Results 1 to 10 of 15
Thread: Not able to access all cloud functions
    Mar 2019
    First post. Please forgive me if I don't get all of the terminology correct. HEX-NET, VCDS-mobile, Macbook Pro, Firefox. 2013 Audi A7.
    Was able to get HEX-NET configured in infrastructure mode, run an autoscan, update the ASAM file(s), upload the saved auto-scan log to VCDS-cloud. I've inserted the log file that I downloaded from VCDS-cloud.
    I was able to make one adaptation, channel 2 Auto Trans, clicked on the cloud function button to get to the "Single Gear Display" and changed it to "D on/S on".
    When I went to make the next adaptation, channel 17 Instruments, when I click on the cloud function button, it shows the trying to connect to the VCDS-cloud, then it says success, but then it redirects me to the VCDS-cloud login page. Tried it multiple times, being already logged in to VCDS-cloud in the same tab, a different tab, or not logged in at all. Same result.
    Is there anything special that I have to do when configuring Firefox so that the cloud function button will work for all controller channels?
    Thanks.
    #hndoc:?docid=00004C4B&xt=hnh:776D89676ABF5F1B01223B2731F9D141D6841CCD379726C927D04532219F98BB
    VCDS Mobile 0.4437.0.4
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 47 52 53
    	 55 56 5F 62 6C 6D 72 8F 90
    8F-Pretension. Front Left -- Status: OK 0000
    90-Pretension. Front Right -- Status: OK 0000
    Address 01: Engine  (CTUA4 J623)	Labels: 4G-01.lbl
    	Part No SW: 4G0 907 551 D	HW: 4G0 907 551 A
    	Component: 3.0l V6 TFSI
    	Revision: --H07---
    	Coding: 1A2A0034052601060000
    	ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
    	ROD: EV_ECM30TFS0214G0907551D.rod
    	VCID: 2A1791AB9D10A160C6B684-807F
    No fault codes found.
    Address 02: Auto Trans  (J217)	Labels: 4G-02.lbl
    	Part No SW: 4G1 927 158 A	HW: 0BK 927 156 AM
    	Component: 0BK 30TFSIUSA H16 1006
    	Revision: --H16---
    	Coding: 000002
    	ROD: EV_TCMAL551211_002_AU57.rod
    	VCID: 2D1D9AB7ACFEB65823D4A7-8078
    Address 03: ABS Brakes  (J104)	Labels: 4G0-907-379-V1.clb
    	Part No SW: 4G0 907 379 H	HW: 4G0 907 379 H
    	Revision: --------
    	Coding: 44A78F0322E5F1C04B00
    	VCID: 362FB5DB59A8F580520E00-8063
    0486 - Function Restriction due to Faults in Other Modules
    	U1113 00 [008] -
    Address 05: Acc/Start Auth.  (J393)	Labels: 8K0-907-064-05.clb
    	Part No SW: 4H0 907 064 CR	HW: 4H0 907 064 CR
    	Component: BCM2 2.0      H33 0433
    	Coding: 0DAA2046000000000000
    	VCID: 7BB964EF220AF0E8EDC019-802E
    	Subsystem 1 -
    	Subsystem 2 - 	Part No SW: 4H0-905-852-C
    Address 08: Auto HVAC  (J255)	Labels: 4G-08.clb
    	Part No SW: 4G0 820 043 AF	HW: 4G0 820 043 AF
    	Component: KLIMA 4 ZONEN H13 0076
    	Coding: 6603207A49
    	VCID: 63893C8FBABA3028C5F011-8036
    Address 09: Cent. Elect.  (J519)	Labels: 4H-09.clb
    	Part No SW: 4H0 907 063 CG	HW: 4H0 907 063
    	Revision: 11012002
    	Coding: 0D072091073E9FE081000884A0003820CF9CD208A6090225800308457B00
    	Shop #: WSC 02311 785 00200
    	VCID: 6FA140BF66729C4851489D-803A
    	Subsystem 1 - 	Part No SW: 4G1-955-119	Labels: 1Kx-955-119.clb
    	Component: WWS57X 130115H36 0080
    	Coding: 0045F7
    	Subsystem 2 - 	Part No SW: 8U0-955-559-B	Labels: 8U0-955-559.clb
    	Component: G397_RLFS    H06 0002
    	Coding: 02006E
    	Subsystem 3 - 	Part No SW: 4G0-941-531-E
    	Component: E1 - LDS     H07 0044
    	Subsystem 4 - 	Part No SW: 4G0-907-410-A
    	Component: USHL4.2      H30 0030
    	Subsystem 5 - 	Part No SW: 8K0-959-772-E
    	Component: SLR-B8       H06 0007
    	Coding: 853000
    	Subsystem 6 - 	Part No SW: 4G0-907-472
    	Component: A31 LED Mod1LH02 0002
    	Subsystem 7 - 	Part No SW: 4G0-907-472
    	Component: A27 LED Mod1RH02 0002
    	Subsystem 8 - 	Part No SW: 4H0-907-705-K
    	Component: EVLS-SG      H08 0300
    	Coding: 020300
    	Subsystem 9 - 	Part No SW: 4H0-907-658
    	Component: AQ_Hum_SensorH03 0003
    	Subsystem 10 - 	Part No SW: 4G0-907-472-A
    	Component: A32 LED Mod2LH02 0002
    	Subsystem 11 - 	Part No SW: 4G0-907-472-A
    	Component: A28 LED Mod2RH02 0002
    Address 10: Park/Steer Assist  (J446)	Labels: 4H0-919-475-7X2.clb
    	Part No SW: 4H0 919 475 AA	HW: 4H0 919 475 AG
    	Revision: 11001001
    	Coding: A8C304
    	VCID: 71A546C7704692B8477C8B-8024
    Address 15: Airbags  (J234)	Labels: 4H0-959-655.clb
    	Part No SW: 4G0 959 655 A	HW: 4G0 959 655 A
    	Component: Airbag10.43   H33 0033
    	Revision: --------
    	Coding: 303145313131303030314A55304C34473853
    	VCID: 33298CCF4ADAE0A8751061-8066
    	Subsystem 1 - 	Part No SW: 5C6-959-339-B
    	Component: BF-Gewichtss.H10 0046
    	Serial Number: 6940000Y150001FDGC0U
    	Subsystem 2 - 	Serial Number: 3575HRB40651S1NK49HL
    	Subsystem 3 - 	Serial Number: 3585HRB40671SJR24HH-
    	Subsystem 4 - 	Serial Number: 3515JRB400K4UPLK80TH
    	Subsystem 5 - 	Serial Number: 3525JRB400250DEK4PF2
    	Subsystem 6 - 	Serial Number: 3554VRB401G50CU4GHR3
    	Subsystem 7 - 	Serial Number: 3564VRB401I50D5Q7GR.
    Address 16: Steering wheel  (J527)	Labels: 4H0-953-568.clb
    	Part No SW: 4G0 953 568 A	HW: 4G0 953 568 A
    	Revision: 00000000
    	Coding: 000034
    	VCID: 302383C3BBCCC3B008F246-8065
    	Subsystem 1 - 	Part No SW: 4G0-951-528-A
    	Component: E221 - MFL   H08 0010
    Address 17: Instruments  (J285)	Labels: 4H0-920-xxx-17.clb
    	Part No SW: 4G8 920 983 E	HW: 4G8 920 983 E
    	Component: TBenUsa       H79 0515
    	Revision: 28460208
    	Coding: 0BE601060B43D705020100
    	ASAM Dataset: EV_RBD4K 004046
    	ROD: EV_RBD4K_AU57.rod
    	VCID: 3731B8DF5EA20C88493835-8062
    Address 19: CAN Gateway  (J533)	Labels: None
    	Part No SW: 4G0 907 468 AC	HW: 4G0 907 468 AC
    	Component: J533--Gateway H12 0037
    	Revision: --------
    	Coding: 00CD073000
    	ASAM Dataset: EV_GatewPkoUDS 001018
    	Subsystem 1 - 	Part No SW: 8T0-915-181
    	Component: J367-BDMHellaH03 8041
    	Serial Number: 6508419001
    	Subsystem 2 -
    Address 28: HVAC, Rear  (E265)	Labels: 4G0-919-158.clb
    	Part No SW: 4G0 919 158 J	HW: 4G0 919 158 J
    	Component: KLIMA FOND    H07 0076
    	Coding: 20
    Address 36: Seat Mem. Drvr  (J136)	Labels: None
    	Part No SW: 4G8 959 760 A	HW: 4G8 959 760 A
    	Revision: AA000000
    	Coding: C0581B008F006001000001010101102030303232203232
    	VCID: 3833BBE353BC1BF040223E-806D
    Address 3B: Sensor Elect.  (J849)	Labels: 4G0-907-637.clb
    	Part No SW: 4G0 907 637 K	HW: 4G0 907 637 F
    	Component: SARA 6D       H02 0056
    	Revision: --------
    	ASAM Dataset: EV_SARA2 005012
    	ROD: EV_SARA2_005.rod
    Address 42: Door Elect, Driver  (J386)	Labels: None
    	Part No SW: 4G8 959 793 J	HW: 4G8 959 793 G
    	Revision: --------
    	Coding: 011F57024E00628002000402
    	VCID: 47D1C81F2E42640839D845-8012
    Address 44: Steering Assist  (J500)	Labels: 4G0-909-144.clb
    	Part No SW: 4G0 909 144 L	HW: 4G0 909 144 G
    	Component: RCEPS         H36 0010
    	Revision: 00001000
    	Coding: 101000010000
    	ASAM Dataset: EV_RCEPS 009008
    	ROD: EV_RCEPS_009.rod
    	VCID: 322789CBB5C0E9A07EE67C-8067
    Address 46: Central Conv.  (J393)	Labels: 4H0-907-064-46.clb
    	Coding: 0126023A20FAF00580B00A8402010D070000000000000000000000000000
    	Subsystem 1 - 	Part No SW: 4G0-959-719
    	Component: GTO BF       H01 0080
    	Subsystem 2 - 	Part No SW: 1K0-951-605-C
    	Component: LIN BACKUP HOH05 1501
    	Subsystem 3 - 	Part No SW: 4G8-959-591
    	Component: J245 PS40.039H01 H01
    	Coding: 101F00
    	Subsystem 4 -
    	Subsystem 5 -
    01403 - Glass-Break Sensors; Rear
    Address 47: Sound System  (J525)	Labels: None
    	Part No SW: 4G0 035 223 C	HW: 4G0 035 223 A
    	Revision: CJ007001
    	Coding: 030000
    	VCID: 1D7D4A77DC5E5ED8B33417-8048
    Address 52: Door Elect, Pass.  (J387)	Labels: None
    	Part No SW: 4G8 959 792 J	HW: 4G8 959 792 G
    	Revision: --------
    	VCID: 46CFC51B29487D00C2AE50-8013
    Address 53: Parking Brake  (----)	Labels: 4H0-907-801.clb
    	Part No SW: 4H0 907 801 F	HW: 4H0 907 801 A
    	Component: EPB-4         H03 0013
    	Revision: --------
    	Shop #: WSC 00000 000
    	ROD: EV_ParkiBrake_AU57.rod
    	VCID: 2B1994AF92EAB8683DA089-807E
    6 Faults Found:
    333568 - Function Restricted due to Missing Message(s)
    	U1111 00 [000] -
    334080 - Function Restricted due to Missing Message(s)
    	U1111 00 [000] -
    331264 - Function Restricted due to Missing Message(s)
    	U1111 00 [000] -
    331520 - Function Restricted due to Missing Message(s)
    	U1111 00 [000] -
    331776 - Function Restricted due to Missing Message(s)
    	U1111 00 [000] -
    460800 - Function Restriction due to Faults in Other Modules
    	U1113 00 [000] -
    Address 55: Xenon Range  (J431)	Labels: 8X0-907-357.clb
    	Part No SW: 4H0 907 357 B	HW: 4H0 907 357 B
    	Coding: 1223A6601002A500
    	ROD: EV_HeadlRegulBasic.rod
    Address 56: Radio  (R)	Labels: None
    	Part No SW: 4G0 035 082 E	HW: 4G0 035 082
    	Component: Radio U SIRIU H60 0121
    	Revision: AB001007
    	Coding: 020007010000000001
    	VCID: 2207798BE52061208E462C-8077
    Address 5F: Information Electr.  (J794)	Labels: 4E0-035-6xx-5F.clb
    	Part No SW: 4G0 035 746 D	HW: 4G0 035 746 B
    	Component: H-BNT-NA      H50 0622
    	Revision: --------
    	Coding: 090200040003E1EF45128B3E00000003100001000000000000
    	VCID: 28136BA3831C8B70D082EE-807D
    	Subsystem 1 - 	Part No SW: 8R0-060-884-BA
    	Component: NAR 2013     0703
    	Subsystem 2 - 	Part No SW: 4G0-919-605-C
    	Component: DU8 C7 SV    H43 0021
    	Subsystem 3 - 	Part No SW: 4G1-919-610-C
    	Subsystem 4 - 	Part No SW: 8R0-060-961-E
    	Component: CD-Database  4949
    Address 62: Door, Rear Left  (J388)	Labels: None
    	Part No SW: 4G8 959 795 J	HW: 4G8 959 795 G
    	Revision: --------
    	Coding: 010F17024000628002000002
    	VCID: 49D5CE27385692782FCC73-801C
    Address 6C: Back-up Cam.	Labels: 4H0-907-441.clb
    	Part No SW: 4G0 907 441 B	HW: 4H0907441
    	Component: SG Rueckfahrkamera   0061
    	Revision: --H06---	Serial Number: 525 PA8J2ZG30U
    	Coding: 1080013
    	VCID: 260F659B89081D00E26EF0-8073
    Address 6D: Trunk Elect.  (----)	Labels: None
    	Part No SW: 4G8 959 107 R	HW: 4G8 959 107 G
    	Component: HDSG-Modul    H13 0043
    	Revision: 12013001
    	Coding: 0A3305C102
    	ASAM Dataset: EV_HDSGAu573 001022
    	ROD: EV_HDSGAu573.rod
    	VCID: 44CBDF131F745710DCBABA-8011
    Address 72: Door, Rear Right  (J389)	Labels: None
    	Revision: --------
    Address 8F: Pretension. Front Left  (J854)	Labels: 4H0-980-94x-RGS.clb
    	Part No SW: 4H0 980 945 B	HW: 4H0 980 945 C
    	ASAM Dataset: EV_RGS_L 002004
    	ROD: EV_RGS_L.rod
    	VCID: 312586C7B0C6D2B807FC4B-8064
    Address 90: Pretension. Front Right  (J855)	Labels: 4H0-980-94x-RGS.clb
    	Part No SW: 4H0 980 946 B	HW: 4H0 980 946 C
    	ASAM Dataset: EV_RGS_R 002004
    	ROD: EV_RGS_R.rod
    Quote Originally Posted by Delfin View Post
    Scratching head why it would do that.
    Is it particular to 17-Instruments? I.e. does it only happen on that module? Try some others. You don't actually have to make any changes in the other modules, just see if cloud functions are accessible.
    Mar 2019
    It will be a couple of days before I'll have time to try it again. When I do, I will try some other modules and report back.
    Mar 2019
    Had time to work on it this afternoon.
    For the controller channels that redirect me to the vcds cloud login page, it always happens for those channels.
    For every channel, when I click on the cloud function button, I see three messages pop up.
    Connecting to vcds cloud
    VCDS cloud connection successful!
    and then in the lower left corner of the screen I see: waiting for vcds-cloud.com...
    For the controller channels that then redirect, it happens right away. I see something that starts with transferring, then another message that starts with reading, and then the login page is displayed.
    For the controller channels that work like I expect them to, I see the waiting for vcds-cloud.com... for much longer, and then the actual cloud menu full of buttons is displayed.
    I tried every available channel, I certainly don't see any pattern as to which channels work and which ones don't.
    Let me know if you want me to try this again with the debug level set higher so there is some log of what messages Firefox sends to the server, and what messages the server sends back.
    Controller      Result - ok - cloud functions available
    Module          Result - redirect - redirects to vcds cloud login page
    01              redirect
    02              ok
    03              ok
    04              Kline timeout error? N/A
    05              ok
    08              redirect
    09              ok
    10              redirect
    15              redirect
    16              ok
    17              redirect
    19              ok
    28              redirect
    36              ok
    3B              redirect
    42              ok
    44              redirect
    46              ok
    47              ok
    52              ok
    53              redirect
    55              redirect
    56              ok
    5F              ok
    62              ok
    6C              ok
    6D              redirect
    72              ok
    8F              redirect
    90              redirect
    04-Steering Angle is not directly accessible. It has an entry in the Gateway Installation List for for internal data routing purposes.
    As for the re-directs on the Cloud functions, I'm going have to to defer to Shaun.
    On the addresses that are redirecting, if you go back and try again do you eventually get in, or do they consistently fail to let you into the main cloud menu?
  7. #7
    Mar 2019
    They consistently fail. Making that list I tried each channel in order. For the failing ones, I tried each one two or three times before moving on. When I got done with the last channel, I went back to the top of the list and re-tried each of the failing ones again in order, and they still failed.
  8. #8
    Can you test one of the failing ones again? I tweaked some things last night.
  9. #9
    Mar 2019
    Unlikely to get a chance to test it until the weekend. Will let you know the results.
  10. #10
    No worries. Shaun is out until sometime next week anyway. A friend of his is getting married out west.
