Page 3 of 11 FirstFirst 12345 ... LastLast
Results 21 to 30 of 102
Thread: Lost remote fob function (7L6 Touareg)
  1. #21
    Mar 2019
    Are Antennas somehow shared somewhere in TPMS with Kessy in tracks for remote functions or supply?
    TPMS deletes for shame dismissed treats?
    My search (so far) of the 1000+ page wiring diagram hasn't yet shown that. HOWEVER it appears that the door button switch connectors that I disconnected months ago MAY share the same connector as the door antennas. Tomorrow I will reconnect the front two, since I know one rear one was faulted but can't remember which one. I've been under the belief that for some reason the car can no longer "see" my fobs. There MUST be another antenna(s) or it would not have worked until now.
    I am learning A LOT here. Tonight I was pulling fuses, checking them, with the car running. Pulled one of the KESSY fuses, car shut off. TPMS immediately came back on. Hmmm. Found there are two fuses for TPMS, one on each side. I replaced the missing fuse. Found a blown fuse for the aux head lamps 20A, replaced that. Also replaced the radio and amplifier fuses.
    Thinking: rerun coding 07 with no changes on CAN 19? See if it finds the KESSY again with ALL the fuses in?
    Frankly I don't like living without the radio, I'll have to determine why it was drawing so much power when off. Could be the amp, I never checked to see which one. Could be as simple as the remote on/off control from the radio has a bad wire so the amp just stays on. I'll investigate that further once I sort out this remote issue.
    What the hell, the laptop is charged and I'm wide away. I'll go run that CAN coding and see what happens lol. Can't hurt at this point.
    Dana: your suggestion of the label file helped immensely for me to understand things a bit better. Thank you!
  2. Likes Dana liked this post
  3. #22
    Mar 2019
    There are antennas all over. Front and rear bumpers, central, luggage rear, two interior, and a couple of others I counted, plus the 4 in the doors which presumably are there to sense the key when it's in your pocket.
    Ran auto scan tonight to clear out all the codes I created by pulling fuses. Came up clean afterwards. TPMS light is lit. No code for that, I'll scan again at work tomorrow.
    I need to ask the dealer if they tried just flashing back to stock. If not, why not? That would rule out anything I did I would think. I AM learning a lot about this SUV. Interesting stuff. Hoping to get the two front door antenna/button connectors hooked back up tomorrow during the day. We will see what, if anything, that does.
    I have it on a charger now, as has been the custom since I bought it a year ago. Oddly no errors for the radio system. However tonight was the first time during a scan it ever showed "Diag." on the MFD.
    I have two weeks to sort this out before deciding if I want to go back to the dealer and spend $500 plus in labor. My KESSY IS bad. It makes the clicks and "Shift into P" on the dash from time to time, although that seems to have cleared up since I disconnected the door antenna/button connectors.
    There is a KESSY for it on eBay right now for $119. Worth buying? Difficult to program or just plug it in and do the key sync thing? Tempted to just track down a TPMS module but I don't really want TPMS, planning on winter tires on another set of rims, would rather NOT buy 4 more sensors. I check tire pressures every third fill up religiously, always have. I have no need for a TPMS really. Which there was a better option to delete it. Maybe just remove the module?
  4. #23
    Quote Originally Posted by Akron04 View Post
    I would think you'd need the PIN for the used KESSY. Do you have some means to obtain that?
    I really don't think the remote problem is intrinsically related to killing off TPMS. Lots of people have done that on T1s for various reasons (mainly because those first generation TPMS systems were a royal PITA) and I don't recall any other complaints that remotes stopped working as a result.
  5. Likes Akron04, Dana liked this post
  6. #24
    OP: I can help you get pins or do a data transfer with proper credentials..........
    Uwe : Back then, the cars were newer and the antennas or tracks were not as damaged as they are now for water ingress & time for corrosion to do all kinds of wonderful things.
    OP: Did you verify that tracks of all antennas are proper and isolate them for Kessy and TPMS?
  7. Likes Akron04 liked this post
  8. #25
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    There are two KESSY variants for this platform. One does true keyless entry (unlock when you touch the door handle) and the lower end one only does remote control where you have to press the button. Can you confirm which you have/had? It's possible during your KESSY recoding adventure that you told it you don't have keyless.
    Silence gives consent.
  9. Likes Jack@European_Parts, Akron04, Dana liked this post
  10. #26
    Mar 2019
    I was able to get my pin for the one in the car now. I would assume that if I plugged another one it I could get the pin in the same manner, thru the diagnostic port......
  11. #27
    Mar 2019
    Jack,
    By credentials I would assume you mean a copy of my title to show proof of ownership?
    I have NOT verified TPMS and Kessy separation. I have identified a bunch of antennas for the Kessy though. Both bumpers, a few inside, one in one of the pillars I believe. I think I tracked down about 7 last night scanning thru the wiring diagram.
    My Kessy is keyless entry. A function I do not need or care for but would replace with the same part. I found one on eBay, all numbers are the same except no "C" on the very end.
    I found a TPMS for $50, I'm going to get that. Worst case I'll just deal with the warning light during the winter on winter tires. Would prefer a full delete however based upon the wiring diagrams everything seems to be very interrelated and it's not likely wise to just remove the module and recode on a car I am trying to get into tip top shape.
    What I have learned is that these cars had a lot of new features that are now common on new cars, VW just had some trouble with the execution in these early ones. Mine is in really great overall shape and very low miles. I want it to last me awhile, at least a few years, at which point I'd like a newer Q7 V8.
  12. Likes Dana, Jack@European_Parts liked this post
  13. #28
    Mar 2019
    I've ordered a TPMS module and a Kessy module. Worst case I can pull my existing Kessy and do the diode repair I have seen on Club Touareg. I happen to have the right tools to do that (electronic soldering equipment).
    Meanwhile I'm going to keep plugging away at this one. Mainly reading the wiring diagrams to make sense of how it all ties together. Haven't gotten to the door antennas yet today. Too busy at work. Hoping to do that right after work.
  14. #29
    Jack,
    Yes drivers license & registration and or title to correlate the owner record of custodial care proof.
  15. #30
    planet earth
    I just noticed this thread, I'm in the same situation as you, but with a VW phaeton. Not the same kessy, but very close.
    After I did auto scan and clear all fault code, I lost remote funcionality. The car still in the shop, I did try everything I can, to learn back the remote, but there is no way in this state it's possible.
    I can't even learn a second key to the kessy,but it had 2 working key before. I tried it with pin, over Gekko, no joy.
    I'm pretty sure the remote was working, because I opened it with a remote, sat in, did a scan as I always do when customer drops off the car, and after I was done,remote was gone.
    I did not think VCDS caused this till I saw this thread, I was thinking how unlucky I'm again, and how these stupid VW immo system fuxx me over most of the time.
    A used kessy on the way, but i will investigate more after reading this....
    Attached autoscan. Don't mind the errors, the car came in for repair.
    Wednesday,13,March,2019,10:55:11:10366
    VCDS Version: 18.9.1.0  HEX-NET CB: 0.4436.4
    Workshop Code: 332 00001 000022
    VIN: WVWZZZ3DZ    License Plate: PHAETON
    Mileage: 229550km-142635mi   Repair Order:
    Chassis Type: 3D (3D - VW Phaeton (2002 > 2006))
    Scan: 01 02 03 05 06 07 08 09 11 13 15 16 17 18 19 23 27 28 29 2E
              34 36 37 38 39 46 47 55 56 57 65 66 68 69 71 75 76 77
    VIN:    Mileage: 229550km-142635miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 3D0 907 401 A    HW: 8E0 907 401 AB
       Component: 3.0L V6TDI  G000AG  0010
       Revision: --H01---    Serial number: VWZ3Z0F1562086
       Coding: 0011773
       Shop #: WSC 80093 222 69422
       VCID: 1D7211D7C599B0A2D6-5160
    012697 - Control Circuit for Intake Manifold Runner (Bank2)
                   P3199 - 002 - Implausible Signal - Intermittent
                        Mileage: 229556 km
                        Torque: 167.7 Nm
                        Voltage: 12.16 V
                        Duty Cycle: 84.8 %
                        Duty Cycle: 0.4 %
                        Duty Cycle: 20.5 %
    008209 - Intake Manifold Flap; Bank 2
                   P2011 - 002 - Electrical Malfunction - Intermittent
                        Mileage: 229556 km
                        RPM: 693 /min
                        Torque: 54.6 Nm
                        Voltage: 11.86 V
                        Duty Cycle: 80.9 %
                        Duty Cycle: 7.9 %
                        Duty Cycle: 80.9 %
       Part No SW: 09L 927 760 J    HW: GS1 911 4
       Component: AG6 09L 3,0 TDI RdW 2806
       Revision: --H01---    Serial number:        4273271
       VCID: 3E30F65B685FCBBAEF-5160
    002069 - Upshift Switch Circuit for Tiptronic (F189)
                   P0815 - 001 - Electrical Malfunction - Intermittent
                        Fault Status: 00100001
                        RPM: 800 /min
                        RPM: 800 /min
                        (no units): 23.0
                        (no units): 21.0
                        Temperature: 83.0°C
                        T.B. Angle: 0.0°
    002309 - Gate Select Position Circuit for Tiptronic (F189)
                   P0905 - 000 - Implausible Signal - Intermittent
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008356
       Shop #: WSC 75337 000 00000
       VCID: 6B960F0F4BAD8E1218-51CE
                000 -  -  - Intermittent
       Part No SW: 3D0 909 139 B    HW: 5WK 485 04
       Component:    Kessy            6840
       Revision: 68406418    Serial number: VWZ3Z0F1562086
       Coding: 0004328
       Shop #: WSC 01065 000 00000
       VCID: 281C30039ADB650AB5-5160
    00087 - Terminal 30 for Starting Relevant Consumers
    00172 - Key 2 not learned
    01176 - Key
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 CA
       Component: Sitzmemory D1 BF    1720
       Coding: 0000003
       VCID: 77BE237F07E53AF2EC-5160
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3D0 035 007 AR
       Component:    ZAB COCKPIT      0253
       Coding: 0400725
       VCID: 699A750741519C026A-5160
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 J
       Component: Climatronic D1      2031
       VCID: 25023937EDC978628E-5160
                014 - Defective
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 L    HW: 3D0 937 049 L
       Component: J519                6200
       Revision: -4003---    Serial number: --------------
       Coding: 600200002B2115000000000000000000
       Shop #: WSC 33316 133 59432
       VCID: 3326D76F531D16D210-5160
       Part No: 3D0 909 601 E
       Component: 0J Airbag 8.4E+ H12 0935
       Coding: 0012362
    00532 - Supply Voltage B+
    Address 16: Steering wheel        Labels: 3D0-953-549.lbl
       Part No: 3D0 953 549 E
       Component: Lenksäulenmodul     3401
       Coding: 0000232
       VCID: 2F2EDB1FBF35323274-5160
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No: 3D0 920 885 A
       Component: KOMBIINSTRUMENT RB8 0610
       Coding: 0022111
    Address 18: Aux. Heat        Labels: None
       Part No: 3D0 815 005 AA
       Component: Standheizung        2426
       Shop #: WSC 45555 125 45725
       VCID: 5CF45CD39E03F9AAE1-5160
    01415 - Recirculating Pump (V55)
                010 - Open or Short to Plus
       Part No: 6N0 909 901
       Coding: 0000006
       VCID: 70AC1863628B6DCA2D-5160
    Address 29: Left Light        Labels: 3D0-909-157.lbl
       Part No: 3D0 909 157
       Component: EVG GDL+AutoLWR(l)  0001
       VCID: 66807E3B504FB37A47-5184
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005521
       Shop #: WSC 00999 444 64523
       VCID: 271E333F97C56A72BC-5160
    01598 - Drive Battery Voltage
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 CA
       Component: Sitzmemory D1 F     1720
       Coding: 0000004
       VCID: 6FAE1B1F7FB5723234-5160
    Address 37: Navigation        Labels: 3D0-919-887.lbl
       Part No: 3D0 919 887 JX
       Component:    NAVIGATION       0188
       Coding: 0400000
       Shop #: WSC 75337 150 179924
       VCID: 136677EF335DF6D270-5160
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 C
       Component: Dachmodul           0708
       Coding: 0000015
       VCID: 2306272FE3FD8652E0-5160
    00220 - Connection to Sunroof
    00308 - Supply Voltage for Motors for Sunroof/sunroof Shade
    00926 - Terminal 30
    00198 - Automatic Day/Night Interior Mirror (Y7)
    00403 - Sunroof Motor (V1)
       Part No: 3D0 909 158
       VCID: 679E733F5745AA727C-5160
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: X3 HSG              0102
       Coding: 0000040
       Shop #: WSC 00046 000 00000
       VCID: 3326D76F531D16D210-4B1E
       Subsystem 1 - Part No: 3D1 959 701 L
       Component: Tuersteuergeraet FS 6001
       Subsystem 2 - Part No: 3D1 959 702 L
       Component: Tuersteuergeraet BF 6001
       Subsystem 3 - Part No: 3D0 959 703 K
       Component: Tuersteuergeraet HL 6001
       Subsystem 4 - Part No: 3D0 959 704 K
       Component: Tuersteuergeraet HR 6001
       Subsystem 5 - Part No: 3D0 909 610 A
       Component: 3G HDSG             2320
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    01134 - Alarm Horn (H12)
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3D0 035 465 A
       Component: 08K-AUDIOVERST      0112
       VCID: 1F0E2BDFCF95A2B2C4-5160
    Address 65: Tire Pressure        Labels: None
       Part No: 3D0 907 273
       Component: Reifendruckueberw.  0018
       Coding: 0010324
       Shop #: WSC 17301 666 36123
       VCID: 6386672FA37DC652A0-5160
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V1.clb
       Part No: 3D1 955 119 A
       Component: Front Wiper         2005
    00155 - Driver-Passenger Side Control Module Communication
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
       VCID: 24042433E6F3816A99-5160
    Address 76: Park Assist        Labels: None
       Part No: 3D0 919 283 D
       Component: 01 Einparkhilfe     0907
       VCID: 2B16CF0F8B2D4E1258-5160
    Address 77: Telephone        Labels: 3W7-035-385.lbl
       Part No SW: 3W7 035 385 H    HW: 3W7 035 385 H
       Component: UHV Premium rSAP    0037
       Coding: 0002320
       VCID: 41CA8DA719A1B44292-5160
    End----(Elapsed Time: 08:14, VBatt start/end: 11.7V/11.6V. VIgn 0.0V)------
    Address 02: DTCs cleared
    Address 03: DTCs cleared
    Address 05: DTCs cleared
    Address 06: DTCs cleared
    Address 08: DTCs cleared
    Address 09: DTCs cleared
    Address 15: DTCs cleared
    Address 16: DTCs cleared
    Address 17: DTCs cleared
    Address 18: DTCs cleared
    Address 19: DTCs cleared
    Address 29: DTCs cleared
    Address 34: DTCs cleared
    Address 36: DTCs cleared
    Address 37: DTCs cleared
    Address 38: DTCs cleared
    Address 39: DTCs cleared
    Address 46: DTCs cleared
    Address 47: DTCs cleared
    Address 65: DTCs cleared
    Address 68: DTCs cleared
    Address 71: DTCs cleared
    Address 76: DTCs cleared
    Address 77: DTCs cleared
