ASAM Update Failure
dpierlot
Canada
C?ID=107193
Hi there,
I'm having issues successfully completing an ASAM update after an auto-scan on my 2019 A4, using VCDS-Mobile.
I do the auto-scan, I'm told there is an update, then it hangs at 0% "Preparing to update" before finally popping up a message saying "Update failed! Please check your internet connection". I don't think it's a network issue. I'm in infrastructure mode and connected to my home wifi, and have no other issues with network connectivity (in fact I successfully updated my HEX-NET sitting in the car.)
Version:
CodeBlock V0.4437
FW version: 0.254
Dataset: 60000055
A little weird that I see newer versions of CB and FW available, yet when I do the update via web or with the Mac HexNetConfig app, I'm told I am up-to-date.
Thanks!
Darcy
Version:
CodeBlock V0.4437
FW version: 0.254
Dataset: 60000055
Sounds like you're on the Release channel. You can put yourself on the Beta channel using VCIConfig. That option is on the Advanced tab.
dpierlot
Canada
C?ID=107193
Thanks for the quick reply! Do you think the issue is because the files don’t exist yet for my vehicle? Any way to make the switch to the beta channel without a windows machine?
Not sure. Easiest way to find out is for you to try.
For you, no. For me, yes. Try updating again.
dpierlot
Canada
C?ID=107193
Thanks! I've been able to update FW and CB, but I keep hitting an Error code -2 on the DS update.
Screenshot below:
https://imgur.com/7zNvM3n
dpierlot
Canada
C?ID=107193
Screenshot below:
Actually tried rebooting things again and finally I think I took. Now I'm told there are no additional updates. Back out to the car to see how it goes!
dpierlot
Canada
C?ID=107193
Okay so I didn’t get errors this time but immediately the warning that no ASAM data was found and no update is available. That must mean I have have to wait until when/if the data becomes available for my vehicle?
https://imgur.com/CAXQrkl
Have you tried a Check for Updates in VCDS-Mobile itself?
dpierlot
Canada
C?ID=107193
Here's the scan with all the "No ASAM data" warnings.
#hndoc:?docid=00004C40&xt=hnh:E79B7ACAA70F51D20264FB2AD9AF1AB51C93D0FB97F6CEC0CF27A0EF359CEED2
VCDS Mobile 0.4502.0.4
VIN: WAUFNAF49KN002005
Scan: 01 02 03 08 09 13 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F
	 6C 75 81 8B A5 BB BC CA CF D6 D7
BB-Door Rear Drv Side -- Status: OK 0000
BC-Door Rear Pass Side -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
Address 01: Engine  (CYMC2 J623)	Labels: None
	Part No SW: 8W0 906 259 AB	HW: 06L 907 425 C
	Component: R4 2.0l TFSI  H15 0003
	Revision: --H15---
	Coding: 0A2500322366010E34280000000000000000000000000000
	ASAM Dataset: EV_ECM20TFS0208W0906259AB 001004
	ROD: N/A
	VCID: 814596078E650253C91C18-80D4
	No ASAM data for: "EV_ECM20TFS0208W0906259AB"
No fault codes found.
Address 02: Auto Trans  (J217)	Labels: None
	Part No SW: 8W2 927 155 CG	HW: 0HK 927 156 B
	Component: 0CL 20TFSINAR H01 0002
	Revision: --H01---
	Coding: 000001
	ASAM Dataset: EV_TCMDL382021 002031
	ROD: N/A
	VCID: 88538B23AD5F331B8E424D-80DD
	No ASAM data for: "EV_TCMDL382021"
Address 03: ABS Brakes  (J104)	Labels: 8W-03.clb
	Part No SW: 8W0 907 379 R	HW: 8W0 907 379 D
	Component: ESP9 Premium  H13 0775
	Coding: 18AA409928A20A98119E4891008252A2E5359A180214508812004A45A7AC59
	ASAM Dataset: EV_ESP9BOSCHCMP 002013
	ROD: N/A
	VCID: 54EBEF53A197C7FBB25A09-8001
	No ASAM data for: "EV_ESP9BOSCHCMP"
Address 08: Auto HVAC  (E87)	Labels: 8W-08.clb
	Part No SW: 8W0 820 043 AA	HW: 8W0 820 043 AA
	Component: Klima Zone 3  H60 0251
	Coding: 140805095544000D10020100080000000000000000000000000000000000
	ROD: N/A
	VCID: 72A749CB3BC3A9CB40667F-8027
	No ASAM data for: "EV_AirCondiBHTCAU491"
	Subsystem 1 - 	Part No SW: 4M1-820-021-B
	Component: J126 FLuftV  H09 0003
	Serial Number: 00000000000002851708
	Subsystem 2 -
Address 09: Cent. Elect.  (J519)	Labels: None
	Part No SW: 8W0 907 063 DG	HW: 8W0 907 063 BG
	Component: BCM1 MLBevo   H13 0313
	Coding: 07501563E0691CCD0517511918AC98BB110B3D08000000000000000020001A010A69012B025709
	ASAM Dataset: EV_BCM1BOSCHAU736 019008
	ROD: N/A
	VCID: 83499C0F94791043DB3032-80D6
	No ASAM data for: "EV_BCM1BOSCHAU736"
	Subsystem 1 - 	Part No SW: 8W1-955-119-A	Labels: 8W-09-01.clb
	Component: J400FRWISCH  051 0822
	Serial Number: 887353F0401824601923
	Coding: 7DC727
	Subsystem 2 - 	Part No SW: 81A-955-555-A
	Component: G397_RLFSS   H06 0002
	Serial Number: 21890953X81A955555A0
	Coding: 02005D
	Subsystem 3 - 	Part No SW: 4M0-941-531-AK
	Component: E1 - LDS     H06 0008
	Serial Number: 14 06 2018  01494046
	Subsystem 4 - 	Part No SW: 4N0-907-410-B
	Component: USHL5        H10 0100
	Serial Number: 0000009600368Z00SR02
	Coding: 350000
	Subsystem 5 - 	Part No SW: 4M0-959-719-A
	Component: GTO BF       H01 0010
	Serial Number: 20180827193748 00340
	Subsystem 6 - 	Part No SW: 8W0-857-511-B
	Component: Y7_InnenspiegH01 0002
	Serial Number: GX1CE125061823610025
	Subsystem 7 - 	Part No SW: 8W0-947-135-CJ
	Component: J528-Dachele H14 0130
	Serial Number: B00918121
	Subsystem 8 - 	Part No SW: 8W0-925-301-BC
	Component: SL-B9/Q5NF   H17 0010
	Serial Number: 2818000106488002
	Subsystem 9 - 	Part No SW: 4N0-963-575
	Component: V512 LLR1SLvLH01 0012
	Serial Number: L84AI22601764
	Subsystem 10 - 	Part No SW: 4N0-963-575
	Component: V514 LLR1SKvLH01 0012
	Serial Number: L84AI22601784
	Subsystem 11 - 	Part No SW: 4N0-963-575
	Component: V516 LLR1SLvRH01 0012
	Serial Number: L84AI22601769
	Subsystem 12 - 	Part No SW: 4N0-963-575
	Component: V518 LLR1SKvRH01 0012
	Serial Number: L84AI22601777
Address 13: Auto Dist. Reg  (J428)	Labels: None
	Part No SW: 8W0 907 561 C	HW: 8W0 907 561
	Component: LRR4          H10 0340
	Coding: B4779FF258FFEC09959A81A1
	ASAM Dataset: EV_ACCBOSCHAU49X 003022
	ROD: N/A
	VCID: 3E3FADFB3F1B3DAB747E3B-806B
	No ASAM data for: "EV_ACCBOSCHAU49X"
Address 15: Airbags  (J234)	Labels: 8W0-959-655.clb
	Part No SW: 8W0 959 655 M	HW: 8W0 959 655 M
	Component: Airbag10.44   H05 0108
	Coding: BFCCF0C000800000A0000033D24C00000000
	ASAM Dataset: EV_AirbaAU10BPAAU736 006016
	ROD: N/A
	VCID: 53E9EC4FA499C0C3AB5002-8006
	No ASAM data for: "EV_AirbaAU10BPAAU736"
	Subsystem 1 - 	Part No SW: 4M0-980-945-B
	Component: BeltPretRevFL306 2040
	Serial Number: 8W0857705G0268S01375
	Coding: 80000D
	Subsystem 2 - 	Part No SW: 4M0-980-946-B
	Component: BeltPretRevFR306 2040
	Serial Number: 8W0857706J0267S01420
	Coding: 80000D
	Subsystem 3 - 	Part No SW: 4M0-959-339
	Component: BF-Gewichtss.H11 0022
	Serial Number: IBH0000J18000ACF3N08
	Subsystem 4 - 	Part No SW: --------------
	Component: SideSensor_Df1E2 0887
	Serial Number: 3577Y00BD279D052F138
	Subsystem 5 - 	Part No SW: --------------
	Component: SideSensor_Pf1E2 0887
	Serial Number: 3587Y00C3279D051F2B8
	Subsystem 6 - 	Part No SW: --------------
	Component: SideSensor_Dr1C7 0148
	Serial Number: 3517700A72AC098363DK
	Subsystem 7 - 	Part No SW: --------------
	Component: SideSensor_Pr1C7 0148
	Serial Number: 3527700A52AC09824022
	Subsystem 8 - 	Part No SW: --------------
	Component: FrontSensor_D1C5 014A
	Serial Number: 35575009F29F7DC2846+
	Subsystem 9 - 	Part No SW: --------------
	Component: FrontSensor_P1C5 014A
	Serial Number: 35675009F29F7DC1A35+
Address 16: Steering wheel  (J527)	Labels: None
	Part No SW: 4N0 907 129 N	HW: 4N0 907 129 N
	Shop #: WSC 00000 000
	ROD: N/A
	VCID: 3C3BA7F329072FBB5A4A01-8069
	No ASAM data for: "EV_SMLSKLOAU736"
Address 17: Instruments  (J285)	Labels: None
	Part No SW: 8W5 920 790 E	HW: 8W5 920 790 E
	Component: FBenRDW       H19 0417
	Coding: 098651C16C88000802A369601800400008000000
	ASAM Dataset: EV_DashBoardAU736 001032
	ROD: N/A
	VCID: 44CBDF1351F7577B22BA79-8011
	No ASAM data for: "EV_DashBoardAU736"
Address 19: CAN Gateway  (J533)	Labels: None
	Part No SW: 80A 907 468 B	HW: 80A 907 468 B
	Component: Gateway       H05 0118
	Coding: 03010001000006402907000000590012DC180007100000000175078E10000000
	ASAM Dataset: EV_Gatew31xAU65x 003160
	ROD: N/A
	VCID: 2D1D9AB7E27DB633DDD464-8078
	No ASAM data for: "EV_Gatew31xAU65x"
	Subsystem 1 - 	Part No SW: 8W0-951-523-H
	Component: J453 MFL     H04 0004
	Serial Number: 20180904013034 20143
	Subsystem 2 - 	Part No SW: 8S0-915-181-C
	Component: J367-BDMHellaH10 9070
	Serial Number: 2977079204
066304 - ROD - Unknown faultcode
131687 - ROD - Unknown faultcode
Address 29: Left Light  (J1018)	Labels: 4M0-907-397.clb
	Part No SW: 4M0 907 397 AC	HW: 4M0 907 397 C
	Component: LCM_MLBevo
	ROD: N/A
	VCID: 78B37BE35DBFC39B7EA2BD-802D
	No ASAM data for: "EV_LCMLeftHELLAAU736"
Address 36: Seat Mem. Drvr  (J136)	Labels: None
	Part No SW: 4M4 959 760	HW: 4M4 959 760
	Component: MEM-FS        009 0042
	Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
	ROD: N/A
	VCID: F9B5FEE7E6B55A9381AC20-80AC
	No ASAM data for: "EV_SCMDriveSideCONTIAU736"
Address 39: Right Light  (J1023)	Labels: 4M0-907-397.clb
	ROD: N/A
	No ASAM data for: "EV_LCMRightHELLAAU736"
Address 3C: Lane Change  (J769)	Labels: None
	Part No SW: 4M0 907 566 E	HW: 4M0 907 566
	Component: MRR1Rear      H20 0430
	Revision: --------
	Coding: 0EC002
	ASAM Dataset: EV_RearRadarS1BoschAU736 001022
	ROD: N/A
	VCID: 3731B8DF10210CE3B738F6-8062
	No ASAM data for: "EV_RearRadarS1BoschAU736"
Address 42: Door Elect, Driver  (J386)	Labels: None
	Part No SW: 4M0 959 793 H	HW: 4M0 959 793 F
	Component: TSG FS        005 0130
	Coding: 005D0B205E00108000010032
	ROD: N/A
	VCID: 43C9DC0F54F950431BB072-8016
	No ASAM data for: "EV_DCU2DriveSideMAXHCONT"
196681 - ROD - Unknown faultcode
Address 44: Steering Assist  (J500)	Labels: None
	Part No SW: 8W0 909 144 H	HW: 8W0 909 144 B
	Component: EPS_MLBEVO_ZF H08 0410
	Coding: 0D008380008080
	ASAM Dataset: EV_EPSZFAU49X 003023
	ROD: N/A
	VCID: 42C7D90B4BE3594B10864F-8017
	No ASAM data for: "EV_EPSZFAU49X"
Address 46: Central Conv.  (J393)	Labels: None
	Part No SW: 8W0 907 064 FC	HW: 8W0 907 064 DC
	Component: BCM2 MLBevo   025 0406
	Coding: 013400004FB00080650FA0002C01000203024000810026502F0400000B04803F001E0001000000
	ASAM Dataset: EV_BCM2HellaAU736 015015
	ROD: N/A
	VCID: 8247990B8B63194BD0060F-80D7
	No ASAM data for: "EV_BCM2HellaAU736"
	Subsystem 1 - 	Part No SW: 5Q0-951-177
	Serial Number: 000000000ZY1825815L2
	Subsystem 2 - 	Part No SW: 5Q0-951-605-A
	Serial Number: 00000000000045328279
	Subsystem 3 - 	Part No SW: 3AA-962-243-H
	Component: GEB.F.HeckoefH16 0905
	Serial Number: 12083448
Address 47: Sound System  (J525)	Labels: None
	Part No SW: 8W0 035 465	HW: 8W0 035 465
	Component: MIB2_amp_P_B9 H11 0420
	Revision: 00000001
	Coding: 0194010800AFAAAFAA0000010000
	ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
	ROD: N/A
	VCID: F6AFF5DBD7AB35EBEC8E03-80A3
	No ASAM data for: "EV_AMPMst16C2Gen2ALPI"
Address 52: Door Elect, Pass.  (J387)	Labels: None
	Part No SW: 4M0 959 792 H	HW: 4M0 959 792 F
	Component: TSG BFS       005 0130
	Coding: 005D0B205E00108000010030
	ROD: N/A
	No ASAM data for: "EV_DCU2PasseSideMAXHCONT"
Address 5F: Information Electr.  (J794)	Labels: 8W-5f.clb
	Part No SW: 8W5 035 880 C	HW: 8W5 035 880
	Component: MU-P-LNS-US   035 1316
	Coding: 019401020000000051220002041A00102F0002E401700904BE
	ROD: N/A
	VCID: 3FC1D0FF381134A37F682E-806A
	No ASAM data for: "EV_MUHig6C3Gen2HBAS"
	Subsystem 1 - 	Part No SW: V03-959-802-DK
	Component: NAR 2018/2019--- 0066
	Serial Number: --------------------
	Subsystem 2 - 	Part No SW: 8W0-919-605
	Component: AU49x_DU_HIGHH40 0008
	Serial Number: AUZ8Z9JBJ05DX2
	Subsystem 3 - 	Part No SW: 8W0-919-614-T
	Component: ControlUnit_HH30 0206
	Serial Number: APVAK120081800020127
	Subsystem 4 - 	Part No SW: V03-959-800-EG
	Component: Gracenote2   --- 3013
007188 - ROD - Unknown faultcode
007219 - ROD - Unknown faultcode
Address 6C: Back-up Cam.  (J928)	Labels: None
	Part No SW: 4M0 907 428 F	HW: 4M0 907 428
	Component: Areaview 2    H13 0318
	Coding: 02940102BA0FA10038004004
	ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 005015
	ROD: N/A
	VCID: 352DB2D70A2DFEF3A504DC-8060
	No ASAM data for: "EV_CamSysRVAV2CE2MLBEv"
Address 75: Telematics  (J949)	Labels: None
	Part No SW: 4K1 035 283 A	HW: 4K1 035 283 A
	Component: ConBox        H08 0100
	Coding: 01C020FE4040800000
	ASAM Dataset: EV_ConBoxAU651 001004
	ROD: N/A
	VCID: 260F659BC78B856B1C6E33-8073
	No ASAM data for: "EV_ConBoxAU651"
Address 81: Gear Shift  (J587)	Labels: None
	Part No SW: 8W1 713 041 N	HW: 8W1 713 041 K
	Component: GSM-LL        H10 0077
	Revision: 0L0D5012
	ROD: N/A
	No ASAM data for: "EV_GSMWaehlZFAU736"
Address 8B: Adaptive Cruise 2  (J850)	Labels: None
	Part No SW: 8W0 907 541 C	HW: 8W0 907 541
	ASAM Dataset: EV_ACC2BOSCHAU49X 003022
	ROD: N/A
	No ASAM data for: "EV_ACC2BOSCHAU49X"
Address A5: Frt Sens. Drv. Assist  (R242)	Labels: None
	Part No SW: 8W0 907 217 D	HW: 8W0 907 217 C
	Component: BVS           H18 0052
	Coding: 0404090100000203022023A6A50000FCB0F0C020C020
	ROD: N/A
	VCID: 3D3DAAF7321D26B36D7434-8068
	No ASAM data for: "EV_BVSMLBevKOSTAAU736"
Address BB: Door Rear Drv Side  (J388)	Labels: None
	Part No SW: 4M0 959 795 H	HW: 4M0 959 795 F
	Component: TSG HFS       005 0130
	Coding: 000D0B200000108040000020
	ROD: N/A
	VCID: 45CDC2175ACD6E7335A46C-8010
	No ASAM data for: "EV_DCU2RearDriveMAXHCONT"
Address BC: Door Rear Pass Side  (J389)	Labels: None
	Component: TSG HBFS      005 0130
	ROD: N/A
	No ASAM data for: "EV_DCU2RearPasseMAXHCONT"
Address CA: Sunroof  (J245)	Labels: 4M0-907-594.clb
	Part No SW: 4M0 907 594 H	HW: 4M0 907 594
	Coding: 2A8000049100
	ROD: N/A
	VCID: 3B39A4EF2C09288353401A-806E
	No ASAM data for: "EV_SunRoofCONTIAU736"
Address CF: Lane Chge Asst 2  (J770)	Labels: None
	Part No SW: 4M0 907 590 E	HW: 4M0 907 590
	Revision: --------
	Coding: 0EC002
	ASAM Dataset: EV_RearRadarS2BoschAU736 001022
	ROD: N/A
	VCID: 342B8FD30157E7FB921AA9-8061
	No ASAM data for: "EV_RearRadarS2BoschAU736"
Address D6: Light Ctrl Left 2  (A31)	Labels: 7PP-941-572.clb
	Part No SW: 7PP 941 572 AB	HW: 7PP 941 572 A
	ROD: N/A
	VCID: 966FD55BF7EB95EB0CCEE3-80C3
	No ASAM data for: "EV_LEDModLeftMELCOAU736"
Address D7: Light Ctrl Right 2  (A27)	Labels: 7PP-941-572.clb
	ROD: N/A
	No ASAM data for: "EV_LEDModRightMELCOAU736"
End--(Elapsed Time: 03:32, VBatt start/end: 12.4/12.3 Vign: 0.0)-
OK, I'm going to need Shaun's input on this.
dpierlot
Canada
C?ID=107193
Fair enough, thanks again for the quick feedback. I’ll stay tuned...
Shaun
It looks like a bunch of those rods should exist. If you do an Autoscan again and then check for updates with VCIConfig, do you get prompted for more rod updates? Another thing you could try is the [Options] -> [Clear Rod Files] function and then autoscan and check for updates.
