Looking for assistance on this. Owner complained of "hard starting" which I determined was really longer than typical cranking time to start of 3 - 5 seconds. This vehicle typically started up almost instantly upon cranking. It needed a lot of service, oil leaks, and carbon removal of intake valves and runners, as well as spark plugs, and a general full service change of fluids, etc. No codes present before beginning work pertinent to engine. Completed the service which did not solve the long crank issue. Fuel pressures while running are within spec., HP fuel pressure raises as expected upon shut down on hot, but LP fuel pressure leaks down to 2 bars within 15 minutes of shutdown. I assume this car has a LP fuel pump prime function when opening the drivers door, or turning the key to ON. LP tank pump does NOT run in either of these cases. I back probed the fuel pump connector to look for voltage for prime function and see none. Voltage appears after cranking begins, and after engine starts. Fuel pump test indicates the pump runs well, and on-road performance is good, so I don't feel the electric pump is faulty, but I could be wrong. I feel the electric pump SHOULD be priming before starting, but I don't know where to begin troubleshooting.
I add the full auto scan below from today below as well as an engine scan from earlier that showed two codes which may offer clues. These codes disappeared without being cleared by me.
Any tips, assistance, or comments are welcome.
VIN: WAUDH98E06A142220 License Plate:
67 69 75 76 77
VIN: WAUDH98E06A142220 Mileage: 235930km-146600miles
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 8E0 910 559 HW: 8E0 907 559 A
Component: 3.2l V6 FSI 0050
Revision: --H16--- Serial number:
Coding: 01040109190F0120
Shop #: WSC 06335 000 00000
VCID: 6ADB065F45B7241A63-803E
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 E HW: 09L 927 156 B
Component: AG6 09L 3,2 FSI USA 0040
Revision: --H01--- Serial number: 4105809
VCID: 295939538031EF02AA-807C
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 E HW: 8E0 614 517 AL
Component: ESP8 quattro H05 0120
Coding: 0004532
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 2832
Coding: 00000
VCID: 6DD10D432759332206-5122
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 L
Component: int. Lastmodul USA 0504
Coding: 01023
Shop #: WSC 65536
VCID: 3B75F31B29AD6D92C8-4AEC
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 H HW: 8E0 959 655 H
Component: Airbag 9.41 H11 3540
Revision: 91H1135 Serial number: 0036N0015SD-
Coding: 0032707
VCID: 3C77F0077FA36AAAC1-8068
Subsystem 1 - Part No: 8E0 910 339 B
Component: BF-Gewichtsens. 002 0070
Subsystem 2 - Serial number: 35SMF
Subsystem 3 - Serial number: 0001.01.000000200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332DRB402644C0BMÿ†63
Subsystem 5 - Serial number: 44C0BMÿ†6342DRB402448BA7Uÿ†63
Subsystem 6 - Serial number: 48BA7Uÿ†6352ARB400B88DAC1ÿ†63
Subsystem 7 - Serial number: 88DAC1ÿ†6362ARB400B5A37EXÿ†63
Subsystem 8 - Serial number: 5A37EXÿ†63729RB400C64922Iÿ†63
Subsystem 9 - Serial number: 64922Iÿ†63829RB400C6489BYÿ
Subsystem 10 - Serial number: 6489BYÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0601
Coding: 04041
Shop #: WSC 06335
VCID: 418981F34B41074292-4AEC
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 982 F HW: 8E0 920 982 F
Component: KOMBI+WFS 4 H12 0110
Revision: 0110 Serial number: 00000000000000
Coding: 0023261
Shop #: WSC 08212 444 85874
VCID: 3169D133ABE197C262-5140
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0023261
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
VCID: 71E911333B61D7C222-4B04
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8E0 959 433 BT
Component: Komfortgerát T7B 3332
Coding: 11836
Shop #: WSC 06335
VCID: 040748E714D3D26AF9-4AEC
Component: Tõrsteuer.FS BRM 0506
Component: Tõrsteuer.BF BRM 0205
Component: Tõrsteuer.HL BRM 0606
Component: Tõrsteuer.HR BRM 0606
01366 - Opened Due to Crash Signal
35-00 - -
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Coding: 0000019
Shop #: WSC 34771 001 1048576
VCID: 285F3C579B3BD60AB5-807C
Subsystem 1 - Part No: 8E0 941 329
Component: AFS-Modul links H03 0020
Subsystem 2 - Part No: 8E0 941 329
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 195 H
Component: symphony II PM6 0460
Coding: 01065
Shop #: WSC 73472
VCID: 2C57C047DCC3FA2A51-5074
36-00 - Open Circuit
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 HW: 8E0 907 273
Component: Reifendruck 3 H03 0110
Coding: 0062121
Shop #: WSC 06435 000 00000
VCID: 69D9795343B12F026A-5122
Part No SW: 8P0 862 335 G HW: 8P0 862 335 G
Component: FSE_255x BT H21 0190
Revision: 00000001 Serial number: 00000000335603
Coding: 0001677
VCID: 3A7BF61F7697549AD3-5140
End-------------------------(Elapsed Time: 05:51)--------------------------
Address 01: Engine Labels: 06E-910-559-BKH.clb
Control Module Part Number: 8E0 910 559 HW: 8E0 907 559 A
Component and/or Version: 3.2l V6 FSI 0050
Software Coding: 01040109190F0120
Work Shop Code: WSC 06335 000 00000
P1602 - 008 - Voltage too Low - Intermittent
Fault Status: 00001000
Reset counter: 38
Mileage: 235927 km
Mass Air / Rev.: 0.0 mg/str
Temperature: 34.5°C
Engine Off
012425 - Signal Line for Fuel Pump Electronics
P3089 - 007 - Electrical Malfunction - Intermittent
Fault Status: 00000010
Reset counter: 38
Mileage: 235926 km
RPM: 800 /min
Mass Air / Rev.: 190.8 mg/str
Temperature: 49.5°C
Idle
Pressure: 2.1 bar
