Results 1 to 10 of 18
Thread: Update Troubles
    Apr 2015
    Update Troubles
    I'm having trouble updating the hex net again.
    The interface Config gets stuck "Building sd update..." then displays "Error code -8, download failed"
    Apr 2015
    I just downloaded the beta 19.1 version st see if it makes a difference. It still acted exactly the same.
    In the config Overview tab, the IP: 0.0.0.0
    Is that right?
    Split these messages from an older thread in Car Repair Support because this qyestoon has nothing to do with fixing a car.
    Server thinks your HEX-NET is up-to-date (at Beta level) with:
    CB: 0.4502
    FW: 0.256
    CFB: 0.10
    BL: 0.28
    DS: 0000057
    Quote Originally Posted by WheelerKB View Post
    Are you within range of a WiFi access point that the HEX-NET knows how to connect to?
    Apr 2015
    I kept trying to update it, and through some unknown combination of trying with the phone, pc, cable, and network connection, it finally did update. But I still cannot connect to my 05 MK4 TDI Jetta control modules. I will get no response from controller every time I try to go into one of the controllers that has. I connected the vcds to a friend's 05 mk4 gli and it seemed to work normally.
    I've tried disconnecting the battery and let it sit for about 20 minutes and trying to connect again, and still get no response from controller.
    Apr 2015
    Update.... I just tried again from my phone and the app, and it worked.
  6. Likes Uwe liked this post
    Make sure the interface is pushed in all the way. If the connector in your car is particularly tight, it might seem to be in but might not have good contact. If you run into this again in the future, posting the results of [Options] -> [Test] would be helpful to see.
    Apr 2015
    Test Results:
    APP Id (1) CodeBlock V0.4502 API V4
    FW version: 0.256
    Dataset: 60000057
    K1: OK
    K2: OK
    CAN: Testing
    VCDS-Cloud: Testing
    Config: OK
    I just tried with my mobile phone app, and this is what I got.
    It would not connect to the engine controller.
  9. #8
    Does this car have an aftermarket radio? Do you have any autoscans saved from when you got it to work, that you could post? What is the status of the car when you are trying to scan, ignition on engine off? Is it on a battery charger?
  10. #9
    Apr 2015
    It does have an aftermarket radio. I have tried it not running but "on" and running but have not tried on a battery charger.
    VIN: WVWSR61J25W054641
    Chassis Type:1J or 9M
             76
    Address 01: Engine      Labels: None
            Part No SW: 038 906 016 Q       HW: 0281011812
            Component: R4 1,9L EDC G000SG   6110
            Revision: 12345678      Serial Number: VWZ7Z0D0988051
            Coding: 0150031
            Shop #: WSC 00000 785 00200
            VCID: 2207798BBF80E0405857788B5E-5184
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
    17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault
    17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
    Address 03: ABS Brakes  Labels: 1C0-907-37x-ESP-F.lbl
            Part No SW: 1C0 907 379 M
            Component: ESP FRONT MK60       0102
            Coding: 0019458
            Shop #: WSC 01266 785 00200
            VCID: 342B8FD315747EF0BA0B3E6344-5184
    Address 15: Airbags     Labels: 6Q0-909-605-VW5.lbl
            Part No SW: 1C0 909 605 F
            Component: 17 AIRBAG VW61 0108 0003
            Coding: 12599
            Shop #: WSC 01266 000
            VCID: 2711689FD4A215680F89B1C71D-5160
    No fault codes found.
    Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
            Part No SW: 1J5 920 906 Q
            Coding: 15232
            Shop #: WSC 00050 000
            VCID: 3B39A4EF382AA1887B518DD7E1-5160
            Subsystem 1 -   Part No SW: WVW-SR6-1J2-5W0
            Component: 54641     VWZ7Z0D0988051
    01304 - Radio
            49-00 - No Communications
            Part No SW: 6N0 909 901
            Coding: 00006
            VCID: F0A3C3C3A1EC92D01E635253D0-5160
    01304 - Radio
    Address 46: Central Conv.       Labels: 1C0-959-799.lbl
            Part No SW: 1C0 959 799 C
            Component: 8A Komfortgerät HLO 0004
            Coding: 00258
            VCID: 3731B8DF040285E89F2961872D-4B3C
            Subsystem 1 -   Part No SW: 1C1-959-801-A
            Component: 8A Türsteuer.FS KLO 0202
    01141 - Luggage Compartment Unlocking Switch (E165)
    End-------------------------(Elapsed Time: 08:27)--------------------------
  11. Likes Shaun liked this post
  12. #10
    I would try disconnecting the radio and then see if the rest of the car talks reliably. Some aftermarket radios have been known to cause diagnostic communication lockups on the Kline.
  13. Likes PetrolDave liked this post
