So this is a scan from my Polo Beats 2017 1.0 Mpi :
Friday,22,March,2019,15:01:15:29555
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4437.4
VIN: WVWZZZ6RZHY026648 License Plate:
Mileage: 34825km-21639mi Repair Order:
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 47 5F
VIN: WVWZZZ6RZHY026648 Mileage: 34825km-21639miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 AB HW: 04E 907 309 CB
Component: R3 1.0l MPI H20 2496
Revision: 33H20000
Coding: 01110032022401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM10MPI01104C906057AB 001002
ROD: EV_ECM10MPI01104C906057AB.rod
VCID: 6596445665E6F11F0DB-8030
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 N HW: 6R0 907 379 BA
Component: ESP9.0i H04 0005
Serial number: 08500081160603
Coding: 23DD2485492533C6091A106D0059C42492CC90080005CBF98F00
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: 3A2CC72ABCD8AEE7909-806E
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 E HW: 6C0 820 045 E
Component: AC Manuell H03 0203
Serial number: 1605311B-0871
Coding: 200100001100100000
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 211E1046314EDD3FB13-8074
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0093
Serial number: 006238046367
Coding: 0300084042530A7B4F844000402703C800005B0253010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 313EE00661AE6DBF213-8064
Subsystem 1 - Part No SW: 5Q0 955 559 B HW: 5Q0 955 559 B Labels: 5Q0-955-547.CLB
Component: RLS 042 0105
Serial number: S2Y16M06D13H01M25S49
Coding: 0038DD
Drivers Door Control Module:
Subsystem 2 - Part No SW: 6R0 959 802 DM HW: 6R0 959 802 DM Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 003 0610
Serial number: KU0KU002051661237247
Coding: 1400A1
Subsystem 3 - Part No SW: 6R0 959 801 DK HW: 6R0 959 801 DK Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 003 0610
Serial number: KU0KU003051661240066
Coding: 0400A1
Subsystem 4 - Part No SW: 6R0 959 812 AA HW: 6R0 959 812 AA
Component: J389__TSG_HR 003 0610
Serial number: KU0KU010061661626049
Coding: 1400A0
Subsystem 5 - Part No SW: 6R0 959 811 AA HW: 6R0 959 811 AA
Component: J388__TSG_HL 003 0610
Serial number: KU0KU011061661634756
Coding: 0400A0
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331616502046
Coding: 0031151001
ROD: EV_EPHVA18AU3700000_VW26.rod
VCID: 43D2BACECB12EF2FC3F-8016
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 08061603214364
Coding: 00000000FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag00Q 002 0380
Revision: -------- Serial number: 003TH007XNP8
Coding: 88C0C000000000005C0000CA008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
Subsystem 1 - Part No SW: ----------- HW: 410 823 005 16
Component: SideSensor_Df 151 0800
Serial number: 3575H009D2101ED120FM
Subsystem 2 - Part No SW: ----------- HW: 410 823 005 16
Component: SideSensor_Pf 151 0800
Serial number: 3585H00AB2101ED2D11L
Subsystem 3 - Part No SW: ----------- HW: 442 152 605 16
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00A51E344453395
Subsystem 4 - Part No SW: ----------- HW: 442 152 505 16
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C12060D75E37B
Part No SW: 6C0 920 740 E HW: 6C0 920 740 E
Component: KOMBI 202 2310
Coding: 272D09002180000801883E011800000000000000
VCID: 241019522E5CC817DA5-8070
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 165
Mileage: 34535 km
Date: 2019.03.15
Time: 06:43:56
9456681 - Key
B104C 29 [008] - Implausible Signal
Mileage: 34804 km
Date: 2019.03.20
Time: 13:33:50
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0093
Revision: -------- Serial number: 006238046367
Coding: 030100046F0A640071000000000000010001010000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2614035A58603A07C41-8072
Subsystem 1 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 1531611045001220AD1B
Coding: 280000
Subsystem 2 - Part No SW: 6C0 915 181 B HW: 6C0 915 181 B
Component: J367-BDM H08 0270
Serial number: 53160F41405881211334
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 323 3232
Serial number: CG661488
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6E843B7AB01032477C1-803A
Address 47: Sound System (J525) Labels:* None
Part No SW: 5Q6 035 456 HW: 5Q6 035 456
Component: KonzernAmp 8K H01 2426
Revision: -------- Serial number: A1117A00000637
Coding: 0262000000AAAA00000000000000
ASAM Dataset: EV_AMPCAN8C1PASE 001015
ROD: EV_AMPCAN8C1PASE_VW26.rod
VCID: 73B22A0EDB321FAF93F-8026
Part No SW: 3Q0 035 824 B HW: 3Q0 035 824 B
Component: MU-S--ER H30 0367
Serial number: VWZAZ2S0301324
Coding: 02620000AA00000051110003000808001F0210D60120010003
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 2C00F172468C0057125-8078
Subsystem 1 - Part No SW: 6C0 919 603 B HW: 6C0 919 603 B
Component: ABTm_Std2 H53 1031
Serial number: VWZ8Z9SKW00Y3K
End----------(Elapsed Time: 00:57, VBatt start/end: 12.0V/12.0V)-----------
Friday,22,March,2019,15:05:58:29555
Revision: 33H20000
Readiness: 1110 0001
Coding: 0038DD
Coding: 1400A1
Coding: 0400A1
Coding: 1400A0
Coding: 0400A0
Coding: 0031151001
Coding: 280000
Coding: 000700
End----------(Elapsed Time: 00:54, VBatt start/end: 12.0V/12.0V)-----------
