I have a 2018 Canadian Alltrack Highline, I had all the Driver Assist functionality except BSM sensors from factory. I ordered the AliExpress BSM retrofit kit and installed, wired, and coded (based on XaGiCo's tutorial), and installed the side mirrors with the integrated LEDs. No matter what I try, I can't get the Blind Spot Monitor option to enable in the MFD. It throws codes about Warning Lamp Open or Short and various other faults. I've been racking my brain about this for weeks now, any help would be greatly appreciated.
Here is an Auto-Scan showing all of the found faults:
Friday,15,February,2019,23:17:08:51593
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 18.9.1.0 HEX-V2 CB: 0.4437.4
VIN: 3VWM17AU4JM759805 License Plate:
Mileage: 24746km-15376mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F 69 A5 CA D6 D7
VIN: 3VWM17AU4JM759805 Mileage: 24746km-15376miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CXBB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 264 M HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0001
Revision: --H13---
Coding: 311900322456002F1000
Shop #: WSC 00066 790 00235
ASAM Dataset: EV_ECM18TFS0208V0906264M 001003
ROD: EV_ECM18TFS0208V0906264M.rod
VCID: 46D5AA3B182B75A7E41-8013
Readiness: 1010 0101
Address 03: ABS Brakes (J104) Labels:* 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AM HW: 5Q0 614 517 AB
Component: ESC H25 0312
Revision: 00000000 Serial number: 61987000000894
Coding: 43FA6AA134250975407F030080C829C2562C9002C001943C34435050E0A9430000010312121212B435351919323200
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 036010
ROD: EV_Brake1UDSContiMK100ESP_036_VW37.rod
VCID: 7CA108D31667FF77C25-8029
Part No SW: 5Q0 959 435 C HW: 5Q0 959 435
Component: VWKESSYMQB 021 0803
Revision: 00021000 Serial number: 0451731886
Coding: 032C0C
ASAM Dataset: EV_KessyHellaMQBAB 002020
VCID: 3C21C8D356E73F77825-8069
Part No SW: 5GM 907 044 G HW: 5GM 907 044 G
Component: Climatronic H04 2001
Revision: 00001K05
Coding: 0202002420011801010400000010140A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
VCID: 48C9A403123F63D716D-801D
Part No SW: 5Q0 937 087 AR HW: 5Q0 937 087 AN
Component: BCM PQ37BOSCH 034 0243
Revision: -------- Serial number: C86416101701RO
Shop #: WSC 00066 790 00395
ROD: EV_BCMBOSCH_018.rod
VCID: 0B435B0F43C9C8CFFBF-805F
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170902 043 0551
Serial number: 97022066170909160759
Component: RLHS 042 0105
Serial number: S7Y17M09D11H15M18S52
Coding: 00A8DD
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000116644R17298
Coding: 0271167901
VCID: 50F98C63EA6FAB174ED-8005
13688835 - Databus
[Steuerger‰t f¸r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
Reset counter: 205
Mileage: 24746 km
Date: 2019.02.15
Time: 23:14:30
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 2D0000C941FFC728949C810510400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
VCID: 3E25C2DB40FB2D67AC1-806B
Part No SW: 5Q0 959 655 T HW: 5Q0 959 655 T
Component: AirbagVW20 011 0830
Serial number: 003MHM040EB7
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 51FF8967E165A21F413-8005
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000007UKKGA
Coding: 303136
Subsystem 2 - Part No SW: ----------- HW: 480 003 008 17
Serial number: 35700000000F022D652H
Subsystem 3 - Part No SW: ----------- HW: 480 003 008 17
Serial number: 358000000008122D652C
Subsystem 4 - Part No SW: ----------- HW: 480 403 009 17
Serial number: 3510001AF2653ED277FN
Subsystem 5 - Part No SW: ----------- HW: 480 400 209 17
Serial number: 3520001BF2711E12D22$
Subsystem 6 - Part No SW: ----------- HW: 480 402 509 17
Serial number: 3550002A3252D870427Z
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 509 17
Serial number: 3560002A125629A1B2F4
Part No SW: 5Q0 953 507 HN HW: 5Q0 953 549 E
Revision: -------- Serial number: 13101704401550
Coding: 0C00
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 094F610749B5DADFC93-805D
Part No SW: 5G1 920 740 C HW: 5G1 920 740 C
Component: KOMBI 242 0310
Coding: 0BA51015ED88CF0502886B0B1001000080000000
VCID: 26150ABBB86B95A7C41-8073
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 31101700840746
Coding: 0901000830085900FB00221A0A0F00000001070000000000000000000000
Shop #: WSC 00066 790 00215
ROD: EV_GatewNF_VW37.rod
VCID: 3333E3EF7BB9F00F53F-8067
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Serial number: 26170001760110071439
Coding: 34FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: U13DCAC H25 0780
Serial number: 0002861
Serial number: HA1-00013.07.17
Coding: 0001
VCID: 4ACD9E0B0C3391C7009-801F
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 D HW: 8V0 907 399 D
Component: LCM_MLBevoH08 0014
VCID: 47CBA73F1F216CAF1F7-8013
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 17000219357008
Coding: 5500000000000000
ROD: EV_ELVMarquMQB.rod
VCID: 3431E0F37EB7F7374A5-8061
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: HRE_Master H11 0071
Serial number: 0391048016
Coding: 02022103
Shop #: WSC 12345 123 12345
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H11 0071
Serial number: 0390829739
Coding: 020221
730378 - Warning Lamp for Blind Spot Detection in Left Exterior Mirror
C122C 15 [009] - Open or Short to Plus
Reset counter: 205
Mileage: 24746 km
Date: 2019.02.15
Time: 23:14:30
730634 - Warning Lamp for Blind Spot Detection in Right Exterior Mirror
C122D 15 [009] - Open or Short to Plus
Reset counter: 205
Mileage: 24746 km
Date: 2019.02.15
Time: 23:14:30
Component: TSG FS 011 0032
Serial number: 5038729500985
Coding: 003B13205000020000000000
Serial number: 00000000000006840570
Coding: 011000
Part No SW: 5QM 909 144 A HW: 5QM 909 144 A
Component: EPS_MQB_ZFLS 171 1072
Coding: 9302
ROD: EV_SteerAssisMQB_013.rod
VCID: 4FFB8F1FF751B4EF577-801B
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD00QJ1P
VCID: 2E05F29B909BDDE73C1-807B
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 24101700840054
Coding: 000000050100211200110F01030000000000000000000000000000000000
VCID: 72BD26EB4423B907989-8027
Component: TSG BFS 011 0032
Serial number: 6038729701846
Coding: 003B13205C00020000000000
Serial number: 00000000000018100107
Coding: 091000
Part No SW: 3Q0 035 876 B HW: 3Q0 035 876 B
Component: MU-S-NS-US 851 0867
Coding: 027312020000000051220002001828001F0508F401200505C6
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT2971141
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
7204 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Tilt-angle indicator (0x24) - function restriction due to communication error - BapErr_retry not successful]
Reset counter: 205
Mileage: 24746 km
Date: 2019.02.15
Time: 23:11:27
Voltage terminal 30: 14.0 V
BAP-BAP_Function_ID: 02
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 H HW: 5Q0 907 383 C
Component: Anhaenger H21 0203
Revision: 8B001003 Serial number: 0382156092
Coding: 0200000202000000
Shop #: WSC 00028 028 00066
136203 - Supply Voltage
P1757 00 [008] - Open Circuit
Reset counter: 245
Mileage: 24746 km
Date: 2019.02.15
Time: 23:11:56
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 08091712K12083
Coding: 000307020002020100221347C150490094000E200120
1122656 - Databus
[TIMEOUT_SWA_Objekt_01_02]
Reset counter: 205
Mileage: 24746 km
Date: 2019.02.15
Time: 23:11:24
Control Module temperature: 30 ∞C
Outside air temperature: 22.0 ∞C
Vehicle speed: 0.00 km/h
System run time: 547.2 s
Voltage terminal 15: 13.8 V
mid: 02 10
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 0
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804073720C
VCID: 3D27C5D74DFD367FB5B-8069
Part No SW: 7P5 941 572 A HW: 7P5 941 572 A
Component: LED1L H06 0002
ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
ROD: EV_LEDMinMaxL_KEBODAVW481.rod
VCID: 392FD1C759D50A5F993-806D
Component: LED1R H06 0002
ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End----------(Elapsed Time: 01:56, VBatt start/end: 13.8V/13.8V)-----------
