I got my VCDS on Friday, anxious to try it out and wanting to get rid of an annoying TPMS warning I fired up VCDS on my laptop. I followed a youtube video on how to get rid of the warning by going into CAN, adaptation, "do it". All was well. Light went away. I also enabled the function to turn off DRL and seat belt warning. At some point I scanned and cleared codes. Once I was done I had lost key fob functionality.
Today I was able to get my security access code and reprogram the keys. Well sort of, I need to do it over because only one key got programmed properly. Anyway still no remote lock/unlock.
Background: The Touareg (2004 V8) has had the dreaded battery drain. I had pulled some various fuses for phone, sat nav, etc. Finally found it to be the radio/amp fuses. Drain is gone BUT I don't think I had all the other fuses back in. Yesterday and today I checked and made sure all proper fuses were populated per my owners manual. Even after key reprogram I have no remote function. I have an 8:30am appointment at the dealer (11 hours from now) to look at it.
What could I have done to lose the remote function? There is no "remote control adaptation" in any menu I can find in VCDS.
This is my latest scan, note I am going back to fix the key issue. I was following the wrong procedure.
VCDS Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: Beta 19.1.2(x64) Data version: 20190131 DS301.0 www.Ross-Tech.com
Dealer/Shop Name: Workshop Code: 000 00000 000000
Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747
VIN: WVGCM77L14D062138 License Plate: Mileage: 165820km-103035mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006)) Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36 37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGCM77L14D062138 Mileage: 165820km-103035miles ------------------------------------------------------------------------------Address 01: Engine Labels: 077-907-560-AXQ.lbl Part No SW: 4D0 907 560 DA HW: 8E0 907 560 Component: 4.2L V8/5V G 0050 Coding: 0007875 Shop #: WSC 05246 444 58887 VCID: 6889B98F1E6D4D77003-5160
1 Fault Found: 17978 - Engine Start Blocked by Immobilizer P1570 - 008 - - Intermittent Readiness: 0000 0000
------------------------------------------------------------------------------Address 02: Auto Trans Labels: 09D-927-750.clb Part No: 09D 927 750 BG Component: AL 600 6Q 0579 Coding: 0004153 Shop #: WSC 26085 444 84534 VCID: 74B1DDFF52A5B997BCB-5160
------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 7L0-907-379-MK25.lbl Part No: 7L0 907 379 D Component: ESP ALLRAD MK25 0108 Coding: 0014593 Shop #: WSC 31414 000 00000 VCID: 3A2D33C730410FE7A67-5160
1 Fault Found: 00778 - Steering Angle Sensor (G85) 000 - - - Intermittent
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 2
Address 05: Acc/Start Auth. Labels: None Part No SW: 7L0 909 137 C HW: 7L0 909 137 C Component: 1W Kessy 6850 Revision: 00H22071 Serial number: VWZ3Z0D7160299 Coding: 0147688 Shop #: WSC 26071 444 85803 VCID: 33331EE3172BFEAF651-5160
Subsystem 1 - Part No: 4E0 905 852 D Component: ELV 1834
2 Faults Found: 01176 - Key 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 14 Reset counter: 255 Time Indication: 0 Date: 2000.00.00 Time: 03:18:20
01179 - Incorrect Key Programming 000 - Freeze Frame: Fault Status: 01100000 Fault Priority: 2 Fault Frequency: 0 Reset counter: 255 Time Indication: 0 Date: 2000.00.00 Time: 03:23:48
------------------------------------------------------------------------------Address 06: Seat Mem. Pass Labels: None Part No: 7L0 959 760 Component: Sitzverstellung 0701 Shop #: WSC 00000 000 00000 VCID: 77ABEAF343D3D28F999-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 3
Address 08: Auto HVAC Labels: 7L6-907-040.clb Part No: 7L6 907 040 H Component: CLIMAtronic R/L X 3716 Coding: 0000030 Shop #: WSC 31414 000 00000 VCID: 353720FB195FE09F4B5-5160
1 Fault Found: 01592 - Air Quality Sensor (G238) 014 - Defective
------------------------------------------------------------------------------Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb Part No: 7L6 937 049 K Component: 2703 Coding: 0105950 Shop #: WSC 03128 444 45725 VCID: 44D14D3F42854917CCB-5160
2 Faults Found: 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent 00907 - Intervention load Management 000 -
------------------------------------------------------------------------------Address 15: Airbags Labels: 3D0-909-601.lbl Part No: 3D0 909 601 C Component: 05 Airbag 8.4E++H01 0352 Revision: BB36963 Serial number: 00010123 Coding: 0012341 Shop #: WSC 31414 000 00000 VCID: 2313EEA3A7CB6E2F951-5160
Subsystem 1 - Part No: 7L0 959 339 B Component: BF-Gewichtsens. 005 0006
------------------------------------------------------------------------------Address 16: Steering wheel Labels: 7L6-953-549.lbl Part No: 7L6 953 549 D Component: Lenksäulenmodul 3301 Coding: 0000022 Shop #: WSC 31414 000 00000 VCID: 40D9412F569D5537E83-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 4
Address 17: Instruments Labels: 7L6-920-xxx-7LA.lbl Part No: 7L6 920 980 M Component: KOMBIINSTRUMENT RB8 2935 Coding: 0010231 Shop #: WSC 26085 444 84534 VCID: 42DD4B2758914727FE7-5160
3 Faults Found: 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication 00464 - Control Module with Display for Radio and Navigation (J503) 004 - No Signal/Communication
------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl Part No: 6N0 909 901 Component: Gateway K<>CAN 0101 Coding: 0000006 Shop #: WSC 31414 000 00000 VCID: 70B9D1EF26BD85B7583-5160
4 Faults Found: 00466 - Control Module for Steering Column Electronics (J527) 004 - No Signal/Communication - Intermittent 01325 - Control Module for Tire Pressure Monitoring (J502) 004 - No Signal/Communication 00463 - Control Module for Digital Sound Package (J525) 004 - No Signal/Communication 00464 - Control Module with Display for Radio and Navigation (J503) 004 - No Signal/Communication
------------------------------------------------------------------------------Address 1C: Position Sensing Labels: 7L6-919-879.lbl Part No: 7L6 919 879 Component: JCI PathPoint 1700 Shop #: WSC 00000 000 00000 VCID: 04518D3F020589178CB-5160
------------------------------------------------------------------------------Address 22: AWD Labels: None Part No: 0AD 927 755 BE Component: TRANSFERCASE 0122 Shop #: WSC 00000 000 00000 VCID: 7F5B02D36BE3EACFD19-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 5
Address 29: Left Light Labels: 3D0-909-157.lbl Part No: 3D0 909 157 Component: EVG GDL+AutoLWR(l) X012 Coding: 0000003 Shop #: WSC 31414 000 00000 VCID: 6695B7B714795B0732F-5184
------------------------------------------------------------------------------Address 34: Level Control Labels: 7Lx-907-553-34.clb Part No: 7L0 907 553 F Component: LUFTFDR.-CDC- 3C3P1 3081 Coding: 0015521 Shop #: WSC 31414 000 00000 VCID: 363527F70459EB8742F-5160
1 Fault Found: 00778 - Steering Angle Sensor (G85) 004 - No Signal/Communication - Intermittent
------------------------------------------------------------------------------Address 36: Seat Mem. Drvr Labels: None Part No: 7L0 959 760 Component: Sitzverstellung 0701 Shop #: WSC 00000 000 00000 VCID: 77ABEAF343D3D28F999-5160
------------------------------------------------------------------------------Address 39: Right Light Labels: 3D0-909-158.lbl Part No: 3D0 909 158 Component: EVG GDL+AutoLWR(r) 0001 Coding: 0000003 Shop #: WSC 62108 001 1048576 VCID: 678BBAB31373420F099-5160
VCDS Self-Diagnosis Log Monday,18,March,2019,15:57:55:59747 Page 6
Address 46: Central Conv. Labels: 7L0-959-933.lbl Part No: 7L0 959 933 E Component: 2M HSG 0201 Coding: 0000085 Shop #: WSC 03128 444 45725 VCID: 3E253FD72C6923C79AF-4B1E
Subsystem 1 - Part No: 7L0 959 701 B Component: Tuersteuergeraet FS 0201
Subsystem 2 - Part No: 7L0 959 702 B Component: Tuersteuergeraet BF 0201
Subsystem 3 - Part No: 7L0 959 703 B Component: Tuersteuergeraet HL 0201
Subsystem 4 - Part No: 7L0 959 704 B Component: Tuersteuergeraet HR 0201
------------------------------------------------------------------------------Address 68: Wiper Electr. Labels: 7L0-955-119-V1.clb Part No: 7L0 955 119 F Component: Front Wiper 2416 Coding: 0000004 Shop #: WSC 31414 000 376832 VCID: 372B2AF30353128F599-5160
------------------------------------------------------------------------------Address 6E: Ctrl Head Roof Labels: None Part No: 7L6 919 044 F Component: DACHDISPLAY 0530 Revision: 00600530 Serial number: 2009289.02 Shop #: WSC 31414 000 00000 VCID: 3A2D33C730410FE7A67-5160
------------------------------------------------------------------------------Address 76: Park Assist Labels: None Part No: 7L0 919 283 E Component: 0E Einparkhilfe 0907 Shop #: WSC 00000 000 00000 VCID: 382929CF0E4D1DF7503-5160
End----------(Elapsed Time: 08:55, VBatt start/end: 13.9V/14.0V)----------
