Hi all,
had a problem last week as some of you might have noticed with lost coding from abs controller which was sorted,
but the reason i had THAT problem is i was trying to get to the bottom of THIS problem.
Few weeks ago customer went to start this car and dashboard was completely dead no lights, starts,runs stops.
couple of checks later found the recovery guy who brought the car in to us had put fuse no1 back into fuse number two under bonnet fuse box,
so once i swapped it back everything was normal but why did it fail in the first place ?
Had the dashboard sent away to be tested and no fault found,
customer had it back for a week before it played up again but this time the warning lights were flashing / flickering when ignition switch on and the dashboard making a ticking noise,
sent dashboard off again for retesting and again no fault found, had it back plug back in - everything fine for about ten minutes now back to flickering warning lights.
anybody had anything like this before ? any help would be appreciated thanks.
scan posted after the abs coding problem was clean - no faults anywhere
below is latest scan nothing been altered on vehicle only turned ignition on
Tuesday,26,March,2019,14:52:48:05858
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8P6CA114311 License Plate: VN12RXZ DASH
Chassis Type: 8P-AU35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 77
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 PP HW: 03L 906 023 KS
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: AUX7Z0L0FNH0UD
Coding: 00114036032501080000
Shop #: WSC 06314 000 00000
ASAM Dataset: EV_ECM16TDI02103L906023PP 003009
ROD: EV_ECM16TDI.rod
VCID: 030F80E88A03FA52C0-8056
6 Faults Found:
6260 - Engine Start Blocked by Immobilizer
P1570 00 [165] - -
Mileage: 999999 km
Time: 31:63:63
Engine speed: 936.25 /min
Normed load value: 27.5 %
Coolant temperature: 10 °C
Intake air temperature: 10 °C
Voltage terminal 30: 11.520 V
Immobilizer snapshot A: 30
6068 - No Communication with Instrument Cluster
U0155 00 [036] - -
Fault Frequency: 7
Mileage: 999999 km
Time: 31:63:63
Coolant temperature: 11 °C
Intake air temperature: 11 °C
Voltage terminal 30: 11.859 V
Driver request torque-TQI_DRIV_SUB: 0.00 Nm
Control Module temperature-TECU: 17 °C
7278 - No Communication with Instrument Cluster
U0155 00 [036] - -
Mileage: 999999 km
Time: 31:63:63
Voltage terminal 30: 11.633 V
7279 - No Communication with Instrument Cluster
U0155 00 [036] - -
Mileage: 999999 km
Time: 31:63:63
7196 - Function Restriction due to Faults in Other Modules
U1113 00 [101] - -
Mileage: 999999 km
Time: 31:63:63
Engine speed: 0 /min
Accelerator position: normalized-Accelerator position: 0.00 %
Battery voltage: 11.1 V
9862 - External Control Module
P150F 00 [037] - Incorrectly Coded
Mileage: 999999 km
Time: 31:63:63
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Shop #: WSC 06314 123 12345
VCID: 7BFFF808FAF3829288-802E
8 Faults Found:
03391 - Coding Not Possible
Reset counter: 13
Mileage: 999999 km
Count: 2
Count: 20992
Count: 8254
Count: 41984
Reset counter: 13
Mileage: 999999 km
Count: 2
Count: 20992
Count: 8224
Count: 41984
Fault Status: 00100101
Reset counter: 13
Mileage: 999999 km
Count: 16391
Count: 2
Count: 20480
Count: 212
Count: 42752
03190 - Incorrect Vehicle Type
Reset counter: 13
Mileage: 999999 km
Count: 16391
Count: 2
Count: 20480
Count: 4160
Count: 42752
Reset counter: 13
Mileage: 999999 km
Count: 16391
Count: 2
Count: 16384
Count: 195
Count: 42752
Fault Status: 01100101
Reset counter: 13
Mileage: 999999 km
Count: 16391
Count: 2
Count: 20480
Count: 279
Count: 42752
Reset counter: 13
Mileage: 999999 km
Count: 16391
Count: 2
Count: 20480
Count: 295
Count: 42752
Reset counter: 13
Mileage: 999999 km
Count: 16391
Count: 2
Count: 20480
Count: 270
Count: 42752
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0180
Revision: 000537 Serial number: 8P0820043BM
VCID: 78F5E7040BC5A98AE5-802C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 13
Mileage: 999999 km
Reset counter: 13
Mileage: 999999 km
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 N HW: 8P0 907 063 N
Component: BCM PQ35 M 110 0667
Revision: AJ110667
Coding: 4E000A2FA005F000207041E00100014C427A23AA006DC12AE4008F800041
VCID: 3F874C18AE6B5EB2E4-806A
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H11 0050
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Component: Innenraumuebe H04 0020
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Fault Frequency: 7
Reset counter: 53
Mileage: 999999 km
Time: 31:63:63
Voltage: 11.85 V
Term 50 On
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 M HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0140
Revision: 11001001 Serial number: 36861201801089
Coding: 000002
VCID: 489557C4FBA5190A55-801C
Reset counter: 53
Mileage: 999999 km
Time: 31:63:63
Temperature: 0.0°C
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 S HW: 8P0 959 655 S
Component: Airbag AU1042 H10 0250
Revision: -------- Serial number: 003JU005LN3I
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 52A175AC05F9A3DA3B-8006
Serial number: 34928RB40000684FE04X
Serial number: 35028RB40000684B29CQ
Serial number: 35128RB40000684FDD3.
Serial number: 35228RB40000684B28CR
Serial number: 35547RB4000068E9901R
Serial number: 35647RB4000068E9904V
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H38 0070
Coding: 0004042
VCID: 468959FC31B10F7AA7-8012
Component: E0221 H02 0100
Address 17: Instruments Labels: None
VCID: 55AB8EB0BC17B4E2DE-FFFE
No Faults Found
Part No SW: 7N0 907 530 N HW: 1K0 907 951
Component: J533 Gateway H43 1623
Revision: H43 Serial number: 070112F1002093
Coding: 350101
VCID: 3B7F3808BA734292C8-806E
Reset counter: 53
Date: 2000.01.09
Time: 04:18:41
Address 25: Immobilizer
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 P HW: 8P0 959 801 P
Component: Tuer-SG H04 0101
Coding: 0131636
VCID: 489557C43BA5190A55-801C
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 232 3305
Revision: 00H22000
VCID: 37772438465B66F22C-8062
Fault Frequency: 7
Reset counter: 53
Mileage: 999999 km
Time: 31:63:63
Voltage: 11.63 V
DD
Temperature: 12.0°C
Part No SW: 8P3 035 382 E HW: 8P3 035 382 E
Component: AB2 SUBWOOFERBOXH31 0160
Revision: 00007 Serial number: 92157116277282
VCID: 356B2E305C5794E23E-8060
Part No SW: 8P0 959 802 P HW: 8P0 959 802 P
Coding: 0131636
VCID: 499352C020AFE0024A-801C
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 AB HW: 8P0 035 186 AB
Component: R Concert2+ H05 0293
Revision: 00H05000 Serial number: AUZ1Z3M3001895
Coding: 0710011
VCID: 72E1D52C6DB9C3DADB-8026
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1623
Coding: F30F185A
VCID: 71E3DA20A8BFF8C222-8024
Component: J367-BDM H07 0180
Serial number: 00000000008900485851
Part No SW: 8P1 862 335 A HW: 8P1 862 335
Component: FSE_256x BT H44 0660
Revision: 00000000 Serial number: 00000005487139
Coding: 0001222
Reset counter: 53
End-------------------------(Elapsed Time: 02:35)--------------------------
