Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Coding for 2014-2017 (preferably 2015) Audi A8 L with night vision and no ACC
    Jan 2019
    Adaptations to enable night vision in menus
    I retrofitted my 2015 A8 with night vision. It works, but I am still missing some menu entries in Driver Assist section. I understand I need to enable the following parameters in modules 5F (or perhaps 84) adaptations. Problem is, I don't know the channel numbers, and for A8 they don't show up in the VCDS drop-down.
    If you have A6 or C7 with NIght Vision, could you post the channel numbers you have in 5F or 84 for the following? I believe they are listed, for C7 at least, in VCDS.
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision activated
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high activated
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18 activated
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus Terminal 15
  2. #12
    Jan 2019
    BTW, there may be user error on my part in terms of accessing the adaptation channels. I used channel mapping application in VCDS and mapped adaptation channels for 5F and 84, but my map looks nothing like the above. None of the channels have labels like "ENG122229...", they just have numbers. Am I looking in the wrong place?
  3. #13
    What version of VCDS are you using?
    Have you tried the latest 18.9.1 or even the beta 19.2.1?
  4. #14
    Jan 2019
    I just tried 19.2.1. Same story. I can access all adaptation channels but there are no descriptions for them (or almost none).
    Can anyone post channel maps for A6 C7 or for Q7, with night vision?
  5. #15
    Jan 2019
    Post 2014 A8 with night vision will be even better!
  6. #16
    Jan 2019
    Security code for Night Vision Module
    Does anyone have the code? Car is 2015 A8L, but any code will be appreciated.
  7. #17
    Threads merged. Please refrain from opening new threads for involving this retrofit when there is already an existing thread.
  8. #18
    Jan 2019
    Still looking for the security code for the NV module. Anyone has it?
