Results 1 to 4 of 4
Thread: Alltrack Blind Spot Monitor/Side Assist Retrofit Issue
    Feb 2019
    I have a 2018 Canadian Alltrack Highline, I had all the Driver Assist functionality except BSM sensors from factory. I ordered the AliExpress BSM retrofit kit and installed, wired, and coded (based on XaGiCo's tutorial), and installed the side mirrors with the integrated LEDs. No matter what I try, I can't get the Blind Spot Monitor option to enable in the MFD. It throws codes about Warning Lamp Open or Short and various other faults. I've been racking my brain about this for weeks now, any help would be greatly appreciated.
    Here is an Auto-Scan showing all of the found faults:
    Friday,15,February,2019,23:17:08:51593
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
    VCDS Version 18.9.1.0  HEX-V2 CB: 0.4437.4
    VIN: 3VWM17AU4JM759805   License Plate:
    Mileage: 24746km-15376mi   Repair Order:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47 4B
              52 5F 69 A5 CA D6 D7
    VIN: 3VWM17AU4JM759805   Mileage: 24746km-15376miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CXBB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 264 M    HW: 06K 907 425 B
       Component: 1.8l R4 TFSI  H13 0001
       Revision: --H13---
       Coding: 311900322456002F1000
       Shop #: WSC 00066 790 00235
       ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
       ROD: EV_ECM18TFS0208V0906264M.rod
       VCID: 46D5AA3B182B75A7E41-8013
    Readiness: 1010 0101
    Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
       Part No SW: 5Q0 614 517 AM    HW: 5Q0 614 517 AB
       Component: ESC           H25 0312
       Revision: 00000000    Serial number: 61987000000894
       Coding: 43FA6AA134250975407F030080C829C2562C9002C001943C34435050E0A9430000010312121212B435351919323200
       Shop #: WSC 01383 790 50316
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
       ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
       VCID: 7CA108D31667FF77C25-8029
       Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
       Component: VWKESSYMQB    021 0803
       Revision: 00021000    Serial number: 0451731886
       Coding: 032C0C
       ASAM Dataset: EV_KessyHellaMQBAB 002020
       VCID: 3C21C8D356E73F77825-8069
       Part No SW: 5GM 907 044 G    HW: 5GM 907 044 G
       Component: Climatronic   H04 2001
       Revision: 00001K05
       Coding: 0202002420011801010400000010140A
       ASAM Dataset: EV_ACClimaBHBVW37X 006146
       VCID: 48C9A403123F63D716D-801D
       Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C86416101701RO
       Shop #: WSC 00066 790 00395
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0B435B0F43C9C8CFFBF-805F
       Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: WWS    170902  043 0551
       Serial number: 97022066170909160759
       Component: RLHS  042 0105
       Serial number: S7Y17M09D11H15M18S52
       Coding: 00A8DD
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000116644R17298
       Coding: 0271167901
       VCID: 50F98C63EA6FAB174ED-8005
    13688835 - Databus
              [Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
                        Reset counter: 205
                        Mileage: 24746 km
                        Date: 2019.02.15
                        Time: 23:14:30
       Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
       Component: ACC BOSCH MQB H10 0654
       Coding: 2D0000C941FFC728949C810510400600000000000000000000
       ASAM Dataset: EV_ACCBOSCHVW416 002006
       VCID: 3E25C2DB40FB2D67AC1-806B
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Component: AirbagVW20    011 0830
       Serial number: 003MHM040EB7
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 51FF8967E165A21F413-8005
       Occupant Detection:
       Serial number: IBH000000000007UKKGA
       Coding: 303136
       Subsystem 2 - Part No SW: -----------    HW: 480 003 008 17
       Serial number: 35700000000F022D652H
       Subsystem 3 - Part No SW: -----------    HW: 480 003 008 17
       Serial number: 358000000008122D652C
       Subsystem 4 - Part No SW: -----------    HW: 480 403 009 17
       Serial number: 3510001AF2653ED277FN
       Subsystem 5 - Part No SW: -----------    HW: 480 400 209 17
       Serial number: 3520001BF2711E12D22$
       Subsystem 6 - Part No SW: -----------    HW: 480 402 509 17
       Serial number: 3550002A3252D870427Z
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 509 17
       Serial number: 3560002A125629A1B2F4
       Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 13101704401550
       Coding: 0C00
       ROD: EV_SMLSKLOMQB_VW37.rod
       VCID: 094F610749B5DADFC93-805D
       Part No SW: 5G1 920 740 C    HW: 5G1 920 740 C
       Component: KOMBI         242 0310
       Coding: 0BA51015ED88CF0502886B0B1001000080000000
       VCID: 26150ABBB86B95A7C41-8073
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 31101700840746
       Coding: 0901000830085900FB00221A0A0F00000001070000000000000000000000
       Shop #: WSC 00066 790 00215
       ROD: EV_GatewNF_VW37.rod
       VCID: 3333E3EF7BB9F00F53F-8067
       Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
       Serial number: 26170001760110071439
       Coding: 34FFFF
       Power Converter DC AC:
       Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
       Component: U13DCAC  H25 0780
       Serial number: 0002861
       Serial number: HA1-00013.07.17
       Coding: 0001
       VCID: 4ACD9E0B0C3391C7009-801F
    Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
       Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
       Component: LCM_MLBevoH08 0014
       VCID: 47CBA73F1F216CAF1F7-8013
       Revision: 00000000    Serial number: 17000219357008
       Coding: 5500000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 3431E0F37EB7F7374A5-8061
    Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
       Component: HRE_Master    H11 0071
       Serial number: 0391048016
       Coding: 02022103
       Shop #: WSC 12345 123 12345
       ROD: EV_HREntryHella_VW37.rod
       Component: HRE_Slave  H11 0071
       Serial number: 0390829739
       Coding: 020221
    730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
              C122C 15 [009] - Open or Short to Plus
                        Reset counter: 205
                        Mileage: 24746 km
                        Date: 2019.02.15
                        Time: 23:14:30
    730634 - Warning Lamp for Blind Spot Detection in Right Exterior Mirror
              C122D 15 [009] - Open or Short to Plus
                        Reset counter: 205
                        Mileage: 24746 km
                        Date: 2019.02.15
                        Time: 23:14:30
       Component: TSG FS        011 0032
       Serial number: 5038729500985
       Coding: 003B13205000020000000000
       Serial number: 00000000000006840570
       Coding: 011000
       Part No SW: 5QM 909 144 A    HW: 5QM 909 144 A
       Component: EPS_MQB_ZFLS  171 1072
       Coding: 9302
       ROD: EV_SteerAssisMQB_013.rod
       VCID: 4FFB8F1FF751B4EF577-801B
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
       Component: MIB2_lite_amp H40 0200
       Revision: 00000001    Serial number: VWZ8Z1HMD00QJ1P
       VCID: 2E05F29B909BDDE73C1-807B
    Address 4B: Multifunc. Module (J745)       Labels:* None
       Part No SW: 3Q0 907 338     HW: 3Q0 907 338
       Component: FCM MQB Low   002 0286
       Serial number: 24101700840054
       Coding: 000000050100211200110F01030000000000000000000000000000000000
       VCID: 72BD26EB4423B907989-8027
       Component: TSG BFS       011 0032
       Serial number: 6038729701846
       Coding: 003B13205C00020000000000
       Serial number: 00000000000018100107
       Coding: 091000
       Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
       Component: MU-S-NS-US    851 0867
       Coding: 027312020000000051220002001828001F0508F401200505C6
       ROD: EV_MUStd4CDELP_VW26.rod
       Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
       Component: ABT_Std-2_Nav  H50 8130
       Serial number: VWZ6ZJT2971141
       Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
       Component: NAR 2017/18  --- 0620
    7204 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Tilt-angle indicator (0x24) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 205
                        Mileage: 24746 km
                        Date: 2019.02.15
                        Time: 23:11:27
                        Voltage terminal 30: 14.0 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
       Component: Anhaenger     H21 0203
       Revision: 8B001003    Serial number: 0382156092
       Coding: 0200000202000000
       Shop #: WSC 00028 028 00066
    136203 - Supply Voltage
              P1757 00 [008] - Open Circuit
                        Reset counter: 245
                        Mileage: 24746 km
                        Date: 2019.02.15
                        Time: 23:11:56
       Component: MQB_B_MFK     H08 0272
       Serial number: 08091712K12083
       Coding: 000307020002020100221347C150490094000E200120
    1122656 - Databus
              [TIMEOUT_SWA_Objekt_01_02]
                        Reset counter: 205
                        Mileage: 24746 km
                        Date: 2019.02.15
                        Time: 23:11:24
                        Control Module temperature: 30 ∞C
                        Outside air temperature: 22.0 ∞C
                        Vehicle speed: 0.00 km/h
                        System run time: 547.2 s
                        Voltage terminal 15: 13.8 V
                        mid: 02 10
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Coding: 00804073720C
       VCID: 3D27C5D74DFD367FB5B-8069
       Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
       Component: LED1L         H06 0002
       ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
       ROD: EV_LEDMinMaxL_KEBODAVW481.rod
       VCID: 392FD1C759D50A5F993-806D
       Component: LED1R         H06 0002
       ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
       ROD: EV_LEDMinMaxR_KEBODAVW481.rod
    End----------(Elapsed Time: 01:56, VBatt start/end: 13.8V/13.8V)-----------
    Tartu, Estonia
    Is wiring correct? Which mirrors/glasses have You installed?
    Possible that polarity of LED is swapped?
    The world is my oyster...
    Feb 2019
    I installed the mirrors that came with the kit, so I can only assume they are correct. I thought about polarity as well and tried reversing the pins on the cable but received the same issue.
    Feb 2019
    Ok, I figured out the issue. The port on the mirrors where the plug enters is deep and the pins were not properly seating into the plugs.
  5. Likes Uwe liked this post
