Results 1 to 8 of 8
Thread: Audi Q5 - Trailer module removal
    Mar 2019
    Canada
    I would like to remove the Trailer module from my 2015 Audi SQ5. I found a few guides to add the module but they seems to be all somewhat different.
    So I probably need to remove the "Hitch installer" options from a few modules like Engine, ABS and Cent. Elect and Back-up Cam. If I forget some modules, I will simply get faults that I can then fix?
    What would be procedure? Do I disconnect the Trailer module before recoding the others module? From my understanding, I should also remove the module from a gateway. When I should do this? At the beginning? At the end?
    Finally, should I disconnect the battery at some point? How reset everything to make sure there is no faults?
    Many thanks!
    Curious why you want to remove the module?
    Please post an Auto-Scan so people can see exactly how the vehicle is equipped and configured.
    Mar 2019
    Canada
    Thanks for chiming in Uwe. And to fulfill your curiosity, I want to remove the hitch before trading my car. :-)
    Here's the Auto-Scan
    Chassis Type: FP-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
              62 69 6C 6D 72 A9
    VIN: WA1LGCFP0FA009583   Mileage: 58530km-36368miles
    Address 01: Engine (J623-CTUD)       Labels:. 06E-907-551-CGW.clb
       Part No SW: 8R0 907 551 G    HW: 4G0 907 551 A
       Component: 3.0l V6 TFSIH07 0007
       Revision: --H07---
       Coding: 2A2A0034053600060000
       Shop #: WSC 05372 002 1048576
       ASAM Dataset: EV_ECM30TFS0218R0907551G 001007
       ROD: EV_ECM30TFS0218R0907551G.rod
       VCID: 3C77216AB785A6AAC1-8069
       Part No SW: 8R0 927 158 AB    HW: 0BK 927 156 AM
       Component: 0BK 30TFSIUSA H18 1002
       Revision: --H18---
       Coding: 000001
       VCID: 7DF1EC6EEC1F6FA2B6-8029
    Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
       Part No SW: 8R0 907 379 AS    HW: 8R0 907 379 AS
       Component: ESP8 quattro  H09 0020
       Coding: 30950801
       VCID: 1129A0DEC8877BC242-8045
       Part No SW: 8K0 907 064 JP    HW: 8K0 907 064 JP
       Component: BCM2 2.0      H14 0650
       Coding: 0D854040000000000000
       Shop #: WSC 06335 000 00000
       VCID: 071D8E86B6C335729C-8053
       Serial number: 0214000098070012
       Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
       Component: KLIMA 3 ZONEN H04 0122
       Revision: C1000000    Serial number: 01300520141818
       Coding: 6601228000
       VCID: 77FDFE46C62345F2EC-8023
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000823055602
       Coding: 26008097863CAFE0010048C300003D0D0F9CE708A2090221000008004400010200040034000000
       Shop #: WSC 27838 001 104857
       VCID: 7AFBE772F531589A93-802F
       Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS416 140522  H12 0050
       Serial number: 90243014140505224316
       Coding: 01DD13
       Serial number: 22716929
       Coding: 02005C
       Component: E1 - LDS  H03 0031
       Serial number: 00000000002405140832
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R9HFP03
       Subsystem 5 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Subsystem 6 - Part No SW: 3D0 941 329     HW: 3D0 941 329
    H05 0012
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 33688037000000000001
       Part No SW: 8K0 959 655 R    HW: 8K0 959 655 R
       Component: AirbagVW-AU10 H51 0812
       Serial number: 003NED1231T3
       Coding: 30373431343238313230554A304C38523053
       ASAM Dataset: EV_AirbaECUVWAUDI010 003114
       VCID: 4C9771AAE725162A71-8019
       Serial number: 6334MSME456E323BL
       Serial number: 6344MSME455E3A71N
       Serial number: 6352QSME01403D4EG
       Serial number: 6362QSME7B3E465E%
       Serial number: 63732SME1146155E-
       Serial number: 63832SME11461066P
       Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
       Component: Lenks.Modul   H03 0003
       Revision: C0062331    Serial number: 90862NF60002A
       Coding: 000037
       VCID: 489F4DBAFB5DFA0A55-801D
    Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
       Part No SW: 8R0 920 931 D    HW: 8R0 920 931 D
       Component: KOMBIINSTR.   H35 0564
       Revision: 00200000    Serial number: ZDS40D56F
       Coding: 8BA722000A010008020000
       VCID: 3663334281A97CFA37-8063
       Component: GW-BEM 5CAN-M H11 0060
       Revision: 1Z120030    Serial number: 3041Z145220B7D
       Coding: 80C103FF00
       VCID: 4C9771AAEF25162A71-8019
       Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
       Component: J367-BDMHella  H07 8043
       Serial number: 1055823203
       Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
       Component: MEM-FS        H07 0077
       Revision: AA000000    Serial number: 00000099709842
       Coding: 00581B00000000000000
       VCID: 428B5F92DD61D05A8B-8017
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H05 0071
       Serial number: 0335720086
       Coding: 010221
       VCID: 3F8D5666A693BDB2E4-806B
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H05 0071
       Serial number: 0336793089
       Coding: 010221
       Component: TSG FA        H02 0510
       Revision:             Serial number: 0000104306510
       Coding: 011D13215E00440004
       VCID: 4FAD66A61E332D3214-801B
       Part No SW: 8R0 909 144 P    HW: 8R0 909 144 B
       Component: RCEPS         H40 0510
       Revision: 00001000    Serial number: 0011578307
       Coding: 100000010000
       Shop #: WSC 06334 000 00000
       ASAM Dataset: EV_RCEPSAU48X 008018
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 4581448EC44FE762AE-8011
       Revision: 00002001    Serial number: 0337366390
       Coding: 0126063A20FA709584B0053200040000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000844542
       Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J245EE04SKB03  H03 0090
       Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
       Component: J394EE04SKB03  H03 0090
       Revision: 00005001    Serial number: 94813030433604
       VCID: 2D511C2E74FF3F2246-8079
       Revision:             Serial number: 0000104426351
       VCID: 4E937BA21939243A1F-801B
       Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
       Component: EPB-4         H02 0005
       Revision: --------    Serial number: 20000000459321
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3A7B2772BDB1989AD3-806F
    Address 56: Radio
       Part No SW: 8R1 035 664 F    HW: 8R1 035 664 D
       Component: H-BN-NA       H41 0812
       Revision: --------    Serial number: 203EN0EB004260
       Coding: 1A020006020581EF5502AB4E00000403F40000020000000000
       VCID: 3979387EB0B79382DA-806D
       Subsystem 1 - Part No: 8R0 060 884 CA
       Component: NAR 2014  1002
       Component: DU7 High  H42 0104
       Serial number: A130EK0E3045162
       Serial number: 00000001881584
       Component: CD-Database  5950
       Component: TSG HL        H01 0510
       Revision:             Serial number: 0000104834410
       Coding: 010C13204000240004
       VCID: 46834382F149EC7AA7-8013
    Address 69: Trailer (J345)       Labels:. 8K0-907-383.clb
       Part No SW: 8K0 907 383 E    HW: 8K0 907 383 E
       Revision: 1A001001    Serial number: 00000154649466
       Coding: 0200000000000000
       Shop #: WSC 94754 999 999999
       Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
       Revision: --H09---    Serial number: 525PA8-J44A1MY
       Coding: 1030010
       VCID: 3467094A57D56EEA09-8061
       Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
       Component: J605  Master  H53 0330
       Revision: --------    Serial number: 8R0827851D
       VCID: 3D712C6EA49FAFA2F6-8069
       Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
       Component: J756  Slave  H53 0330
       Serial number: 8R0827852D
       Component: TSG HR        H01 0510
       Revision:             Serial number: 0000104346764
       Part No SW: 8R0 907 159 A    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H06 0001
       Serial number: 140506200085
    End-------------------------(Elapsed Time: 05:47)--------------------------
    Yeah, there's quite a few other modules that would need to have coding adjusted if you removed the trailer module. If you really want to go there, start by physically removing the trailer module and then un-checking it in the Gateway's [Installation List] function. Then let's see what starts to complain.
    However... Do you really want the module? I think the hitch itself can be removed while leaving the module in place and none of the other modules will be any the wiser.
    Mar 2019
    Canada
    Ok, I removed the module physically and from the gateway.
    I then had fault in the following modules.
    01-Engine
    03-ABS Brakes
    09-Cent. Elect.
    3C-Lane Change
    5F-Information Electr.
    6C-Back-up Cam.
    I could fix all the malfunctions (by removing the hitch/trailer option) except for 5F-Information Electr. in which I could not find anything related to trailer/hitch. Any idea how to fix this fault?
    I also tried to reboot the MMI.
                    Address 5F: Information Electr.       Labels: 4E0-035-6xx-5F.clb
    Control Module Part Number: 8R1 035 664 F    HW: 8R1 035 664 D
      Component and/or Version: H-BN-NA       H41 0812
               Software Coding: 1A020006020581EF5502AB4E00000403F40000020000000000
                Work Shop Code: WSC 05372 002 1048576
    03278 - Functionality Limited due to Missing Messages
                        Reset counter: 61
                        Mileage: 58598 km
                        Date: 2019.03.25
                        Time: 15:22:28
                        Bin. Bits: 00000000 00000000
                        Bin. Bits: 00000000 00000100
  7. Likes Dana liked this post
    These Codings should be without trailer.
    Explanation
    [Controller number] > New coding
    [01] > 2A2A0034052600060000
    [03] > 30150801
    [09] > 26008097863CAFE0010048C300003D0D0F9CC708A2090221000008004400010200040034000000
    [3C] > 010211
    [5F] > 1A020006020581EF55028B4E00000403F40000020000000000
    [6C] > 1020010
  9. Likes Dana, Uwe liked this post
  10. #7
    Mar 2019
    Canada
    Explanation
    [03] > 30150801
    [3C] > 010211
    [6C] > 1020010
    No more fault!!!
    Thanks a lot for this!
  11. Likes Uwe, Dana liked this post
  12. #8
    jezzb's posts in this thread have been split into their own thread here:
    https://forums.ross-tech.com/showthread.php?22532
