 km
                        Date: 2019.04.17
                        Time: 15:26:05
    12583936 - Data Bus for Suspension
              U10AC 00 [008] - No Communications
                        Reset counter: 204
    12656926 - Databus
                        Reset counter: 164
                        Mileage: 3833 km
                        Date: 2019.04.17
                        Time: 15:26:06
       Coding: 072401082190000801080A001000000000000000
              U1014 00 [009] - -
                        Reset counter: 164
                        Mileage: 3833 km
                        Date: 2019.04.17
                        Time: 15:37:28
    16776980 - Databus
                        Reset counter: 164
                        Mileage: 3833 km
                        Date: 2019.04.17
                        Time: 15:37:28
       Coding: 000700
    1062912 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 164
                        Mileage: 3833 km
                        Date: 2019.04.17
                        Time: 15:59:29
    End-------------------------(Elapsed Time: 02:38)--------------------------
    regards
