Results 1 to 4 of 4
Thread: Turning off DRL winking in updated C7 S6
    Oct 2017
    Hi all,
    I have a 2017 S6. With the updated VAG-COM software there is now a long coding helper in module 9. I was looking to turn off the winking feature, however there are a lot of lighting options available. I did uncheck the box on byte 27, bit 4 which was something like turn off led with turn signal.
    When I did this the lower led would flash opposite the yellow blinker. I don't really want to be that flashy like an emergency vehicle!
    Is there other coding that needs to be done i.e. dimming of led? As mentioned earlier there are a lot of options and I don't really want to start checking boxes willy-nilly.
    Thanks for your help in advance.
    Monday,21,January,2019,16:55:43:49599
    VCDS Version: 18.9.1.0 (x64)
    VIN: WAUHFAFC4HN122204   License Plate: CLZ
    Mileage: 16688km-10369mi   Repair Order:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
              44 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 BA
    VIN: WAUHFAFC4HN122204   Mileage: 16688km-10369miles
    BA-Motor Mounts -- Status: OK 0000
    Address 01: Engine (------CTGE)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 4G0 906 014 D    HW: 4H0 906 014
       Component: 4.0l V8TFSI / H63 0002
       Revision: NCH63---
       Coding: 0A2500326546010E3000
       ASAM Dataset: EV_ECM40TFS0114G0906014D 001002
       ROD: EV_ECM40TFS0114G0906014D.rod
       VCID: 234F11CC2A144752E0-8076
    Readiness: 0010 0101
       Part No SW: 4G0 927 166 F    HW: 0B5 927 156 K
       Component: 0B5 40TFSINAR H06 0007
       Revision: --H06---
       Coding: 000001
       ASAM Dataset: EV_TCMDL501021 001022
       ROD: EV_TCMDL501021.rod
       VCID: 3065EE806BE2ECCA6D-8064
       Coding: 65BED449A67D2B921B00
       ROD: EV_ESP9BOSCHAU57X.rod
       VCID: 4183BB44D048754292-8014
       Part No SW: 4H0 907 064 HR    HW: 4H0 907 064 HR
       Component: BCM2 2.0      H61 0825
       Coding: 0DA86F4E000000000000
       VCID: 00057E4093C2BC4ADD-8054
       Serial number: 3217000044182016
       Part No SW: 4G0 820 043 BL    HW: 4G0 820 043 BL
       Serial number: 05041700040969
       Coding: 688130B85D0000
       VCID: 6AD13CE88DBE561A63-803E
       Part No SW: 4H0 907 063 GM    HW: 4H0 907 063 AM
       Component: BCM1 2.0      H20 0368
       Revision: 2102003S    Serial number: 00001631940501
       Coding: 01050011043C9FF2F90148C7A0003800CF9CD208AE08022180000894F10017020060002D0B0000
       VCID: 79F313A4F018ED829A-802C
       Component: WWS57X 170301  H38 0080
       Serial number:         170308110529
       Coding: 0045F7
       Serial number: 20172518X81A955547A0
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531 AN    HW: 4G0 941 531 AN
       Component: E1 - LDS  H07 0044
       Serial number: 29 03 2017  00000451
       Component: USHL4.2  H30 0030
       Serial number: 00000000095Z02D5DBEB
       Subsystem 5 - Part No SW: 4H0 907 705 K    HW: 4H0 907 705 C
       Component: EVLS-SG  H08 0300
       Serial number: WA127015000030971731
       Coding: 020300
       Subsystem 6 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Serial number: 37284C9800PAG0MUFU03
       Part No SW: 4G0 907 561 B    HW: 4G0 907 561
       Component: ACC3          H21 0055
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContrAU57X 002015
       ROD: EV_AdaptCruisContrAU57X_002.rod
       VCID: 295303E448389D02AA-807C
       Part No SW: 4G0 959 655 B    HW: 4G0 959 655 B
       Component: Airbag10.43   H62 0092
       Revision: --------    Serial number: 003G0003ZU67
       Coding: 303331343135303334354A55304C34473053
       VCID: 346DE2909FFAD0EA09-8060
       Component: BF-Gewichtss.  H15 0046
       Serial number: 6940000Y170001L1E40G
       Serial number: 3575HRB405T4CVFI58VM
       Serial number: 3585HRB405T468HIC91H
       Serial number: 3515JRB400U599TUIH3A
       Serial number: 3525JRB4014599TUE0TY
       Serial number: 3554VRB400659I8MP24H
       Serial number: 3564VRB400459I8MS96S
       Component: Lenks.Modul   H05 0005
       Revision: --------    Serial number: 90372QD40000S
       Coding: 0004FC
       VCID: 3875D6A08B92348A25-806C
       Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
       Serial number: 11 01 2017  C0010692
       Part No SW: 4G0 920 982 S    HW: 4G0 920 982 S
       Component: TBenUsaAccNv  H15 0225
       Revision: 15001309    Serial number: 658050417596017
       Coding: 03CF0905BF51D705020200
       ASAM Dataset: EV_RBD4K 004060
       ROD: EV_RBD4K.rod
       VCID: 3C7DCAB0B7AA18AAC1-8068
       Part No SW: 4G8 907 468 H    HW: 4G8 907 468
       Component: J533--Gateway H15 0096
       Revision: --------    Serial number: 00000002573622
       Coding: C0ED074814
       VCID: 3D7BC7B4ACB011A2F6-8068
       Subsystem 1 - Part No SW: 8S0 915 181 B    HW: 8S0 915 181 B
       Serial number: 0986723504
       Voltage stabilizer:
       Serial number: 17012100000000000169
       Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
       Component: DYNAMIKLENK.  H06 0740
       Coding: 0E0100
       VCID: 3A71CCA8B59E269AD3-806E
       Part No SW: 4H0 857 511     HW: 4H0 857 511
       Component: FLA           H04 0021
       Revision: AA001002
       VCID: 67D745DC96AC6B727C-8032
    Address 22: AWD (J492)       Labels: 4H0-907-163.clb
       Part No SW: 4H0 907 163 B    HW: 4H0 907 163 A
       Component: 4 Wheel Drive H19 0200
       Serial number: 003003170001009
       ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
       VCID: 285506E05332A40AB5-807C
       Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
       Component: KLIMA FOND    H08 0113
       Serial number: 04041700041266
       Coding: 20
       VCID: 3E79C0B8A1B60ABAEF-806A
       Part No SW: 4G0 907 553 G    HW: 4G0 907 553 F
       Component: LUFE-DAEMPFER H19 0783
       Coding: 008006
       ASAM Dataset: EV_AirSuspe 003025
       ROD: EV_AirSuspe_VW51.rod
       VCID: 2F67EDFC76DCF33274-807A
       Revision: AA000000    Serial number: 00000250158008
       VCID: 77F7159CC60CFBF2EC-8022
       Component: SARA 6D red   H04 0056
       Revision: --------    Serial number: EJ1BPA7E02RDES
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 3777D59C8E8C3BF22C-8062
       Part No SW: 4G0 907 566 M    HW: 4H0 907 566 F
       Component: SWA Master    H08 0070
       Serial number: 0437049975
       Coding: 040211
       VCID: 3973D3A4B8982D82DA-806C
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 4G0 907 568 M    HW: 4H0 907 568 F
       Component: SWA Slave  H08 0070
       Serial number: 0436831968
       Coding: 040211
       Part No SW: 4G8 959 793 H    HW: 4G8 959 793 F
       Component: TSG FA        H04 0511
       Coding: 011F17015E00628002000013
       VCID: 458BAF54CC605962AE-8010
       Component: RCevo         H54 0202
       Revision: 00000001    Serial number: 0000689500
       Coding: 011001010001
       ASAM Dataset: EV_RCEPS 106007
       ROD: EV_RCEPS_106.rod
       VCID: 3A71CCA8BD9E269AD3-806E
       Revision: 00002001    Serial number: 0437268663
       Coding: 0106063A00FA718581B0088402070E470000000000000000000000000000
       Component: GTO BF  H01 0081
       Serial number: 00000000000000392588
       Subsystem 3 - Part No SW: 4G8 959 591 A    HW: 8V3 959 591 A
       Component: J245 PS40.402  H03 0004
       Serial number: 0000FST001J0OFN00000
       Coding: 101F02
       Subsystem 4 - Part No SW: 4G0 947 135 G    HW: 4G0 947 135
       Serial number: 0000000AP00032177956
       Subsystem 5 - Part No SW: 3AA 962 243 D    HW: 3AA 962 243 D
       Serial number: 6600213=
       Coding: 011F17015E00628002000002
       VCID: 4689A858F166527AA7-8012
       Part No SW: 4H0 907 801 M    HW: 4H0 907 801 M
       Component: EPB-4         H01 0018
       Revision: --------    Serial number: 00000002154574
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 3261E48865EEDEDA1B-8066
       Coding: 04FA0A1122600400
       Coding: E01E00
       Coding: E01E00
    Address 5F: Information Electr. (J794)       Labels:* 4G1-035-MIB-HGH2.clb
       Part No SW: 4G1 035 025 D    HW: 4G1 035 025 C
       Component: MU-H-LNS-US   053 0902
       Serial number: A741C0H7535311
       Coding: 017551020000000013220002041A00102F0007E5F17001047E
       VCID: 1F471D3C067C63B2C4-804A
       Subsystem 1 - Part No SW: V03 959 802 DK    HW: -----------
       Component: NAR 2018/2019  --- 0066
       Subsystem 2 - Part No SW: 4G1 919 605 B    HW: 4G1 919 605 B
       Serial number: AUZ8Z9HY807NQ1
       Multimedia Operating Unit:
       Serial number: 90349QD60002J
       Component: Gracenote2---  --- 3011
       VCID: 4993A364E078BD024A-801C
       Part No SW: 4H0 907 428 E    HW: 7P6 907 441 G
       Component: TopView       H09 0380
       Revision: 11001001    Serial number: 82330JG0394149
       Coding: 0212000101010000000102000000
       ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
       ROD: EV_CamerSysteTopViewAUDI_008_AU57.rod
       Part No SW: 4G5 959 107 C    HW: 4G5 959 107 A
       Component: HDSG-Modul    H02 0049
       Revision: 13002001    Serial number: 056700456
       Coding: 111104C120
       ASAM Dataset: EV_HDSGAu571 001022
       ROD: EV_HDSGAu571.rod
    Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
       Part No SW: 4G0 919 604 M    HW: 4G0 919 604 M
       Component: HeadUpDisplay H09 0306
       Coding: C60000
       ASAM Dataset: EV_HUDContiC7 001027
       ROD: EV_HUDContiC7.rod
       VCID: 356BDF949480C9E23E-8060
       Part No SW: 4H0 907 217 F    HW: 4H0 907 217 A
       Component: DPC-SG        H28 0081
       Coding: EA060000
       ROD: EV_OnBoardCamerDPC.rod
       VCID: 2C5DFAF047CA882A51-8078
       Part No SW: 4G0 907 541 B    HW: 4G0 907 541
       Coding: 7E01010102
       ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
       ROD: EV_AdaptCruisContr2AU57X_002.rod
       VCID: 275705DC5E2CAB72BC-8072
       Part No SW: 4H0 907 107 H    HW: 4H0 907 107
       Component: BV-SG         H34 0090
       Serial number: 005002450204177
       Coding: 04C1BA1B0111
       ASAM Dataset: EV_BC7 001001
       ROD: EV_BC7.rod
       Component: RGS-VL        H16 0080
       Coding: 0066E608031F0376070308014240C0010000
       ASAM Dataset: EV_RGS_L 002004
       ROD: EV_RGS_L.rod
       VCID: 3163EB8460E8E5C262-8064
       Component: RGS-VR        H16 0080
       ASAM Dataset: EV_RGS_R 002004
       ROD: EV_RGS_R.rod
       Part No SW: 4G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0010
       Serial number: 170307200507
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145 B    HW: 4H0 907 145
       Component: AEM - LEAR    H10 0008
       Revision: 00001001    Serial number: 97813008226001
       ASAM Dataset: EV_AEMLearAU64X 002016
       ROD: EV_AEMLearAU64X_AU57.rod
    End-------------------------(Elapsed Time: 07:09)--------------------------
    Sent from Mail for Windows 10
    Maybe Byte 3, bit 7?
    Oct 2017
    Thanks for the response Uwe. Byte 3 bit 7 didn't work. It still wants to wink. If someone wants a busy turn signal bit 27 byte 4 is the way to go. It alternates flashing yellow top led with the white bottom one. A little bit busy for me.
  4. Likes Uwe liked this post
    Oct 2017
    Here is what unchecking bit 27, byte 4 looks like. Thoughts anyone?
    https://drive.google.com/file/d/1wpF...ew?usp=sharing
