Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: VW Phaeton 2006 Electrical Problem
    Quote Originally Posted by bekescars.sk View Post
    Then after remove fuse nr. 33- navigation current drain is 0,03A finally. So it is possible to defective CAN gateway right?
    Whatever modules are powered by fuse 33 should be investigated first before condemning the CAN gateway.
  2. Likes Jack@European_Parts, Uwe liked this post
  3. #12
    Verified VCDS User langyyyy's Avatar
    Jun 2014
    Slovakia
    I agree with you, but I have no any usefull WD...
  4. #13
    You can download them from erWin
    Just purchase a 1 hour subscription and download everything relevant as PDF files and save them on your PC.
  5. Likes langyyyy, Jack@European_Parts, Uwe liked this post
  6. #14
    So why it's not turning sleep mode just to radio and Navi? If will be faulty ign switch, all interior components will stay in wake mode I think.
    and it is impossible to connect via vcds to radio and Navi unit..faulty ign switch? Still don't think so.
    And secondly, in autoscan you can see fault about Can databus.
    014 - Defective
    Says the opposition response & dismissing a possibility without having the RTFB or reviewing a WD.........you are right I shouldn't of shared.
    Yawn...........
    http://www.volkspage.net/technik/ssp/ssp/SSP_272_d1.pdf
    The control unit for battery monitoring is-activated by the control unit for entry and start authorization (J 518) with the signals 'Ignition key in the ignition lock' (Key-In) 'Ignition switched on'(Terminal 15) and the start signal (Terminal 50).
  7. #15
    014 - Defective
    The radio/sat nav uses messages on the Infotainment CAN bus to tell it to turn on/off, it does NOT have an ignition feed only permanent power - so IMHO it's nothing to do with the ignition switch.
    The faulty Infotainment CAN bus message can be caused by ANY device on the Infotainment CAN bus being faulty - not just the CAN Gateway. This is why you need a WD to see what devices are connected to the Infotainment CAN bus and then disconnect them ONE AT A TIME until the fault goes away.
    Fault find - do not assume
  8. Likes Jack@European_Parts, Uwe, jyoung8607 liked this post
  9. #16
    As implausible as it sounds it can indeed happen, however is rare...........
  10. Likes PetrolDave liked this post
  11. #17
    Jun 2014
    Slovakia
    Look at this.
    What I have to do now?
  12. #18
    Look at this.
    That WD (which doesn't show the complete Infotainment CAN bus BTW) shows that the |Infotainment CAN bus connects to many units, at least:
    J526
    J401
    J523
    J525
    J412
    J415
    ... and possibly others on other pages of the WD - so you need to check all pages of the WD that the Infotainment CAN bus is shown on.
    First I would disconnect the radio/sat nav and see if the other units on the Infotainment CAN bus communicate OK.
    If that fails then what you need to do is disconnect one of those units at a time and see when the radio/sat nav starts communicating again.
    It's not rocket science - eliminate one possible cause of the fault at a time until you find the root cause.
  13. Likes Jack@European_Parts, Uwe liked this post
  14. #19
    Jun 2014
    Slovakia
    I found complete diagram from CAN connection.
    After disconnecting Additional Heating is ALL OK. (Burned additional heating unit J167).
    Thank you guys for help!
