I have a 2019 S3 and I've been trying to implement the Single Gear Display.
All of the mods say to change the adaptation in the auto trans (module 2), however I only have 3 Adaptations for this module. None of which come close to changing the gear display. After dumping admap and blockmap for that module, I was able to find this in the blockmap
IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged
I'm familiar with the old HEX/CAN protocol but now using USD things have changed and i'm lost.
In the blockmap, I found the adaptation I want to change, but it was missing from the adaptation drop down.
1) Is is possible to make a custom label file based off of the information in a blockmap file?
2) If so, how do you figure out what the channel information is? Can it be derived from the identifier (IDE02736-ENG100252)
From the information I've been reading, it looks like we (end users) can't make custom labels using this new format.
Which really sucks because we can't send our custom files to you and have to rely on you to add them.
Thursday,21,March,2019,15:02:06:13348
VCDS Version: 19.1.2.0 (x64) HEX-NET CB: 0.4502.4
Data version: 20190131 DS301.0
Chassis Type: FF-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
4B 52 5F 6C A5 A9 BB BC CF D6 D7
Address 01: Engine (J623-DLRA) Labels: None
Part No SW: 8V0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0002
Revision: --H13---
Coding: 0A2500322466010E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
ROD: EV_ECM20TFS0208V0906259Q.rod
VCID: CED0E73291E38139F1-809A
Readiness: 1110 0101
Part No SW: 0GC 300 014 B HW: 0GC 927 711 H
Component: GSG DQ381 H06 2405
Revision: 00H06V07
ROD: EV_TCMDQ381061_AU37.rod
VCID: A404659AAFEF5B6977-80F0
Part No SW: 8V0 614 517 D HW: 8V0 614 517 C
Component: ESC H25 0640
Revision: 00000000 Serial number: 63478000000638
Coding: 31AA6B7D549B23AB89960B6B4099698CD62AC491D0029676184150D482A8420000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
VCID: BA38BBE23D6B3D993D-80EE
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 0503083488
Coding: 030C0C1720
ROD: EV_KessyHellaMQBAB.rod
VCID: C3C6C6064AA17C516E-8096
Part No SW: 8V0 820 043 AF HW: 8V0 820 043 AF
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001728420
Coding: 03000014010000001000000000001400
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: F6A06FD249F399F919-80A2
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 6B90D46900PAG0MUFU03
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 00001835300289
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019.rod
VCID: 8B562E262271F41156-80DE
Subsystem 1 - Part No SW: 8V1 955 119 C HW: 8V1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS371 181124 043 0585
Serial number: 181206000637
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21755654X81A955547A0
Coding: 00006C
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 09 10 2018 20001876
Serial number: 00000000000046091300
Sun Roof:
Component: J245 PS73.404 H04 0005
Serial number: 0000FST0027Z0W400000
Coding: 101F00
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 CQ HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000020121820240419
Part No SW: 5QA 919 298 D HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0050
Serial number: 000308417318272
Coding: 0270167851
ASAM Dataset: EV_EPHVA2CAU3700000 009041
ROD: EV_EPHVA2CAU3700000_009_AU37.rod
VCID: D1EAFC4E80DD9EC1EC-8084
Part No SW: 5Q0 907 572 P HW: 5Q0 907 572 J
Coding: B51887E19DFFCC247498815580302600000000000000000004
VCID: C4C4C51A4FAF7B6957-8090
1076 - Databus
[FAULT_TIMEOUT_GRA_ACC_01]
Reset counter: 80
Mileage: 1963 km
Date: 2019.03.21
Time: 14:52:09
Control Module temperature: 42 °C
Voltage terminal 15: 11.3 V
Address 14: Susp. Elect. (J250) Labels: 8V0-907-376.clb
Part No SW: 8V0 907 376 H HW: 8V0 907 376 F
Component: DAEMPFUNGS-SG H11 0083
Serial number: 181018002
ASAM Dataset: EV_AudiMagneRide 003007
ROD: EV_AudiMagneRide_003.rod
VCID: C6C0DF127993497949-8092
Serial number: 003GCR0AY21J
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: C7DED2167E995071B2-8092
Belt Pretensioner left:
Serial number: 34230167A09011920501
Coding: 333135
Belt Pretensioner right:
Serial number: 34230168A03011920123
Coding: 333135
Occupant Detection:
Serial number: 694000000000001SMYT4
Coding: 303439
Subsystem 4 - Part No SW: ----------- HW: 480 000 401 19
Serial number: 35700000000DFC0DD533
Subsystem 5 - Part No SW: ----------- HW: 480 000 401 19
Serial number: 3580000000069028E53K
Subsystem 6 - Part No SW: ----------- HW: 480 401 912 18
Component: SideSensor_Dr 004 6149
Serial number: 35100012E2B76D01C4B7
Subsystem 7 - Part No SW: ----------- HW: 480 401 912 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001AF2E1DC52971G
Subsystem 8 - Part No SW: ----------- HW: 480 401 412 18
Component: FrontSensor_D 004 6149
Serial number: 35500010C2B7F1C39123
Front Sensor Passenger:
Subsystem 9 - Part No SW: ----------- HW: 480 401 412 18
Component: FrontSensor_P 004 6149
Serial number: 35600010C2B7F1C3A608
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI2
Part No SW: 8V0 920 890 B HW: 8V0 920 890 B
Component: FBenUSA H19 0108
Coding: 00EF18537F9CCF050281FE001800401000000000
ASAM Dataset: EV_DashBoardFPKAU37X 001032
VCID: BC34BDFA375F03A92F-FFFE
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 03121810804856
Coding: 030100043F085A005B00807EB80B00000001010000000000000000000000
ROD: EV_GatewNF.rod
VCID: EE9047B231A3A139D1-80BA
Component: 0-01-0d-01-04
Subsystem 2 - Part No SW: 8W0 951 523 F HW: 8W0 951 523 F
Component: J453 MFL H04 0004
Serial number: 20181218080606 21209
Component: J367-BDMConti H03 1051
Serial number: 7588600391181211015D
Part No SW: 0CQ 907 554 K HW: 0CQ 525 130
Component: Haldex4Motion H55 7762
Serial number: HA1-00014.11.18
Coding: 0001
VCID: CDD2E03E9CE5BA2188-8098
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
VCID: C2C8C30255BB755965-8096
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 18000407845016
Coding: 0800000000000000
ROD: EV_ELVMarqMQBA0_VW37.rod
VCID: B12A9CCEE01DFEC18C-80E4
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 H HW: 3Q0 907 566
Component: MRR1Rear H23 0630
Revision: --------
Coding: 04C002
VCID: BD32B0FE2C450AA118-80E8
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RLB15339
Coding: 005E1B205000008000000002
ROD: EV_DCU2DriveSideMAXHCONT.rod
Part No SW: 3Q0 909 144 M HW: 3Q0 909 144 L
Component: EPS_MQB_ZFLS 507 5082
Coding: 931F0000
ROD: EV_SteerAssisMQB_015.rod
VCID: BC34BDFA375F03A92F-80E8
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 466 B HW: 81A 035 466
Component: MIB2_amp_P_A3 H10 0440
Revision: 00000001 Serial number: AUZ8ZAJ5F021J2J
Coding: 0173030000AAAA2AAA0000010000
ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
ROD: EV_AMPMst16C9Gen2ALPI.rod
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0345
Serial number: 20121811601682
Coding: 000000050900147206113300040000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002006
ROD: EV_MultiModulContiVW48X_002_VW41.rod
VCID: B522A8DE1475D2E1D0-80E0
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RJP15829
Coding: 005E13205C00008000000002
ROD: EV_DCU2PasseSideMAXHCONT.rod
Part No SW: 8V1 035 880 C HW: 8V1 035 880 C
Component: MU-P-LNS-US 055 1363
Serial number: A702A0KS014566
Coding: 017351020000000011220002049A00332F0027E401700108FE
Subsystem 1 - Part No SW: V03 959 802 DL HW: -----------
Component: NAR 2019 --- 0069
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0FH8L
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BT HW: 8V0 919 614 BT
Component: ControlUnit_H H85 0858
Serial number: ALJAL118101800050588
Component: Gracenote2 --- 3013
Component: RVC Compact H15 0231
Coding: 0273010102002001400040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
VCID: B93AA4EE386D368134-80EC
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H09 0610
Serial number: 15111815K23709
Coding: 040307010000020101222346C14F890092000E20012000
ROD: EV_MFKBoschMQBB.rod
VCID: C0CCC90A5BB7674973-8094
Part No SW: 8V0 907 159 A HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 181103201411
VCID: BE30B7F2214311B901-80EA
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0187
Serial number: YE007RJU16282
Coding: 000E13204000008000000002
ROD: EV_DCU2RearDriveMAXHCONT.rod
Component: TSG HBFS003 0187
Serial number: YE007RJU16288
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 H HW: 3Q0 907 590
Revision: --------
Coding: 04C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 977E42566EB900F1E2-80C2
Component: LED1R H09 0008
End(Elapsed Time: 18:50, VBatt start/end: 11.5V/11.3V. VIgn 11.3V, Deb=2)--
