Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: No Haldex function
    Nov 2015
    No Haldex function
    I have a 2016 Yeti 4x4 which has no rear wheel drive at all. The Haldex doesn't engage, just front wheel spinning and traction control lights flash when it should be active. It's a Gen 5 Haldex, so no filter to block.
    There are no fault codes relevant to the Haldex unit, the pump is functional and clean, been bench tested with a battery pack and spins freely, I've exchanged the pump for a new one just to prove a point and situation remains the same.
    I've logged pump voltage, PWM, amps with vcds on a launch on gravel and there's no voltage increase at the pump when the front wheels spin, all I get is maximum voltage of about 3v DC which cleary isn't enough to activate the clutch pack. I also have a Tiguan (same year, same engine, same Haldex unit, part numbers, software etc.) and doing a launch on the same gravel surface in this gives a voltage spike to about 8.5v DC and the Haldex kicks in fine.
    It appears as though there's a lack of signal to the Haldex controller that the fronts are losing traction so it never calls for the rear Haldex pump to increase in speed.
    Saturday,23,March,2019,13:09:38:61903
    VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4436.4
    VIN: TMBMD75L2G******   License Plate: ******
    Mileage: 98050km-60925mi   Repair Order:
    Chassis Type: 5L-SK35 (7N0)
    Scan: 01 03 05 08 09 10 15 16 17 19 22 25 2B 42 44 46 52 55 5F 61
              62 72
    VIN: TMBMD75L2G6******  Mileage: 98050km-60925miles
    Address 01: Engine (J623-CUUB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 J    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1186
       Revision: 8AH20---
       Coding: 01190012042701091000
       Shop #: WSC 33361 790 00999
       ASAM Dataset: EV_ECM20TDI01104L906016J 001003
       ROD: EV_ECM20TDI01104L906016F_001.rod
       VCID: 303A1AB3CAAC4F772ED-8064
       Part No SW: 1K0 907 379 CB    HW: 1K0 907 379 CB
       Component: ESP MK60EC1   H46 0174
       Revision: 00H46001
       Coding: 933F400E09240103C90E02EB9020809AA1000021
       VCID: 74B2D6A37EB433578A5-8020
       Revision: 00092000    Serial number: 0370993080
       Coding: 030C0C
       VCID: 372821AF2FC2984F6F7-8062
       Part No SW: 3T0 907 044 CJ    HW: 3T0 907 044 CJ
       Component: Climatronic   H19 0709
       Revision: 00001009
       Coding: 0010000003
       VCID: 7CA2FE8356647B17C25-8028
       Part No SW: 1K0 937 087 AR    HW: 1K0 937 087 AR
       Component: BCM PQ35  H   112 0903
       Revision: AC112903
       Coding: 4E000ABCE01BF1C0440800C0110089E44B7100AE666D87F08081C704A041
       Shop #: WSC 73430 790 00063
       VCID: 015C8F77310616FF913-8054
       Subsystem 1 - Part No: 5L2 955 119 B  Labels: 1KX-955-119.CLB
       Component: SK356  26  0610
       Coding: 00F7B5
       Component: RLS 150915 05  54  0403
       Coding: 062BED
    Address 10: Park/Steer Assist (J446)       Labels:| 5J0-919-475.clb
       Part No SW: 5J0 919 475 C    HW: 5J0 919 475 A
       Component: PARKHILFE 4K  H11 0011
       Revision: --H11---    Serial number: 32961525500848
       Coding: 108007
       ASAM Dataset: EV_EPHVA14SKxxx0000 002001
       ROD: EV_EPHVA14SKxxx0000_002.rod
       VCID: 35342BA735CE6A5F7DB-8060
       Part No SW: 5C0 959 655 B    HW: 5C0 959 655 B
       Component: AirbagVW10    014 0613
       Serial number: 003G5RAV523G
       Coding: 00004E42
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 313C1FB7C1A6467F213-8064
       Serial number: 3572MSME65011E53ZZZS
       Serial number: 3582MSME4F642C54ZZZ3
       Serial number: 3516KSME2C064939ZZZY
       Serial number: 3526KSME6A094939ZZZ/
       Part No SW: 5K0 953 521 DT    HW: 5K0 953 569 AH
       Component: LENKS.MODUL   016 0162
       Revision: FF010042    Serial number: 20150904300396
       Coding: 1002140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 015C8F77318616FF913-8054
       Subsystem 1 - Part No SW: 5E0 919 719 L    HW: 5E0 919 719 L
       Component: E221__MFL-PR6  H02 0150
       Serial number: 000000000B0968110915
       Coding: 820000
       Part No SW: 5L0 920 940 T    HW: 5L0 920 940 T
       Component: KOMBI         H03 1007
       Coding: 420E210100
       ROD: EV_Kombi_UDS_VDD_RM09_005_SK26.rod
       VCID: 3D2433870DFEB21FB5B-8068
       Part No SW: 7N0 907 530 BE    HW: 7N0 907 530 AL
       Component: J533  Gateway H58 1673
       Revision:   H58       Serial number: 170915F1003184
       Coding: 356323
       Shop #: WSC 30504 002 1048576
       Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
       Component: Haldex4Motion H52 7531
       Serial number: HA1-00029.07.15
       Coding: 0301
       Shop #: WSC 73430 790 00999
       VCID: 52FE703BA4605D67789-8006
       Component: IMMO          H03 1007
       Coding: 000007
       VCID: 6A8EC8DB2CF0F5A7209-803E
       Revision: 00000000    Serial number: 15000193421008
       Coding: 4100000000000000
       ROD: EV_ELVMarquMPVW36X.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 7N0-959-793.clb
       Part No SW: 7N0 959 793 J    HW: 7N0 959 793 G
       Component: TSG FA        H04 0561
       Revision:             Serial number: 0000165582676
       Coding: 01150220D001231003
       VCID: 49CC575749B61EBF093-801C
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 70     3501
       Revision: 00H22000
       VCID: 392C279715568E3F993-806C
    Address 52: Door Elect, Pass. (J387)       Labels:. 7N0-959-792.clb
       Part No SW: 7N0 959 792 J    HW: 7N0 959 792 G
       Component: TSG BF        H04 0561
       Revision:             Serial number: 0000167133767
       Coding: 01150020D001231003
       VCID: 48CA525352BCE7B716D-801C
    Address 55: Headlight Range
    Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
       Part No SW: 5L0 035 200 C    HW: 5L0 035 200 C
       Component: MU-S-D-ER     H22 0245
       Serial number: SKZAZ2R8856584
       Coding: 03130600FF00000011111201008800002F0000C60120810000
       ROD: EV_MUStd4CTSAT_SK35.rod
       VCID: 1E66D40BA038C9078C1-804A
       Part No SW: 7N0 907 534     HW: 7N0 907 530 AL
       Component: Batt.regelung H58 1673
       Coding: 030F1873
       VCID: 71BCDFB701A6067F613-8024
       Component: J367-BDM  H07 0180
       Serial number: 42251412211491655569
    Address 62: Door, Rear Left (J388)       Labels:. 7N0-959-795.clb
       Part No SW: 7N0 959 795 F    HW: 7N0 959 795 E
       Component: TSG HL        H04 0561
       Revision:             Serial number: 0000166784151
       Coding: 010000200001531004
       VCID: 47C8516F5FA2E8CF1F7-8012
    Address 72: Door, Rear Right (J389)       Labels:. 7N0-959-795.clb
       Component: TSG HR        H04 0561
       Revision:             Serial number: 0000166784145
    End----(Elapsed Time: 01:35, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    I also have graphs of Voltage, Amps, PWM of both vehicle launches for comparison, but the forum won't allow me to show them as embedded pics, so they're here
    Tiguan launch...
    http://www.viking-heating.co.uk/dama...n%20launch.jpg
    Yeti launch...
    http://www.viking-heating.co.uk/dama...i%20launch.jpg
    Any ideas where this would be faulting?
    Cheers.
    planet earth
    Strange fault. Did this car had an accident and was repaired before?
    Can you may copy here the Tiguan autoscan? Does it have the same AWD software version?
    There is a software update available for the AWD ecu.
    Nov 2015
    Yep, scan log from the Tiguan just now (ignore the Hvac fault).
    Sunday,24,March,2019,10:05:15:61903
    VIN: WVGZZZ5NZGW******   License Plate: *******
    Mileage: 61270km-38071mi   Repair Order:
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 03 05 08 09 10 15 16 17 19 22 25 2B 42 44 46 4C 52 53 55
              5F 61 62 69 72 A5
    VIN: WVGZZZ5NZG******   Mileage: 61270km-38071miles
    Address 01: Engine (J623-CUVC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 CM    HW: 04L 907 309 K
       Component: R4 2,0L EDC   H20 1842
       Revision: 8AH20---
       Coding: 01190032043701083000
       ASAM Dataset: EV_ECM20TDI01104L906016CM 001004
       ROD: EV_ECM20TDI01104L906016BJ_001.rod
       VCID: 76B6ECAB68482147B41-8022
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 BN    HW: 5N0 614 109 BN
       Component: J104   C6 450M VDF2 0021
       Revision: --H07---    Serial number: 00000008995242
       Coding: 0040254
       VCID: 78AAE2936EDC5737A6D-802C
       Revision: 00092000    Serial number: 0376241579
       Coding: 030C0C
       ROD: EV_KESSYPQ35G_A02_VW36.rod
       Part No SW: 1K8 907 044 AC    HW: 1K8 907 044 AC
       Component: Climatronic   H05 0304
       Revision: 00001K03
       Coding: 001000C003
       VCID: 70BADAB30A2C0F776ED-8024
    9479185 - Signal Line for Air Quality Sensor
              B10A4 11 [008] - Short to Ground
                        Reset counter: 254
                        Mileage: 60823 km
                        Date: 2019.03.06
                        Time: 06:30:02
    9479189 - Signal Line for Air Quality Sensor
              B10A4 15 [008] - Open or Short to Plus
                        Reset counter: 253
                        Mileage: 60816 km
                        Date: 2019.03.06
                        Time: 06:21:27
       Part No SW: 5K0 937 086 T    HW: 5K0 937 086 T
       Component: BCM PQ35 M    122 0183
       Revision: BC122001
       Coding: 4E180A3F8817E1C0408A00C8340089644AD5AB08676D85B0E4848700A041
       VCID: 45D45B6765AEFADFEDB-8010
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 14091  013 0204
       Serial number: N2955119   °204!
       Coding: 009795
       Component: RLS 280915 05  54  0403
       Coding: 02304D
       Subsystem 3 - Part No: 5C0 951 171
       Component: Sensor, DWA 0  005 0502
       Part No SW: 1K8 919 475 B    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0479
       Revision: --------    Serial number: 39431526401714
       Coding: 0131060141
       ASAM Dataset: EV_EPHVA2CVW364GP00 001010
       ROD: EV_EPHVA2CVW364GP00_VW36.rod
       VCID: 392C279719D68E3F993-806C
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__20E VW10 HI   3018
       Revision: 32022000    Serial number: 003L7PKE8TNL
       Coding: 0012357
       VCID: 7CA2FE835AE47B17C25-8028
       Subsystem 1 - Serial number: 6332MTS648222245
       Subsystem 2 - Serial number: 6342MTS623872365
       Subsystem 3 - Serial number: 6351HTS6MU2USDKR
       Subsystem 4 - Serial number: 6361HTS6PR9USDKJ
       Part No SW: 5K0 953 521 GP    HW: 5K0 953 569 BG
       Component: LENKS.MODUL   018 0230
       Revision: FF010042    Serial number: 20150914300830
       Coding: 300A240000
       ROD: EV_SMLSNGVOLWSR8C.rod
       VCID: 005A8A733A8C1FF79ED-8054
       Component: E221__MFL-TAS  H31 0037
       Serial number: 0885854
       Coding: 820000
       Part No SW: 5N0 920 983 K    HW: 5N0 920 983 K
       Component: KOMBI         H04 1008
       Coding: 111F210000
       Part No SW: 7N0 907 530 BG    HW: 7N0 907 530 AN
       Component: J533  Gateway H56 1674
       Revision:   H56       Serial number: 060915F1002954
       Coding: 356033
       Shop #: WSC 14488 002 1048576
       VCID: 76B6ECAB68C82147B41-8022
       Serial number: HA1-00025.08.15
       Coding: 0001
       Component: IMMO          H04 1008
       Coding: 000007
       Revision: 00000000    Serial number: 15000210474007
       Part No SW: 5N0 959 701 G    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0504
       Revision: 12110009    Serial number: 0010044445
       Coding: 0212BE
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  010 1505
       Serial number: 00000009548862
       Coding: 000090
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 202    3501
       Revision: 00H22000
       Shop #: WSC 01324 785 00200
       VCID: 40DA4A73768CDFF7DED-8014
       Part No SW: 5N0 959 702 G    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0504
       Revision: 14110009    Serial number: 0010046266
       Coding: 0212BE
       VCID: 3A2E389B1CD08527909-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  010 1505
       Serial number: 00000009569209
       Coding: 000090
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H19       Serial number: 00000000858501
       Coding: 0026167
       VCID: 382A22932E5C973766D-806C
       Component: AFS-ECU       H05 0111
       Coding: 049E00000B000200
       ROD: EV_HeadlRegulVWAFSPt_VW32.rod
       Subsystem 1 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Subsystem 2 - Part No: 5N0 941 329   Labels: 3D0-941-329.CLB
       Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
       Component: MU-S-ND-ER    H22 0245
       Serial number: VWZAZ2R8841613
       Coding: 02130601FF00000011111101008808001F0106C600200100CF
       ROD: EV_MUStd4CTSAT_VW36.rod
       VCID: 211CEFF79146F6FFB13-8074
       Subsystem 1 - Part No SW: 5NA 919 866 H    HW: -----------
       Component: ECE1 2019/20  --- 1115
       Component: Batt.regelung H56 1674
       Coding: 330F1873
       Serial number: 42253040211491656318
       Part No SW: 1K0 907 383 G    HW: 1K0 907 383 G
       Component: Anhaenger     H12 0110
       Revision: 3B001001    Serial number: 00000377468478
       Coding: 410D000101000000
       VCID: 313C1FB7C126467F213-8064
       Part No SW: 3Q0 980 654 C    HW: 3Q0 980 654
       Component: MQB_B_MFK     H04 0023
       Serial number: 16091511K21100
       Coding: 000301060000040100021341C080400080000E100020
    End----------(Elapsed Time: 01:42, VBatt start/end: 12.0V/12.1V)-----------
    Nov 2015
    As far as I'm aware the car has not been accident damaged. It's clear on the HPI report at least.
    Quote Originally Posted by Viking View Post
    That's all via the powertrain CAN, and there's really only two places were it could come from, the ECU and/or the ABS.
    Both ECUs are coded for AWD, which is as it should be.
    However, I'm not sure about the MK60EC1 ABS in Yeti. Someone with better knowledge of that coding scheme than I have might check that for you, but I doubt it's there either, since I'd expect some sort of coding mismatch DTCs if the ABS didn't match the ECU.
    In the end, I'm not keen on the theory that the Hadlex isn't being told to do its job.
    Nov 2015
    So that would put it into the territory of the Haldex controller not doing as it's supposed to?
    planet earth
    I would say from your log pictures, the yeti also tries to engaging, only the signal amplitude is lower. So it's receiving the necessary data from the can network. It's unlikely the controller is bad, or anything coding related.
    I'm not familiar with these latest AWD system's,but it's possible the controller feedbacking from the wheel speed signals, what's happening while engaging rear drive, so if nothing happens, doesn't increase the engaging pressure.
    I heard some nasty things from late haldex units, which they had to replace under warranty with very low mileage. I don't know with what symptons, but they was internal mechanically damaged.
  9. #8
    Nov 2015
    Most Haldex failures have been due to there being no filter on the Gen 5 Hadex units I think. The pump clogs up rather than the filter, pump burns out, and so on.
    As regards the Haldex not getting feedback, it never gets enough voltage to engage the pump to lock the clutch pack so unlikely to be a feedback problem I think.
  10. #9
    planet earth
    Did you checked the power and ground on the haldex ecu connector? I mean the gnd wire resistant to chassis, power wire preferably under load.
    What the voltage , amperage, and pwm is measured at these channel you showing? Is it the pump current and voltage?
  11. #10
    Nov 2015
    Quote Originally Posted by Aitrui View Post
    Yes, those readings are all pump related.
    I've not checked any wires to the controller, they'reall as factory at the moment so sheathed.
