I'm in the process of retrofitting OEM air suspension to my 07 Q7.
I've got all the wiring done, the module connects and reads properly. I've coded it in with under the CAN gateway, but I need help with the following:
- ABS is throwing codes saying "module coded incorrectly" and there is no coding helper for it.
- I don't have the Air suspension menu in the MMI, and can't get into the "green menu". It's coded and enabled but the two-button trick doesn't work.
- What other modules do I need to code to fully add the air suspension?
I apologize that I don't have the required auto-scan, I borrowed my friend's VCDS and had to return it. I may be able to get it again this weekend, at which point I will scan and post it.
