Results 1 to 5 of 5
Thread: BCM Part number query
    Mar 2019
    I have a VW T5 1.9 2008. I have identified an issue with my BCM with regards to the intermittent wipers. It is a well documented issue. My reason for posting is regards to part numbers. The part number for the BCM in my van is 7H0 937 049 AB. I want to know how critical the letters 'AB' are? I can find a variation of letters for my years van, but not the specific AB. An example is I found a 7H0 937 049 AD. Could I not get one of these and use the current coding for AB. My van has no electric windows or fancy stuff like that.
    Thanks
    Tuesday,12,March,2019,17:45:27:15067
    VIN: WV1ZZZ7HZ8H149753   License Plate: T5 CTG
    Mileage: 237330km-147470mi   Repair Order:
              57 6E 76 77 78 7D
    VIN: WV1ZZZ7HZ8H149753   Mileage: 237330km-147470miles
       Part No SW: 038 906 016 AH    HW: 038 906 016 AH
       Component: R4 1,9L EDC  000SG  9960
       Revision: --H06---    Serial number: VWZ7Z0H6434921
       Coding: 0000031
       Shop #: WSC 02736 790 00000
       VCID: 5AED90CC900CD467B09-5184
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ABS.clb
       Part No SW: 7H0 907 379 S    HW: 7H0 907 379 S
       Component: (M)ABS MK25E        0103
       Revision: 00H21001
       Coding: 0000552
       VCID: 45D753B009B24B9FEDB-5160
       Part No: 7H0 937 049 AB
       Component: BORDNETZ SGVER 1.0  1201
       Coding: 0000006
       VCID: 72BDD86C68BC8C27989-5160
    00077 - Windshield Wiper Stop Switch (F229)
       Part No: 1C0 909 605 A
       Component: 3C AIRBAG VW51      0011
       Coding: 13123
       Shop #: WSC 02736
       VCID: 221DE82CFDDC5CA7A89-5160
       Part No: 7H0 920 952 B
       Coding: 00413
       Shop #: WSC 00001
       VCID: 2C0106148F189AD7125-5160
       WV1ZZZ7HZ8H149753     VWZ7Z0H6434921
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 02736
       VCID: 70B9D26463B0BE376ED-5160
       Part No: 7H0 959 433 B
       Component: C11 KomfortgerŠt     0004
       Coding: 00021
       Shop #: WSC 02736
       VCID: 323D186CAD3CCC27589-4B3C
       Part No SW: 7H0 035 152 H    HW: 7H0 035 152 H
       Component: Radio 9NK           0008
       Revision: 00005000    Serial number: VWZ4Z4H1130278
       Coding: 0010200
       VCID: 270BF93893FEB98FFF7-5160
    End----------(Elapsed Time: 06:08, VBatt start/end: 12.6V/12.6V)-----------
    Quote Originally Posted by Triton View Post
    I would suggest that they are very critical.
    That doesn't mean there aren't other suffixes that will work, but I doubt you will have good results with some random 7H0 937 049 xx module.
    Someone with parts catalog access should be able to give you a list of modules that supersede the -AB one.
    Sep 2016
    Riga, Latvia
    7H0937049AB superseded by 7H0937049AE
  4. Likes Uwe liked this post
    Mar 2019
    A number of AEís available. They are all saying for cruise.
    How do they assign the letters as would have thought AD followed AB rather than AE. So many versions 😳
    How do they assign the letters as would have thought AD followed AB rather than AE. So many versions ��
    If you figure out a definitive pattern to how the suffices are assigned, let us know!
    My guess is it's done chronologically, so that AC would be assigned right after AB, but AC may not have the same functionality. Then AD with different functionality again, and then the realized the need to fix or improve something with AB and the next available suffice is AE. But this is just a guess.
