Hi there we have a Audi a6 with both Led and matrix lamps installed car was in accident and new owner says that headlights were working fine until he took it to audi dealer who must of done software update and lossed coding for rhs headlight which is matrix type lamp. Car comes with led lamps , could i code back in matrix lamps anyone know or could someone have coding for me thank you
Tuesday,19,March,2019,11:54:37:25103
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
Dealer/Shop Name: Castleshane Motora
VIN: WAUZZZ4G9FN027232 License Plate: GY64 VRU
Mileage: 104072km-64667mi Repair Order:
Chassis Type: 4G-AU57 (4G8)
Scan: 01 02 03 05 08 09 15 16 17 19 20 28 36 3B 42 44 46 52 53 55
5F 62 72 AC
VIN: WAUZZZ4G9FN027232 Mileage: 104072km-64667miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FQ HW: 04L 907 309
Component: R4 2,0L EDC H23 0655
Revision: 85H23---
Coding: 0A254012242401080000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01104L906021FQ 002002
ROD: EV_ECM20TDI01104L906021FQ_002.rod
VCID: 79AE1DC6095F723FD93-802C
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
Mileage: 104072 km
Date: 2019.03.19
Time: 10:41:42
Coolant temperature: 9 °C
Intake air temperature: 9 °C
Voltage terminal 30: 13.700 V
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.17 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 0 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1015.8 hPa
Mean injection quantity: 0.00 mg/stroke
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4G0 927 153 L HW: 0CK 927 156 Q
Component: 0CK 20TDI RdW H01 0005
Revision: --H01--- Serial number: 0000000170
Coding: 100001
Shop #: WSC 62019 001 1048576
ASAM Dataset: EV_TCMDL382021 002020
ROD: EV_TCMDL382021_AU57.rod
VCID: 323CEAEA94A94167589-8066
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 H
Component: V553 MTFP HC4 0421
Serial number: S2AG75.109_01 11
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
Part No SW: 4G0 907 379 Q HW: 4G0 907 379 Q
Component: ESP9 Premium H01 0420
Coding: 06A29E41604579829B00
ASAM Dataset: EV_ESP9BOSCHAU57X 003019
ROD: EV_ESP9BOSCHAU57X_003.rod
VCID: 3FDAB3DE57FB9C0FA77-806A
Part No SW: 4H0 907 064 FP HW: 4H0 907 064 EP
Component: BCM2 2.0 H36 0551
Coding: 05B86F4E000000000000
VCID: 7CA004D206ED4717C25-8028
Serial number: 3214000108065010
Part No SW: 4G0 820 043 CC HW: 4G0 820 043 CC
Serial number: 02101400041708
Coding: 34210978210000
VCID: 629C5AAA84C991E7E89-8036
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
Part No SW: 4H0 907 063 DH HW: 4H0 907 063 AH
Component: BCM1 2.0 H20 0311
Revision: 15020001 Serial number: 00000919201401
Coding: 0105001440349FE04101408080001800CF9DC3082F08020100000894E100140200400024030000
VCID: 71BE25E651AF3A7F613-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 140902 H37 0080
Serial number: 140920161513
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 23286807
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 01 10 2014 00000406
Serial number: 92198D47000000000001
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 227
Mileage: 104072 km
Date: 2019.03.19
Time: 10:41:49
Part No SW: 4H0 959 655 H HW: 4H0 959 655 H
Component: Airbag10.43 H82 0086
Revision: -------- Serial number: 003P1001YT9G
Coding: 30333130313830313839554A305234473053
VCID: 3B22C7CE43E3802F8BF-806E
Serial number: 3575HRB40532P43OD0TF
Serial number: 3585HRB40532P43OAH12
Serial number: 3515JRB404T31BAK58QK
Serial number: 3525JRB406131BAKI1P0
Serial number: 3554VRB400M52QV4OOO.
Serial number: 3564VRB400I52QV4F9I4
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20141009000069
Coding: 000034
VCID: 3038E0E29A2573772ED-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Part No SW: 4G8 920 985 L HW: 4G8 920 985 L
Component: TDieGb H07 0043
Revision: 03001036 Serial number: 658011014592029
Coding: 33A60A000B412600010000
ASAM Dataset: EV_RBD4K 004048
ROD: EV_RBD4K.rod
VCID: 40D8B0222A05E3F7DED-8014
Part No SW: 4G8 907 468 HW: 4G8 907 468
Component: J533--Gateway H13 0075
Revision: -------- Serial number: 00000001585339
Coding: C0CD074418
ASAM Dataset: EV_GatewPkoUDS 001024
VCID: 75B611F62547165FBDB-8020
Serial number: 2279134103
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 140722000000000003F2
Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
Component: FLA H04 0012
Revision: AA001002
Coding: 04028264747464545425363E00
Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
Component: KLIMA FOND H08 0112
Serial number: 07101400042288
Coding: 22
VCID: 3D26C9D65DF78E1FB5B-8068
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0157
Revision: AA000000 Serial number: 00000120302575
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77AA1BFE3FCB644FAF7-8022
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA720CUWB2
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 3332EFEE6BB3486F53F-8066
Part No SW: 4G8 959 793 J HW: 4G8 959 793 G
Component: TSG FA H03 0507
Coding: 011F16015E01620002080002
VCID: 47CAAB3E0FABD4CF1F7-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0028037449
Coding: 101000010001
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0349060080
Coding: 011B0E2280B90081C320080400030E470000000000000000000000000000
Subsystem 3 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
Component: GEB.F.Heckoef H16 0811
Serial number: 93346704
Component: TSG BF H03 0507
VCID: 46D4A63A08A1CDC7E41-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001227405
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D06F9968D971E9F05B-8078
Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
Part No SW: 4H4 907 357 D HW: 7P6 907 357 B
Component: MxB-ECU 001 0081
Coding: 04FE02102A630200
ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005003
Coding: E01E00
Coding: E01E00
5538322 - Temperature Sensor for Right High Beam
C1170 01 [009] - Electrical Failure
Reset counter: 227
Mileage: 104072 km
Date: 2019.03.19
Time: 10:41:46
5538323 - Bulb for High Beam Headlamp; Right
B121A F0 [137] - Current Coding Electrical Error
Reset counter: 227
Mileage: 104072 km
Date: 2019.03.19
Time: 10:41:46
Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
Part No SW: 4G1 035 021 A HW: 4G1 035 021
Component: MU-H-LND-EU H33 0073
Serial number: A276J0E7513605
Coding: 01750101FF0A000013111101000A00102F0006E7F1700100DF
VCID: 1868384212158B3746D-804C
Subsystem 1 - Part No SW: V03 959 801 ES HW: -----------
Component: ECE 2014/2015 --- 0086
Subsystem 2 - Part No SW: 4G1 919 605 HW: 4G1 919 605
Component: DU8 C7 SV H42 0005
Serial number: AUZ8Z9EL80053C
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4G2 919 610 F HW: 4G2 919 610 F
Component: E380 BDT C7 H20 0250
Serial number: 90349NJ7000M3
Component: Gracenote --- 1010
Component: TSG HL H03 0507
Coding: 010F14004001620002080002
VCID: 49CEAD0619BF22BF093-801C
Component: TSG HR H03 0507
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 140780419
ROD: EV_RDCMA00100_008.rod
VCID: 2B02F78EB38310AF1BF-807E
End----------(Elapsed Time: 01:51, VBatt start/end: 14.3V/14.3V)-----------
