Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Audi A5 3.0 TDi Limp mode after acceleration in Sport Mode
    Feb 2017
    Barnstaple, England and Linz, Austria
    5580 - Oil Pressure fault was what caused my CCWA 3.0 TDI to go into limp mode just over 2500 rpm. If you search in this forum for "5580 - Oil Pressure" there are only a few results one of which is mine.
    Hopefully this link works:
    https://forums.ross-tech.com/showthr...6-3-0-TDi-Audi
    The challenge you will face to verify if this fault is also one of your problems is that oil pressure is not constant, which sounds obvious to say, but what I mean is that the engine control system dynamically increases the oil pressure at 2500 rpm and verifys that the increase has taken place by sensors. If the sensors do not see the increase in oil pressure expected, the car goes into limp mode. An open loop controlled solenoid valve on the front of the engine is what physically enables the oil pressure to increase but in my case/opinion this valve got 'sticky' due to age/wear. I also suspected the oil pressure sensors, but I got lucky by choosing to replace the valve first.
    Good luck.
  2. #12
    Mar 2019
    I’ve had a look at the fuel metering valve and that was clear of any debris. I’ve yet to change the fuel filter and I’m going to change the oil and filter as well.
    I took the car out for a drive after checking the metering valve and keeping it in D, I didn’t get the flashing coil and limp mode after hard acceleration. I haven’t tried it again in Sport mode yet.
    Top tip on the oil solenoid valve andythechief, I’ll keep that in mind for any further diagnosis.
  3. #13
    Feb 2017
    Jasegarn - random thought along the solenoid valve lines again - I recall engine oil temperature on mine was important for the dynamic oil pressure system to activate/operate. Cold oil obviously runs at a higher pressure anyway so this would mask the problem if the cold pressure exceeded the higher pressure expected by the sensors over 2500 rpm. You can use measuring blocks to see the oil pressure readings, I'd have to check my post to see which ones but I think I just searched for 'oil' ( very handy feature thanks VCDS!) in advanced measuring blocks and that took me to all the possible oil pressure sensor values, and from the labels and some system architecture knowledge it was possible to discern which ones were relevant. If you also watch/log engine oil temperature, you get to know what temperature threshold is important and can make sure you exceed it before your driving test. Please don't think I'm trying to push my theory, I just wanted to tell you what I remembered when I wondered how hot the engine oil was when you tested the car.
  5. #14
    Agreed Andy......
  6. #15
    Feb 2017
    Jasegarn- any update?
  7. #16
    Mar 2019
    Hi. No not yet. Iíve just come back off holiday so am going to start looking at this again.
  8. #17
    Mar 2019
    Quote Originally Posted by andythechief View Post
    I may be being a biff here but, my car doesn't want to rev above 2500 when stood still. The engine is warmed up as I had just been for a drive before trying to rev the engine. I didn't have VCDS plugged in a the time but, I'm wondering if this is normal. I didn't get any warning lights or other indication.
  9. #18
    Quote Originally Posted by Jasegarn View Post
    That's completely normal, nothing to worry about.
  10. Likes Uwe liked this post
  11. #19
    Mar 2019
    So, I finally got around to changing my oil, oil filter and fuel filter. After a weeks driving to work and back, trying all the conditions that threw the fault up in the first place, I haven’t had the car go in to limp mode again. It has only been a week but, time will tell I suppose.
    While I was doing the mini service I did the oil regulator valve test in VCDS and I could hear the solenoid clicking. Don’t know if this means that the valve is fully functioning but at least that bit works.
    Thanks for the replies and help. If it happens again, I’ll be revisiting this thread!
  12. Likes Uwe liked this post
