Results 1 to 6 of 6
Thread: Audi A4 2013 volume currently unavailable
    Mar 2019
    Guatemala
    Hello everyone. First time posting. was wondering if you guys could help me. so here is what happened mmi died and another shop changed it. so mmi started working but no sound. Fuses checked, optical bus diagnostics done and everythig seems OK. Autoscan down below
    thanks for your help
     Thursday,21,March,2019,09:08:26:24100
    VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
    VIN: WAUEFAFL3DA148538   License Plate:
    Chassis Type: FL-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
              72
    VIN: WAUEFAFL3DA148538   Mileage: 65450km-40668miles
    09-Cent. Elect. -- Status: Sporadic communication error 1000
    Address 01: Engine (0-----CAEB)       Labels:. 06H-907-115-CDN.clb
       Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
       Component: 2.0l R4/4V TF H09 0005
       Revision: ECH09---
       Coding: 4A030013242400062000
       Shop #: WSC 04039 001 1048576
       ASAM Dataset: EV_ECM20TFS0118K5907115C 001006
       ROD: EV_ECM20TFS0118K5907115C.rod
       VCID: 3228E235657145DA1B-8066
    Readiness: 1110 0101
       Part No SW: 8K2 927 155 E    HW: 0AW 927 156 K
       Component: 0AW 20TAVSUSA H05 0003
       Revision: --H05---    Serial number: 0000000974
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_TCMVL381 A02431
       ROD: EV_TCMVL381.rod
       VCID: 373ED3218E13A0F22C-8062
       Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
       Component: ESP8 front    H09 0100
       Coding: 081D18
       VCID: 014A7DF998572E42D2-8054
    02214 - Tire Pressure Warning
                000 -  -
                        Reset counter: 41
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 01:35:52
                        Hex Value: 0x0000
                        Hex Value: 0x0702
                        Hex Value: 0x0021
                        Hex Value: 0x1BA9
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
       Component: BCM2 2.0      H11 0621
       Coding: 0D814000000000000000
       Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
       Serial number: 0812000166707014
       Serial number: 2312000222218016
                        Fault Status: 00101101
                        Reset counter: 81
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 00:00:01
       Revision: C1000000    Serial number: 01101020120303
       Coding: 6400208000
       VCID: 393AD519B007B682DA-806C
       Revision: 08016001    Serial number: 00000489663702
       Coding: 26000091863CAFC00000480300003D0D0F1C5208A2090221000008004000020100000030000000
       VCID: 78BC101DCB8D6F8AE5-802C
       Component: WWS 091012  H07 0080
       Serial number: SWF12100096167
       Coding: 00FD11
       Serial number: 20631161
       Coding: 02005D
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000210120112
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R38T602
       Serial number: 6E384F46000000000001
       Serial number: 003KJD90V48L
       Coding: 303844354730303030304A55304C384B3053
       Shop #: WSC 09805 002 1048576
       VCID: 4AD89AD5EDE12D1A43-801E
       Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
       Serial number: 5810000R120000AGFL
       Serial number: 6334MSME7166053DE
       Serial number: 6344MSME7165532FI
       Serial number: 6352QSME2125287AE
       Serial number: 6362QSME4C242C70L
       Serial number: 63732SME49241658
       Serial number: 63832SME4924244A$
       Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
       Component: Lenks.Modul   H02 0171
       Revision: 00000000    Serial number: 20121011000234
       Coding: 000036
       VCID: 4FEE8BC11E83083214-801A
       Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
       Component: KOMBIINSTR.   H35 0553
       Revision: 00000000    Serial number: RBI36LK9D
       Coding: 8BB609000301D705020000
       VCID: 3522D9299C1F52E23E-8060
       Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
       Component: GW-BEM 4CAN-M H11 0051
       Revision: 1Y050025    Serial number: 2541Y129280141
       Coding: 80C303FF00
       VCID: 44C4B4EDC7C5FB6AB9-8010
       Serial number: 5180858101
                        Reset counter: 81
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 00:00:01
                        Bin. Bits:    00000
                        Voltage: 12.00 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.90 s
       Component: MEM-FS        H06 0076
       Revision: AA000000    Serial number: 00000039539758
       Coding: 00581B00000000000000
       VCID: 3B36CF11BA3B8492C8-806E
       Component: TSG FA        H09 0304
       Coding: 011C13204E00410001
       VCID: 56E07EA5215979FAD7-8002
       Revision: 00001000    Serial number: 0021900568
       Coding: 100000000001
       Shop #: WSC 06324 000 00000
       ROD: EV_RCEPSAU48X_008.rod
       VCID: 3424E42D9F654BEA09-8060
    18689 - Terminal 30
              U140A 00 [009] - Open Circuit
              [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
                        Reset counter: 41
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 00:06:39
                        Write only channel
       Revision: 00002001    Serial number: 0184829737
       Coding: 0106023A00FA400580B0013200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000583166
       Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
       Component: J245 PS050  H08 0043
                        Reset counter: 81
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 00:00:01
       Component: TSG BF        H09 0304
       VCID: 55E279A93C5F72E2DE-8000
       Revision: --------    Serial number: 00000001186863
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 383CD01D830DAF8A25-806C
       Part No SW: 4G0 035 082 D    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0112
       Revision: AB001007    Serial number: 156H-0C7621138
       Coding: 020007010000000000
       Shop #: WSC 31414 790 00001
       VCID: 210A1D793897CE42F2-8074
       Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
       Component: H-BNT-NA      H43 0624
       Revision: --------    Serial number: 204JY0C7535433
       Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
       VCID: 373ED3218613A0F22C-8062
       Subsystem 1 - Part No: 8R0 060 884 AM
       Component: NAR 2012  0605
       Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
       Component: DU7 High  H41 0104
       Serial number: A130JQ0C2552604
       Serial number: 00000001297653
       Subsystem 4 - Part No: 8R0 060 961 D
       Component: CD-Database  4353
    01524 - Antenna for Telephone
                        Fault Status: 00101011
                        Reset counter: 41
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 01:58:02
                        Voltage: 12.40 V
    00822 - Connection DSP to Radio
                        Reset counter: 41
                        Mileage: 65452 km
                        Date: 2018.11.13
                        Time: 01:41:05
                        Voltage: 13.40 V
       Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
       Component: TSG HL        H07 0304
       Coding: 010C13204000210001
       VCID: 59FA759950475682FA-800C
       Revision: --H07---    Serial number: 525PA8-J2791UV
       Coding: 1000006
       VCID: 383CD01D4B0DAF8A25-806C
       Component: TSG HR        H07 0304
    End----------(Elapsed Time: 02:01, VBatt start/end: 13.8V/13.7V)-----------
    Dec 2016
    Amsterdam
    Well, if I remember correctly, DSP = amplifier. If the infotainment unit complains about not being connected to the amp, i’d say theres your problem. If the car doesnt have an amp, the new unit is coded incorrectly and/or has the wrong dataset.
    Current:
  3. Likes Uwe liked this post
    Quote Originally Posted by MasterTommy View Post
    I've looked at what coding info we have for that 5F / J794 and I don't see anything pertaining to sound system, amp, or speaker configuration.
    Mar 2019
    Guatemala
    so what you're saying is that the mmi unit doesnt need coding? the mmi unit is used... any ideas if that could be the problem?
    Quote Originally Posted by purebmw View Post
    Could be the wrong MMI unit or the wrong data/parameter set in it?
    I don't suppose you have a scan from before it was swapped out?
    Mar 2019
    Guatemala
    no i dont, it was changed in another shop same mmi unit . same part no. but its an ebay unit
