Results 1 to 6 of 6
Thread: Adpmap blockmap uds oh my
    Mar 2019
    I have a 2019 S3 and I've been trying to implement the Single Gear Display.
    All of the mods say to change the adaptation in the auto trans (module 2), however I only have 3 Adaptations for this module. None of which come close to changing the gear display. After dumping admap and blockmap for that module, I was able to find this in the blockmap
    IDE02736-ENG100252,Display of gear in instrument panel-Display Driving Gear,no gear engaged
    I'm familiar with the old HEX/CAN protocol but now using USD things have changed and i'm lost.
    In the blockmap, I found the adaptation I want to change, but it was missing from the adaptation drop down.
    1) Is is possible to make a custom label file based off of the information in a blockmap file?
    2) If so, how do you figure out what the channel information is? Can it be derived from the identifier (IDE02736-ENG100252)
    From the information I've been reading, it looks like we (end users) can't make custom labels using this new format.
    Which really sucks because we can't send our custom files to you and have to rely on you to add them.
    Thursday,21,March,2019,15:02:06:13348
    VCDS Version: 19.1.2.0 (x64)  HEX-NET CB: 0.4502.4
    Data version: 20190131 DS301.0
    Chassis Type: FF-AU37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47
              4B 52 5F 6C A5 A9 BB BC CF D6 D7
    Address 01: Engine (J623-DLRA)       Labels: None
       Part No SW: 8V0 906 259 Q    HW: 06K 907 425 J
       Component: R4 2.0l TFSI  H13 0002
       Revision: --H13---
       Coding: 0A2500322466010E3004
       Shop #: WSC 06385 790 00016
       ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
       ROD: EV_ECM20TFS0208V0906259Q.rod
       VCID: CED0E73291E38139F1-809A
    Readiness: 1110 0101
       Part No SW: 0GC 300 014 B    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2405
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_AU37.rod
       VCID: A404659AAFEF5B6977-80F0
       Part No SW: 8V0 614 517 D    HW: 8V0 614 517 C
       Component: ESC           H25 0640
       Revision: 00000000    Serial number: 63478000000638
       Coding: 31AA6B7D549B23AB89960B6B4099698CD62AC491D0029676184150D482A8420000000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 037008
       VCID: BA38BBE23D6B3D993D-80EE
       Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
       Component: VWKESSYMQB    037 1204
       Revision: 00037000    Serial number: 0503083488
       Coding: 030C0C1720
       ROD: EV_KessyHellaMQBAB.rod
       VCID: C3C6C6064AA17C516E-8096
       Part No SW: 8V0 820 043 AF    HW: 8V0 820 043 AF
       Component: AC Automat    H03 0150
       Revision: 20003000    Serial number: 00000001728420
       Coding: 03000014010000001000000000001400
       ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
       VCID: F6A06FD249F399F919-80A2
       Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: 6B90D46900PAG0MUFU03
       Part No SW: 5Q0 937 085 BS    HW: 5Q0 937 085 BF
       Component: BCM MQBAB MNA H38 0273
       Serial number: 00001835300289
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019.rod
       VCID: 8B562E262271F41156-80DE
       Component: WWS371 181124  043 0585
       Serial number:         181206000637
       Coding: 0A47F7
       Serial number: 21755654X81A955547A0
       Coding: 00006C
       Light switch:
       Subsystem 3 - Part No SW: 8V0 941 531 AR    HW: 8V0 941 531 AR
       Component: E1 - LDS MQB  H06 0032
       Serial number: 09 10 2018  20001876
       Serial number: 00000000000046091300
       Sun Roof:
       Component: J245 PS73.404  H04 0005
       Serial number: 0000FST0027Z0W400000
       Coding: 101F00
       Steering Column Switch:
       Subsystem 6 - Part No SW: 82A 953 521 CQ    HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0060
       Serial number: 00000020121820240419
       Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
       Component: PLA 3.0 12KH07 0050
       Serial number: 000308417318272
       Coding: 0270167851
       ASAM Dataset: EV_EPHVA2CAU3700000 009041
       ROD: EV_EPHVA2CAU3700000_009_AU37.rod
       VCID: D1EAFC4E80DD9EC1EC-8084
       Part No SW: 5Q0 907 572 P    HW: 5Q0 907 572 J
       Component: ACC BOSCH MQB H11 0682
       Coding: B51887E19DFFCC247498815580302600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: C4C4C51A4FAF7B6957-8090
    1076 - Databus
              [FAULT_TIMEOUT_GRA_ACC_01]
                        Reset counter: 80
                        Mileage: 1963 km
                        Date: 2019.03.21
                        Time: 14:52:09
                        Control Module temperature: 42 °C
                        Voltage terminal 15: 11.3 V
       Part No SW: 8V0 907 376 H    HW: 8V0 907 376 F
       Component: DAEMPFUNGS-SG H11 0083
       Serial number:       181018002
       ASAM Dataset: EV_AudiMagneRide 003007
       ROD: EV_AudiMagneRide_003.rod
       VCID: C6C0DF127993497949-8092
       Serial number: 003GCR0AY21J
       Coding: 9DCCFCC0000000005000001AC24800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: C7DED2167E995071B2-8092
       Belt Pretensioner left:
       Component: BeltPretRevFL  H37 0350
       Serial number: 34230167A09011920501
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H37 0350
       Serial number: 34230168A03011920123
       Coding: 333135
       Occupant Detection:
       Subsystem 3 - Part No SW: 5C6 959 339 B    HW: 5C6 959 339 B
       Serial number: 694000000000001SMYT4
       Coding: 303439
       Subsystem 4 - Part No SW: -----------    HW: 480 000 401 19
       Serial number: 35700000000DFC0DD533
       Subsystem 5 - Part No SW: -----------    HW: 480 000 401 19
       Serial number: 3580000000069028E53K
       Subsystem 6 - Part No SW: -----------    HW: 480 401 912 18
       Component: SideSensor_Dr  004 6149
       Serial number: 35100012E2B76D01C4B7
       Subsystem 7 - Part No SW: -----------    HW: 480 401 912 18
       Component: SideSensor_Pr  003 6149
       Serial number: 3520001AF2E1DC52971G
       Subsystem 8 - Part No SW: -----------    HW: 480 401 412 18
       Component: FrontSensor_D  004 6149
       Serial number: 35500010C2B7F1C39123
       Front Sensor Passenger:
       Subsystem 9 - Part No SW: -----------    HW: 480 401 412 18
       Component: FrontSensor_P  004 6149
       Serial number: 35600010C2B7F1C3A608
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI2
       Part No SW: 8V0 920 890 B    HW: 8V0 920 890 B
       Component: FBenUSA       H19 0108
       Coding: 00EF18537F9CCF050281FE001800401000000000
       ASAM Dataset: EV_DashBoardFPKAU37X 001032
       VCID: BC34BDFA375F03A92F-FFFE
       Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
       Component: GW MQB High   521 5366
       Serial number: 03121810804856
       Coding: 030100043F085A005B00807EB80B00000001010000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: EE9047B231A3A139D1-80BA
       Component: 0-01-0d-01-04
       Subsystem 2 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
       Component: J453 MFL  H04 0004
       Serial number: 20181218080606 21209
       Component: J367-BDMConti  H03 1051
       Serial number: 7588600391181211015D
       Part No SW: 0CQ 907 554 K    HW: 0CQ 525 130
       Component: Haldex4Motion H55 7762
       Serial number: HA1-00014.11.18
       Coding: 0001
       VCID: CDD2E03E9CE5BA2188-8098
    Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
       Part No SW: 8S0 907 397 D    HW: 8S0 907 397 D
       Component: LCM_MQB       H07 0022
       ASAM Dataset: EV_LCMLeftCONTIAU426 001009
       ROD: EV_LCMLeftCONTIAU426_VW41.rod
       VCID: C2C8C30255BB755965-8096
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 18000407845016
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: B12A9CCEE01DFEC18C-80E4
    Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
       ASAM Dataset: EV_LCMRightCONTIAU426 001009
    Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
       Part No SW: 3Q0 907 566 H    HW: 3Q0 907 566
       Component: MRR1Rear      H23 0630
       Revision: --------
       Coding: 04C002
       VCID: BD32B0FE2C450AA118-80E8
       Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
       Component: TSG FS001 0287
       Serial number: YE007RLB15339
       Coding: 005E1B205000008000000002
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
       Component: EPS_MQB_ZFLS  507 5082
       Coding: 931F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: BC34BDFA375F03A92F-80E8
       Part No SW: 81A 035 466 B    HW: 81A 035 466
       Component: MIB2_amp_P_A3 H10 0440
       Revision: 00000001    Serial number: AUZ8ZAJ5F021J2J
       Coding: 0173030000AAAA2AAA0000010000
       ASAM Dataset: EV_AMPMst16C9Gen2ALPI 001002
       ROD: EV_AMPMst16C9Gen2ALPI.rod
       Part No SW: 3Q0 907 338 C    HW: 3Q0 907 338 C
       Component: FCM MQB Low   002 0345
       Serial number: 20121811601682
       Coding: 000000050900147206113300040000000000000000000000000000000000
       ASAM Dataset: EV_MultiModulContiVW48X 002006
       ROD: EV_MultiModulContiVW48X_002_VW41.rod
       VCID: B522A8DE1475D2E1D0-80E0
       Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
       Component: TSG BFS001 0287
       Serial number: YE007RJP15829
       Coding: 005E13205C00008000000002
       ROD: EV_DCU2PasseSideMAXHCONT.rod
       Part No SW: 8V1 035 880 C    HW: 8V1 035 880 C
       Component: MU-P-LNS-US   055 1363
       Serial number: A702A0KS014566
       Coding: 017351020000000011220002049A00332F0027E401700108FE
       Subsystem 1 - Part No SW: V03 959 802 DL    HW: -----------
       Component: NAR 2019  --- 0069
       Component: DU High  H49 0014
       Serial number: AUZ8Z9J1Y0FH8L
       Multimedia Operating Unit:
       Subsystem 3 - Part No SW: 8V0 919 614 BT    HW: 8V0 919 614 BT
       Component: ControlUnit_H  H85 0858
       Serial number: ALJAL118101800050588
       Component: Gracenote2  --- 3013
       Component: RVC Compact   H15 0231
       Coding: 0273010102002001400040
       ROD: EV_CamSysRVRVCPANAMQBAB.rod
       VCID: B93AA4EE386D368134-80EC
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H09 0610
       Serial number: 15111815K23709
       Coding: 040307010000020101222346C14F890092000E20012000
       ASAM Dataset: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB.rod
       VCID: C0CCC90A5BB7674973-8094
       Part No SW: 8V0 907 159 A    HW: 4H0 907 159 A
       Serial number: 181103201411
       VCID: BE30B7F2214311B901-80EA
       Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
       Component: TSG HFS003 0187
       Serial number: YE007RJU16282
       Coding: 000E13204000008000000002
       ROD: EV_DCU2RearDriveMAXHCONT.rod
       Component: TSG HBFS003 0187
       Serial number: YE007RJU16288
       ROD: EV_DCU2RearPasseMAXHCONT.rod
    Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
       Part No SW: 3Q0 907 590 H    HW: 3Q0 907 590
       Revision: --------
       Coding: 04C002
       Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A
       Component: LED1L         H09 0008
       VCID: 977E42566EB900F1E2-80C2
       Component: LED1R         H09 0008
    End(Elapsed Time: 18:50, VBatt start/end: 11.5V/11.3V. VIgn 11.3V, Deb=2)--
    Look at those block maps.
    There's a Measuring Value for it, but no Adaptation Channel.
    Mar 2019
    So this means you can measure it but you can't change it?
    Quote Originally Posted by BoydG View Post
    Seems that way.
    Unfortunately, we don't make the software inside these control modules, nor define the API used to access the data in them.
    Mar 2019
    Seems that way.
    Understood, There was no attitude in that sentence.
    I'm just trying to educate myself on what can and can't be done.
    How do you (ross-tech) find what adaptations are supported by each module?
    I read that with UDS you can't query the module like you can with older protocol.
    We look at what the factory tool supports.
